Crash when rendering with OptiX denoiser enabled #83925
Closed
opened 2020-12-18 12:02:51 +01:00 by Robert Guetzkow · 20 comments
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version:
  • 2.92.0 Alpha, branch: master, commit date: 2020-12-28 21:34, hash: 81c57c9471
  • 2.92.0 Alpha, branch: master, commit date: 2020-12-18 08:18, hash: 4f9e21bdc9
  • 2.92.0 Alpha, branch: master, commit date: 2020-12-16, hash: 3a1d1aaa86
  • 2.92.0 Alpha, branch: master, commit date: 2020-12-15, hash: 977bd7937a
  • 2.92.0 Alpha, branch: master, commit date: 2020-12-14, hash: 010f44b855
    Worked: 2.92.0, branch: master, commit date: 2020-11-19, hash: fdd3032f8f
Rendering with OptiX denoiser enabled results in a crash
  • Open Blender.
  • Set the render engine to Cycles.
  • Use the CPU as render device.
  • Enable Sampling > Denoising > Render and set it to OptiX.
Render the default cube.
2020-12-18_optix_denoise.blend
std::vector<ccl::BVH *,ccl::GuardedAllocator<ccl::BVH *>>::operator- [ ](const unsigned __int64 _Pos) Lines 1504	C++
ccl::MultiDevice::build_bvh(ccl::BVH * bvh, ccl::Progress & progress, bool refit) Lines 270	C++
ccl::GeometryManager::device_update_bvh(ccl::Device * device, ccl::DeviceScene * dscene, ccl::Scene * scene, ccl::Progress & progress) Lines 1170	C++
ccl::GeometryManager::device_update(ccl::Device * device, ccl::DeviceScene * dscene, ccl::Scene * scene, ccl::Progress & progress) Lines 1663	C++
ccl::Scene::device_update(ccl::Device * device_, ccl::Progress & progress) Lines 271	C++
ccl::Scene::update(ccl::Progress & progress, bool & kernel_switch_needed) Lines 507	C++
ccl::Session::update_scene() Lines 1034	C++
ccl::Session::run_cpu() Lines 794	C++
ccl::Session::run() Lines 879	C++
 	[External Code]
ccl::thread::run(void * arg) Lines 53	C++
 	[External Code]
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30 **Blender Version** Broken: version: - 2.92.0 Alpha, branch: master, commit date: 2020-12-28 21:34, hash: `81c57c9471` - 2.92.0 Alpha, branch: master, commit date: 2020-12-18 08:18, hash: `4f9e21bdc9` - 2.92.0 Alpha, branch: master, commit date: 2020-12-16, hash: `3a1d1aaa86` - 2.92.0 Alpha, branch: master, commit date: 2020-12-15, hash: `977bd7937a` - 2.92.0 Alpha, branch: master, commit date: 2020-12-14, hash: `010f44b855` Worked: 2.92.0, branch: master, commit date: 2020-11-19, hash: `fdd3032f8f` **Short description of error** Rendering with OptiX denoiser enabled results in a crash **Exact steps for others to reproduce the error** - Open Blender. - Set the render engine to *Cycles*. - Use the CPU as render device. - Enable *Sampling > Denoising > Render* and set it to *OptiX*. # Render the default cube. [2020-12-18_optix_denoise.blend](https://archive.blender.org/developer/F9516346/2020-12-18_optix_denoise.blend) ```lines std::vector<ccl::BVH *,ccl::GuardedAllocator<ccl::BVH *>>::operator- [ ](const unsigned __int64 _Pos) Lines 1504 C++ ccl::MultiDevice::build_bvh(ccl::BVH * bvh, ccl::Progress & progress, bool refit) Lines 270 C++ ccl::GeometryManager::device_update_bvh(ccl::Device * device, ccl::DeviceScene * dscene, ccl::Scene * scene, ccl::Progress & progress) Lines 1170 C++ ccl::GeometryManager::device_update(ccl::Device * device, ccl::DeviceScene * dscene, ccl::Scene * scene, ccl::Progress & progress) Lines 1663 C++ ccl::Scene::device_update(ccl::Device * device_, ccl::Progress & progress) Lines 271 C++ ccl::Scene::update(ccl::Progress & progress, bool & kernel_switch_needed) Lines 507 C++ ccl::Session::update_scene() Lines 1034 C++ ccl::Session::run_cpu() Lines 794 C++ ccl::Session::run() Lines 879 C++ [External Code] ccl::thread::run(void * arg) Lines 53 C++ [External Code] ```
Author
Member
Added subscriber: @rjg
#84241 was marked as duplicate of this issue
#84231 was marked as duplicate of this issue
Author
Member
Contributor
Added subscriber: @Raimund58
Contributor
This 4f9e21bdc9 might be the bad boy.
EDIT: No, can't be. The time doesn't match, no?
~~This 4f9e21bdc9 might be the bad boy.~~ EDIT: No, can't be. The time doesn't match, no?
Author
Member
@Raimund58 No, the crash also occurs in:
  • 3a1d1aaa86 2020-12-16
  • 977bd7937a 2020-12-15
  • 010f44b855 2020-12-14
@Raimund58 No, the crash also occurs in: - `3a1d1aaa86` 2020-12-16 - `977bd7937a` 2020-12-15 - `010f44b855` 2020-12-14
Added subscriber: @brecht
Brecht Van Lommel self-assigned this 2020-12-24 14:11:53 +01:00
Fixed by c4f8aed, same underlying cause.
Author
Member
@brecht I think this was incorrectly closed, it still crashes when rendering on the CPU with OptiX denoiser enabled.
Author
Member
Changed status from 'Resolved' to: 'Confirmed'
Author
Member
Added subscriber: @JasonClarke
Member
Added subscriber: @kaban
Added subscriber: @rlneumiller
I am able to reproduce with nightly build Blender 2.92.0 Alpha January 01, 00:24:12- 0da1fc2fc4 Windows 64 bit
blender_debug_output.txt
2020-12-18_optix_denoise.crash.txt
blender_system_info.txt
But Curiously it does not reproduce with my local "Release" build sync'd to the same commit as the nightly build.
I am able to reproduce with nightly build Blender 2.92.0 Alpha January 01, 00:24:12- 0da1fc2fc417 Windows 64 bit [blender_debug_output.txt](https://archive.blender.org/developer/F9544661/blender_debug_output.txt) [2020-12-18_optix_denoise.crash.txt](https://archive.blender.org/developer/F9544662/2020-12-18_optix_denoise.crash.txt) [blender_system_info.txt](https://archive.blender.org/developer/F9544663/blender_system_info.txt) But Curiously it does not reproduce with my local "Release" build sync'd to the same commit as the nightly build.
This issue was referenced by 3373d14b1b
This issue was referenced by 3373d14b1b05b2ee5dc88efff5dc8b1a5fe20f36
Member
Added subscriber: @pmoursnv
Brecht Van Lommel was unassigned by Patrick Mours 2021-01-05 18:39:53 +01:00
Patrick Mours self-assigned this 2021-01-05 18:39:53 +01:00
Member
Member
Should be fixed now!
7 Participants
Reference: blender/blender#83925
