bpy.types.Bone.AxisRollFromMatrix() returns bad roll value #82930
Reference: blender/blender#82930
Operating system: Win 10
Graphics card: Nvidia
Broken: 2.82a+, ..., 2.90
Worked: 2.81a
The roll value returned by bpy.types.Bone.AxisRollFromMatrix() changes between 2.81 and 2.82, and is still broken in 2.90. This means that bones created with this function have a wrong local matrix and become unusable.
The broken roll values are consistently tiny (about e-07).
good - 2.81a:
result_axis:
<Vector (-0.0448, -0.8975, -0.4387)>
result_roll: 1.6745758056640625
broken - 2.82+:
result_axis:
result_roll: 8.284717296191957e-06
Run the py script in the attached blend file with the blender versions mentioned above.AxisRollFromMatrix.blend
Added subscriber: @csnyfan
This issue was referenced by
8330e19cb2
Added subscribers: @angavrilov, @mano-wii
I'm not familiar with this area and I do not know what results to expect.
But this change occurred in the commit
d1657b40
.So, @angavrilov, could you shed some light here?
Well, this matrix is flipped with negative scale (determinant is -1), so technically AxisRollFromMatrix has no solution - there is no possible axis and roll it could return so that
matrix == MatrixFromAxisRoll(*AxisRollFromMatrix(matrix))
. The old code seemed to work because it was very simple and based on a lot of assumptions, while the new code includes a full conversion to quaternions.Internally this is a non-issue for the actual armature code because rest pose cannot have scale, and may only potentially cause problems in a degenerate case for B-Bones, which were the cause of that fix in the first place due to previous math having issues in a way less degenerate case.
Personally I would lean to making the function error out if determinant is negative (or just documenting the restriction for the sake of performance), because there isn't a single 'best' way to unflip a matrix, so doing that is best left to the caller.
@angavrilov, would it be a good idea to set an error message in these cases?
Something like:
This is good to know - I wasn't aware that the function needed a positive determinant since the same data just worked on the old blender.
Raising an error and documenting it seems like the best solution.
There is no error return - I didn't check, but this probably fails the matrix to quaternion conversion and outputs a zero rotation quaternion. To do a check you would actually have to compute the determinant of the matrix. Also, a sheared matrix isn't great either. The math behind this function basically expects a so called 'special orthogonal matrix', meaning there should be no scaling or shear, so the easiest solution without a performance impact is to adjust the documentation string.
If you really want to do a check it would be something like:
Would this be a good description?:
"Convert a rotational matrix to the axis + roll representation. Note that the resulting roll value is unpredictable if the matrix has shear or is negative"
According to wikipedia, "negative matrix" means all matrix elements are negative, so you have to say "has negative determinant" to be correct. In practical terms it means it mirrors/flips the object.
Bastien Montagne referenced this issue2023-08-08 18:26:05 +02:00
