Inconsitency in channel pinning mechanic (animation/drivers) #83479
Open
opened 2020-12-06 18:45:23 +01:00 by Vas · 14 comments
Operating system: Windows-10-10.0.17763-SP0 64 Bits
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: 0f45cab862
Apparently pinning function is a bit broken, here's the issue:
Here's list of data blocks that don't trigger channel pinning icon:
  • Shape keys
  • Materials
  • Object data > Autosmooth
  • Object data > Remesh
  • Particles > Physics
  • Particles > Render
  • Particles > Emission > Seed
  • Particles > Emission >Lifetime
  • Particles > Emission >Lifetime Randomness
  • Particles > Viewport Display > Display as
  • Particles > Viewport Display > Color
  • Particles > Viewport Display > Amount
  • Particles > Viewport Display > Size
  • Particles > Children
  • Particles > Field Weights
  • World > (All nodes don't display pins)
  • World > Viewport display
  • Scene > (All scene settings can't be pinned)
  • View Layer properties > (all settings can't be pinned)
  • Output properties > (all settings can't be pinned)
  • Render properties > (all settings can't be pinned)
Here's list of data blocks that do trigger channel pinning icon:
  • Object data transforms (location rotation scale)
  • Modifiers
  • Constraints
  • Rigid body constraints
  • Particles >Render > Show Emitter
  • Particles > Viewport Display > Show emitter
  • Physics properties (all modifiers)
The issue:Currently there's a limitation where channel pinning mechanic is only available onObjectlevel datablocks (feature introduced in 98c7e75897), but apparently its possible to circumvent this limitation to deeper types of datablocks (materials, particles, etc.) by adding a keyframe to any type of object level value (Eg. Location data). Even after removing that keyframe, the object keeps pin functionality (that previously was inaccessible)Also same issue persists in Drivers window too
Solution
Just keep pinning option always available
Here's the video demonstrating in detail this issue
2020-12-06 17-20-58_1.mp4
**System Information** Operating system: Windows-10-10.0.17763-SP0 64 Bits Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30 **Blender Version** Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: `0f45cab862` Worked: (newest version of Blender that worked as expected) **Short description of error** Apparently pinning function is a bit broken, here's the issue: Here's list of data blocks that **don't** trigger channel pinning icon: - Shape keys - Materials - Object data > Autosmooth - Object data > Remesh - Particles > Physics - Particles > Render - Particles > Emission > Seed - Particles > Emission >Lifetime - Particles > Emission >Lifetime Randomness - Particles > Viewport Display > Display as - Particles > Viewport Display > Color - Particles > Viewport Display > Amount - Particles > Viewport Display > Size - Particles > Children - Particles > Field Weights - World > (All nodes don't display pins) - World > Viewport display - Scene > (All scene settings can't be pinned) - View Layer properties > (all settings can't be pinned) - Output properties > (all settings can't be pinned) - Render properties > (all settings can't be pinned) Here's list of data blocks that **do** trigger channel pinning icon: - Object data transforms (location rotation scale) - Modifiers - Constraints - Rigid body constraints - Particles >Render > Show Emitter - Particles > Viewport Display > Show emitter - Physics properties (all modifiers) **`The issue:`**Currently there's a limitation where channel pinning mechanic is only available on**Object**level datablocks (feature introduced in 98c7e75897), but apparently its possible to circumvent this limitation to deeper types of datablocks (materials, particles, etc.) by adding a keyframe to any type of object level value (Eg. Location data). Even after removing that keyframe, the object keeps pin functionality (that previously was inaccessible)**Also same issue persists in Drivers window too** ![image.png](https://archive.blender.org/developer/F9490227/image.png) **`Solution`** Just keep pinning option always available Here's the video demonstrating in detail this issue [2020-12-06 17-20-58_1.mp4](https://archive.blender.org/developer/F9480852/2020-12-06_17-20-58_1.mp4) **Exact steps for others to reproduce the error** [Please describe the exact steps needed to reproduce the issue] [Based on the default startup or an attached .blend file (as simple as possible)]
Author
Added subscriber: @Alumx
Added subscriber: @rjg
@Alumx am I understanding your video correctly that the pin option and visibility option is sometimes not displayed in the Graph Editor, e.g. when adding a shape key, but it is displayed when adding an action? Removing the action however, does not remove the pin and visibility option?
@Alumx am I understanding your video correctly that the pin option and visibility option is sometimes not displayed in the *Graph Editor*, e.g. when adding a shape key, but it is displayed when adding an action? Removing the action however, does not remove the pin and visibility option?
Added subscriber: @LucianoMunoz
I would argue pinning should be always present on a per channel basis not on a per channel group.
Added subscribers: @vas-1, @dr.sybren
@vas-1 Please fill out the bug report form completely, and don't rely on a video to convey the information. Videos are nice extras, but are not replacement for a textual description of the problem.
Author
Removed subscriber: @vas-1
Author
@dr.sybren added more info! (also you mentioned someone else back there :p)
^I agree to this, would be nice universal solution
yes, this issue is even more severe if you add keyframe for example in Particles > Viewport display
@dr.sybren added more info! (also you mentioned someone else back there :p) > In #83479#1069859, @LucianoMunoz wrote: > I would argue pinning should be always present on a per channel basis not on a per channel group. ^I agree to this, would be nice universal solution > In #83479#1069851, @rjg wrote: > @Alumx am I understanding your video correctly that the pin option and visibility option is sometimes not displayed in the *Graph Editor*, e.g. when adding a shape key, but it is displayed when adding an action? Removing the action however, does not remove the pin and visibility option? yes, this issue is even more severe if you add keyframe for example in Particles > Viewport display ![2020-12-07-18-34-16.gif](https://archive.blender.org/developer/F9490245/2020-12-07-18-34-16.gif)
Thanks for the update.
Channel pinning was introduced in 98c7e75897 and was limited to certain channel types.
This means that it's a known limitation of Blender, and not considered a bug.
Thanks for the update. Channel pinning was introduced in 98c7e75897 and was limited to certain channel types. This means that it's a known limitation of Blender, and not considered a bug.
Author
I mean, I found a way to break the functionality and keep the pin persistent even if it shouldn't be available for those kinds of data blocks
You can force pin availability by adding and removing object type animation
Isn't that literally a bug?
> In #83479#1070807, @dr.sybren wrote: > Thanks for the update. > > Channel pinning was introduced in 98c7e75897 and was limited to certain channel types. > This means that it's a known limitation of Blender, and not considered a bug. I mean, I found a way to break the functionality and keep the pin persistent even if it shouldn't be available for those kinds of data blocks You can force pin availability by adding and removing object type animation Isn't that literally a bug?
@dr.sybren as you've marked this as a known issue, I'm setting the status to confirmed.
Philipp Oeser removed the
label 2023-02-09 14:35:57 +01:00
Reference: blender/blender#83479
