Eevee not working
Closed, DuplicatePublic
Operating system: Windows 10
Graphics card: Rx570
Broken: (2.91)
Worked: (2.90)
Eevee render engine not working.
Eevee just don't work on my pc anymore but cycles is perfectly fine.
Alaska (Alaska) changed the task status from Needs Triage to Needs Information from User.Dec 17 2020, 11:59 PM
Alaska (Alaska) added a subscriber: Alaska (Alaska).
There have been various reports of rendering issues with AMD GPUs in Blender after recent driver updates. Are you able to try downgrading your GPU drivers to see if it helps?
For reference, we keep track of these issues with the drivers in T82856.
You can also try enable Render Properties -> Performance -> High Quality Normals as a temporary workaround.
Downgrading only helps on 2.91 in the current documented cases., for 2.92 the issue still persists on RX 4XX and RX 5XX series.
For eevee using the newest enterprise driver also works in 2.92 older adrenalin drivers should also work but I haven't tested them on 2.92
@Hannah Umit (Koterminion) if the workarounds described in T82856 don't solve the problem for you, please create a separate ticket.
