Blender baking's margin overlap if multiple meshes are selected #83971
7 Participants
Reference: blender/blender#83971
Basically just a duplicate of https://developer.blender.org/T51134 that Aaron Carlisle asked me to send as a new report.
Operating system: Linux-5.4.0-58-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: AMD RAVEN (DRM 3.35.0, 5.4.0-58-generic, LLVM 10.0.0) X.Org 4.6 (Core Profile) Mesa 20.0.8
Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash:
3e85bb34d0
Worked: never with Cycles as far as I know.
Cycles overlap the region margin on other islands in the final result.
Cycles will bake an object/island, apply the margin, then proceed to do the same to the next one on top of the previous and they will overlap if the margin is bigger than the distance of the UVs, instead of applying to the finished bake and having the margins having an equal distance between islands, as Blender Internal used to do.
Just press bake on the file. Or any multiple objects with a margin bigger than the UV islands.
As far as I know this has always been a problem with the Cycles baking implementation, besides some other issues of performance and usability. For instance if baked with multiple objects selected it is much, much slower than if I collapse them and merge, as I mentioned in the previous bug report.
I understand it should be slower if they are separated, but I don't imagine it should be that much slower.
Added subscriber: @alexfaiad
UVoverlap.blend
I forgot to send the files again.
Added subscribers: @Blendify, @rjg
This is how the margin for the bake works in Cycles, I don't think we can consider this a bug. If the margin is too large the resulting bakes will overlap each other.
@Blendify Is there a particular reason why you think this would be a bug?
I dont know if is a bug or not, I just wanted a new report to not involve all the subscribers of the original report.
Why I think it's a bug and reported it (and so did the other guy before me):
1- This has always worked in Blender Internal. The way it works in Cycles makes it essentially a useless feature when you have multiple objects selected since you risk destroying hours of bake for no good reason.
2- It is supposed (or at least I strongly believe so) to be a simple post processing filter applied to the END result (not after each object as is currently the case) to save the user some time since otherwise I have to manually do this in photoshop or something else later on. It saves a lot of time when you have to do multiple tests or multiple bakes.
3-Above all, the objects you see are supposed to have single colored materials with the bake, and now they are all messed up. If cycles is messing up with that, it's a bug, no? In my 20 years working with graphical arts I have never seen a use case where someone would want this to happen. There must be, but it's certainly rare, as opposed to mipmappng bleeding.
Just in case the reason for this feature (or so it was in Blender Internal) was not understood by the original developer, it's so that the margins don't become visible when you see a mipmapped texture in a game engine, specially lower end one. Something absolutely essential to be done, and the main reason to bake multiple objects in a single texture (called an atlas) is to save on draw calls for performance on lower end devices. So I would say that the majority of time someone wants to bake multiple objects in a single texture, they will have to disable margin in Blender and do it manually themselves.
I am just astonished that in all this years only myself and the previous guy were bothered enough by this issue to post about it. Which makes me think that people working in actual production just find work around or give up and change to another software. I know I usually do it as well. I just thought this one could be an easy fix while being a big headache for me.
Ah yeah, the other reason I never reported is because Cycles bake was new back then, and to me this was clearly a bug that you guys just didn't have enough time to fix and I could just wait.
But after all these years I realize that's not going to happen. And judging by Robert's answer, I guess it's because you guys think this is intentional. Hopefully with my explanation it becomes clear why it can't be intentional, just that probably the original developer didn't fully understand the purpose of the feature. Which is surely not obvious if you don't work with game design.
And if you guys still think this could be a feature (and I can guarantee that the vast majority of users who want margin on the bake would not have that intention), then maybe it could be just an option that you activate saying something like "Per object margin - Applies the margin for each object instead of the final result".
But then this would be a feature, and one that rarely anyone will try to use. But more options are always better for the end user in production anyway, if Blender foundation can afford to add them. For simplicity sake I would recommend to just change it to be done after all objects and see if anyone will ever report missing the previous behaviour.
Added subscriber: @brecht
@brecht seems like this might need your input. The core problem appears to be that margin is applied per object instead of for all objects in the end.
Added subscriber: @ziflin
I just ran into this issue as well. It can easily result in bad bakes when baking multiple objects into a single texture which we do all the time. I don't think anyone would see the current result as being desirable. Ideally the margin would just be a single/separate step done after the baking of all objects completes.
Added subscriber: @endike
folks, this is a very big bug. now blender is neary unusable for serious baking works...
I dont understand why the developers says it is not bug :-O
Added subscriber: @leomozoloa
I just ran into this very problem and I agree, I fail to see how this would be desirable, it considerably slows down the baking process...
