Crash when using curve deform
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.09
Broken: version: 2.91.0 Beta, branch: master, commit date: 2020-11-17 08:33, hash: rB2e1498ff1619
Worked: Likely never, problematic code existed since at least 2.61.
Crash when using the curve deform modifier.
Open the given file and set the deform axis to either Z or -Z
Robert Guetzkow (rjg) changed the task status from Needs Triage to Confirmed.Nov 25 2020, 10:07 AM
This only crashes in debug builds because it triggers the BLI_assert(cycl || ctime >= 0.0f); in where_on_path. The ctime doesn't appear to be a valid floating point number.
_BLI_assert_abort() Lines 51	C
where_on_path(const Object * ob, float ctime, float * r_vec, float * r_dir, float * r_quat, float * r_radius, float * r_weight) Lines 249	C
where_on_path_deform(const Object * ob_curve, float ctime, float * r_vec, float * r_dir, float * r_quat, float * r_radius) Lines 103	C
calc_curve_deform(const Object * ob_curve, float * co, const short axis, const CurveDeform * cd, float * r_quat) Lines 187	C
curve_deform_coords_impl(const Object * ob_curve, const Object * ob_target, float[3] * vert_coords, const int vert_coords_len, const MDeformVert * dvert, const int defgrp_index, const short flag, const short defaxis, BMEditMesh * em_target) Lines 423	C
BKE_curve_deform_coords(const Object * ob_curve, const Object * ob_target, float[3] * vert_coords, const int vert_coords_len, const MDeformVert * dvert, const int defgrp_index, const short flag, const short defaxis) Lines 440	C
deformVerts(ModifierData * md, const ModifierEvalContext * ctx, Mesh * mesh, float[3] * vertexCos, int numVerts) Lines 148	C
BKE_modifier_deform_verts(ModifierData * md, const ModifierEvalContext * ctx, Mesh * me, float[3] * vertexCos, int numVerts) Lines 1038	C
mesh_calc_modifiers(Depsgraph * depsgraph, Scene * scene, Object * ob, int useDeform, const bool need_mapping, const CustomData_MeshMasks * dataMask, const int index, const bool use_cache, const bool allow_shared_mesh, Mesh * * r_deform, Mesh * * r_final) Lines 1102	C
mesh_build_data(Depsgraph * depsgraph, Scene * scene, Object * ob, const CustomData_MeshMasks * dataMask, const bool need_mapping) Lines 1806	C
makeDerivedMesh(Depsgraph * depsgraph, Scene * scene, Object * ob, BMEditMesh * em, const CustomData_MeshMasks * dataMask) Lines 1927	C
BKE_object_handle_data_update(Depsgraph * depsgraph, Scene * scene, Object * ob) Lines 194	C
BKE_object_eval_uber_data(Depsgraph * depsgraph, Scene * scene, Object * ob) Lines 385	C
 	[External Code]
blender::deg::`anonymous namespace'::evaluate_node(const blender::deg::`anonymous-namespace'::DepsgraphEvalState * state, blender::deg::OperationNode * operation_node) Lines 115	C++
blender::deg::`anonymous namespace'::deg_task_run_func(TaskPool * pool, void * taskdata) Lines 127	C++
Task::()::__l2::<Lambdafunktion>() Lines 118	C++
tbb::interface7::internal::delegated_function<void <Lambdafunktion>(void) const ,void>::operator()() Lines 94	C++
 	[External Code]
tbb::interface7::internal::isolate_impl<void,void <Lambdafunktion>(void) const>(const Task::()::__l2::void <Lambdafunktion>(void) & f) Lines 161	C++
tbb::interface7::this_task_arena::isolate<void <Lambdafunktion>(void)>(const Task::()::__l2::void <Lambdafunktion>(void) & f) Lines 396	C++
Task::operator()() Lines 122	C++
tbb::internal::function_task<Task>::execute() Lines 1049	C++
I'll try to investigate this. I currently don't have a debug build from before 2.91, but earlier versions may also be affected.
It seems the factor calculation in calc_curve_deform doesn't handle edge cases for floating point division well/correctly and a division by zero can occur.
Note: The patch didn't make it into 2.91 as today the release is being finalized.
