RMB cancel of translation of an object-offset array leaves the array in a visually undeterminate state #83724
2 Participants
Reference: blender/blender#83724
Operating system: Linux-5.9.12-1-default-x86_64-with-glibc2.17 64 Bits
Graphics card: AMD Radeon (TM) RX 480 Graphics (POLARIS10, DRM 3.39.0, 5.9.12-1-default, LLVM 11.0.0) X.Org 4.6 (Core Profile) Mesa 20.2.4
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-12-12 18:07, hash:
4797c13e8f
A curve object (named "Cage") has been duplicated in a circular pattern using an Array modifier and an Empty object as an object offset. The Empty object is parented to the curve object. If I try to move "Cage" (the parent object) with
G
and canceling the operation withRMB
, the object-offset duplication pattern appears to be visually destroyed, as shown in this image:However, hitting
Tab
twice to enter/leave the Edit mode, brings back the object in a correct state.Oddly enough, saving the file
Ctrl+S
with the object in an apparently destroyed state and reloading it also brings back the object back to normal. So, this appears to be a strictly viewport update glitch and therefore likely to be a true bug.Exact steps for others to reproduce the error
In the attached blend file:
G
the Object called "Cage" and move it around without confirming the operationRMB
=> Object is destroyedTab
twice => Object is repairedcages_array-update-bug.blend
Added subscriber: @s12a
Rotate
R
and ScaleS
operations on the same object are also affected by thisRMB
-cancel bug, it turns out.Transform operations with numerical input are also affected by this visual glitch, but after the operation is confirmed the object returns to its normal state.
Steps from the previously attached .blend file:
G
X
, then1
=> Object is destroyedEnter
orLMB
=> Object is repairedAdded subscriber: @rjg
You have a dependency cycle in your project. The position of the cage array elements depend on the location of the empty, whose location depends on the cage as it is parented to it. If you parent the cage to the empty, instead of the empty to the cage, you can move the empty around and everything follows.
After arranging the parent-child relationship differently, it does indeed work correctly. I guess there was an expectation that the program would have tried to cope with the issue more consistently or warn the user.
@s12a A warning is printed to the console (Window > Toggle System Console), which is easy to miss. We're planning to display warning and error messages more consistently in the future.
I confirm those messages appearing in the console, although on Linux I had to launch Blender from the terminal to see them (no Window>Toggle System Console option here).
