Status: Export grease pencil drawings and animations to PDF format to be used in other softwares.
Team
Commissioner: @Antonio Vazquez (antoniov), @Matias Mendiola (mendio), @Daniel Martinez Lara (pepeland)
Project leader: @Antonio Vazquez (antoniov)
Project members: @Antonio Vazquez (antoniov), @Matias Mendiola (mendio), @Daniel Martinez Lara (pepeland), @Falk David (filedescriptor)
Big picture: In a studio pipeline, several tools are used to create th production. To have a PDF exporter allows to import grease pencil drawings and also the PDF can be used for printing comics or create storyboards.
Use cases:
- Import in different softwares that don't support other formats.
- Print drawings.
- Print Storyboards.
Design:
The video above shows how works the tool. The test was done using a Windows version of libharu lib compiled inside blender.
Engineer plan:
- To do the export, a new C++ class will be added to the IO export module for grease pencil.
- The export needs the open source libharulibrary. http://libharu.org/
Relevant links:
Libharu library: http://libharu.org/
