Bump map node is doing something strange which is causing unusable viewport performance. #83624
5 Participants
Reference: blender/blender#83624
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.38
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-11-30 18:56, hash:
007a0e43a0
Grab the below file and watch the video to see how to reproduce.
bump map eevee performance issue.blend
bump problem.mp4
Added subscriber: @3di
Added subscriber: @deadpin
It's not necessarily the bump per-se, it's that the final shader is too complex. If you unconnect the last Noise node at the very bottom you'll see "good" behavior. The additional Noise node is what causes the issue in this particular graph and has popped up a few times in the past when new features were added to it (it used to not work at all; and might still not work if pushed further with more nodes). The old issue being #69776 and its duplicates.
That's what I thought, but then:
It's a pixel shader at the end of the day so the fewer pixels that need shading (when zoomed out) the better it'll be (I can get increased performance by keeping the zoom level and just shrinking the viewport even more etc.; remember that this shader math runs per-pixel effectively). Bump is also a rather complex node so there's any number of ways you can stray over the limit.
I still think there's something that doesn't make sense. It seems that the bump node is forcing all downstream nodes to recalculate each draw unnecessarily, at least that's the only reason I can think of for the below:
This setup plays back in the viewport at 3 fps
But the below node setup which contains the same number of nodes plays back at over 30 fps. The only difference is that the bump node only has one noise node downstream, and the others are going into the base colour. Why do the noise nodes need to be recalculated each draw if they're plugged into the bump node, but not when they're plugged into the base colour? Or if I'm wrong and they're not being recalculated, then why would the bump node perform slower with 4 noise nodes connected to it than it does with 1 noise node connected to it, even if the output of 1 noise node is more detailed than the output of the 4 combined noise nodes.....baring in mind that we know the noise nodes are not the bottleneck, because we've tested how quickly they calculate when connected to the base colour.
Added subscriber: @mano-wii
Unfortunately I'm having problems with drivers and I can't investigate this slowdown for now.
This seems to be the same problem as #79522 (Eevee: Procedural material very slow), but a change from 3 to 30 fps because of the bump does not seem normal.
Bump node works at a higher resolution. So it is expected to be 3 or 4 times slower than the color slot.
Thanks. I can appreciate that the bump node may be 3 to 4 times slower than the colour slot, but why would it be slower with 4 noise nodes connected to it than it is with 1 noise node connected to it. Wouldn't the result of 4 combined noise nodes result in the same amount of data as 1 noise node?
Also, when the noise nodes are connected to the bump node, shouldn't they calculate at the same speed they do when they're connected to the base colour? Or perhaps the bump node is forcing all noise nodes to be recalculated more often than they do when they're connected to the base colour?
No,( and I'm not even sure how this could be implemented in any software).
As a general rule, less nodes, less complex shader, faster.
As mentioned, the node is being calculated for an internal texture with higher resolution, if I'm not mistaken containing 4 times more pixels.
I don't know if Eevee uses the result of this texture to optimize the color slot, but that doesn't exempt the fact that it is slower.
hmm, but the 4 identical noise nodes will calculate at the same speed regardless of whether they're going to the bump node or the base colour, and in memory 4 noise nodes added together will still result in the same amount of pixel information as 1 noise node (both 4x the screen resolution internally). So with this in mind the bump node is receiving the same amount of data from 1 noise node as it is from 4 combined noise nodes, and therefore shouldn't be slower with 1 noise connected to it than it is with 4 noise nodes connected to it, because there are still 4 noise nodes being calculated in the entire shader regardless of whether 3 are going to the base colour and 1 to the bump, or 4 to the bump and 0 to the base colour.
Added subscriber: @Stan_Pancakes
@3di that's not the way it works. This isn't about the amount of data (it can be, but not in this case), it's about the size of resultant shader (i.e. code size), and complexity of computation. This is the real downside of visual programming with black boxes (which is what a node-based shader constructor is) - very easy to dramatically increase complexity. It's not at all WYSIWYG. The whole tree that's connected to the Height input of the Bump node is duplicated, twice, under the hood. So if you have one node feeding it, you really have three. If you have 11 like in your example file, you really have 33. Each noise node evaluates noise not once, but per octave (Detail setting), and each evaluation is quite costly. With settings from your example, the four noise nodes would run these expensive computations for a total of 2+7+2+2 = 13 times. Or 39 total taking duplication in mind. All the Add nodes introduce dependencies in the overall shader computation, reducing parallelization in the GPU (depends on hardware and driver). There is only so much code you can feed to the GPU before it can no longer keep up.
You can try this yourself: unplug the bump, group the nodes feeding it, add two more instances, Add them together using a mix node and feed result into base color. You will get a comparable slowdown (and that's before considering that the Bump node itself, which would be skipped entirely in this configuration, has its own overhead). Reduce Detail level on each noise node to 1, and you'll notice significant improvement in performance, even in the bloated graph.
To sum it up: adding a tree branch to a Bump input adds in triplicate; Noise nodes are expensive, each made more so by the Detail setting.
Thanks. Why does it only triple the node tree if it’s connected to the bump and not the base colour?
Because the Bump needs that data :)
So let’s say you have one noise node, which gets duplicated twice because that’s what the bump nose needs apparently. For an individual pixel that’s being calculated, what is the difference between the output of the original tree, the second copy and the third copy?
Could the tree be executed once, and then the result of the two additional iterations be calculated from that instead of having to execute the identical node tree twice more? Presumably there’s a relationship between the difference considering the nodes are identical.
Could you point me to any documentation which explains the purpose for this tripling up of full branches for bump nodes. Not necessarily blender specific.
Added subscriber: @EAW
Let's take a trip, way back to 2.80,
when shadows were softer, and per light,and bump was aliased.On the left 2.80, and on the right 2.92.
In fact, the manual suggested to render out at twice the needed resolution, and downscale the result, if you used a bump node in EEVEE.
(In fact, the manual still says that. I have been meaning to submit a update, but it got lost in my personal TODO pile.)
Sure. Here is a start:
ffd5e1e6ac
Edit: Another article just showing a GLSL implementation of the derivative calculation and how it is calculated on 2x2 pixel blocks. If you want to get the derivative down to the individual pixel size, then you have to manually calculate it by duplicating your texture twice, offsetting one of the duplicates a pixel in the x direction, and the other along the y.
I'll be closing this task as it is as the code is working as designed, and therefor doesn't meet this trackers definition of a bug.
So it's duplicating and recalculating entire node branches just so it can add a 1 pixel offset in the x and y directions?
Would it not be better to just render an additional 1 pixel outside of the screen and then perform a translation on the data from the first branch's execution, rather than recalculating the entire branch 3 times to get identical information moved slightly in two different directcions?
Where would be the best place to move this conversation to in order to get a dev to look at it? Seems a shame to cast it off into oblivion when there appears to be an approach which will give a 3x performance increase for materials that use bump in EEVEE.
ignore that, I just realised it's not just a case of moving the screen pixels, it's a case of moving them along the surface of the object, and the out of view pixels arent there to be moved because it's a screenspace renderer.
Perhaps it could use one iteration of the branch, and render one additional pixel for all borders, and then move the result in uv space instead of executing the node branch 3 times?
Removed subscriber: @Stan_Pancakes
Closed as duplicate of #79522
