List with fixes that could be in 2.91.1
Fixes that could be in 2.91.2
- rB20f8130d6f90: Fix T82777: Some transform modes using incorrect default orientation
- rB898231fdbcc3: Fix transform redo panel showing only the first custom orientation
- rB44f5d99cbf87: Fix T83020: Transform: AutoConstraint being confirmed without releasing the MMB
- rBf9e994d0f463: Fix T83092: Direction of rotation with View orientation changed in 2.91
- rBe4e7dfc1d8c0: Fix transform snap mixed with incremental
- rBc576d65c2f96: Fix T83161: Crash when moving ruler endpoints and opening or closing the…
- rBf3b08af24c9f: Fix T83352: Move with constraint showing an incorrect value in the header
- rBb9eb59213329: Fix T83460: Regression in snap for measure tool
- rB561d9169fea7: Fix T83280: Crash when deleting hair collision collection.
- rB97651f428b6a: Fix T83050: Crash dragging shared collection to master collection
- rBd1cedf53faaf: Revert "Fix T78823: Slash in custom property name does not work"
- rBc2a01a6c118e: Fix T83347: Smart UV project crashes with wire edges
- rB3d0b65f89b2d: Fix T83296: Unknown actions no longer perform an undo push
- rB2b9eb5eee58a: Fix T83361: UV Editor does not draw pinned selected UVs as pinned
- rBe035d7301c8c: Fix crash sliding effect sequence strips
- rBcf2ebaf27c78: Fix T83875: Converting Proxy to override crashes blender.
- rBebd8a703ccb6: Fix T83851: Python: operator macros cause a crash
- rB8d590e4b8628: Fix T83801: UVEditor translation ignores "Pixel Coordinates" and aspect
- rB7d25139eaf4a: Fix T82960: Inaccurate selection on collapsed outliner rows
- rB4b56c1829073: Fix T84426: Limit dissolve ignores selection with custom normals
- rB967cf303f32f: Fix T83372: Point.select can be True when unselected
- rBf0071dfa10b7: Fix T79779: Pick shortest UV face-path ignores sticky setting
- rB691c021679f6: Fix T82952: Crash changing mesh data block and switching scenes
- rBf35a38fba708: Fix BKE_blender_atexit_unregister error removing from linked list
- rB15bb8f9f936e: Fix file-handle leak when parsing xdg user directories
- rB2d3f96cace6d: Fix T84453: Crash bezier curves transfrom
- rB08e44b5e3ebb: Fix Increment Snapping Without Constraints in Non-Axis-Aligned Views
- rBd11a87b88c4d: DrawManager: High quality normals for non meshes
- rBa3fcbb54f4b0: GPU: Add HQ normals workaround.
- rBcb2517016ba1: GPU: Enable HQ normal work around for AMD Polaris
- rB9fb32b2b2921: Fix T84459: Wireframe not displaying with AMD GPU
- rB4c44a5309cfa: Fix T84459: Face normals not displaying (AMD GPU)
- rBc716b9862aa2: Fix: Update normals when switching scene quality
- rB5d9919988009: Fix T83084: Smart UV Project inverts the resulting UVs
- rB55c56f1ffb6c: Fix T79356: Improved icons for MSIX builds
- rBabbc43e4e419: Fix T84397: Creating and removing many objects very quickly causes a crash
- rBffb6648a970e: Fix T83625: Shading attribute names cause compilation error.
- rB84451f89f5c1: Fix T83300: constant scene refreshing in Cycles with empty volumes
Fixes that could be in 2.91.3
- rBe25f7e33ff4f: Fix T84568: UV loop selection marks edges sharp
- rBe9cd3d50a795: Fix T84988: Armature symmetries crashes with action constraint
- rBacc662ea5a77: Revert "Fix T83092: Direction of rotation with View orientation changed in 2.91"
- rB216ebe0b7392: Fix T83092: Direction of rotation with View orientation changed in 2.91
- rB419c67c8515b: Fix error in recent commit
