Transparency in Solid View Causes Glitch Artifacts #83022
33 Participants
Reference: blender/blender#83022
Operating system: Windows 10
Broken: 2.91.0
Worked: 2.90.0
Looks very scary once you get it. All objects turn black and the transparent object turns white and all that is covered with randomly colored artifacts. Once you pan around the viewport, you can see the black stuff leaves a trail behind it. See the attached image
Open a new scene with the default cube
On the material tab, scroll down to Viewport Display and in Color make alpha something different than 1.
Click on the plus icon that adds a new material slot.
Voila.
Added subscriber: @ZackMercury-2
#98186 was marked as duplicate of this issue
#98083 was marked as duplicate of this issue
#94444 was marked as duplicate of this issue
#94229 was marked as duplicate of this issue
#93070 was marked as duplicate of this issue
#92895 was marked as duplicate of this issue
#92231 was marked as duplicate of this issue
#92251 was marked as duplicate of this issue
#89318 was marked as duplicate of this issue
#90934 was marked as duplicate of this issue
#90473 was marked as duplicate of this issue
#90122 was marked as duplicate of this issue
#87690 was marked as duplicate of this issue
#84938 was marked as duplicate of this issue
#87126 was marked as duplicate of this issue
#83530 was marked as duplicate of this issue
#82240 was marked as duplicate of this issue
#83298 was marked as duplicate of this issue
#83179 was marked as duplicate of this issue
#83369 was marked as duplicate of this issue
#83383 was marked as duplicate of this issue
#83039 was marked as duplicate of this issue
Added subscriber: @Alaska
There has been a bunch of graphical glitches on AMD GPUs with the latest GPU driver release. Are you able to try downgrading your driver to an older version to see if it helps?
If that doesn't work, it would be helpful if we had more information about your computer. This can be automatically generated by selecting from the top of Blender
Help -> Save System Info
and uploading the file it produces to this site.Added subscriber: @rjg
For reference the problematic driver @Alaska is referring to is 20.11.2, 27.20.14501.18003 (see #82856). Try to install a current driver, but avoid that specific version.
I have no clue what you're talking about, I haven't updated my driver since I installed the OS which was half a year ago.
The issue is occuring only since 2.91.0 and in experimental builds. When I use older builds it works fine.
system-info.txt
Added subscriber: @jochem_m
Can confirm this issue. I have an RX 460.
Issue is present in 2.91, but not in 2.90.1.
Once the issue occurred, I tried updating video drivers. This caused a separate issue (as described in #83053) which has been fixed by downgrading back to 20.9.1 amd drivers.
Blender 2.90.1 did not exhibit the issue described in this ticket on the latest AMD drivers.
An additional way to trigger this issue is by having two objects, one with viewport display color alpha set to 1, and another with a different material with alpha set to <1. I duplicated the default cube, created a single user copy of its material, and changed the viewport display color alpha slider.
system-info.txt attached{F9381438}
Added subscriber: @oxben
I managed to reproduce it also on my Radeon Vega 8 thanks to the steps given by @jochem_m above.
Graphics card: Radeon Vega 8 (drivers 20.9.1)
My ticket #83039 is probably a duplicate of this one.
Added subscribers: @starweaver, @girafic, @Jewls
Tested here on Windows 10 with RX 480, seems to be fine with Blender 2.91.
Graphics card: RX 480
Blender 2020-11-26 19-17-59_.mp4
@girafic, in fact you need two objects to demonstrate the issue. One with alpha material, and one without as stated by @jochem_m
For me, it works fine with a single cube too. As soon as the second one is added with the other material, the viewport display is broken.
Removed subscriber: @Jewls
@girafic please, make sure to follow the exact instructions I left before commenting.
Re: Drivers: I can also confirm having had this with 19.something drivers before updating, both today and a week or two ago when I tried the beta.
@oxben and @ZackMercury-2 also works fine with two objects
Blender 2020-11-28 00-09-40_.mp4
@girafic Followed your exact steps, but encountered the bug when adding the second material slot like @ZackMercury-2
described.
In your first video (from Nov 26th at 7:34pm), you need either two objects like @oxben pointed out, or the second material slot @ZackMercury-2
used.
In your most recent video, you're using 2.82.5, not 2.91. I haven't tested 2.82.5, but 2.90.1 doesn't exhibit this bug so I assume 2.82.5 also doesn't. I was going to test 2.82.5 but I can't find that version on https://download.blender.org/release/
While I was on the release page, I downloaded the latest LTS (2.83.9) and it works fine.
bug_re_Stas.mp4
@jochem_m ohh, sorry, wrong Blender version, same bug I've also here with Windows 10 and RX 480.
I've tested it on the latest alpha build of Blender 2.92 (November 30, 21:03:39 -
007a0e43a0
).The issue is still present with my Radeon Vega 8.
Do you think there is any chance this bug will be fixed ?
I have no idea if all the AMD GPU users are affected or only a small subset of the AMD GPUs ?
In the mean time it limits my usage of Blender 2.91 on my AMD-based laptop. :-(
Removed subscriber: @Alaska
Added subscribers: @Julian-4, @APEC
Added subscriber: @Yatov
This comment was removed by @Yatov
Problem with Blender 2.91 on AMD GPU rx560x{F9477086}
Added subscribers: @mano-wii, @iss
I can't reproduce with Radeon RX550/550 Series ATI Technologies Inc. 4.5.14736 Core Profile Context 20.8.3 27.20.12027.1001
@mano-wii can you reproduce this?
Added subscribers: @Richard-Reimer, @Alaska
I can reproduce.
It's the same problem as #83179 (Issue in viewport/shading mode with Color Type Random and Object)
It is a problem in the driver.
I will look for a driver update as it has been tested with Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.13596 Core Profile Context 20.10 27.20.1034.6
Added subscriber: @indian_buffalo
Added subscriber: @Homos
Added subscribers: @carlosmu, @GuillermoEspertino, @Harti, @lichtwerk, @nicholashawkes
Excuse me, how come it is possible that the issue "in the driver" is only present in the latest release and only in Blender?
Also, what the hell are we waiting for, what is this "needs triage"?
@ZackMercury-2 Please keep it civil and polite on the bug tracker. The ticket status is confirmed and it does happen that graphics drivers have bugs that are only apparent under specific circumstances. Although this may as well be a combination of an issue in Blender and a bug in the graphics driver.
I understand your point, but if this worked in 2.90, could we just find what from the changes triggers it and undo?
For me, I rely on transparent meshes quite a lot and this bug is crucial as well as some of the sculpt mode updates that we got in the new version which keeps me using it.
Even if it is a bug from AMD, how soon those lazy bastards are going to fix it? I can't wait that long.
There is a workaround yes:
But this may not be good for performance and it may be bad for other hardware.
It is quite possible that the regression came with some automatic windows update (which can install new drivers).
I'm using the 2019 driver, it's the one windows automatically installed for me after OS installation. I disabled Windows automatic updates right after installing it.
Here's my version in the Blender's system-info.txt:
version: '4.5.13559 Core Profile Context 26.20.12028.2'
And even right now, when I click on Update Driver, windows is telling me I'm using the latest driver (even though I'm not).
In addition to @ZackMercury-2 's comment above, the issue does not present itself on 2.90, while it does on 2.91 using the same drivers. It could of course still be a driver issue, but then it's an issue that is triggered in 2.91, but not in 2.90
Updated my driver to the latest version
version: '4.5.13596 Core Profile Context 20.Q4 27.20.11027.5002'
The issue is still there.
Any news about the issue?
Added subscriber: @Jeroen-Bakker
@mano-wii I remember we had some issues with multi attachment clearing on some platforms. It seems to be that the current codebase doesn't have all the workarounds anymore. Note that there are more areas where this could be the case. Can you check if forcing update_attachments in GLFrameBuffer::bind also solves this issue?
P1907: Potential fix for #83022
@Jeroen-Bakker, I can't test this patch because with it the blender takes forever to load on the gray screen (and do not know if it will finish loading sometime) :
Is there any other way for me to test this?
UPDATE:
Actually it loads, but the screen goes gray
In an attempt to test this "
update_attachments
", I tried this:But nothing has changed.
(I forgot to mention that the problem is only this in Release Build).
Added subscriber: @CHECO62
Removed subscriber: @Yatov
I have the same problem i'm using amd rx590. any clue how to fix it?
I have the RX480. I think it's affected all the Polaris models. Next GPU I'll switch to Nvidia... of course.
Added subscriber: @PlayerEmers
bug.mp4
It started happening just now. When i activate x-ray.
My gpu is a RX 580 (Sapphire)
using 2.92 version
funny thing is that its only happening in one blend file
new ones are normal
Re-tested it with the newly released 2.92. I had hope but unfortunately the bug is still there for me too. :-(
GPU: AMD Radeon Vega 8.
Added subscriber: @CreatorSiSo
The solution I found (Im using a radeon rx570) was to install the Radeon™ Pro Software for Enterprise version of the driver.
Added subscriber: @Dval
Added subscriber: @Jknb1
Added subscribers: @Vortex64, @alectt, @small
Added subscriber: @typicallyze
this issue is still there in the latest experimental builds (2.93 and 3.0)
I have checked most of the driver versions but non of them seem to solve the issue
Added subscriber: @Mononoe
Removed subscriber: @carlosmu
Added subscriber: @McGybeer
Added subscribers: @INdek-2, @PratikPB2123, @hoanguk
Added subscriber: @M_Filmtrip
Added subscriber: @jefrau
Multiple times same issue is reported so may be a high priority report?
Could you make a list of affected hardware prior (and add that to the report description)?
Sure
Edit: added to the description. Will update if I find more
Digging deeper into the problem, I found some things in the code that are related to the bug.
The problem is related to the fact that:
wpd->material_buffer_tx
andwpd->accum_buffer_tx
are the same textureswpd->normal_buffer_tx
andwpd->reveal_buffer_tx
are the same texturesAnd for the bug to happen
DRW_draw_pass(psl->opaque_ps)
andDRW_draw_pass(psl->transp_depth_ps)
need to be called at least once.It's like when these two lines are called, the state of
fbl->transp_accum_fb
is changed so thatGPU_framebuffer_clear_color
no longer clears 2 channels of each pixel of the textures.Here is a file that triggers the bug:
transp_and_opaque_bug.blend
Added subscribers: @tims-4, @EAW
Assuming that #89318 is a duplicate @tims-4 ‘bisected’ this to be caused by
854c999d82
Indeed it seems to be a duplicate. In #89318 the artifacts only appear indirectly due to importing, since the imported model has transparent viewport display colors, but the root cause remains the same. The affected hardware in my tests were Radeon RX 470 and Radeon RX Vega 11 (this one is not yet in the description).
Added subscribers: @Zanci19, @zJustSimple
Added subscriber: @Juangmagic
So I tested it on Linux which has opensource AMDGPU driver and everything works fine there.
Are there any folks from AMD here to tag?
Added subscriber: @miketeiniker
Is there any new or development in fixing this bug yet?
Has this been resolved for blender 2.93 or are the AMD Radeon cards not compatible. Please, if somebody could come back to me regarding this bug.
Do I have to submit a new bug report?
Added subscriber: @padone
Windows 10 pro 21H1, ryzen 2200G with vega 8, ati driver 21.10.2, blender 2.93.5
Happens here too. The issue seems limited to blender 2.93.5. I can confirm that blender 2.90.1 works fine.
In my case the issue happened after I updated the driver from 19.9.2 to 21.10.2. Reinstalling the old driver 19.9.2 that worked fine before didn't fix the issue. Using the ati utility to cleanup the drivers didn't work either. So I guess somewhat the drivers update broke something. But blender 2.90 doesn't seem to care and works fine anyway. While blender 2.93 is more "picky" and doesn't work.
edit. Test scene included alpha-glitch.blend. In my test scene there are no textures and the issue does appear anyway. So, if I understand correctly, the fix by Germano Cavalcante can't work.
edit. If I may add a comment. We understand that blender works fine with nvidia, so this is an issue with the ati driver and the optimal solution would be for ati to fix it. Nevertheless, since this seems to be around in a while and ati didn't, a fix or workaround from you blender guys would be great so we ati users can enjoy blender better. Then thank you for everything you do, blender is great.
update. Just tested blender 2.93.6 candidate and doesn't work either.
update. Updated windows from 1909 to 21H1 with ati driver 21.10.2, doesn't fix it.
alpha-glitch.blend
Added subscriber: @RhysRodrigues
Added subscriber: @CJPrinsloo
Hey blender guys. Is there any news regarding this bug yet?
Removed subscriber: @Harti
Added subscriber: @KennethThomas
This beta driver fixes it for me https://www.amd.com/en/support/kb/release-notes/rn-rad-win-21-40-beta-blender-3-0
Does it fix the issue for blender 2.93.5?
Can't install 21.40 beta here, if fails for unsupported hardware. I have a ryzen 2200G with vega 8. Until today 12 dec 2021 at the amd site the recommended driver for my hardware is 21.10.2. That doesn't work fine and gets the alpha glitch.
Yes I tried 2.93.5 & 6 and the 3.0.0 beta and It works. I'm using an RX580.
There are still issues. Is there a fix for blender 2.93 with these AMD cards. The updated driver does not seem to work.
blender 2.93.6, ati driver 21.10.2 (latest for my hardware, 21.40 doesn't install here), ryzen 2200G with Vega 8
I believe I have a game changer here. That's a simple workaround to avoid the glitch and hope helps the developers. At least it works here. Basically you go to object color for the viewport shading so that the viewport materials are not displayed while you edit them, then modify your viewport materials as you wish, then go back to material color for the viewport shading.
Please note that in step 3 you have to assign a material to the new cube. If you don't assign a material then when you go to step 4 the glitch will happen. Once the glitch happens there's no way to fix it in the same session. I have to save the scene, then reset with file > new, then load the scene back, this way I can fix the glitch if it happens.
Again please note that the alpha glitch does not happen with blender 2.90. Also the workaround below may suggest that this is not a driver issue but rather some out of sync with the viewport in blender 2.93 when we edit a material.
how to trigger the alpha glitch
how to avoid the alpha glitch
edit. important note. I just got that the viewport materials must be all transparent to avoid the glitch, if we mix opaque and transparent materials then the glitch will happen. But with all transparent the workaround above works fine. Again hope this helps the developers.
update. Just tested blender 3.0 and it's the same as 2.93.
We use a lot of scripting in our addons, which changes the object's alpha value to less than 0. The glitch seems to occur with the change of the alpha value.
Added subscriber: @MCsculpt
Added subscriber: @niewiemxze
Removed subscriber: @McGybeer
Added subscriber: @Abdulla563
I am getting similar issue to this and it seems to be related to having multiple materials for the same object but if the object only have one material the alpha doesn't produce this glitch.
Added subscriber: @persun
Added subscriber: @Captain_husky
Added subscriber: @FJGC
Added subscriber: @Corps3
This comment was removed by @Corps3
Interesting. After updating driver to 22.7.1, this does not happen to me anymore. Confirmed in 3.3, 3.2.1, and 2.93.
(Maybe new driver's OpenGL optimization solved this?)
Windows 10/RX 570 here.
I can no longer replicate this problem.
So in fact some update from AMD solved this.
However another very similar bug can still be seen #100034 (Glitches with new AMD drivers (Adrenalin 22.7.1 or 22.8.2) when overlay has transparent images)
update. I can confirm that the new amd drivers work fine, no more glitches here. I am using the whql 22.5.1 driver with a ryzen 2200G.
