Baking broken when progressive refine is enabled #83344
Reference: blender/blender#83344
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Operating system: Windows 8.1
Graphics card: Nvidia GTX 1650
Broken:
Worked:
Bakes are nearly blank / transparent when the Progressive Refine option is enabled, as if the samples are not properly accumulated.
bake_without_progressive_refine.blend
belowbake_without_progressive_refine.blend
bake_with_progressive_refine.blend
The result should look like a very faint image of how the actual baked texture should look like.
Added subscriber: @l.leonard.dadx2
Added subscriber: @rjg
I've tested this and couldn't find any problem. The file below was created in 2.83.9 and bakes fine in 2.91. Does this file work for you?
bake_2_83_9.blend
Could you please upload a minimal example file that works for you 2.83 but doesn't in 2.91.0?
Thank you for your quick reply!
Yes your file works as it should in 2.83.0 and up, I can recreate this type of minimal baking as well and all is good. I think the issue must be in the baking of selected objects with textures to active object texture or I my process is set up incorrectly and my files work accidently?well.blend
I apologize for the file size but it is the smallest file I have with baking.
@l.leonard.dadx2 Thank you for the file. I will look into this tomorrow.
Don't worry about the file size, 12 MB is completely fine. We just always say minimal because some users upload production files >500 MB. This complicates identifying the relevant parts to reproduce the bug and unnecessarily occupies storage on our server.
I can reproduce some odd results in 2.90.1, 2.91.0 and 2.92.0 with your file that do not happen in 2.83.9. I'll have to investigate this further.
For my own reference: There have been issues in the past that should be fixed (#77298, #78072).
Observations:
Thank you for looking into this. After applying your suggestions I did see that it did in fact bake in 2.91.0, just nearly black. I can get some color and clarity by changing some lighting settings such as the Background strength to 500 in the World tab or adjusting the Exposure in the Render tab, still unfortunately with unusable results.
I just tried baking a beveled edge and textured cube to another cube in 2.91.0 using the same set up process I use in 2.83.0, this is not baking at all.
bakedBrick.blend
A bit off topic, I see that 2.91.0 only utilizes my GPU as low as 10% and only up to 60% while baking and rendering, whereas 2.83.0 utilizes 99%.
This appears to be caused by the Render Properties > Performance > Tiles > Progressive Refine option.
2.91 and 2.90 not baking?to Baking broken when progressive refine is enabledChanged status from 'Needs Triage' to: 'Confirmed'
Thank you, it works! ...not as intended I'm assuming, but that did the trick.
@l.leonard.dadx2 Definitely not intended, I've set the status to Confirmed. This is a bug.
Thank you again, Blender is such a great asset (even with the bug), and you guys do amazing work here.
This issue was referenced by
3fd92b5c22
ef6d652428
