Sound strips don't change length when sound file is changed #84027
Open
opened 2020-12-21 21:48:44 +01:00 by Marco · 14 comments
Member
Operating system: Windows 10
Graphics card: Nvidia MX150
Broken: 2.91 and 2.92 Alpha
Steps to reproduce
Add sound, change file to another one with different length.
Strip length is not updated.
**System Information** Operating system: Windows 10 Graphics card: Nvidia MX150 **Blender Version** Broken: 2.91 and 2.92 Alpha **Steps to reproduce** Add sound, change file to another one with different length. Strip length is not updated.
Author
Member
Added subscriber: @nacioss
#94149 was marked as duplicate of this issue
Added subscriber: @iss
This may happen if file on disk has changed sound strips do recalculate length on various updates. It would help to provide any info how this could be reproduced from scratch if file was never touched and check if this happens with older versions.
Can you share .blend and sound file?
I think I should treat this as bug regardless if file has been changed or not. Sound can't be longer than actual sound length, but no strip should automatically increase it's length - it can mess up timeline.
This may happen if file on disk has changed sound strips do recalculate length on various updates. It would help to provide any info how this could be reproduced from scratch if file was never touched and check if this happens with older versions. Can you share .blend and sound file? I think I should treat this as bug regardless if file has been changed or not. Sound can't be longer than actual sound length, but no strip should automatically increase it's length - it can mess up timeline.
Author
Member
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Author
Member
Test.zip
Simplified the file.
Steps:
  • Open Final.blend
  • Open FPS dropdown and click on 24
[Test.zip](https://archive.blender.org/developer/F9525352/Test.zip) Simplified the file. Steps: - Open Final.blend - Open FPS dropdown and click on 24
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
Thanks for example file. As far as I can see, code is working as intended - if sound length doesn't match, it is updated. Sound length is about 27s, while in timeline it is only 24s.
I would need to know how this difference happened in first place. When I add sound again, it has correct length. This could be caused by some addon or perhaps vile was created in old version where length wasn't updated.
Thanks for example file. As far as I can see, code is working as intended - if sound length doesn't match, it is updated. Sound length is about 27s, while in timeline it is only 24s. I would need to know how this difference happened in first place. When I add sound again, it has correct length. This could be caused by some addon or perhaps vile was created in old version where length wasn't updated.
Author
Member
Not sure if that was it but, I'm sure I did add them and then updated the sound files... will try to reproduce later but not sure i will be able to.
Author
Member
I got it :), basically it happens when a file with same name has changed its length... so is it normal behaviour? shouldn't it update the strip UI when you open the project? or even tell that the file has changed?
Test1.zip
Steps:
  • Go inside Music/Exports
  • Delete "Final.wav"
  • Rename "Rename this.wav" file to "Final.wav"
  • Open the blend file and change the fps to 24
I got it :), basically it happens when a file with same name has changed its length... so is it normal behaviour? shouldn't it update the strip UI when you open the project? or even tell that the file has changed? [Test1.zip](https://archive.blender.org/developer/F9526925/Test1.zip) Steps: - Go inside Music/Exports - Delete "Final.wav" - Rename "Rename this.wav" file to "Final.wav" - Open the blend file and change the fps to 24
Thanks for update. This is expected behavior.
When you load file, ideally nothing should happen. This is because this way we can open files as fast as possible.
Blender has no control of what happens to files on HDD when it is not running. Ideally you should change media using Blender UI controls. However sound length is not updated using these controls either, so this should be fixed at least.
Thanks for update. This is expected behavior. When you load file, ideally nothing should happen. This is because this way we can open files as fast as possible. Blender has no control of what happens to files on HDD when it is not running. Ideally you should change media using Blender UI controls. However sound length is not updated using these controls either, so this should be fixed at least.
Richard Antalik changed title from VSE: strips update when changing fps value to Sound strips don't change length when sound file is changed 2020-12-27 14:45:45 +01:00
Added subscribers: @georgK, @PratikPB2123
Thomas Dinges added this to the 2.93 LTS milestone 2023-02-07 18:40:57 +01:00
Richard Antalik added this to the Video Sequencer project 2023-02-09 21:19:14 +01:00
Philipp Oeser removed the
label 2023-02-10 09:31:57 +01:00
Pratik Borhade removed this from the 2.93 LTS milestone 2023-07-31 13:05:42 +02:00
Reference: blender/blender#84027
