Bake All Dynamics doesn't include all when Lifetime of particle system gets animated #83802
Reference: blender/blender#83802
Operating system: Windows 10
Graphics card: Quattro
Broken: 2.91.0
Worked:
When the lifetime setting of a particle system gets changed during an animation of the emitter and the animation gets baked, the number of frames are not aligned to the changed lifetime.
Initial lifetime of 100 will be changed during the animation to 500. Number of frames after bake is the frame end setting of the particle system plus the initial life time setting - in this case 100.
Open attached file or (Based on the default startup):
Bake all Dynamics
You will see 351 frames in memory and not 751 as expected
Although the error is the same, rendering of animation does still work in Blender 2.83.5 but not in Blender 2.91.0 anymore
WORKAROUND: Set keyframe for lifetime on frame 0 with lifetime value 500
LiveTimeTest_002.blend
Added subscriber: @Nadir
Bake All Dynamics doesn't include all when Life time of particle system gets animatedto Bake All Dynamics doesn't include all when Lifetime of particle system gets animatedAdded subscriber: @mano-wii
I followed all the steps, but I was unable to reproduce the problem :\I cannot reproduce this with either the latest stable or current development versions of Blender:
Can you try the latest daily build? https://builder.blender.org/download/
Could you provide a simple blend file saved right before the bug occurs? So only a few steps are needed to trigger the bug.
I tested it withthe latest Alpha build version 2.92.0 Alpha and withthe latest release build 2.91.0 . Same result - if you Bake all Dynamics you do get 351 frames in memory. But it should be 751 because of the lifetime change at frame 50.
Added subscriber: @dfelinto
Thanks for the report. Marking this as known issue since it depends on the old particle settings which is end of life .
#107447 is probably related
