Operating system: Windows 8.1
Graphics card: AMD Radeon HD 7310
Broken:2.80-rc3 and 2.83.9
(example: 2.79b release)
Principled BSDF gives out this pink/purple tint when connected to image texture in rendered mode in lookdev looks fine. It is not a missing texture issue I thought it could be a memory issue however I disabled everything else but motorcyclehelmet.obj from viewport as well as render the issue still persisted.
PS. This may be a duplicate thread since I found similar issue with Fix T64363 but I do not know how to apply this fix to released versions of blender also I have been unable to find a version where this fix was applied since I also tried 2.83.9 version but still same problem.
