NLA: Strip Blend-space Transforms to Easily Align Actions #83615
5 Participants
Reference: blender/blender#83615
(NOTE) Custom build at: https://builder.blender.org/download/temp-nla-strip-alignment/temp-nla-strip-alignment-blender-2.92.0-8118685a831a-windows64.zip
In this build, the preblend transform is in world space but that removes the animators ability to properly change the character's origin of animation. Future builds should have it changed to a more convenient space.
The build won't properly support keyframe remapping when a strip has a non-identity blend-space transform. I wanted to roughly add support before I made the custom build. But I'm also working on other NLA patches at the same time and it was too difficult to properly track everything. This feature will only be properly worked on after D8296: Feature: NLA: Evaluate Whole NLA Stack in Tweak Mode is accepted.
Specific Example
(Rough video example of the blend-space problem and solution)
https://www.youtube.com/watch?v=M9ogJygo2VM
The video was made where IK evaluation wasn't working so everything was baked to FK. Things like feet clipping through the ground due to blending should be ignored as they're a non-problem otherwise.
Problem: There is no way to properly blend two Replace action clips through space. As an example, if we have a through-space Walk cycle blended mid-way into a through-space Run cycle, then there is no way to blend them properly using the NLA only. Let's say the hip bone is the main traversal bone. At the start of the blend, the Walk cycle has the hips at
hips.location.x = 10
. It blends into the start of the Run cycle, which starts athips.location.x = 0
. Thus the hip blends back to 0 which can be a difficult problem to fix.Solution: Per strip, we apply a pre-blend transform to the hips. In this example, there will be no blend transform for the Walk cycle strip. The Run cycle strip will have
blend_transform->location.x = 10
applied on the hips only. Thus, when the Walk blends into the Run, it won't blend to 0. It will blend properly from hipslocation.x = 10
to somewhere around the same world-space location for the Run.Work arounds
Base Proposal
In general, the goal is to blend two actions. Two concrete intended use cases are:
Both cases share the same problem. Blending with the next strip results in the Walk traversal bones blending back to origin because the NLA blends channels in local space. The solution is to provide a pre-blend strip transform for a specific set of bones (root in case (1), Hips and IK legs in case (2)).
This transform cannot be a World-Space transform as that conflicts with the animator's ability to change the character's origin of animation. One solution is a per-bone Local Space transform. It works for both cases but is a bit inconvenient in case (2), where the Hips and IK legs may be children of the root bone, and then potentially require two unique transforms. Another solution is to specify the parent. The children will be preblend-transformed and the transform will be relative to the Parent Pose Space.
Implementation Ideas
At this point, the animator has core access to everything they need to align multiple actions together. Further improvements are about user friendliness and convenience for authoring the blend transforms.
In the above video, the use-case for an arbitrary alignment bone can be found near the end where I align the 3rd action based on the feet position. This operator is likely to be frequently used for alignment. The video also shows and example when the location alignment should ignore the upward (Z) axis, when I aligned the 1st action with the 2nd (so the feet don't clip the ground when the 2nd action plays)
The video shows me temporarily changing the Blend In property to 0 so I can properly align it. This is inconvenient and error-prone.
Design Questions
For my thoughts: see https://developer.blender.org/T83615#1353434
Related problem:
For replace strips, there is a rotation interpolation direction problem. (A character doing a Back Flip blended into a Back-Handspring action clip, video doesn't show this issue) Should we always interpolate along the shortest angle? Is there ever a case where the longer angle is desirable? This is complicated even more since the two strips are animating through the blend which means that even the shortest rotation direction may change over the blend. This problem should only apply to Replace strips. They define absolute poses while all the other blend modes define offsets.
Added subscriber: @wbmoss_dev
Added subscriber: @BClark
Added subscriber: @ChristiaanMoleman
Added subscriber: @TodorNikolov
Added subscriber: @carlosedubarreto
This problem should probably be solved in a separate patch when the problem is more well understood. So the core patch for adding preblend support shouldn't worry about it yet.
I don't think we need to make Strip Modifiers until there are more than one use.
I'm leaning towards a subpanel for now until it becomes an issue. It can easily be moved later.
