Blender crashes sometime on right click sl;ecting objects sometimes on ctrlz. I have the latest version 2.91 and updated graphics card as well(crash reoprt is linked) #83489
Closed
opened 2020-12-07 06:36:50 +01:00 by Abhay Chouksey · 6 comments
Operating system: Windows 10
Graphics card: NVIDIA Geforce GTX 1080ti
Broken: 2.91
(example: 2.79b release)
Blender crashes randomly, sometimes when I right click to sleect an object sometime when i press ctrl z
I have attached the crash report.
**System Information** Operating system: Windows 10 Graphics card: NVIDIA Geforce GTX 1080ti **Blender Version** Broken: 2.91 (example: 2.79b release) (example: 2.80, edbf15d3c044, blender2.8, 2018-11-28, as found on the splash screen) Worked: (optional) **Short description of error** Blender crashes randomly, sometimes when I right click to sleect an object sometime when i press ctrl z **Exact steps for others to reproduce the error** I have attached the crash report.
Author
Added subscriber: @abhay_chouksey
Added subscriber: @rjg
@abhay_chouksey your report is missing the crash log you're referring to. Please attach the file. Unfortunately, random crashes without reproducible steps are usually not enough information for us to identify the issue. Does this only happen in a particular project or with a particular add-on enabled (you've tag the report as "Add-ons (Community)"?
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
2 Participants
Reference: blender/blender-addons#83489
