Create Arabic Documentation #83018
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
2 Participants
Reference: blender/blender-manual#83018
Status:
Single line or paragraph human readable text.Team
Commissioner:
Omar Aglan (Me)
Core developer or artist, sign off the project, works as client.Project leader:
Omar Aglan
Main developer responsible for the implementation, only in one project.Project members:
Optional other developers, can be in multiple projects at once.Description
Big picture:
Translating the Documentation to Arabic
Short text explaining the vision of the project.Use cases:
Reading Arabic Documentation
Which specific scenarios will be tackled by the milestones .Design:
end user usability
Mental model, end user usability, paradigms, mockups.Engineer plan:
Translation
Abstract code samples - linked here, UML, API guidelines, library changes.Relevant links:
Added subscriber: @Omar_Gamer
Added subscriber: @dfelinto
Added subscriber: @Blendify
Hi Omar, I can create the translation files needed however the is currently an issue with RTL languages that require a fix to our HTML theme.
So here is what would happen, people can translate the strings and I will work on fixing the RTL issue.
For the RTL issue follow: https://github.com/readthedocs/sphinx_rtd_theme/pull/986
I have Foreked the Blender Documentation and began Translating the "getting Start Section".
so what do you want me to do - Wait or Begin from my side?
Did you generate the ar po files?
Yes, anyway can you like to create the files required and I will do the translation, and after they fix the RT issue, I will commit the changes I made.
anyway, do I have like the Authentication to push any changes to the main respiratory.
@Omar_Gamer I will commit the po files and you can merge the changes you made already.
@Blendify thanks
The translation files are available at https://svn.blender.org/svnroot/bf-manual-translations/trunk/blender_docs/locale/ar/
You have commit access using the same username and password as this website.
Thanks @Blendify
