Mesh: Subdivide op flushes selection too eagerly #83181
5 Participants
Reference: blender/blender#83181
Broken: 2.92 master
Worked: N/A
The Subdivide operator selects geometry that it shouldn't. Consider this example:
It looks as if the op flushes selection a bit too much. Note that the 'Expected' selection is valid selection in edge mode, as the edge rings around the rims are not selected. Those edges should neither participate in the op, nor be selected as the result of it, if vertex selection mode is not enabled.
A better example:
...here in face mode, a lone edge is getting selected by the op.
Alternatively, load this simplified example file:
subdivide_selection_issue.blend
...and Subdivide. Resulting selection of the middle face is unwarranted.
Added subscriber: @Stan_Pancakes
Added subscriber: @lichtwerk
Think this is a similar problem/situation as {#73771}?
After subdivide, the original selection as well as the added geometry are selected. If this is flushed, you end up with everything selected
2.79b did the same thing, no?
So unless we can really make a point for this being a bug, I think we have to close this.
Like I said, feel free to comment again [we can always reopen], but as it stands now, I dont think this is a bug.
My bad, I must've done something wrong while testing on 2.79b. Re-testing indeed shows the same behavior as current.
Still, I maintain that this flush is incorrect. The new geometry in this case is that which is selected in my "Expected" case: the new loops and new faces, and as a result - edges around them. Had this been done in vertex selection mode, then yes, it should've selected the rim as well, as a consequence of vertex selection propagating to edges. But in this case this is done in edge selection mode, yet it seems the op is still flushing from verts.
Here's a more concrete indication that this is a bug:
In both edge and face mode, the edge between those original selections gets selected as a result of Subdivide. It shouldn't be, in either mode, especially in face mode as that creates selection inconsistent with current mode.
@lichtwerk Any thoughts wrt. above?
Should I open a new one?..
Changed status from 'Archived' to: 'Needs Triage'
Need to have a look again...
Added subscriber: @wiwa
This comment was removed by @wiwa
Added subscriber: @dr.sybren
Removed subscribers: @dr.sybren, @wiwa
@Stan_Pancakes : Still think this is expected behavior tbh.
We have https://docs.blender.org/api/current/bmesh.html#keeping-a-correct-state which tells us each faces vertices should get selected on the operation and flushed.
Both participating verts of the edge in question are selected in your example (and thus drawn selected).
In a way, your second example does not really differ from your first example?
This (drawing indirectly participating edges selected) doesnt happen on raw face selection (because I think flushing only takes places when changing to e.g. vertex or edge selection mode), so I would still think this is all expected actually.
Why again would you think the second example is different from the first?
It's not different, it's the same thing just better illustraded. That edge is getting selected regardless of mode you're in. For face mode, that's not even a correct selection state - you can't achieve such selection through normal means (and should not be able to).
I haven't looked at the code yet, but from what's going on I gather that the op simply selects all the resulting verts and flushes from them. That's not correct behavior. If you're in edge selection mode, flushing should be done from edges to verts and to faces, but not to verts and then back to edges. I.e. something like this (quick mockup, not thoroughly tested):
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Added subscribers: @DanielBystedt, @mont29, @ideasman42
Afraid I cannot make the final call here.
To me, this does not look like a bug, but there are cases where the described behavior would be benificial.
CC @mont29
CC @ideasman42
CC @DanielBystedt
Good find @Stan_Pancakes
I agree with what you write regarding not ending up with the expected selection after using the subdivide operator. I am stating this from a design perspective as it this might be the expected behavior based on how the code is written.
Below I did a test with the example you described above. I agree that after subdividing the "inner" and "outer" edge ring, the faces pointing in +Z and -Z should not be selected.
#83181 subdivide edges.mp4
Interesting enough, I ended up with the expected selection in this example below. After subdividing the selected faces I first changed to vertex select and then face select, which gave me a desired selection. I agree that the edge in the middle should not be selected after subdividing the faces in the example below
#83181 subdivide faces.mp4
Yes, mode switching validates selection, thus enabling exclusive face selection mode while having a lone edge selected deselects that edge. This is why I maintain that such selection shouldn't be created by the op in the first place (i.e. that this behavior is actually a bug in the op). The thing is, the examples are equivalent: in both cases the stray edge is being selected due to flushing from vertices regardless of selection mode. It's just that the second example shows more clearly why this is a problem.
