Boolean modifier Exact solver creates square cut when subtracting cylinder from plane #83403
Reference: blender/blender#83403
Graphics card: GeForce GTX 960M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.70
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash:
0f45cab862
When using "Boolean modifier -> Difference -> Exact" to cut circular holes in a plane by means of a collection of cylinders, no vertices are created along the circumference of the cuts, which turn out square, and remove unintended portions of the plane if the cylinders are on the edge (see figures). This does not happen with the Fast Solver.
Create a plane, subdivide it if you want. Create cylinders, move them to a separete collection, and place them on some of the vertices of the plane. Add a Boolean modifier to the plane, select the collection as the operand an Exact solver. The cuts will be square and not round as the should be (and indeed are with the Fast solver)
BooleanExactBug.blend
Starting point
{F9477079, size=full}
Boolean modifier - Exact solver (incorrect result)
{F9477082, size=full}
Boolean modifier - Fast solver (correct result)
{F9477089, size=full}
Added subscriber: @simone.alicino
Added subscribers: @howardt, @mano-wii
Although it works with the fast method, as explained in the manual , this modifier is expected to be used in Manifold meshes (ie, closed volumes).
In your example, neither the face nor the cylinders are Manifold meshes.
So this is a known limitation.
Thanks for the clarification
Changed status from 'Archived' to: 'Resolved'
While still no guarantees, the commit just mentioned makes this case work in exact boolean.
