Cycles OSL - compiling shaders failing due "\" and "n" symbols combination inside include paths - Needs OSL update #83631
7 Participants
Reference: blender/blender#83631
Operating system: Windows 10 Enterprise 1909 18363.1198
Graphics card: Intel(R) UHD Graphics 620
OSL Compiler version: 1.10.10
Broken:
46e66d154c
During building OSL shaders a compiler reports errors like this:
The problem is, that "" and "n" symbol combinations, which naturally appears in file paths, handled as new line, which cause fail of the file including.
P.S. Is it upstream problem and should be reported to OSL compiler tracker?
Added subscriber: @Sirgienko
Added subscriber: @maxim_d33
CC: @maxim_d33
Added subscribers: @LazyDodo, @EAW
Researching this, it looks like this was fixed upstream already, fixed in Blender, then broken again? I'll have to test.
b9c9b00171
stdosl.h
issue fixed in a commit Feb 11 D6812: Fix: OSL warnings during builddf1e9b662b
8d60e6fa38
Fixed on Feb 17 see #73830 (Blender complains that it cannot find "stdosl.h", despite it existing at "/usr/share/OSL/shaders/stdosl.h") for further details.@LazyDodo Is a pair of parenthesis missing in a CMake file? Did fixing Linux break Windows perhaps?
No this is an issue in oslc nothing we do on the blender side can fix/unfix this behavior.
i'd have to test with the latest osl to see if the issue has been fixed already and if not report it upstream.
Added subscriber: @brecht
The bug was fixed in the clang code path in #1101, but the boost_wave codepath above it still has the issue which sadly is the current path our libraries take.
couple of options here
@brecht thoughts?
I wouldn't mind upgrading to 1.11. I already did adjustments for API changes a bit before the release, hopefully it will just build and work as is. But if note I can update the code.
I managed to build 1.11, passes all tests without any modifications in blender (and fixes this issue). The deps builder for osl needed some more substantial changes and cleanup, i'll try to get that polished up in the next couple of days.
Thanks!
Cycles OSL - compiling shaders failing due "\" and "n" symbols combination inside include pathsto Cycles OSL - compiling shaders failing due "\" and "n" symbols combination inside include paths - Needs OSL updateThis issue was referenced by blender/cycles@5fe5537a34
4fb0c83c1c
Added subscriber: @hargettp
FYI, the commit in D10212 broke builds on Mac OS X Big Sur (Apple M1 Mac / darwin arm64).
The error after running
make
is:The contents of CMakeError.log are:
The commit just before this one still builds just fine.
Update your svn libs, @sebbas was on that yesterday, i assume that was completed?
Added subscriber: @sebbas
I see you're on Apple M1. @hargettp the libs still have to be updated for that, so far the changes only considered x86.
As soon as I have access to an M1 machine again, I'll make the lib update.
@LazyDodo Yeah, I think it's time to make Apple arm a hard requirement for lib updates.
Ah this makes sense @sebbas ; I ran
make update
before doing a fresh build, so missing ARM libraries would certainly do it.@hargettp ARM libraries have been updated, so after
make update
builds should work again!Worked like a charm and running again on Apple M1--thx @sebbas !
Great, let's consider this resolved then.
