Boolean works not badly - multiprecision/float round trips #83136
Reference: blender/blender#83136
Operating system: Windows 10 64BIT version 20H2
Graphics card: Built-in NVIDIA GEFORCE 820M
blender-2.91.0-31bf8307afc0-windows64
Boolean (exact) works not good. There are some remained faces
CLOCK ENGINE HOUSE.blend
Please see attached image and .blend file.
Added subscriber: @qvinh222
Added subscriber: @AnityEx
Try recalculating normals beforehand (shift+n in edit mode)
Added subscriber: @howardt
The problem here is different trips in and out of floating point, with different transformation matrices, lead to coordinates that should logically be the same in fact having very slightly different values. In this example, the cylinders are subtracted from the Cube, leaving some cylinder-derived coordinates on the resulting mesh. Then the cube-minus-cylinders thing is subtracted from the big cylinder (Cylinder005), leaving more cylinder-derived coordinates on the big cylinder. The finally, the original cylinders are subtracted from that last result -- the user expects that the cylinder-derived coordinates will exactly line up with the corresponding ones on the original cylinders. This is not an unreasonable expectation.
But: because each individual modifier ends by going back into floating point coordinates, it is not guaranteed that that expectation will be true.
This is a known limitation, so I am marking this as Invalid. Sorry, Invalid seems harsh here, but there is not a "Known Limitation" status.
The only way I can think of to fix this limitation is to do all modifier calculations in exact arithmetic, passing the exact-arithmetic result of one modifier to the others that use that result. This would require major surgery on the way modifier stacks work in Blender, and unlikely to be done any time soon, if ever. Maybe the move to "everything nodes" could allow for a new type of geometry pass-through, "exact geometry", that could solve this problem.
Boolean works not badlyto Boolean works not badly - multiprecision/float round trips
