Operating system: arch linux
Graphics card: RX 460 (radeonsi)
llvm 11.0.0-4, and master compiled today
mesa 20.2.3-1, and master compiled today
Broken: 2.83.9, 2.91.0, 2.92 daily build
Worked: 2.80
selecting a grease pencil object tanks performance and the outline fails to render.
I assume it's the grease pencil outline shader, as it does not render, and other object selection outlines seem to render fine with no slowdown.
I don't know for sure if it's an issue with blender, could also be an LLVM/mesa bug.
blender 2.80 downloaded from blender.org does not have the issue, I'm assuming it's bundled with it's own older LLVM.
these are the relevant lines from startup:
LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr1 = V_CNDMASK_B32_e32 32768, killed $vgpr2, implicit killed $vcc, implicit $exec LLVM failed to compile shader radeonsi: can't compile a main shader part LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader radeonsi: can't compile a main shader part
and then this prints at least once per frame with a grease pencil object selected in object mode:
- start blender (e.g. git-master) in a termimal
$ blender-tip
Read prefs: ... .config/blender/2.92/config/userpref.blend LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr1 = V_CNDMASK_B32_e32 32768, killed $vgpr2, implicit killed $vcc, implicit $exec LLVM failed to compile shader radeonsi: can't compile a main shader part LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader radeonsi: can't compile a main shader part
- delete cube
- add grease pencil → monkey
Info: Deleted 1 object(s) LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec LLVM failed to compile shader LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec ....
