Smart UV Project invert the resulting UVs #83084
Closed
opened 2020-11-27 01:51:26 +01:00 by Oliver Villar · 17 comments
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: 0f45cab862
Worked: 2.90.1
Caused by 850234c1b1
When using Smart UV Project, the resulting UVs are inverted in the X axis, compared to resulting UVs from Unwrap.
  1. Create a plane.
  2. Use Smart UV Project.
  3. If a material with a texture is added to the plane, the image will be inverted.
This doesn't happen using Unwrap.
Thanks!
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30 **Blender Version** Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: `0f45cab862` Worked: 2.90.1 Caused by 850234c1b1 **Short description of error** When using Smart UV Project, the resulting UVs are inverted in the X axis, compared to resulting UVs from Unwrap. **Exact steps for others to reproduce the error** 1. Create a plane. 2. Use Smart UV Project. 3. If a material with a texture is added to the plane, the image will be inverted. This doesn't happen using Unwrap. Thanks!
Author
Added subscriber: @OliverVillar
#84573 was marked as duplicate of this issue
Added subscriber: @MarcFree3D
I have exactly the same problem. If use Smart UV project the texture image is inverted. But if I use Unwrap it works fine.
Member
Added subscriber: @lichtwerk
Member
Not sure if there is really a "right" or "wrong" here?
If you compare Unwrap to Smart UV to the generated default UVs then they all have a different orientation.
Not sure if there is really a "right" or "wrong" here? If you compare `Unwrap` to `Smart UV` to the `generated default` UVs then they **all** have a different orientation.
Author
I would understand a difference in orientation, but this is not the problem. They show inverted, as in -1 scale in the X axis. A simple texture won't seem problematic, but if the texture includes a text, the text will be "reflected". The resulting UVs have to be scaled in X -1 to be fixed.
And the question is: if I Scale in X-1 when this are fixed all of the textures stay inverted?
The inversion may be not clear in a normal texture, but if the texture contains text it's very clear .
image.png this is inverted using smart uv project. Similar to look a book in front of mirror
image.png and if you use simply unwrap this is the result, works fine, and text isn't inverted
I think this two images can shed light to the question
And the question is: if I Scale in X-1 when this are fixed all of the textures stay inverted? The inversion may be not clear in a normal texture, but if the texture contains text it's very clear . ![image.png](https://archive.blender.org/developer/F9405033/image.png) *this is inverted using smart uv project. Similar to look a book in front of mirror* ![image.png](https://archive.blender.org/developer/F9405044/image.png) *and if you use simply unwrap this is the result, works fine, and text isn't inverted* I think this two images can shed light to the question
Added subscriber: @iss
This is regression from 2.90.1. When I flip normals in 2.92, I get same result as 2.90.1
Added subscriber: @leric8925
Philipp Oeser self-assigned this 2021-01-12 17:54:06 +01:00
Member
OK, get it now, caused by 850234c1b1
Member
Dare setting this to High prio, since it is a regression
This issue was referenced by 20c71ca5d9
This issue was referenced by 20c71ca5d9f942e7596aa5016b50ad5efd047fe5
This issue was referenced by 5d99199880
This issue was referenced by 5d9919988009b158cd918b402d29fc516ad47e35
7 Participants
Reference: blender/blender#83084
