Crash when selecting Bone #83293
Closed
opened 2020-12-01 19:48:38 +01:00 by Julian Mohr · 18 comments
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-12-01 09:45, hash: 01b94c5d8a
Worked: Prior to e922dd7d8a
Blender crashes when Bone is selected.
bonetest.blend
It will not crash if another operation is done like circle select etc.
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30 **Blender Version** Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-12-01 09:45, hash: `01b94c5d8a` Worked: Prior to e922dd7d8a **Short description of error** Blender crashes when Bone is selected. **Exact steps for others to reproduce the error** - Open Blender with the default startup scene - Add armature - Enter edit mode - Select bone [2020-12-01 19-47-05.mp4](https://archive.blender.org/developer/F9420879/2020-12-01_19-47-05.mp4) [bonetest.blend](https://archive.blender.org/developer/F9420859/bonetest.blend) It will not crash if another operation is done like circle select etc.
Author
Added subscriber: @Jewls
Member
Member
Added subscriber: @EitanSomething
Member
I can confirm this crash in 2.92.0 Alpha, branch: master, commit date: 2020-11-30 18:56, hash: 007a0e43a0
blender_debug_output.txt
I can confirm this crash in 2.92.0 Alpha, branch: master, commit date: 2020-11-30 18:56, hash: `007a0e43a0` [blender_debug_output.txt](https://archive.blender.org/developer/F9421068/blender_debug_output.txt)
Added subscribers: @JacquesLucke, @rjg
@JacquesLucke It appears that this issue was introduced by commit e922dd7d8a
Member
The video looks quite bad. Unfortunately, I can't seem to be able to reproduce it.
@rjg If you can still reproduce it, can you try undoing the change Clement commented about in D9640?
2020-12-02 10-51-03.mp4
The video looks quite bad. Unfortunately, I can't seem to be able to reproduce it. @rjg If you can still reproduce it, can you try undoing the change Clement commented about in [D9640](https://archive.blender.org/developer/D9640)? [2020-12-02 10-51-03.mp4](https://archive.blender.org/developer/F9424003/2020-12-02_10-51-03.mp4)
@JacquesLucke I will check shortly.
@JacquesLucke Undoing the change avoids the crash.
Member
Do you have any idea for what I'm doing wrong so that I can't reproduce it?
Can you give me a stack trace or ASAN report?
Do you have any idea for what I'm doing wrong so that I can't reproduce it? Can you give me a stack trace or ASAN report?
I don't see anything wrong with your steps in the video.
  • Add > Armature
  • Use {key Tab} to switch to edit mode
Click on the bone
I reproduced the crash on Windows with the following stack trace. base and ebone are NULL which triggers the assert.
_BLI_assert_abort() Line 51	C
get_nearest_editbonepoint(ViewContext * vc, bool findunsel, bool use_cycle, Base * * r_base, int * r_selmask) Line 790	C
ED_armature_edit_select_pick(bContext * C, const int * mval, bool extend, bool deselect, bool toggle) Line 983	C
view3d_select_exec(bContext * C, wmOperator * op) Line 2415	C
view3d_select_invoke(bContext * C, wmOperator * op, const wmEvent * event) Line 2508	C
wm_operator_invoke(bContext * C, wmOperatorType * ot, wmEvent * event, PointerRNA * properties, ReportList * reports, const bool poll_only, bool use_last_properties) Line 1296	C
wm_handler_operator_call(bContext * C, ListBase * handlers, wmEventHandler * handler_base, wmEvent * event, PointerRNA * properties, const unsigned char * kmi_idname) Line 2143	C
wm_handlers_do_keymap_with_keymap_handler(bContext * C, wmEvent * event, ListBase * handlers, wmEventHandler_Keymap * handler, wmKeyMap * keymap, const bool do_debug_handler) Line 2453	C
wm_handlers_do_intern(bContext * C, wmEvent * event, ListBase * handlers) Line 2750	C
wm_handlers_do(bContext * C, wmEvent * event, ListBase * handlers) Line 2959	C
wm_event_do_handlers(bContext * C) Line 3370	C
WM_main(bContext * C) Line 638	C
main(int argc, const unsigned char * * UNUSED_argv_c) Line 526	C
It's the same on Linux for me.
I don't see anything wrong with your steps in the video. - *Add > Armature* - Use {key Tab} to switch to edit mode # Click on the bone I reproduced the crash on Windows with the following stack trace. `base` and `ebone` are `NULL` which triggers the assert. ```lines _BLI_assert_abort() Line 51 C get_nearest_editbonepoint(ViewContext * vc, bool findunsel, bool use_cycle, Base * * r_base, int * r_selmask) Line 790 C ED_armature_edit_select_pick(bContext * C, const int * mval, bool extend, bool deselect, bool toggle) Line 983 C view3d_select_exec(bContext * C, wmOperator * op) Line 2415 C view3d_select_invoke(bContext * C, wmOperator * op, const wmEvent * event) Line 2508 C wm_operator_invoke(bContext * C, wmOperatorType * ot, wmEvent * event, PointerRNA * properties, ReportList * reports, const bool poll_only, bool use_last_properties) Line 1296 C wm_handler_operator_call(bContext * C, ListBase * handlers, wmEventHandler * handler_base, wmEvent * event, PointerRNA * properties, const unsigned char * kmi_idname) Line 2143 C wm_handlers_do_keymap_with_keymap_handler(bContext * C, wmEvent * event, ListBase * handlers, wmEventHandler_Keymap * handler, wmKeyMap * keymap, const bool do_debug_handler) Line 2453 C wm_handlers_do_intern(bContext * C, wmEvent * event, ListBase * handlers) Line 2750 C wm_handlers_do(bContext * C, wmEvent * event, ListBase * handlers) Line 2959 C wm_event_do_handlers(bContext * C) Line 3370 C WM_main(bContext * C) Line 638 C main(int argc, const unsigned char * * UNUSED_argv_c) Line 526 C ``` It's the same on Linux for me.
Author
@JacquesLucke the first click after entering edit mode must be on the bone. if you click somewhere else it wont be triggerd.
Member
Added subscriber: @fclem
Member
Thanks. I'm able to reproduce it now.
The issue is that the armature is drawn in the FOREACH_OBJECT_IN_MODE_BEGIN in DRW_draw_select_loop. However, only the DEG_OBJECT_ITER_FOR_RENDER_ENGINE_BEGIN sets the correct select_id on the cow object.
Here are two possible fixes. @fclem, can you decide what is better, or do you have a better fix?
  1. Make sure that the select_id is correct on the cow object.
diff --git a/source/blender/draw/intern/draw_manager.c b/source/blender/draw/intern/draw_manager.c
index 988975bd399..d19b784f963 100644
--- a/source/blender/draw/intern/draw_manager.c
+++ b/source/blender/draw/intern/draw_manager.c
@@ -2380,6 +2380,8 @@ void DRW_draw_select_loop(struct Depsgraph *depsgraph,
     if (use_obedit) {
       FOREACH_OBJECT_IN_MODE_BEGIN (view_layer, v3d, object_type, object_mode, ob_iter) {
+        Object *ob_iter_orig = DEG_get_original_object(ob_iter);
+        ob_iter->runtime.select_id = ob_iter_orig->runtime.select_id;
         drw_engines_cache_populate(ob_iter);
       FOREACH_OBJECT_IN_MODE_END;
  1. Revert the part of e922dd7d8a that introduces this error. I guess this should be fine for edit mode drawing, but I'm not sure...
diff --git a/source/blender/draw/engines/overlay/overlay_armature.c b/source/blender/draw/engines/overlay/overlay_armature.c
index 1f95eec4486..cbd2589f20f 100644
--- a/source/blender/draw/engines/overlay/overlay_armature.c
+++ b/source/blender/draw/engines/overlay/overlay_armature.c
@@ -1910,7 +1910,7 @@ static void draw_armature_edit(ArmatureDrawContext *ctx)
   edbo_compute_bbone_child(arm);
-  for (eBone = arm->edbo->first, index = ob->runtime.select_id; eBone;
+  for (eBone = arm->edbo->first, index = ob_orig->runtime.select_id; eBone;
        eBone = eBone->next, index += 0x10000) {
     if (eBone->layer & arm->layer) {
       if ((eBone->flag & BONE_HIDDEN_A) == 0) {
@@ -2005,7 +2005,8 @@ static void draw_armature_pose(ArmatureDrawContext *ctx)
         DRW_state_is_select();
     if (is_pose_select) {
-      index = ob->runtime.select_id;
+      const Object *ob_orig = DEG_get_original_object(ob);
+      index = ob_orig->runtime.select_id;
Thanks. I'm able to reproduce it now. The issue is that the armature is drawn in the `FOREACH_OBJECT_IN_MODE_BEGIN` in `DRW_draw_select_loop`. However, only the `DEG_OBJECT_ITER_FOR_RENDER_ENGINE_BEGIN` sets the correct `select_id` on the cow object. Here are two possible fixes. @fclem, can you decide what is better, or do you have a better fix? 1. Make sure that the `select_id` is correct on the cow object. ``` diff --git a/source/blender/draw/intern/draw_manager.c b/source/blender/draw/intern/draw_manager.c index 988975bd399..d19b784f963 100644 --- a/source/blender/draw/intern/draw_manager.c +++ b/source/blender/draw/intern/draw_manager.c @@ -2380,6 +2380,8 @@ void DRW_draw_select_loop(struct Depsgraph *depsgraph, if (use_obedit) { FOREACH_OBJECT_IN_MODE_BEGIN (view_layer, v3d, object_type, object_mode, ob_iter) { + Object *ob_iter_orig = DEG_get_original_object(ob_iter); + ob_iter->runtime.select_id = ob_iter_orig->runtime.select_id; drw_engines_cache_populate(ob_iter); } FOREACH_OBJECT_IN_MODE_END; ``` 2. Revert the part of e922dd7d8a that introduces this error. I guess this should be fine for edit mode drawing, but I'm not sure... ``` diff --git a/source/blender/draw/engines/overlay/overlay_armature.c b/source/blender/draw/engines/overlay/overlay_armature.c index 1f95eec4486..cbd2589f20f 100644 --- a/source/blender/draw/engines/overlay/overlay_armature.c +++ b/source/blender/draw/engines/overlay/overlay_armature.c @@ -1910,7 +1910,7 @@ static void draw_armature_edit(ArmatureDrawContext *ctx) edbo_compute_bbone_child(arm); - for (eBone = arm->edbo->first, index = ob->runtime.select_id; eBone; + for (eBone = arm->edbo->first, index = ob_orig->runtime.select_id; eBone; eBone = eBone->next, index += 0x10000) { if (eBone->layer & arm->layer) { if ((eBone->flag & BONE_HIDDEN_A) == 0) { @@ -2005,7 +2005,8 @@ static void draw_armature_pose(ArmatureDrawContext *ctx) DRW_state_is_select(); if (is_pose_select) { - index = ob->runtime.select_id; + const Object *ob_orig = DEG_get_original_object(ob); + index = ob_orig->runtime.select_id; } } ```
I would go for option number 2.
Member
Ok, I'll commit that then. Thanks.
This issue was referenced by 85f9d319a4
This issue was referenced by 85f9d319a409f26a4ca29d780de6a529794dc13e
Member
Jacques Lucke self-assigned this 2020-12-02 15:34:13 +01:00
6 Participants
Reference: blender/blender#83293
