Blender 2.9 crashes during texture bake #84107
Closed
opened 2020-12-24 11:17:45 +01:00 by Brendan · 11 comments
Operating system: Mac OSX Catalina version 10.15.7 (2,3 GHz Quad-Core Intel Core i7)
Graphics card: NVIDIA GeForce GT 750M OpenGL Engine NVIDIA Corporation 4.1 NVIDIA-14.0.32 355.11.11.10.10.143
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-12-11 22:08, hash: 0c1d476923
Worked: Blender 2.83
UV unwrap an object
Create a material with principled shader
Add an image texture
Switch to cycles render engine
With the texture selected in the node editor click the bake button
Blender crashes immediately.
**System Information** Operating system: Mac OSX Catalina version 10.15.7 (2,3 GHz Quad-Core Intel Core i7) Graphics card: NVIDIA GeForce GT 750M OpenGL Engine NVIDIA Corporation 4.1 NVIDIA-14.0.32 355.11.11.10.10.143 **Blender Version** Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-12-11 22:08, hash: `0c1d476923` Worked: Blender 2.83 **Short description of error** Blender 2.9 crashes during texture bake **Exact steps for others to reproduce the error** UV unwrap an object Create a material with principled shader Add an image texture Switch to cycles render engine With the texture selected in the node editor click the bake button Blender crashes immediately.
Author
Added subscriber: @Brendan-White-1
#84309 was marked as duplicate of this issue
Added subscriber: @rjg
Please test a more recent daily build of Blender 2.92 . This could be the same as #84016 which has been fixed.
Should this problem still occur, please add to your report:
  • If you're using CPU or GPU compute and if CUDA or OptiX is select in Edit > Preferences > System
  • Copy the text from the crash reporter that should open into a file and attach it to your report
Please test a more recent [daily build of Blender 2.92 ](https://builder.blender.org/download/). This could be the same as #84016 which has been fixed. Should this problem still occur, please add to your report: - If you're using CPU or GPU compute and if CUDA or OptiX is select in *Edit > Preferences > System* - Copy the text from the crash reporter that should open into a file and attach it to your report
Author
I eventually found the cause of the bug - the issues was caused by and add-on called bezier utilities. (Awesome add-on by the way). Once disabled the issue is fixed.
https://github.com/Shriinivas/blenderbezierutils/blob/master/README.md
I eventually found the cause of the bug - the issues was caused by and add-on called bezier utilities. (Awesome add-on by the way). Once disabled the issue is fixed. https://github.com/Shriinivas/blenderbezierutils/blob/master/README.md
Thanks for getting back to us. Just at a first glance I don't see how the add-on would cause a crash during bake. Please either provide the requested crash log or if you're certain that this is caused by the add-on, report the problem on the GitHub page.
@Brendan-White-1 Could you please provide us the crash log?
Author
Apologies for the ate response, i have been on vacation. Here is the requested crash report:
Process: Blender [2353]
Path: /Applications/Blender.app/Contents/MacOS/Blender
Identifier: org.blenderfoundation.blender
Version: 2.92.0 (2.92.0 2020-12-28)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Blender [2353]
User ID: 501
Date/Time: 2021-01-09 20:42:03.294 +0200
OS Version: Mac OS X 10.15.7 (19H114)
Report Version: 12
Anonymous UUID: 566ADE8C-E821-A684-2C95-097561082086
Sleep/Wake UUID: DED5B8D6-F1FF-4920-AB96-FF01112FC505
Time Awake Since Boot: 12000 seconds
Time Since Wake: 2800 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGSEGV)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: Blender [2353]
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff67bdf882 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff67ca0425 _pthread_cond_wait + 698
2 org.blenderfoundation.blender 0x000000010e35ff30 take_gil + 240
3 org.blenderfoundation.blender 0x000000010e36048f PyEval_RestoreThread + 31
4 org.blenderfoundation.blender 0x000000010e39b4ab PyGILState_Ensure + 59
5 org.blenderfoundation.blender 0x0000000108592f85 bpy_context_set + 37
6 org.blenderfoundation.blender 0x00000001085ac3fa cb_region_draw + 26
7 org.blenderfoundation.blender 0x00000001086b333b ED_region_draw_cb_draw + 75
8 org.blenderfoundation.blender 0x00000001085bbde1 ED_region_do_draw + 801
9 org.blenderfoundation.blender 0x0000000107fdbf2d wm_draw_update + 1757
10 org.blenderfoundation.blender 0x0000000107fd95c0 WM_main + 48
11 org.blenderfoundation.blender 0x0000000107bbd2cb main + 907
12 libdyld.dylib 0x00007fff67a9bcc9 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fff67a42aed _dispatch_sema4_wait + 16
2 libdispatch.dylib 0x00007fff67a42fbf _dispatch_semaphore_wait_slow + 98
3 org.blenderfoundation.blender 0x000000010dca8f32 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50
4 org.blenderfoundation.blender 0x000000010dca7a9e void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_deletestd::__1::__thread_struct >, void (IlmThread_2_4::Thread::)(), IlmThread_2_4::Thread> >(void*) + 62
5 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148
6 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
0 libsystem_pthread.dylib 0x00007fff67c9bb68 start_wqthread + 0
Thread 10:: AMCP Logging Spool
1 com.apple.audio.caulk 0x00007fff61671b16 caulk::mach::semaphore::wait() + 16
2 com.apple.audio.caulk 0x00007fff616719b2 caulk::semaphore::timed_wait(double) + 106
3 com.apple.audio.caulk 0x00007fff616717c4 caulk::concurrent::details::worker_thread::run() + 30
4 com.apple.audio.caulk 0x00007fff616711e4 void* caulk::thread_proxy<std::__1::tuple<caulk:🧵:attributes, void (caulk::concurrent::details::worker_thread::)(), std::__1::tuplecaulk::concurrent::details::worker_thread* > >(void) + 45
Thread 11:
Thread 12:
Thread 13:
Thread 14:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff67bdcdfa mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff67bdd170 mach_msg + 60
2 com.apple.audio.CoreAudio 0x00007fff2d114bf1 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111
3 com.apple.audio.CoreAudio 0x00007fff2d010d88 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 2677
4 com.apple.audio.CoreAudio 0x00007fff2d144b9e HALB_IOThread::Entry(void*) + 72
Thread 15:
2 com.apple.GeForceMTLDriver 0x00007fff29201cbb 0x7fff29095000 + 1494203
3 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148
4 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15
Thread 16:
1 org.blenderfoundation.blender 0x0000000107fd0118 tbb::internal::rml::private_worker::run() + 104
2 org.blenderfoundation.blender 0x0000000107fd00a9 tbb::internal::rml::private_worker::thread_routine(void*) + 9
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:: com.apple.NSEventThread
2 com.apple.CoreFoundation 0x00007fff2da32ef5 __CFRunLoopServiceMachPort + 247
3 com.apple.CoreFoundation 0x00007fff2da319c2 __CFRunLoopRun + 1319
4 com.apple.CoreFoundation 0x00007fff2da30e3e CFRunLoopRunSpecific + 462
5 com.apple.AppKit 0x00007fff2ae44954 _NSEventThread + 132
6 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148
7 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15
Thread 24:
Thread 25:
Thread 26:
0 libGL.dylib 0x00007fff378e9393 glGetProgramiv + 20
1 org.blenderfoundation.blender 0x000000010e1b958d blender::gpu::GLShader::vertformat_from_shader(GPUVertFormat*) const + 77
2 org.blenderfoundation.blender 0x00000001091c4141 py_shader_calc_format + 33
3 org.blenderfoundation.blender 0x000000010e295427 _PyMethodDef_RawFastCallKeywords + 775
4 org.blenderfoundation.blender 0x000000010e29b421 _PyMethodDescr_FastCallKeywords + 81
5 org.blenderfoundation.blender 0x000000010e36a978 call_function + 888
6 org.blenderfoundation.blender 0x000000010e36734e _PyEval_EvalFrameDefault + 27230
7 org.blenderfoundation.blender 0x000000010e36b69d _PyEval_EvalCodeWithName + 3021
8 org.blenderfoundation.blender 0x000000010e294689 _PyFunction_FastCallKeywords + 217
9 org.blenderfoundation.blender 0x000000010e36a90c call_function + 780
10 org.blenderfoundation.blender 0x000000010e367408 _PyEval_EvalFrameDefault + 27416
11 org.blenderfoundation.blender 0x000000010e36b69d _PyEval_EvalCodeWithName + 3021
12 org.blenderfoundation.blender 0x000000010e294187 _PyFunction_FastCallDict + 455
13 org.blenderfoundation.blender 0x000000010859012a bpy_app_generic_callback + 314
14 org.blenderfoundation.blender 0x0000000107c01992 BKE_callback_exec_id_depsgraph + 146
15 org.blenderfoundation.blender 0x0000000107d7864d scene_graph_update_tagged + 461
16 org.blenderfoundation.blender 0x00000001087be48a bake + 1610
17 org.blenderfoundation.blender 0x00000001087c02f5 bake_startjob + 341
18 org.blenderfoundation.blender 0x0000000107ff1b07 do_job_thread + 39
19 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148
20 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000104  rbx: 0x0000000000000002  rcx: 0x00007ffee8186818  rdx: 0x0000000000000000
rdi: 0x00000001154e3660  rsi: 0x0000020100000300  rbp: 0x00007ffee81868b0  rsp: 0x00007ffee8186818
 r8: 0x0000000000000000   r9: 0x00000000000000a0  r10: 0x0000000000000000  r11: 0x0000000000000202
r12: 0x00000001154e3660  r13: 0x0000000000000016  r14: 0x0000020100000300  r15: 0x000000012562cdc0
rip: 0x00007fff67bdf882  rfl: 0x0000000000000203  cr2: 0x00007000042d0000
Logical CPU: 0
Error Code: 0x02000131
Trap Number: 133
Binary Images:
0x107a79000 - 0x112430f8f +org.blenderfoundation.blender (2.92.0 - 2.92.0 2020-12-28) <3F8822B8-8F38-366A-9BCE-B1AE9AE62EE1> /Applications/Blender.app/Contents/MacOS/Blender
0x1191e8000 - 0x119254ffb +libomp.dylib (0) <535E76BC-1650-3651-9C62-97A995647107> /Applications/Blender.app/Contents/Resources/lib/libomp.dylib
0x11aee6000 - 0x11aeeafff com.apple.audio.AppleHDAHALPlugIn (283.15 - 283.15) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x11daf3000 - 0x11dc4cff7 com.apple.audio.units.Components (1.14 - 1.14) <21193A0C-D32B-3EAD-B84B-28DF911131B6> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x11dc7f000 - 0x11e0dffff com.apple.audio.AudioDSPComponents (1.0 - 1) /System/Library/Components/AudioDSP.component/Contents/MacOS/AudioDSP
0x11e14c000 - 0x11e14f047 libobjc-trampolines.dylib (787.1) <88F9B648-C455-36F8-BBB9-7D1A9F57D073> /usr/lib/libobjc-trampolines.dylib
0x125562000 - 0x1255f3f47 dyld (750.6) /usr/lib/dyld
0x12772c000 - 0x12772eff3 com.apple.CloudDocsFileProvider (1.0 - 698.17) /System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider
0x127738000 - 0x12773bfff com.apple.FileProviderOverride (304.1 - 304.1) /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
0x12c047000 - 0x12c048ff7 +_heapq.cpython-37m-darwin.so (0) <20086BF0-0130-3463-B824-F98C6D51BE39> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_heapq.cpython-37m-darwin.so
0x12c251000 - 0x12c256ffb +math.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/math.cpython-37m-darwin.so
0x12c9a3000 - 0x12c9a8ff3 +_blake2.cpython-37m-darwin.so (0) <7FD886EF-36D2-329A-B8CE-AAF09D7269E8> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_blake2.cpython-37m-darwin.so
0x12c9d3000 - 0x12c9e3ff3 +_sha3.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_sha3.cpython-37m-darwin.so
0x12c9ee000 - 0x12c9effff +test_compile.cpython-37m-darwin.so (0) <1F455AF4-310D-3F55-9312-0D2D6E241239> /Users/USER/Library/Application Support/Blender//test_compile.cpython-37m-darwin.so
0x12ca53000 - 0x12cc6c11b +_hashlib.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_hashlib.cpython-37m-darwin.so
0x12cd45000 - 0x12cd49ff3 +_struct.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_struct.cpython-37m-darwin.so
0x12cd57000 - 0x12cd69fff +zlib.cpython-37m-darwin.so (0) <8EF3CAAD-13A3-3C17-B25F-8F3D16F65850> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/zlib.cpython-37m-darwin.so
0x12cdb4000 - 0x12cdc6fff +_pickle.cpython-37m-darwin.so (0) <85237162-4DE3-38EA-99F5-287A1DB8BB02> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_pickle.cpython-37m-darwin.so
0x12cdd7000 - 0x12cdedffb +_bz2.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_bz2.cpython-37m-darwin.so
0x12cdf8000 - 0x12ce26ff7 +_lzma.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_lzma.cpython-37m-darwin.so
0x12ce35000 - 0x12ce35ffb +grp.cpython-37m-darwin.so (0) <DEEAC15B-D65-3D28-9F79-32426A8C67B7> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/grp.cpython-37m-darwin.so
0x12cebd000 - 0x12cebdffb +_bisect.cpython-37m-darwin.so (0) <1F871C75-B7E3-3531-B4FD-9127E49825DD> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_bisect.cpython-37m-darwin.so
0x12cec5000 - 0x12cec6ffb +_random.cpython-37m-darwin.so (0) <6EA0F0A9-EB67-39B1-8BC9-CD20C494E8F6> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_random.cpython-37m-darwin.so
0x12cf4e000 - 0x12cf53ff7 +cmath.cpython-37m-darwin.so (0) <4032EF0D-74B8-370D-A823-4F202C0A740F> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/cmath.cpython-37m-darwin.so
0x12d1a0000 - 0x12d509ff7 +_multiarray_umath.cpython-37m-darwin.so (0) <8B761C71-2D89-37F3-BEB5-B9254A2C3E02> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/core/_multiarray_umath.cpython-37m-darwin.so
0x12d666000 - 0x12d674ff3 +_datetime.cpython-37m-darwin.so (0) <87D99FDA-6F48-3410-B90A-CD992418681B> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_datetime.cpython-37m-darwin.so
0x12d804000 - 0x12d811ff7 +_multiarray_tests.cpython-37m-darwin.so (0) <15017CB9-B1EE-3481-9902-487DBE7BDB6E> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/core/_multiarray_tests.cpython-37m-darwin.so
0x12d825000 - 0x12d837ff7 +_ctypes.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_ctypes.cpython-37m-darwin.so
0x12d88d000 - 0x12d88efff +_posixsubprocess.cpython-37m-darwin.so (0) <3DC85D51-0860-37D2-9F6A-0AD91A2595CE> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_posixsubprocess.cpython-37m-darwin.so
0x12d896000 - 0x12d899fff +select.cpython-37m-darwin.so (0) <02400D4C-4C27-3FCA-B63B-7F29026E1FB1> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/select.cpython-37m-darwin.so
0x12d8e4000 - 0x12d8e5ffb +lapack_lite.cpython-37m-darwin.so (0) <13E4865F-46D4-3301-9D3E-49CCFDD3D095> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/linalg/lapack_lite.cpython-37m-darwin.so
0x12d8ed000 - 0x12d905ffb +_umath_linalg.cpython-37m-darwin.so (0) <01FBC95E-932B-3A93-962E-52168F690BD9> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/linalg/_umath_linalg.cpython-37m-darwin.so
0x12da18000 - 0x12da55ff7 +_decimal.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_decimal.cpython-37m-darwin.so
0x12da7a000 - 0x12da8bff3 +_pocketfft_internal.cpython-37m-darwin.so (0) <988AA5B5-36FB-3D86-805C-F00EEF719789> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/fft/_pocketfft_internal.cpython-37m-darwin.so
0x12dad4000 - 0x12db3cff7 +mtrand.cpython-37m-darwin.so (0) <8D5E395F-CCC8-36F1-96D9-A6E9DDA41AAF> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/mtrand.cpython-37m-darwin.so
0x12db94000 - 0x12dbc4ff3 +common.cpython-37m-darwin.so (0) <61D582CA-1C59-3309-8A00-F442A082F200> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/common.cpython-37m-darwin.so
0x12dbde000 - 0x12dc30ffb +bounded_integers.cpython-37m-darwin.so (0) <36A58A6D-37D5-3609-8C1B-BBA03F904E00> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/bounded_integers.cpython-37m-darwin.so
0x12dc58000 - 0x12dc6bffb +mt19937.cpython-37m-darwin.so (0) <2802AEBB-A054-36AF-A4C8-CC8456F69F62> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/mt19937.cpython-37m-darwin.so
0x12dc7c000 - 0x12dc9affb +bit_generator.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/bit_generator.cpython-37m-darwin.so
0x12dcfa000 - 0x12dd00ff7 +binascii.cpython-37m-darwin.so (0) <03796BF6-3DC5-3C9B-9D69-32549A2602EB> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/binascii.cpython-37m-darwin.so
0x12dd09000 - 0x12dd16ff3 +philox.cpython-37m-darwin.so (0) <57D29373-83CC-374B-96C9-4B36D0F68B4F> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/philox.cpython-37m-darwin.so
0x12dd27000 - 0x12dd31ff3 +pcg64.cpython-37m-darwin.so (0) <90C29A5D-B621-3CE6-B439-AAB6B4337604> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/pcg64.cpython-37m-darwin.so
0x12dd41000 - 0x12dd49ff7 +sfc64.cpython-37m-darwin.so (0) <2C7FCA5F-DA2E-34A5-9D04-A984B86BC536> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/sfc64.cpython-37m-darwin.so
0x12dd58000 - 0x12ddceff7 +generator.cpython-37m-darwin.so (0) <86FEA253-4515-3EF4-8253-E3E8DF2F4BD3> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/generator.cpython-37m-darwin.so
0x12e367000 - 0x12e367ff7 +_opcode.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_opcode.cpython-37m-darwin.so
0x12e3ef000 - 0x12e41cff3 +pyexpat.cpython-37m-darwin.so (0) <8DE98AAE-6AC5-322D-B1B4-BB5B13CD12CE> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/pyexpat.cpython-37m-darwin.so
0x12e7f5000 - 0x12e7fbfff +array.cpython-37m-darwin.so (0) <13F2F1B6-3644-36EB-A680-74EBC5DCE26F> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/array.cpython-37m-darwin.so
0x12ea0a000 - 0x12ea10ffb +_json.cpython-37m-darwin.so (0) <6C52949D-6062-3DBB-8601-8FC34D195603> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_json.cpython-37m-darwin.so
0x12ec59000 - 0x12ec62ffb +_socket.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_socket.cpython-37m-darwin.so
0x12eef5000 - 0x12eefdff3 +_elementtree.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_elementtree.cpython-37m-darwin.so
0x12f38c000 - 0x12f63c81b +_ssl.cpython-37m-darwin.so (0) <354522B6-4702-3B5C-BA0E-AB7A4E479091> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_ssl.cpython-37m-darwin.so
0x12f746000 - 0x12f746ff3 +_scproxy.cpython-37m-darwin.so (0) <9673CE7F-B1B9-3C49-96D2-D03BFEB345AE> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_scproxy.cpython-37m-darwin.so
0x12f8ce000 - 0x12f8cffff +_queue.cpython-37m-darwin.so (0) <2E95FB49-FE7E-3065-A632-9E7EBE8D25EA> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_queue.cpython-37m-darwin.so
0x12f918000 - 0x12f918ff3 +_uuid.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_uuid.cpython-37m-darwin.so
0x12f99f000 - 0x12f9a1ffb +murmurhash3.cpython-37m-darwin.so (0) <9FBCE98F-6717-38A9-82B4-824AEA3C5B98> /Users/USER/Library/Application Support/Blender/
/murmurhash3.cpython-37m-darwin.so
0x12f9a5000 - 0x12f9a6ff7 +utils.cpython-37m-darwin.so (0) <3CF51A19-C559-3005-8009-479278D8D205> /Users/USER/Library/Application Support/Blender//utils.cpython-37m-darwin.so
0x12f9aa000 - 0x12f9c0ff7 +implementations.cpython-37m-darwin.so (0) <6F546C77-8754-3366-9F04-90BD15DF5E75> /Users/USER/Library/Application Support/Blender/
/implementations.cpython-37m-darwin.so
0x12f9da000 - 0x12f9e4ff3 +clist.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//clist.cpython-37m-darwin.so
0x12f9ee000 - 0x12fb8bff3 +base_lists.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/base_lists.cpython-37m-darwin.so
0x12fc50000 - 0x12fc52fff +geometry.cpython-37m-darwin.so (0) <8D468471-BC20-3A54-B375-FCDBFA731B24> /Users/USER/Library/Application Support/Blender//geometry.cpython-37m-darwin.so
0x12fc56000 - 0x12fc59ff3 +vector.cpython-37m-darwin.so (0) <8C7C1C06-8383-3233-8516-D13A39910C0C> /Users/USER/Library/Application Support/Blender/
/vector.cpython-37m-darwin.so
0x12fc5d000 - 0x12fc68ffb +conversion.cpython-37m-darwin.so (0) <5C3BBBF3-8909-3DC5-8D55-A1C67DD31251> /Users/USER/Library/Application Support/Blender//conversion.cpython-37m-darwin.so
0x12fc6e000 - 0x12fc74ff3 +list_operations.cpython-37m-darwin.so (0) <08F2DAD4-B9E1-3A75-9C1E-76D3BBB69F55> /Users/USER/Library/Application Support/Blender/
/list_operations.cpython-37m-darwin.so
0x12fc7a000 - 0x12fc80ff7 +matrix.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//matrix.cpython-37m-darwin.so
0x12fc85000 - 0x12fc8bff3 +rotation_conversion.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/rotation_conversion.cpython-37m-darwin.so
0x12fc91000 - 0x12fc96ff3 +utils.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//utils.cpython-37m-darwin.so
0x12fc9b000 - 0x12fcafffb +polygon_indices_list.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/polygon_indices_list.cpython-37m-darwin.so
0x12fcbd000 - 0x12fcd2fff +virtual_list.cpython-37m-darwin.so (0) <84D01A38-4777-323B-98A8-14013CCB17BC> /Users/USER/Library/Application Support/Blender//virtual_list.cpython-37m-darwin.so
0x12fce1000 - 0x12fd1aff7 +virtual_clists.cpython-37m-darwin.so (0) <0E90D8E3-549E-332C-8045-3DD634326A67> /Users/USER/Library/Application Support/Blender/
/virtual_clists.cpython-37m-darwin.so
0x12fd7d000 - 0x12fd82ff3 +default_list.cpython-37m-darwin.so (0) <1AA25C9E-B6A8-3EC0-9A10-FE58335F0447> /Users/USER/Library/Application Support/Blender//default_list.cpython-37m-darwin.so
0x12fd87000 - 0x12fd8bffb +c_default_list.cpython-37m-darwin.so (0) <9A9C9050-967B-31B4-81B0-5CD0A21F0A8B> /Users/USER/Library/Application Support/Blender/
/c_default_list.cpython-37m-darwin.so
0x12fd90000 - 0x12fdbafff +mesh_data.cpython-37m-darwin.so (0) <765C8D73-2B67-3B19-B8DD-A795E0443ED6> /Users/USER/Library/Application Support/Blender//mesh_data.cpython-37m-darwin.so
0x12fdcc000 - 0x12fdceff3 +number.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/number.cpython-37m-darwin.so
0x12fdd2000 - 0x12fde8ff7 +validate.cpython-37m-darwin.so (0) <415435FA-00EA-37D2-B5FA-106D99644623> /Users/USER/Library/Application Support/Blender//validate.cpython-37m-darwin.so
0x12fdf5000 - 0x12fdfdffb +triangulate_mesh.cpython-37m-darwin.so (0) <5FA7BE67-5F79-38BB-AFC9-01D17B8CC031> /Users/USER/Library/Application Support/Blender/
/triangulate_mesh.cpython-37m-darwin.so
0x12fe05000 - 0x12fe11ff7 +poly_spline.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//poly_spline.cpython-37m-darwin.so
0x12fe1b000 - 0x12fe33ff7 +base_spline.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/base_spline.cpython-37m-darwin.so
0x12fe41000 - 0x12fe43ff3 +lists.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//lists.cpython-37m-darwin.so
0x12fe47000 - 0x12fe5cff7 +bezier_spline.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/bezier_spline.cpython-37m-darwin.so
0x12fe68000 - 0x12fe76ff7 +evaluation.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//evaluation.cpython-37m-darwin.so
0x12fe80000 - 0x12fe89fff +falloff_base.cpython-37m-darwin.so (0) <31372925-48FE-315C-99AC-1E696A6160DD> /Users/USER/Library/Application Support/Blender/
/falloff_base.cpython-37m-darwin.so
0x12fe91000 - 0x12fe97ff3 +types.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//types.cpython-37m-darwin.so
0x12fe9d000 - 0x12fe9eff3 +pointers.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/pointers.cpython-37m-darwin.so
0x12fea2000 - 0x12fea8fff +interpolation.cpython-37m-darwin.so (0) <7012E25F-C844-32CA-8E38-DC5267528473> /Users/USER/Library/Application Support/Blender//interpolation.cpython-37m-darwin.so
0x12feaf000 - 0x12fec2ff7 +action_base.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/action_base.cpython-37m-darwin.so
0x12fed1000 - 0x12fedbff3 +action_channels.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//action_channels.cpython-37m-darwin.so
0x12fee3000 - 0x12ff11ff3 +action_types.cpython-37m-darwin.so (0) <79E076C4-EF89-3D29-8A44-7F3BB8AF753B> /Users/USER/Library/Application Support/Blender/
/action_types.cpython-37m-darwin.so
0x12ffec000 - 0x12ffeeff7 +clamp.cpython-37m-darwin.so (0) <6899B1CC-7B10-309F-9ECE-8F84463C4061> /Users/USER/Library/Application Support/Blender//clamp.cpython-37m-darwin.so
0x12fff2000 - 0x12fff5fff +limits.cpython-37m-darwin.so (0) <1CD28F8F-DF9A-3ADB-AA70-C73DC9A52899> /Users/USER/Library/Application Support/Blender/
/limits.cpython-37m-darwin.so
0x12fffa000 - 0x130002ffb +presets.cpython-37m-darwin.so (0) <637E965F-73D5-3B5E-8D08-8316F5A56CE9> /Users/USER/Library/Application Support/Blender//presets.cpython-37m-darwin.so
0x13000a000 - 0x130014fff +shuffle.cpython-37m-darwin.so (0) <01F31611-7CF8-38BA-9AD2-84FA0CA13B70> /Users/USER/Library/Application Support/Blender/
/shuffle.cpython-37m-darwin.so
0x13001e000 - 0x130025ffb +reverse.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//reverse.cpython-37m-darwin.so
0x13002d000 - 0x130039ff3 +repeat.cpython-37m-darwin.so (0) <14B8AF64-FE83-326A-BD54-A046AEA19A6D> /Users/USER/Library/Application Support/Blender/
/repeat.cpython-37m-darwin.so
0x130043000 - 0x13004effb +sample.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//sample.cpython-37m-darwin.so
0x130058000 - 0x130064ffb +fill.cpython-37m-darwin.so (0) <21911DD3-1F12-30B9-B221-5DA0626E9833> /Users/USER/Library/Application Support/Blender/
/fill.cpython-37m-darwin.so
0x13006e000 - 0x130077ff7 +mask.cpython-37m-darwin.so (0) <598278F1-199B-37F8-B7B9-D1A68CAD9669> /Users/USER/Library/Application Support/Blender//mask.cpython-37m-darwin.so
0x130081000 - 0x13008cffb +repeat_elements.cpython-37m-darwin.so (0) <98592AFE-7A0E-349D-AD2F-DE2062BCE70C> /Users/USER/Library/Application Support/Blender/
/repeat_elements.cpython-37m-darwin.so
0x130096000 - 0x13009dff7 +random.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//random.cpython-37m-darwin.so
0x1300a5000 - 0x1300aafff +py_interface.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/py_interface.cpython-37m-darwin.so
0x1300af000 - 0x1300b7ffb +symbol_string.cpython-37m-darwin.so (0) <5B99B66F-218D-30DD-9767-0D7F260F7814> /Users/USER/Library/Application Support/Blender//symbol_string.cpython-37m-darwin.so
0x1300c1000 - 0x1300c9ff3 +apply_rules.cpython-37m-darwin.so (0) <1DC18DD0-D42F-33CE-9EFD-EE58451A6EF3> /Users/USER/Library/Application Support/Blender/
/apply_rules.cpython-37m-darwin.so
0x1300d1000 - 0x1300d9fff +geometry.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//geometry.cpython-37m-darwin.so
0x1300e1000 - 0x1300f1ff7 +parsing.cpython-37m-darwin.so (0) <5BFC15A7-727A-36CC-B158-BEF8C188B5BA> /Users/USER/Library/Application Support/Blender/
/parsing.cpython-37m-darwin.so
0x1300f7000 - 0x1300feffb +translation.cpython-37m-darwin.so (0) <5ED7CB0F-A430-395C-9F6B-1BB258633B6B> /Users/USER/Library/Application Support/Blender//translation.cpython-37m-darwin.so
0x130106000 - 0x13010dff3 +rotation.cpython-37m-darwin.so (0) <2EE132CE-40FF-3E44-8995-283027B00F97> /Users/USER/Library/Application Support/Blender/
/rotation.cpython-37m-darwin.so
0x130115000 - 0x13011bffb +scale.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//scale.cpython-37m-darwin.so
0x130123000 - 0x13012cff7 +points_scatter.cpython-37m-darwin.so (0) <84BF952F-AB12-3FF9-89C8-ABF93737F82E> /Users/USER/Library/Application Support/Blender/
/points_scatter.cpython-37m-darwin.so
0x130134000 - 0x130137ff7 +splitmix64.cpython-37m-darwin.so (0) <38222BA7-3BE2-3420-96E8-A5482BA04227> /Users/USER/Library/Application Support/Blender//splitmix64.cpython-37m-darwin.so
0x13013c000 - 0x13013fffb +xoshiro256starstar.cpython-37m-darwin.so (0) <9893CE02-5BAC-3BA8-85ED-F861097797A5> /Users/USER/Library/Application Support/Blender/
/xoshiro256starstar.cpython-37m-darwin.so
0x130144000 - 0x130147fff +xoshiro256plus.cpython-37m-darwin.so (0) <6B317636-E300-3F92-B9D7-1631E14B689E> /Users/USER/Library/Application Support/Blender//xoshiro256plus.cpython-37m-darwin.so
0x13014c000 - 0x130156fff +circle.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/circle.cpython-37m-darwin.so
0x13015f000 - 0x130169ff7 +cylinder.cpython-37m-darwin.so (0) <8CE85044-6069-3AB6-AA62-7DB210195C69> /Users/USER/Library/Application Support/Blender//cylinder.cpython-37m-darwin.so
0x130173000 - 0x13017eff7 +find_shortest_path.cpython-37m-darwin.so (0) <1D62A4A4-6FB2-34E3-B5B0-778C6C3887FA> /Users/USER/Library/Application Support/Blender/
/find_shortest_path.cpython-37m-darwin.so
0x130188000 - 0x130190ffb +line.cpython-37m-darwin.so (0) <1BD1401C-8205-3EAF-BB17-C3258F174B8F> /Users/USER/Library/Application Support/Blender//line.cpython-37m-darwin.so
0x130198000 - 0x1301aaff3 +grid.cpython-37m-darwin.so (0) <4D6AA531-6D63-384A-A4B6-DA59519C419F> /Users/USER/Library/Application Support/Blender/
/grid.cpython-37m-darwin.so
0x1301b6000 - 0x1301cdff7 +loft.cpython-37m-darwin.so (0) <0EF5929D-6745-32C2-8ADD-15283E62D71C> /Users/USER/Library/Application Support/Blender//loft.cpython-37m-darwin.so
0x1301dc000 - 0x1301e7ffb +revolve.cpython-37m-darwin.so (0) <792EA137-5885-35D4-BCB7-ED041B0D2F79> /Users/USER/Library/Application Support/Blender/
/revolve.cpython-37m-darwin.so
0x1301f1000 - 0x1301fcff3 +perlin_noise.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//perlin_noise.cpython-37m-darwin.so
0x130206000 - 0x130210ff3 +random.cpython-37m-darwin.so (0) <26827144-E41F-3348-9866-87FAE93FEA77> /Users/USER/Library/Application Support/Blender/
0x130218000 - 0x130222ffb +rotation_and_direction.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//rotation_and_direction.cpython-37m-darwin.so
0x1302ac000 - 0x1302f9fff +convert.cpython-37m-darwin.so (0) <1AA044E9-6AD9-3F9A-BE45-17E26DDCB35C> /Users/USER/Library/Application Support/Blender/
/convert.cpython-37m-darwin.so
0x13038b000 - 0x130393fff +to_blender.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//to_blender.cpython-37m-darwin.so
0x130399000 - 0x13039ffff +c_utils.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/c_utils.cpython-37m-darwin.so
0x1303a6000 - 0x1303b1ff3 +mesh_indices.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//mesh_indices.cpython-37m-darwin.so
0x1303fb000 - 0x130516ff3 +wrapper.cpython-37m-darwin.so (0) <3169E079-3A4B-357D-9157-C11977FF0440> /Users/USER/Library/Application Support/Blender/
/wrapper.cpython-37m-darwin.so
0x13052e000 - 0x130530ff3 +color.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//color.cpython-37m-darwin.so
0x130534000 - 0x130536ffb +euler.cpython-37m-darwin.so (0) <5C552C61-D51-3900-AC61-5285FFCD2380> /Users/USER/Library/Application Support/Blender/
/euler.cpython-37m-darwin.so
0x13053a000 - 0x13053cff3 +quaternion.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//quaternion.cpython-37m-darwin.so
0x130540000 - 0x130552ff3 +action_from_object.cpython-37m-darwin.so (0) <8654974E-958D-3BE5-8821-6528AE58DAFE> /Users/USER/Library/Application Support/Blender/
/action_from_object.cpython-37m-darwin.so
0x130560000 - 0x130571fff +chain_actions.cpython-37m-darwin.so (0) <09D55FBB-EF94-375B-837E-35F28A28D4F4> /Users/USER/Library/Application Support/Blender//chain_actions.cpython-37m-darwin.so
0x13057f000 - 0x130585ffb +delay_action.cpython-37m-darwin.so (0) <7A7549CF-551C-39F3-B6D6-7D8174F72574> /Users/USER/Library/Application Support/Blender/
/delay_action.cpython-37m-darwin.so
0x13058c000 - 0x130597ff3 +follow_spline_action.cpython-37m-darwin.so (0) <8159E9EF-F134-3477-8DCB-EFC10759081D> /Users/USER/Library/Application Support/Blender//follow_spline_action.cpython-37m-darwin.so
0x1305a2000 - 0x1305baff7 +object_action_output.cpython-37m-darwin.so (0) <5AE9B392-8500-3DD0-8D75-37BB00060BE8> /Users/USER/Library/Application Support/Blender/
/object_action_output.cpython-37m-darwin.so
0x13060b000 - 0x13061cff7 +overlay_action.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//overlay_action.cpython-37m-darwin.so
0x13062a000 - 0x13063dfff +wiggle_action.cpython-37m-darwin.so (0) <52DEA5B4-80AF-3BF3-8CE8-DEF335774CA5> /Users/USER/Library/Application Support/Blender/
/wiggle_action.cpython-37m-darwin.so
0x13064c000 - 0x130653ff7 +c_utils.cpython-37m-darwin.so (0) <20FBF653-1532-3B74-A3EE-6199823394E7> /Users/USER/Library/Application Support/Blender//c_utils.cpython-37m-darwin.so
0x13065b000 - 0x13066aff7 +c_utils.cpython-37m-darwin.so (0) <8F62B4EA-8C5D-3958-A9C9-FC33A34F01B0> /Users/USER/Library/Application Support/Blender/
0x130675000 - 0x13067fff3 +constant_falloff.cpython-37m-darwin.so (0) <3A86C057-51DF-367B-9520-6D7A129781E4> /Users/USER/Library/Application Support/Blender//constant_falloff.cpython-37m-darwin.so
0x130689000 - 0x130693fff +custom_falloff.cpython-37m-darwin.so (0) <7EC82DC5-04B3-3055-A83E-F86102D8CF93> /Users/USER/Library/Application Support/Blender/
/custom_falloff.cpython-37m-darwin.so
0x13069e000 - 0x1306a9ff3 +delay_falloff.cpython-37m-darwin.so (0) <513DF90C-B113-3BA7-A151-75986C271991> /Users/USER/Library/Application Support/Blender//delay_falloff.cpython-37m-darwin.so
0x1306b4000 - 0x1306beff7 +interpolate_falloff.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/interpolate_falloff.cpython-37m-darwin.so
0x1306c8000 - 0x1306d5fff +directional_falloff.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//directional_falloff.cpython-37m-darwin.so
0x130722000 - 0x130732ff7 +evaluate_falloff.cpython-37m-darwin.so (0) <3C430908-1CF8-30FA-A142-943FE14556AB> /Users/USER/Library/Application Support/Blender/
/evaluate_falloff.cpython-37m-darwin.so
0x130740000 - 0x130750ff7 +fade_falloff.cpython-37m-darwin.so (0) <6518B1FB-0747-300C-9098-6E3F2CB66520> /Users/USER/Library/Application Support/Blender//fade_falloff.cpython-37m-darwin.so
0x13075e000 - 0x13076cff7 +index_mask_falloff.cpython-37m-darwin.so (0) <4FB845FC-985B-3470-9C70-5C7B44B6307B> /Users/USER/Library/Application Support/Blender/
/index_mask_falloff.cpython-37m-darwin.so
0x130779000 - 0x130784ff3 +interpolate_list_falloff.cpython-37m-darwin.so (0) <80F27467-74BE-329F-AE50-0B0524D1D203> /Users/USER/Library/Application Support/Blender//interpolate_list_falloff.cpython-37m-darwin.so
0x13078f000 - 0x13079bffb +remap_falloff.cpython-37m-darwin.so (0) <6EEC05DF-A99F-3653-BDFC-D1746D442C27> /Users/USER/Library/Application Support/Blender/
/remap_falloff.cpython-37m-darwin.so
0x1307a7000 - 0x1307b3ffb +mesh_falloff.cpython-37m-darwin.so (0) <216C61B3-AAFF-394F-9256-96E0A3E6E796> /Users/USER/Library/Application Support/Blender//mesh_falloff.cpython-37m-darwin.so
0x1307be000 - 0x1307d8ff7 +mix_falloffs.cpython-37m-darwin.so (0) <57220CA9-0F42-3D39-A707-7DEBAAA4615C> /Users/USER/Library/Application Support/Blender/
/mix_falloffs.cpython-37m-darwin.so
0x1307ec000 - 0x1307f7ff7 +noise_falloff.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//noise_falloff.cpython-37m-darwin.so
0x130803000 - 0x13081effb +object_controller_falloff.cpython-37m-darwin.so (0) <1BC16317-75B8-3977-81C7-CF273CF86AE2> /Users/USER/Library/Application Support/Blender/
/object_controller_falloff.cpython-37m-darwin.so
0x13082e000 - 0x130838ff7 +radial_falloff.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//radial_falloff.cpython-37m-darwin.so
0x130843000 - 0x13084dff3 +point_distance_falloff.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/point_distance_falloff.cpython-37m-darwin.so
0x130858000 - 0x130862fff +random_falloff.cpython-37m-darwin.so (0) <646419F6-C496-3D0A-8306-16C3EAC5FBB7> /Users/USER/Library/Application Support/Blender//random_falloff.cpython-37m-darwin.so
0x13086c000 - 0x13088affb +sound_falloff.cpython-37m-darwin.so (0) <9C12BD2A-0995-3A91-B138-03AF95D7DE0C> /Users/USER/Library/Application Support/Blender/
/sound_falloff.cpython-37m-darwin.so
0x13089e000 - 0x1308b2fff +spline_falloff.cpython-37m-darwin.so (0) <302C603C-44D3-3DB3-85C2-51DC6424C455> /Users/USER/Library/Application Support/Blender//spline_falloff.cpython-37m-darwin.so
0x1308c1000 - 0x1308ccffb +wiggle_falloff.cpython-37m-darwin.so (0) <153CF1DA-CE59-383A-8F26-35CE782201EA> /Users/USER/Library/Application Support/Blender/
/wiggle_falloff.cpython-37m-darwin.so
0x1308d7000 - 0x1308e0ff7 +c_utils.cpython-37m-darwin.so (0) <4B71C4BC-A602-36E0-AA82-62D27FCAE36D> /Users/USER/Library/Application Support/Blender//c_utils.cpython-37m-darwin.so
0x130928000 - 0x13093affb +c_utils.cpython-37m-darwin.so (0) <70E81877-119F-3BBC-BB63-46986CEE70F6> /Users/USER/Library/Application Support/Blender/
0x130987000 - 0x130995fff +c_utils.cpython-37m-darwin.so (0) <62A271D2-6145-30C4-B1D0-BEBDF9BB7F80> /Users/USER/Library/Application Support/Blender//c_utils.cpython-37m-darwin.so
0x1309a0000 - 0x1309aaffb +c_utils.cpython-37m-darwin.so (0) <7C87D245-15B2-3881-BACB-43D04C26064B> /Users/USER/Library/Application Support/Blender/
0x130a34000 - 0x130a47ff7 +c_utils.cpython-37m-darwin.so (0) <1617C212-A5FA-34E1-94A9-749DE85CFDEA> /Users/USER/Library/Application Support/Blender//c_utils.cpython-37m-darwin.so
0x130a55000 - 0x130a70fff +distribute_matrices.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/distribute_matrices.cpython-37m-darwin.so
0x130ac4000 - 0x130aecff7 +c_utils.cpython-37m-darwin.so (0) <054BF2CF-F623-37B7-A14C-489BEE7B80E4> /Users/USER/Library/Application Support/Blender//c_utils.cpython-37m-darwin.so
0x130b40000 - 0x130b51fff +offset_vector.cpython-37m-darwin.so (0) <8C4BB186-29BB-3303-AC02-AA2D99AFB4CE> /Users/USER/Library/Application Support/Blender/
/offset_vector.cpython-37m-darwin.so
0x130b5f000 - 0x130b81fff +float_math.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender//float_math.cpython-37m-darwin.so
0x130bd9000 - 0x130bf2ffb +vector_math.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
/vector_math.cpython-37m-darwin.so
0x130c04000 - 0x130c16ff3 +object_matrix_output.cpython-37m-darwin.so (0) <7BBE9303-91AD-3C17-B0CF-D70AB2BB00D6> /Users/USER/Library/Application Support/Blender//object_matrix_output.cpython-37m-darwin.so
0x130c65000 - 0x130c6bff3 +c_utils.cpython-37m-darwin.so (0) /Users/USER/Library/Application Support/Blender/
0x130c72000 - 0x130c7cfff +c_utils.cpython-37m-darwin.so (0) <75C3E4CA-8564-385E-A198-0DE9B5516D29> /Users/USER/Library/Application Support/Blender//c_utils.cpython-37m-darwin.so
0x130cc6000 - 0x130ccffff +c_utils.cpython-37m-darwin.so (0) <507BC8A6-DAED-3BE1-8381-15E76B302F88> /Users/USER/Library/Application Support/Blender/
0x130cd7000 - 0x130ce0ffb +splines_from_edges_utils.cpython-37m-darwin.so (0) <6EA76869-9E19-3801-ADA3-2440E5005D2E> /Users/USER/Library/Application Support/Blender/*/splines_from_edges_utils.cpython-37m-darwin.so
0x130da9000 - 0x130daaff3 +_lsprof.cpython-37m-darwin.so (0) /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_lsprof.cpython-37m-darwin.so
0x1316a4000 - 0x1316bbffb com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride (1.0 - 1298.7.1) <1911451B-5BA5-3A08-AB9F-2729A55BDE38> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
0x7fff20aa1000 - 0x7fff20ceeff8 com.apple.RawCamera.bundle (9.02.0 - 1350.29) <59F81722-039E-33F5-A20E-936E997575A3> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff23950000 - 0x7fff23e5dff7 com.apple.driver.AppleIntelHD5000GraphicsGLDriver (14.7.11 - 14.0.7) <07F632A9-EEC9-3E00-89E6-3F060FDDA5AD> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver
0x7fff23e5e000 - 0x7fff23ef1ffd com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (14.7.11 - 14.0.7) /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsMTLDriver
0x7fff280b0000 - 0x7fff289bcfff com.apple.GeForceGLDriver (14.0.32 - 14.0.0) /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x7fff289bd000 - 0x7fff29094fff libclh.dylib (14.0.32) <8E599513-C443-3D47-8484-E529BE971893> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x7fff29095000 - 0x7fff29248ff3 com.apple.GeForceMTLDriver (14.0.32 - 14.0.0) /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
0x7fff29636000 - 0x7fff29636fff com.apple.Accelerate (1.11 - Accelerate 1.11) <4F9977AE-DBDB-3A16-A536-AC1F9938DCDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff29637000 - 0x7fff2964dfef libCGInterfaces.dylib (524.2.1) <8FD09D09-BB19-36C5-ADE9-4F22DA235AEE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff2964e000 - 0x7fff29ca4fff com.apple.vImage (8.1 - 524.2.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff29ca5000 - 0x7fff29f0cff7 libBLAS.dylib (1303.60.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff29f0d000 - 0x7fff2a3e0fef libBNNS.dylib (144.100.2) <99C61C48-B14C-3DA6-8C31-6BF72DA0A3A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff2a3e1000 - 0x7fff2a77cfff libLAPACK.dylib (1303.60.1) <5E3E3867-50C3-3E6A-9A2E-007CE77A4641> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff2a77d000 - 0x7fff2a792fec libLinearAlgebra.dylib (1303.60.1) <3D433800-0099-33E0-8C81-15F83247B2C9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff2a793000 - 0x7fff2a798ff3 libQuadrature.dylib (7) <371F36A7-B12F-363E-8955-F24F7C2048F6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff2a799000 - 0x7fff2a809fff libSparse.dylib (103) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff2a80a000 - 0x7fff2a81cfef libSparseBLAS.dylib (1303.60.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff2a81d000 - 0x7fff2a9f4fd7 libvDSP.dylib (735.140.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff2a9f5000 - 0x7fff2aab7fef libvMisc.dylib (735.140.1) <3601FDE3-B142-398D-987D-8151A51F0A96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff2aab8000 - 0x7fff2aab8fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff2aab9000 - 0x7fff2ab18ff0 com.apple.Accounts (113 - 113) /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff2ac62000 - 0x7fff2ba22ff2 com.apple.AppKit (6.9 - 1894.60.100) <322D043D-1140-3486-9523-3F56FF4D8349> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2ba72000 - 0x7fff2ba72fff com.apple.ApplicationServices (48 - 50) <20CF59CD-A395-3570-A4DB-589D55C70B3F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff2ba73000 - 0x7fff2badefff com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <87EA5DE1-506A-39FD-88BE-D8A3416C9012> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff2bb77000 - 0x7fff2bbb5ff0 libFontRegistry.dylib (274.0.5.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff2bc10000 - 0x7fff2bc3ffff com.apple.ATSUI (1.0 - 1) <5F513967-DDD7-3F22-AD14-8A38ABD9F2D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff2bc40000 - 0x7fff2bc44ffb com.apple.ColorSyncLegacy (4.13.0 - 1) <72EE68DB-F069-37F5-AA2A-40D5FCF139F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff2bcde000 - 0x7fff2bd35ffa com.apple.HIServices (1.22 - 676) <14DF4D42-E24D-3EBD-9A9D-93124D8D6AA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff2bd36000 - 0x7fff2bd44fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <01B8B6B3-E2C3-3607-B34A-8283A7E0E924> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff2bd45000 - 0x7fff2bd8affa com.apple.print.framework.PrintCore (15.4 - 516.2) <437BCF12-48D2-3770-8BC9-567718FB1BCA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff2bd8b000 - 0x7fff2bd95ff7 com.apple.QD (4.0 - 413) <27A36D07-B5E9-32E6-87B6-3127F260F48D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff2bd96000 - 0x7fff2bda3ffc com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <75344F8F-32CA-3558-B4E6-F56D498250E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff2bda4000 - 0x7fff2be85ffa com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <6185BF20-D2E7-3812-8FD8-EC5237672104> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff2be87000 - 0x7fff2be87fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <918ED3EB-0232-31F3-9BF5-18D1CB11523F> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff2c21e000 - 0x7fff2c5adffa com.apple.CFNetwork (1128.0.1 - 1128.0.1) <07F9CA9C-B954-3EA0-A710-3122BFF9F057> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff2c629000 - 0x7fff2c629fff com.apple.Carbon (160 - 162) <6A5EB506-7A43-3879-A358-E6B9182C3733> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff2c62a000 - 0x7fff2c62dff3 com.apple.CommonPanels (1.2.6 - 101) <9F6E13D9-374B-386F-8E15-FDD6CE967859> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff2c62e000 - 0x7fff2c922ff3 com.apple.HIToolbox (2.1.1 - 994.6) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff2c923000 - 0x7fff2c926ff3 com.apple.help (1.3.8 - 71) <36483951-6F3E-3F7E-8A5B-191C2357EF17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff2c927000 - 0x7fff2c92cff7 com.apple.ImageCapture (9.0 - 1600.65) <1A1F320E-3E85-3F3D-8AE0-B238C4E92D40> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff2c92d000 - 0x7fff2c92dfff com.apple.ink.framework (10.15 - 227) <284507AE-EF47-3ABC-86A4-669243DB1D33> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff2c92e000 - 0x7fff2c948ffa com.apple.openscripting (1.7 - 185.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff2c969000 - 0x7fff2c969fff com.apple.print.framework.Print (15 - 271) <0D9FB08F-EA87-3BE7-821B-C61BA5601050> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff2c96a000 - 0x7fff2c96cff7 com.apple.securityhi (9.0 - 55008) <390C6FAA-99BF-3924-9180-9EAE41D9C6BE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff2c96d000 - 0x7fff2c973fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <9614A01E-8303-3422-A3BA-6CE27540E09A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff2c974000 - 0x7fff2cb0cffa com.apple.cloudkit.CloudKit (867 - 867) <1B851180-FC00-357F-B6C1-BB0EA7D6D5CA> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff2cb0d000 - 0x7fff2cb0dfff com.apple.Cocoa (6.11 - 23) <85C8B9B4-6F0B-3BD5-8934-C299FE481A44> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff2cb1b000 - 0x7fff2cc11fff com.apple.ColorSync (4.13.0 - 3394.9) /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff2cefc000 - 0x7fff2d405ffb com.apple.audio.CoreAudio (5.0 - 5.0) <47923B12-3D14-328A-9C86-27A3A2A73068> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff2d458000 - 0x7fff2d490fff com.apple.CoreBluetooth (1.0 - 1) <23DBB313-A082-3C08-8E1F-2D31EE4247EF> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff2d491000 - 0x7fff2d87bfe8 com.apple.CoreData (120 - 977.3) <49AE61CA-C91E-31FE-9BD0-1AACFFB5181E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff2d87c000 - 0x7fff2d9aeff6 com.apple.CoreDisplay (1.0 - 186.6.15) <213D7011-8180-3CF4-9BE7-FB8F75DCDB95> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff2d9af000 - 0x7fff2de2efeb com.apple.CoreFoundation (6.9 - 1677.201) <56B0FE5F-D493-3DF1-ABFF-ECC450268B97> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff2de30000 - 0x7fff2e4a5ff8 com.apple.CoreGraphics (2.0 - 1355.22) <4A3CDE7B-4578-3058-966A-3D1DC095A935> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff2e4b3000 - 0x7fff2e80eff0 com.apple.CoreImage (15.0.0 - 940.9) <69361069-01AB-342E-862B-73A74271A765> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff2e80f000 - 0x7fff2e878ff0 com.apple.corelocation (2394.0.22 - 2394.0.22) <75966124-2FB7-33C3-BE49-3DD5F327F911> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff2ebcf000 - 0x7fff2ecaaffc com.apple.CoreMedia (1.0 - 2625.9) /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff2ed97000 - 0x7fff2ed97fff com.apple.CoreServices (1069.24 - 1069.24) <2D1A6C60-DD34-368F-88FF-E39C9FE549A9> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff2ed98000 - 0x7fff2ee1dfff com.apple.AE (838.1 - 838.1) <2E5FD5AE-8A7F-353F-9BD1-0241F3586181> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff2ee1e000 - 0x7fff2f0ffff7 com.apple.CoreServices.CarbonCore (1217 - 1217) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff2f100000 - 0x7fff2f14dffd com.apple.DictionaryServices (1.2 - 323.6) <26B70C82-25BC-353A-858F-945B14C803A2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff2f14e000 - 0x7fff2f156ff7 com.apple.CoreServices.FSEvents (1268.100.1 - 1268.100.1) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff2f157000 - 0x7fff2f391ff6 com.apple.LaunchServices (1069.24 - 1069.24) <9A5359D9-9148-3B18-B868-56A9DA5FB60C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff2f392000 - 0x7fff2f42aff1 com.apple.Metadata (10.7.0 - 2076.7) <0973F7E5-D58C-3574-A3CE-4F12CAC2D4C7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff2f42b000 - 0x7fff2f458fff com.apple.CoreServices.OSServices (1069.24 - 1069.24) <0E4F48AD-402C-3E9D-9CA9-6DD9479B28F9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff2f459000 - 0x7fff2f4c0fff com.apple.SearchKit (1.4.1 - 1.4.1) <2C5E1D85-E8B1-3DC5-91B9-E3EDB48E9369> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff2f4c1000 - 0x7fff2f4e5ff5 com.apple.coreservices.SharedFileList (131.4 - 131.4) <02DE0D56-E371-3EF5-9BC1-FA435451B412> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff2f80a000 - 0x7fff2f9c1ffc com.apple.CoreText (643.1.5.2 - 643.1.5.2) /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff2f9c2000 - 0x7fff2fa06ffb com.apple.CoreVideo (1.8 - 344.3) <5314E70D-325F-3E98-99FC-00FDF520747E> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff2fa07000 - 0x7fff2fa94ffc com.apple.framework.CoreWLAN (13.0 - 1601.2) <6223BFD5-D451-3DE9-90F6-F609AC0B0027> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff2fd2b000 - 0x7fff2fd31fff com.apple.DiskArbitration (2.7 - 2.7) <0BBBB6A6-604D-368B-9943-50B8CE75D51D> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff2ff26000 - 0x7fff30054ff6 com.apple.FileProvider (304.1 - 304.1) /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff30069000 - 0x7fff3006bff3 com.apple.ForceFeedback (1.0.6 - 1.0.6) <9B324178-4FAA-3686-9E01-634607F38493> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
0x7fff3006c000 - 0x7fff30431fff com.apple.Foundation (6.9 - 1677.201) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff3049e000 - 0x7fff304eeff7 com.apple.GSS (4.0 - 2.0) <2F3A67E6-D42A-3CF0-9041-A42C22D46F95> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff3062b000 - 0x7fff3073fff3 com.apple.Bluetooth (7.0.6 - 7.0.6f8) /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff307a5000 - 0x7fff30849ff3 com.apple.framework.IOKit (2.0.2 - 1726.140.1) <14223387-6F81-3976-8605-4BC2F253A93E> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff3084b000 - 0x7fff3085cffb com.apple.IOSurface (269.11 - 269.11) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff308db000 - 0x7fff30a38fee com.apple.ImageIO.framework (3.3.0 - 1976.11.4) <6FC6EE76-F76F-312C-9C67-4B9F0E0B832A> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff30a39000 - 0x7fff30a3cfff libGIF.dylib (1976.11.4) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff30a3d000 - 0x7fff30af6fe7 libJP2.dylib (1976.11.4) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff30af7000 - 0x7fff30b1afe3 libJPEG.dylib (1976.11.4) <37FA33BD-1C78-3FA6-8D35-3F3755462597> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff30d97000 - 0x7fff30db1fef libPng.dylib (1976.11.4) <1AD4B940-5B1F-39A4-873C-9C568AA287B7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff30db2000 - 0x7fff30db3fff libRadiance.dylib (1976.11.4) <868D2C2C-1909-31B1-A0C2-C971F0BE1EC5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff30db4000 - 0x7fff30dfafff libTIFF.dylib (1976.11.4) <1125DCD0-337D-3E01-84F9-106DEEEA5715> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff3235c000 - 0x7fff3236eff3 com.apple.Kerberos (3.0 - 1) <03BB492B-016E-37BF-B020-39C2CF7487FE> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff3236f000 - 0x7fff3236ffff libHeimdalProxy.dylib (77) <0A2905EE-9533-3345-AF9B-AAC71513BDFD> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff32701000 - 0x7fff3270bffb com.apple.MediaAccessibility (1.0 - 125.1) <98065EA1-3484-3A5A-B05C-D2FABED8CEA4> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff327d7000 - 0x7fff32f24ff2 com.apple.MediaToolbox (1.0 - 2625.9) <3A848992-9182-382A-BF7D-5CB9707BE27B> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff32f26000 - 0x7fff32ff0fff com.apple.Metal (212.8 - 212.8) <98C944D6-62C8-355E-90F8-C1CA2429EF24> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff3300d000 - 0x7fff3304aff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <7EBAC15D-7837-395D-B405-1E29F7DA68FA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff3304b000 - 0x7fff330d5fe2 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff330d6000 - 0x7fff330fbff4 com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <02006D92-E2AB-3892-A96B-37F6520C19BA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff330fc000 - 0x7fff33111ffb com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff33112000 - 0x7fff33270ffc com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <05612E06-50CB-318F-9F8E-EF4D49FAB3B0> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff33271000 - 0x7fff332c0ff4 com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff332c1000 - 0x7fff332c2ff5 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff34350000 - 0x7fff3435cffe com.apple.NetFS (6.0 - 4.0) <4415F027-D36D-3B9C-96BA-AD22B44A4722> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff3435d000 - 0x7fff344b4ff3 com.apple.Network (1.0 - 1) <4A0F3B93-4D23-3E74-9A3D-AD19E9C0E59E> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff344b5000 - 0x7fff34715ffa com.apple.NetworkExtension (1.0 - 1) <3ED35C5A-B170-373E-8277-D4198E408810> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
0x7fff347a0000 - 0x7fff347c2fff com.apple.audio.OpenAL (1.8 - 1.8) <6D66C5D7-8410-35B7-B06E-3BE56E0A708E> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x7fff36edd000 - 0x7fff36ee5ff7 libcldcpuengine.dylib (2.14) /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff36ee6000 - 0x7fff36f3efff com.apple.opencl (3.5 - 3.5) <293FE223-9186-320B-81A4-EC8104C38357> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff36f3f000 - 0x7fff36f5bfff com.apple.CFOpenDirectory (10.15 - 220.40.1) <7E6C88EB-3DD9-32B0-81FC-179552834FA9> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff36f5c000 - 0x7fff36f67ffd com.apple.OpenDirectory (10.15 - 220.40.1) <4A92D8D8-A9E5-3A9C-942F-28576F6BCDF5> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff378cd000 - 0x7fff378cffff libCVMSPluginSupport.dylib (17.10.22) <2B6C3C16-3F5F-36A8-8070-2A862B90328B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff378d0000 - 0x7fff378d5fff libCoreFSCache.dylib (176.15) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff378d6000 - 0x7fff378dafff libCoreVMClient.dylib (176.15) <018A48BA-1326-3847-8FB5-A7C99322EB87> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff378db000 - 0x7fff378e3ff7 libGFXShared.dylib (17.10.22) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff378e4000 - 0x7fff378eefff libGL.dylib (17.10.22) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff378ef000 - 0x7fff37923ff7 libGLImage.dylib (17.10.22) <9A3FE633-61B8-3CC7-8183-62960109401A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff37924000 - 0x7fff37ab8ff7 libGLProgrammability.dylib (17.10.22) <85815C4E-3376-33DF-9FBB-6512142AB61B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff37ab9000 - 0x7fff37af5fff libGLU.dylib (17.10.22) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff38531000 - 0x7fff38540ff7 com.apple.opengl (17.10.22 - 17.10.22) /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff38541000 - 0x7fff386bafff GLEngine (17.10.22) /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff386bb000 - 0x7fff386e3fff GLRendererFloat (17.10.22) /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff38b9e000 - 0x7fff38ba4ff6 com.apple.PushKit (1.0 - 1) /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
0x7fff394fe000 - 0x7fff39781ffb com.apple.QuartzCore (1.11 - 841.4) /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff3a304000 - 0x7fff3a64dff1 com.apple.security (7.0 - 59306.140.5) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff3a64e000 - 0x7fff3a6d6ffb com.apple.securityfoundation (6.0 - 55236.60.1) <7C69DF47-4017-3DF2-B55B-712B481654CB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff3a705000 - 0x7fff3a709ff8 com.apple.xpc.ServiceManagement (1.0 - 1) <9B36FD0E-D280-35EB-ABAB-6AC5D7B2118F> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff3b3b5000 - 0x7fff3b42fff7 com.apple.SystemConfiguration (1.19 - 1.19) <84F9B3BB-F7AF-3B7C-8CD0-D3C22D19619F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff3b6af000 - 0x7fff3ba32ff4 com.apple.VideoToolbox (1.0 - 2625.9) <6CF18E28-A7A8-3952-8171-7E4FF4FB37FA> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff3f39f000 - 0x7fff3f464fe7 com.apple.APFS (1412.141.1 - 1412.141.1) /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff40579000 - 0x7fff4057aff1 com.apple.AggregateDictionary (1.0 - 1) <95A291F5-B69F-3C37-9483-C3B2EBF52AC1> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff40b14000 - 0x7fff40b31ff4 com.apple.AppContainer (4.0 - 448.100.6) <87CEE13C-8585-3EFB-92CD-0852DFF0921B> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff40b86000 - 0x7fff40b94ff7 com.apple.AppSandbox (4.0 - 448.100.6) <0F49AA04-3400-349A-9096-6D4D7ED61027> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff41010000 - 0x7fff41034ffb com.apple.framework.Apple80211 (13.0 - 1610.1) /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff412f2000 - 0x7fff41301fd7 com.apple.AppleFSCompression (119.100.1 - 1.0) <466ABD77-2E52-36D1-8E39-77AE2CC61611> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff41400000 - 0x7fff4140bff7 com.apple.AppleIDAuthSupport (1.0 - 1) <74F6CD9C-27A7-39C7-A7EB-47E60D2517EB> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff4144d000 - 0x7fff41495ff7 com.apple.AppleJPEG (1.0 - 1) <6DE30A07-C627-319B-A0DE-EB7A832BEB88> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff41858000 - 0x7fff4187effb com.apple.aps.framework (4.0 - 4.0) <3ED300B6-43E3-31DC-B3C6-6A0FF41A2595> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff4187f000 - 0x7fff41883ff7 com.apple.AppleSRP (5.0 - 1) <70C25EA9-F7A7-366C-97C6-EEE7845FFCC3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff41884000 - 0x7fff418a6fff com.apple.applesauce (1.0 - 16.25) <68E0364C-AEA7-3654-A030-136BF3CD92F3> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff41965000 - 0x7fff41968fff com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <67255151-F989-39F0-BC87-0C0BDAE70730> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff41969000 - 0x7fff419b9ff7 com.apple.AppleVAFramework (6.1.2 - 6.1.2) <8E18983B-AF92-3853-8251-A6577A55AC15> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff41a02000 - 0x7fff41a11ff9 com.apple.AssertionServices (1.0 - 223.140.2) <48AD21CA-B81D-380E-A04F-90C48FDA5203> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff41f54000 - 0x7fff4234fff8 com.apple.audio.AudioResourceArbitration (1.0 - 1) <2BD68521-C19C-3D67-B5EB-DE3E9A4DAF0A> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff4248e000 - 0x7fff424dfff9 com.apple.audio.AudioSession (1.0 - 17) /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
0x7fff424e0000 - 0x7fff4250dff7 libSessionUtility.dylib (17) <54A1C204-FCBA-3106-A896-28F22ECF144E> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
0x7fff425a5000 - 0x7fff427e5fe8 com.apple.audio.AudioToolboxCore (1.0 - 1104.95) <9DB96FE2-AE60-32AE-B706-546E25BAE53F> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff427e9000 - 0x7fff42905fff com.apple.AuthKit (1.0 - 1) /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff42ac2000 - 0x7fff42acbff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff42acc000 - 0x7fff42b6dff5 com.apple.backup.framework (1.11.7 - 1298.7.1) /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff42b6e000 - 0x7fff42bfaff6 com.apple.BaseBoard (466.3 - 466.3) <10D0F3BB-E8F3-365E-8528-6AC996A9B0E7> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff42cfc000 - 0x7fff42d38ff7 com.apple.bom (14.0 - 219.2) <79CBE5E7-054F-377B-9566-A86A9F120CF1> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff42e56000 - 0x7fff42e8dff5 com.apple.C2 (1.3 - 495) <4A7E2A63-E19A-3936-92F5-03F2FD602172> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
0x7fff438b8000 - 0x7fff43907fff com.apple.ChunkingLibrary (307 - 307) <5B09C30D-FD2B-3E98-8B64-C5EF470FC13C> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff43a62000 - 0x7fff43aedff8 com.apple.CloudDocs (1.0 - 698.17) <900567ED-DEA4-30D5-A1C0-78BD53C58CD6> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff447b4000 - 0x7fff447c4ffb com.apple.CommonAuth (4.0 - 2.0) /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff447d8000 - 0x7fff447effff com.apple.commonutilities (8.0 - 900) /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff44ef6000 - 0x7fff452cbfc8 com.apple.CoreAUC (283.0.0 - 283.0.0) <4341271C-D270-3F9F-8464-31A20D15158D> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff452cc000 - 0x7fff452f9ff7 com.apple.CoreAVCHD (6.1.0 - 6100.4.1) /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff4531c000 - 0x7fff4533dff4 com.apple.analyticsd (1.0 - 1) <2162671C-D49D-3891-AB69-9EEB1FA47DD8> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff45648000 - 0x7fff45653ff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff458d4000 - 0x7fff458e4ff3 com.apple.CoreEmoji (1.0 - 107.1) <7C2B3259-083B-31B8-BCDB-1BA360529936> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff45f24000 - 0x7fff45f8eff0 com.apple.CoreNLP (1.0 - 213) /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff463bc000 - 0x7fff463c4ff8 com.apple.CorePhoneNumbers (1.0 - 1) /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff46db1000 - 0x7fff46dd4fff com.apple.CoreSVG (1.0 - 129.3) /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff46dd5000 - 0x7fff46e08fff com.apple.CoreServicesInternal (446.7 - 446.7) <65F53A22-6B61-382C-AAC2-B2C53F8FFB44> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff46e09000 - 0x7fff46e37ffd com.apple.CSStore (1069.24 - 1069.24) /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff4735c000 - 0x7fff473f2ff7 com.apple.CoreSymbolication (11.4 - 64535.33.2) <0B3BF87A-7F95-3D79-B4F8-421D6FAC4A6C> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff4748a000 - 0x7fff475b6ff6 com.apple.coreui (2.1 - 609.4) <788818B7-7EBC-316D-9464-D12E365E3791> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff475b7000 - 0x7fff47770ffa com.apple.CoreUtils (6.2.4 - 624.7) /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff478aa000 - 0x7fff478bdff1 com.apple.CrashReporterSupport (10.13 - 15016) /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff47976000 - 0x7fff47988ff8 com.apple.framework.DFRFoundation (1.0 - 252.50.1) <8162057E-E856-3451-9160-04AEDDECFFA4> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff47989000 - 0x7fff4798efff com.apple.DSExternalDisplay (3.1 - 380) <31ECB5FD-7660-33DB-BC5B-2B2A2AA7C686> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff47a18000 - 0x7fff47a92ff0 com.apple.datadetectorscore (8.0 - 659) /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff47ade000 - 0x7fff47b1bff8 com.apple.DebugSymbols (194 - 194) <040AE30B-CF2C-3798-A289-0929B8CAB10D> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff47b1c000 - 0x7fff47ca4ff6 com.apple.desktopservices (1.14.6 - 1281.6.1) /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff4819c000 - 0x7fff481d1ff7 com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
0x7fff49665000 - 0x7fff49a80ff1 com.apple.vision.FaceCore (4.3.0 - 4.3.0) <5D32F65D-2CD7-3204-975C-F4C9256E505F> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff4a0d8000 - 0x7fff4a0d8fff com.apple.FinderSyncPriv (1.0.7 - 1298.7.1) <5E08FCCF-B5AA-367F-BD08-DEFD32AB073F> /System/Library/PrivateFrameworks/FinderSyncPriv.framework/Versions/A/FinderSyncPriv
0x7fff4a11f000 - 0x7fff4a256ff4 libFontParser.dylib (277.2.6.3) /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff4a257000 - 0x7fff4a28bfff libTrueTypeScaler.dylib (277.2.6.3) <93039A1A-4946-3166-88B6-82EDD1649C3D> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
0x7fff4a2ef000 - 0x7fff4a2ffff6 libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff4d7e0000 - 0x7fff4d7e1fff libmetal_timestamp.dylib (902.14.11) /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff4ee8f000 - 0x7fff4ee9aff7 libGPUSupportMercury.dylib (17.10.22) <398D9635-B9CB-3BBB-A1E4-D1D1270D3F99> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff4ee9b000 - 0x7fff4eea1fff com.apple.GPUWrangler (5.2.7 - 5.2.7) /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff4f1c0000 - 0x7fff4f1e6ff1 com.apple.GenerationalStorage (2.0 - 314) <54483E50-20BB-3AF8-900F-992320C109B0> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff4f1ff000 - 0x7fff501e8ff1 com.apple.GeoServices (1.0 - 1624.26.4.26.9) /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff50314000 - 0x7fff50322ffb com.apple.GraphVisualizer (1.0 - 100.1) <507D5812-9CB4-3C94-938C-59ED2B370818> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff504c1000 - 0x7fff5057fff4 com.apple.Heimdal (4.0 - 2.0) /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff5270b000 - 0x7fff52713ff5 com.apple.IOAccelerator (438.7.3 - 438.7.3) <06E3E70B-C0D0-39A2-96B7-12ED6A0EBEE7> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff52720000 - 0x7fff52737fff com.apple.IOPresentment (47.10 - 37) <32F1B3BC-4644-3982-AAB2-8EB5D5FF0161> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff52abf000 - 0x7fff52b0aff1 com.apple.IconServices (438.3 - 438.3) <0DADB4C3-46FF-3FDB-8A86-51E2067FC7F4> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff52cc8000 - 0x7fff52ccfff9 com.apple.InternationalSupport (1.0 - 45.4) <8D8D4A7D-FD35-36B8-A456-7C93030EDAB3> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff52f5c000 - 0x7fff52f7bffd com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <6F655A32-F963-3A7E-B475-E460F4AC7D99> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff530b0000 - 0x7fff5317effd com.apple.LanguageModeling (1.0 - 215.1) /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff5317f000 - 0x7fff531c7fff com.apple.Lexicon-framework (1.0 - 72) <41F208B9-8255-3EC7-9673-FE0925D071D3> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff531ce000 - 0x7fff531d3ff3 com.apple.LinguisticData (1.0 - 353.18) <3B92F249-4602-325F-984B-D2DE61EEE4E1> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff531fa000 - 0x7fff5321effe com.apple.locationsupport (2394.0.22 - 2394.0.22) /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
0x7fff53a6c000 - 0x7fff53a6ffff com.apple.Mangrove (1.0 - 25) <482F300F-9B70-351F-A4DF-B440EEF7368D> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff53cd8000 - 0x7fff53d62ff8 com.apple.MediaExperience (1.0 - 1) <0203AF27-AB5E-32FA-B529-AB7F29EEB887> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff5453c000 - 0x7fff54588fff com.apple.spotlight.metadata.utilities (1.0 - 2076.7) <0237323B-EC78-3FBF-9FC7-5A1FE2B5CE25> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff54589000 - 0x7fff5465affa com.apple.gpusw.MetalTools (1.0 - 1) <99876E08-37D7-3828-8796-56D90C9AFBDB> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff546b8000 - 0x7fff546d1ff4 com.apple.MobileAssets (1.0 - 619.120.1) <07E116E6-7EBC-39F2-B5B4-31BAB6BAF852> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff5488e000 - 0x7fff548acfff com.apple.MobileKeyBag (2.0 - 1.0) /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff54b0f000 - 0x7fff54b3fff7 com.apple.MultitouchSupport.framework (3440.1 - 3440.1) <6794E1C8-9627-33DF-84F4-FDD02C97F383> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff5503f000 - 0x7fff55049fff com.apple.NetAuth (6.2 - 6.2) /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff55a55000 - 0x7fff55aa0ffb com.apple.OTSVG (1.0 - 643.1.5.2) /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff56cbd000 - 0x7fff56cc8ff2 com.apple.PerformanceAnalysis (1.243.2 - 243.2) /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff56cc9000 - 0x7fff56cf1ffb com.apple.persistentconnection (1.0 - 1.0) <5B2D87A8-2641-3F6D-ACEA-96B00F85AAB5> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff587c7000 - 0x7fff587daffc com.apple.PowerLog (1.0 - 1) /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
0x7fff59656000 - 0x7fff596b0ff6 com.apple.ProtectedCloudStorage (1.0 - 1) <6F271388-3817-336D-9B96-08C7AAC4BA39> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff596b1000 - 0x7fff596caffb com.apple.ProtocolBuffer (1 - 274.24.9.16.3) <5A020941-C43C-303E-8DE8-230FC6A84DBC> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff59b2a000 - 0x7fff59b53ff1 com.apple.RemoteViewServices (2.0 - 148) /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff59cb8000 - 0x7fff59cf3ff0 com.apple.RunningBoardServices (1.0 - 223.140.2) <96BB04BD-D6E0-3D70-8F36-89B46DA1DA30> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff5b5d4000 - 0x7fff5b5d7ff5 com.apple.SecCodeWrapper (4.0 - 448.100.6) /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff5b74a000 - 0x7fff5b871fff com.apple.Sharing (1526.37 - 1526.37) /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff5cc86000 - 0x7fff5cf7cff7 com.apple.SkyLight (1.600.0 - 451.4) /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff5d7c9000 - 0x7fff5d7d7ffb com.apple.SpeechRecognitionCore (6.0.91.2 - 6.0.91.2) <4D6CAC2A-151B-3BBE-BDB7-E2BE72128691> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff5d899000 - 0x7fff5db25ffe com.apple.spotlight.index (10.7.0 - 2076.7) <932C7705-353B-395F-9A23-09D62EAFAD81> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff5deb3000 - 0x7fff5def4ff9 com.apple.StreamingZip (1.0 - 1) <72CA32F8-4C96-3264-A655-623329EB3A28> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff5e00b000 - 0x7fff5e014ff7 com.apple.SymptomDiagnosticReporter (1.0 - 1238.120.2) /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff5e2cb000 - 0x7fff5e2dbff3 com.apple.TCC (1.0 - 1) /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff5e800000 - 0x7fff5e8c6ff0 com.apple.TextureIO (3.10.9 - 3.10.9) /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff5ea96000 - 0x7fff5eceeff0 com.apple.UIFoundation (1.0 - 662) /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff5f964000 - 0x7fff5f984ffc com.apple.UserManagement (1.0 - 1) <9F00880E-6EA6-3684-B208-455E14EC07C8> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff60730000 - 0x7fff6081bff2 com.apple.ViewBridge (467 - 467) <09E8FFB8-4DA1-3E80-8E19-927A2D987BF9> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff609c1000 - 0x7fff609c2fff com.apple.WatchdogClient.framework (1.0 - 67.120.2) /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff615f2000 - 0x7fff615f5ffa com.apple.dt.XCTTargetBootstrap (1.0 - 16091) /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff6166f000 - 0x7fff6167dff5 com.apple.audio.caulk (1.0 - 32.3) <06D695EA-E2BC-31E4-9816-9C12542BA744> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff619bf000 - 0x7fff619c1ff3 com.apple.loginsupport (1.0 - 1) <12F77885-27DC-3837-9CE9-A25EBA75F833> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff619c2000 - 0x7fff619d5ffd com.apple.login (3.0 - 3.0) /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff644a5000 - 0x7fff644d8ffa libAudioToolboxUtility.dylib (1104.95) /usr/lib/libAudioToolboxUtility.dylib
0x7fff644df000 - 0x7fff64513fff libCRFSuite.dylib (48) <5E5DE3CB-30DD-34DC-AEF8-FE8536A85E96> /usr/lib/libCRFSuite.dylib
0x7fff64516000 - 0x7fff64520fff libChineseTokenizer.dylib (34) <7F0DA183-1796-315A-B44A-2C234C7C50BE> /usr/lib/libChineseTokenizer.dylib
0x7fff645ac000 - 0x7fff645aeff7 libDiagnosticMessagesClient.dylib (112) /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff645f4000 - 0x7fff647abffb libFosl_dynamic.dylib (100.4) <737573B2-190A-3BA1-8220-807AD0A2CE5E> /usr/lib/libFosl_dynamic.dylib
0x7fff647d2000 - 0x7fff647d8ff3 libIOReport.dylib (54) <75D177C4-BAD7-3285-B8E1-3019F49B3178> /usr/lib/libIOReport.dylib
0x7fff648ba000 - 0x7fff648c1fff libMatch.1.dylib (36) <5C6F3971-9D9E-3630-BDB6-60BFC5A665E0> /usr/lib/libMatch.1.dylib
0x7fff648f0000 - 0x7fff64910ff7 libMobileGestalt.dylib (826.140.5) <2BE94E6A-FA61-312F-84A1-F764D71B7E39> /usr/lib/libMobileGestalt.dylib
0x7fff64a82000 - 0x7fff64a83fff libSystem.B.dylib (1281.100.1) <8E6AD412-91E7-36FC-A6FD-C13B06A4952A> /usr/lib/libSystem.B.dylib
0x7fff64b10000 - 0x7fff64b11fff libThaiTokenizer.dylib (3) <4F4ADE99-0D09-3223-B7C0-C407AB6DE8DC> /usr/lib/libThaiTokenizer.dylib
0x7fff64b29000 - 0x7fff64b3ffff libapple_nghttp2.dylib (1.39.2) <07FEC48A-87CF-32A3-8194-FA70B361713A> /usr/lib/libapple_nghttp2.dylib
0x7fff64b74000 - 0x7fff64be6ff7 libarchive.2.dylib (72.140.2) /usr/lib/libarchive.2.dylib
0x7fff64be7000 - 0x7fff64c80fe5 libate.dylib (3.0.1) <76EA60FB-748C-313F-8951-B076540BEA97> /usr/lib/libate.dylib
0x7fff64c84000 - 0x7fff64c84ff3 libauto.dylib (187) /usr/lib/libauto.dylib
0x7fff64d4a000 - 0x7fff64d5affb libbsm.0.dylib (60.100.1) <00BFFB9A-2FFE-3C24-896A-251BC61917FD> /usr/lib/libbsm.0.dylib
0x7fff64d5b000 - 0x7fff64d67fff libbz2.1.0.dylib (44) <14CC4988-B6D4-3879-AFC2-9A0DDC6388DE> /usr/lib/libbz2.1.0.dylib
0x7fff64d68000 - 0x7fff64dbafff libc++.1.dylib (902.1) <59A8239F-C28A-3B59-B8FA-11340DC85EDC> /usr/lib/libc++.1.dylib
0x7fff64dbb000 - 0x7fff64dd0ffb libc++abi.dylib (902) /usr/lib/libc++abi.dylib
0x7fff64dd1000 - 0x7fff64dd1fff libcharset.1.dylib (59) <72447768-9244-39AB-8E79-2FA14EC0AD33> /usr/lib/libcharset.1.dylib
0x7fff64dd2000 - 0x7fff64de3fff libcmph.dylib (8) /usr/lib/libcmph.dylib
0x7fff64de4000 - 0x7fff64dfbfd7 libcompression.dylib (87) <64C91066-586D-38C0-A2F3-3E60A940F859> /usr/lib/libcompression.dylib
0x7fff650d5000 - 0x7fff650ebff7 libcoretls.dylib (167) <770A5B96-936E-34E3-B006-B1CEC299B5A5> /usr/lib/libcoretls.dylib
0x7fff650ec000 - 0x7fff650edfff libcoretls_cfhelpers.dylib (167) <940BF370-FD0C-30A8-AA05-FF48DA44FA4C> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff656aa000 - 0x7fff65709ff7 libcups.2.dylib (483.7) <821ED293-B7B3-3B37-88C9-7B6CA91DA7FA> /usr/lib/libcups.2.dylib
0x7fff65813000 - 0x7fff65813fff libenergytrace.dylib (21) <162DFCC0-8F48-3DD0-914F-FA8653E27B26> /usr/lib/libenergytrace.dylib
0x7fff65814000 - 0x7fff6582cfff libexpat.1.dylib (19.60.2) /usr/lib/libexpat.1.dylib
0x7fff6583a000 - 0x7fff6583cfff libfakelink.dylib (149.1) <36146CB2-E6A5-37BB-9EE8-1B4034D8F3AD> /usr/lib/libfakelink.dylib
0x7fff6584b000 - 0x7fff65850fff libgermantok.dylib (24) /usr/lib/libgermantok.dylib
0x7fff65851000 - 0x7fff6585aff7 libheimdal-asn1.dylib (564.140.1) <0AC6FB62-2B0F-3E93-A931-E4DC4B1D757A> /usr/lib/libheimdal-asn1.dylib
0x7fff6585b000 - 0x7fff6594bfff libiconv.2.dylib (59) <18311A67-E4EF-3CC7-95B3-C0EDEE3A282F> /usr/lib/libiconv.2.dylib
0x7fff6594c000 - 0x7fff65ba3fff libicucore.A.dylib (64260.0.1) <8AC2CB07-E7E0-340D-A849-186FA1F27251> /usr/lib/libicucore.A.dylib
0x7fff65bbb000 - 0x7fff65bbcfff liblangid.dylib (133) <30CFC08C-EF36-3CF5-8AEA-C1CB070306B7> /usr/lib/liblangid.dylib
0x7fff65bbd000 - 0x7fff65bd5ff3 liblzma.5.dylib (16) /usr/lib/liblzma.5.dylib
0x7fff65bed000 - 0x7fff65c94ff7 libmecab.dylib (883.11) <0D5BFD01-D4A7-3C8D-AA69-C329C1A69792> /usr/lib/libmecab.dylib
0x7fff65c95000 - 0x7fff65ef7ff1 libmecabra.dylib (883.11) /usr/lib/libmecabra.dylib
0x7fff66264000 - 0x7fff66293fff libncurses.5.4.dylib (57) <995DFEEA-40F3-377F-B73D-D02AC59D591F> /usr/lib/libncurses.5.4.dylib
0x7fff663c3000 - 0x7fff6683fff5 libnetwork.dylib (1880.120.4) /usr/lib/libnetwork.dylib
0x7fff66840000 - 0x7fff66857fff libnetworkextension.dylib (1095.140.2) /usr/lib/libnetworkextension.dylib
0x7fff668e0000 - 0x7fff66913fde libobjc.A.dylib (787.1) <6DF81160-5E7F-3E31-AA1E-C875E3B98AF6> /usr/lib/libobjc.A.dylib
0x7fff66926000 - 0x7fff6692afff libpam.2.dylib (25.100.1) <0502F395-8EE6-3D2A-9239-06FD5622E19E> /usr/lib/libpam.2.dylib
0x7fff6692d000 - 0x7fff66963ff7 libpcap.A.dylib (89.120.1) /usr/lib/libpcap.A.dylib
0x7fff669e7000 - 0x7fff669fffff libresolv.9.dylib (67.40.1) /usr/lib/libresolv.9.dylib
0x7fff66a01000 - 0x7fff66a45ff7 libsandbox.1.dylib (1217.141.2) /usr/lib/libsandbox.1.dylib
0x7fff66a59000 - 0x7fff66a5aff7 libspindump.dylib (281.3) /usr/lib/libspindump.dylib
0x7fff66a5b000 - 0x7fff66c45ff7 libsqlite3.dylib (308.5) <35A2BD9F-4E33-30DE-A994-4AB585AC3AFE> /usr/lib/libsqlite3.dylib
0x7fff66e96000 - 0x7fff66e99ffb libutil.dylib (57) /usr/lib/libutil.dylib
0x7fff66e9a000 - 0x7fff66ea7ff7 libxar.1.dylib (425.2) /usr/lib/libxar.1.dylib
0x7fff66ead000 - 0x7fff66f8ffff libxml2.2.dylib (33.7) <20567881-7204-3C11-9179-50FE34B3301B> /usr/lib/libxml2.2.dylib
0x7fff66f93000 - 0x7fff66fbbfff libxslt.1.dylib (16.9) <34A45627-DA5B-37D2-9609-65B425E0010A> /usr/lib/libxslt.1.dylib
0x7fff66fbc000 - 0x7fff66fceff3 libz.1.dylib (76) <793D9643-CD83-3AAC-8B96-88D548FAB620> /usr/lib/libz.1.dylib
0x7fff6787d000 - 0x7fff67882ff3 libcache.dylib (83) /usr/lib/system/libcache.dylib
0x7fff67883000 - 0x7fff6788efff libcommonCrypto.dylib (60165.120.1) /usr/lib/system/libcommonCrypto.dylib
0x7fff6788f000 - 0x7fff67896fff libcompiler_rt.dylib (101.2) <49B8F644-5705-3F16-BBE0-6FFF9B17C36E> /usr/lib/system/libcompiler_rt.dylib
0x7fff67897000 - 0x7fff678a0ff7 libcopyfile.dylib (166.40.1) <3C481225-21E7-370A-A30E-0CCFDD64A92C> /usr/lib/system/libcopyfile.dylib
0x7fff678a1000 - 0x7fff67933fdb libcorecrypto.dylib (866.140.1) <60567BF8-80FA-359A-B2F3-A3BAEFB288FD> /usr/lib/system/libcorecrypto.dylib
0x7fff67a40000 - 0x7fff67a80ff0 libdispatch.dylib (1173.100.2) /usr/lib/system/libdispatch.dylib
0x7fff67a81000 - 0x7fff67ab7fff libdyld.dylib (750.6) <789A18C2-8AC7-3C88-813D-CD674376585D> /usr/lib/system/libdyld.dylib
0x7fff67ab8000 - 0x7fff67ab8ffb libkeymgr.dylib (30) /usr/lib/system/libkeymgr.dylib
0x7fff67ab9000 - 0x7fff67ac5ff3 libkxld.dylib (6153.141.10) <11EABEB3-CD17-3787-86BE-B8B21817E89B> /usr/lib/system/libkxld.dylib
0x7fff67ac6000 - 0x7fff67ac6ff7 liblaunch.dylib (1738.140.2) <7200E214-9B4D-3B22-9844-4C7892FC890B> /usr/lib/system/liblaunch.dylib
0x7fff67ac7000 - 0x7fff67accff7 libmacho.dylib (959.0.1) /usr/lib/system/libmacho.dylib
0x7fff67acd000 - 0x7fff67acfff3 libquarantine.dylib (110.40.3) /usr/lib/system/libquarantine.dylib
0x7fff67ad0000 - 0x7fff67ad1ff7 libremovefile.dylib (48) <7C7EFC79-BD24-33EF-B073-06AED234593E> /usr/lib/system/libremovefile.dylib
0x7fff67ad2000 - 0x7fff67ae9ff3 libsystem_asl.dylib (377.60.2) <1563EE02-0657-3B78-99BE-A947C24122EF> /usr/lib/system/libsystem_asl.dylib
0x7fff67aea000 - 0x7fff67aeaff7 libsystem_blocks.dylib (74) <0D53847E-AF5F-3ACF-B51F-A15DEA4DEC58> /usr/lib/system/libsystem_blocks.dylib
0x7fff67aeb000 - 0x7fff67b72fff libsystem_c.dylib (1353.100.2) /usr/lib/system/libsystem_c.dylib
0x7fff67b73000 - 0x7fff67b76ffb libsystem_configuration.dylib (1061.141.1) <0EE84C33-64FD-372B-974A-AF7A136F2068> /usr/lib/system/libsystem_configuration.dylib
0x7fff67b77000 - 0x7fff67b7afff libsystem_coreservices.dylib (114) /usr/lib/system/libsystem_coreservices.dylib
0x7fff67b7b000 - 0x7fff67b83fff libsystem_darwin.dylib (1353.100.2) <5B12B5DB-3F30-37C1-8ECC-49A66B1F2864> /usr/lib/system/libsystem_darwin.dylib
0x7fff67b84000 - 0x7fff67b8bfff libsystem_dnssd.dylib (1096.100.3) /usr/lib/system/libsystem_dnssd.dylib
0x7fff67b8c000 - 0x7fff67b8dffb libsystem_featureflags.dylib (17) <29FD922A-EC2C-3F25-BCCC-B58D716E60EC> /usr/lib/system/libsystem_featureflags.dylib
0x7fff67b8e000 - 0x7fff67bdbff7 libsystem_info.dylib (538) <8A321605-5480-330B-AF9E-64E65DE61747> /usr/lib/system/libsystem_info.dylib
0x7fff67bdc000 - 0x7fff67c08ff7 libsystem_kernel.dylib (6153.141.10) /usr/lib/system/libsystem_kernel.dylib
0x7fff67c09000 - 0x7fff67c50fff libsystem_m.dylib (3178) <00F331F1-0D09-39B3-8736-1FE90E64E903> /usr/lib/system/libsystem_m.dylib
0x7fff67c51000 - 0x7fff67c78fff libsystem_malloc.dylib (283.100.6) <8549294E-4C53-36EB-99F3-584A7393D8D5> /usr/lib/system/libsystem_malloc.dylib
0x7fff67c79000 - 0x7fff67c86ffb libsystem_networkextension.dylib (1095.140.2) /usr/lib/system/libsystem_networkextension.dylib
0x7fff67c87000 - 0x7fff67c90ff7 libsystem_notify.dylib (241.100.2) /usr/lib/system/libsystem_notify.dylib
0x7fff67c91000 - 0x7fff67c99fef libsystem_platform.dylib (220.100.1) <009A7C1F-313A-318E-B9F2-30F4C06FEA5C> /usr/lib/system/libsystem_platform.dylib
0x7fff67c9a000 - 0x7fff67ca4fff libsystem_pthread.dylib (416.100.3) <62CB1A98-0B8F-31E7-A02B-A1139927F61D> /usr/lib/system/libsystem_pthread.dylib
0x7fff67ca5000 - 0x7fff67ca9ff3 libsystem_sandbox.dylib (1217.141.2) <051C4018-4345-3034-AC98-6DE42FB8273B> /usr/lib/system/libsystem_sandbox.dylib
0x7fff67caa000 - 0x7fff67cacfff libsystem_secinit.dylib (62.100.2) /usr/lib/system/libsystem_secinit.dylib
0x7fff67cad000 - 0x7fff67cb4ffb libsystem_symptoms.dylib (1238.120.2) <702D0910-5C34-3D43-9631-8BD215DE4FE1> /usr/lib/system/libsystem_symptoms.dylib
0x7fff67cb5000 - 0x7fff67ccbff2 libsystem_trace.dylib (1147.120.1) /usr/lib/system/libsystem_trace.dylib
0x7fff67ccd000 - 0x7fff67cd2ff7 libunwind.dylib (35.4) <42B7B509-BAFE-365B-893A-72414C92F5BF> /usr/lib/system/libunwind.dylib
0x7fff67cd3000 - 0x7fff67d08ffe libxpc.dylib (1738.140.2) <54EEF402-42C7-3995-BADE-93C48EFC4452> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
  task_for_pid: 0
  thread_create: 0
  thread_set_state: 0
Calls made by this process:
  task_for_pid: 0
  thread_create: 0
  thread_set_state: 0
Calls made by all processes on this machine:
  task_for_pid: 7301
  thread_create: 0
  thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=876.9M resident=0K(0%) swapped_out_or_unallocated=876.9M(100%)
Writable regions: Total=971.0M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=971.0M(100%)
                              VIRTUAL   REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 128K 1
Activity Tracing 256K 1
CG backing stores 992K 2
CG image 588K 8
CoreAnimation 152K 12
CoreGraphics 8K 1
CoreImage 32K 4
CoreUI image data 936K 8
Foundation 4K 1
Kernel Alloc Once 8K 1
MALLOC 570.4M 361
MALLOC guard page 32K 7
MALLOC_LARGE (reserved) 992K 4 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 256.0M 1 reserved VM address space (unallocated)
OpenGL GLSL 256K 3
STACK GUARD 108K 27
Stack 38.7M 27
VM_ALLOCATE 88.9M 499
__DATA 103.5M 549
__DATA_CONST 360K 7
__FONT_DATA 4K 1
__GLSLBUILTINS 5176K 1
__LINKEDIT 445.4M 182
__OBJC_RO 32.3M 1
__OBJC_RW 1908K 2
__TEXT 431.5M 483
__UNICODE 564K 1
mapped file 73.5M 25
shared memory 640K 16
TOTAL 2.0G 2236
TOTAL, minus reserved VM space 1.8G 2236
Model: MacBookPro11,3, BootROM 429.0.0.0.0, 4 processors, Quad-Core Intel Core i7, 2,3 GHz, 16 GB, SMC 2.19f12
Graphics: kHW_IntelIrisProItem, Intel Iris Pro, spdisplays_builtin
Graphics: kHW_NVidiaGeForceGTX750MItem, NVIDIA GeForce GT 750M, spdisplays_pcie_device, 2 GB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x02FE, -
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x02FE, -
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1615.3)
Bluetooth: Version 7.0.6f8, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0512F, 500,28 GB
USB Device: USB 3.0 Bus
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
Apologies for the ate response, i have been on vacation. Here is the requested crash report: Process: Blender [2353] Path: /Applications/Blender.app/Contents/MacOS/Blender Identifier: org.blenderfoundation.blender Version: 2.92.0 (2.92.0 2020-12-28) Code Type: X86-64 (Native) Parent Process: ??? [1] Responsible: Blender [2353] User ID: 501 Date/Time: 2021-01-09 20:42:03.294 +0200 OS Version: Mac OS X 10.15.7 (19H114) Report Version: 12 Anonymous UUID: 566ADE8C-E821-A684-2C95-097561082086 Sleep/Wake UUID: DED5B8D6-F1FF-4920-AB96-FF01112FC505 Time Awake Since Boot: 12000 seconds Time Since Wake: 2800 seconds System Integrity Protection: enabled Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_CRASH (SIGSEGV) Exception Codes: 0x0000000000000000, 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY Termination Signal: Segmentation fault: 11 Termination Reason: Namespace SIGNAL, Code 0xb Terminating Process: Blender [2353] Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 libsystem_kernel.dylib 0x00007fff67bdf882 __psynch_cvwait + 10 1 libsystem_pthread.dylib 0x00007fff67ca0425 _pthread_cond_wait + 698 2 org.blenderfoundation.blender 0x000000010e35ff30 take_gil + 240 3 org.blenderfoundation.blender 0x000000010e36048f PyEval_RestoreThread + 31 4 org.blenderfoundation.blender 0x000000010e39b4ab PyGILState_Ensure + 59 5 org.blenderfoundation.blender 0x0000000108592f85 bpy_context_set + 37 6 org.blenderfoundation.blender 0x00000001085ac3fa cb_region_draw + 26 7 org.blenderfoundation.blender 0x00000001086b333b ED_region_draw_cb_draw + 75 8 org.blenderfoundation.blender 0x00000001085bbde1 ED_region_do_draw + 801 9 org.blenderfoundation.blender 0x0000000107fdbf2d wm_draw_update + 1757 10 org.blenderfoundation.blender 0x0000000107fd95c0 WM_main + 48 11 org.blenderfoundation.blender 0x0000000107bbd2cb main + 907 12 libdyld.dylib 0x00007fff67a9bcc9 start + 1 Thread 1: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 libdispatch.dylib 0x00007fff67a42aed _dispatch_sema4_wait + 16 2 libdispatch.dylib 0x00007fff67a42fbf _dispatch_semaphore_wait_slow + 98 3 org.blenderfoundation.blender 0x000000010dca8f32 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50 4 org.blenderfoundation.blender 0x000000010dca7a9e void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62 5 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 6 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 2: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 libdispatch.dylib 0x00007fff67a42aed _dispatch_sema4_wait + 16 2 libdispatch.dylib 0x00007fff67a42fbf _dispatch_semaphore_wait_slow + 98 3 org.blenderfoundation.blender 0x000000010dca8f32 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50 4 org.blenderfoundation.blender 0x000000010dca7a9e void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62 5 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 6 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 3: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 libdispatch.dylib 0x00007fff67a42aed _dispatch_sema4_wait + 16 2 libdispatch.dylib 0x00007fff67a42fbf _dispatch_semaphore_wait_slow + 98 3 org.blenderfoundation.blender 0x000000010dca8f32 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50 4 org.blenderfoundation.blender 0x000000010dca7a9e void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62 5 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 6 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 4: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 libdispatch.dylib 0x00007fff67a42aed _dispatch_sema4_wait + 16 2 libdispatch.dylib 0x00007fff67a42fbf _dispatch_semaphore_wait_slow + 98 3 org.blenderfoundation.blender 0x000000010dca8f32 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50 4 org.blenderfoundation.blender 0x000000010dca7a9e void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62 5 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 6 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 5: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 libdispatch.dylib 0x00007fff67a42aed _dispatch_sema4_wait + 16 2 libdispatch.dylib 0x00007fff67a42fbf _dispatch_semaphore_wait_slow + 98 3 org.blenderfoundation.blender 0x000000010dca8f32 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50 4 org.blenderfoundation.blender 0x000000010dca7a9e void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62 5 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 6 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 6: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 libdispatch.dylib 0x00007fff67a42aed _dispatch_sema4_wait + 16 2 libdispatch.dylib 0x00007fff67a42fbf _dispatch_semaphore_wait_slow + 98 3 org.blenderfoundation.blender 0x000000010dca8f32 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50 4 org.blenderfoundation.blender 0x000000010dca7a9e void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62 5 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 6 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 7: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 libdispatch.dylib 0x00007fff67a42aed _dispatch_sema4_wait + 16 2 libdispatch.dylib 0x00007fff67a42fbf _dispatch_semaphore_wait_slow + 98 3 org.blenderfoundation.blender 0x000000010dca8f32 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50 4 org.blenderfoundation.blender 0x000000010dca7a9e void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62 5 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 6 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 8: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 libdispatch.dylib 0x00007fff67a42aed _dispatch_sema4_wait + 16 2 libdispatch.dylib 0x00007fff67a42fbf _dispatch_semaphore_wait_slow + 98 3 org.blenderfoundation.blender 0x000000010dca8f32 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50 4 org.blenderfoundation.blender 0x000000010dca7a9e void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62 5 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 6 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 9: 0 libsystem_pthread.dylib 0x00007fff67c9bb68 start_wqthread + 0 Thread 10:: AMCP Logging Spool 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 com.apple.audio.caulk 0x00007fff61671b16 caulk::mach::semaphore::wait() + 16 2 com.apple.audio.caulk 0x00007fff616719b2 caulk::semaphore::timed_wait(double) + 106 3 com.apple.audio.caulk 0x00007fff616717c4 caulk::concurrent::details::worker_thread::run() + 30 4 com.apple.audio.caulk 0x00007fff616711e4 void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 45 5 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 6 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 11: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 com.apple.audio.caulk 0x00007fff61671b16 caulk::mach::semaphore::wait() + 16 2 com.apple.audio.caulk 0x00007fff616719b2 caulk::semaphore::timed_wait(double) + 106 3 com.apple.audio.caulk 0x00007fff616717c4 caulk::concurrent::details::worker_thread::run() + 30 4 com.apple.audio.caulk 0x00007fff616711e4 void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 45 5 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 6 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 12: 0 libsystem_pthread.dylib 0x00007fff67c9bb68 start_wqthread + 0 Thread 13: 0 libsystem_pthread.dylib 0x00007fff67c9bb68 start_wqthread + 0 Thread 14:: com.apple.audio.IOThread.client 0 libsystem_kernel.dylib 0x00007fff67bdcdfa mach_msg_trap + 10 1 libsystem_kernel.dylib 0x00007fff67bdd170 mach_msg + 60 2 com.apple.audio.CoreAudio 0x00007fff2d114bf1 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111 3 com.apple.audio.CoreAudio 0x00007fff2d010d88 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 2677 4 com.apple.audio.CoreAudio 0x00007fff2d144b9e HALB_IOThread::Entry(void*) + 72 5 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 6 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 15: 0 libsystem_kernel.dylib 0x00007fff67bdf882 __psynch_cvwait + 10 1 libsystem_pthread.dylib 0x00007fff67ca0425 _pthread_cond_wait + 698 2 com.apple.GeForceMTLDriver 0x00007fff29201cbb 0x7fff29095000 + 1494203 3 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 4 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 16: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 org.blenderfoundation.blender 0x0000000107fd0118 tbb::internal::rml::private_worker::run() + 104 2 org.blenderfoundation.blender 0x0000000107fd00a9 tbb::internal::rml::private_worker::thread_routine(void*) + 9 3 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 4 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 17: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 org.blenderfoundation.blender 0x0000000107fd0118 tbb::internal::rml::private_worker::run() + 104 2 org.blenderfoundation.blender 0x0000000107fd00a9 tbb::internal::rml::private_worker::thread_routine(void*) + 9 3 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 4 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 18: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 org.blenderfoundation.blender 0x0000000107fd0118 tbb::internal::rml::private_worker::run() + 104 2 org.blenderfoundation.blender 0x0000000107fd00a9 tbb::internal::rml::private_worker::thread_routine(void*) + 9 3 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 4 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 19: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 org.blenderfoundation.blender 0x0000000107fd0118 tbb::internal::rml::private_worker::run() + 104 2 org.blenderfoundation.blender 0x0000000107fd00a9 tbb::internal::rml::private_worker::thread_routine(void*) + 9 3 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 4 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 20: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 org.blenderfoundation.blender 0x0000000107fd0118 tbb::internal::rml::private_worker::run() + 104 2 org.blenderfoundation.blender 0x0000000107fd00a9 tbb::internal::rml::private_worker::thread_routine(void*) + 9 3 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 4 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 21: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 org.blenderfoundation.blender 0x0000000107fd0118 tbb::internal::rml::private_worker::run() + 104 2 org.blenderfoundation.blender 0x0000000107fd00a9 tbb::internal::rml::private_worker::thread_routine(void*) + 9 3 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 4 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 22: 0 libsystem_kernel.dylib 0x00007fff67bdce36 semaphore_wait_trap + 10 1 org.blenderfoundation.blender 0x0000000107fd0118 tbb::internal::rml::private_worker::run() + 104 2 org.blenderfoundation.blender 0x0000000107fd00a9 tbb::internal::rml::private_worker::thread_routine(void*) + 9 3 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 4 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 23:: com.apple.NSEventThread 0 libsystem_kernel.dylib 0x00007fff67bdcdfa mach_msg_trap + 10 1 libsystem_kernel.dylib 0x00007fff67bdd170 mach_msg + 60 2 com.apple.CoreFoundation 0x00007fff2da32ef5 __CFRunLoopServiceMachPort + 247 3 com.apple.CoreFoundation 0x00007fff2da319c2 __CFRunLoopRun + 1319 4 com.apple.CoreFoundation 0x00007fff2da30e3e CFRunLoopRunSpecific + 462 5 com.apple.AppKit 0x00007fff2ae44954 _NSEventThread + 132 6 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 7 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 24: 0 libsystem_pthread.dylib 0x00007fff67c9bb68 start_wqthread + 0 Thread 25: 0 libsystem_pthread.dylib 0x00007fff67c9bb68 start_wqthread + 0 Thread 26: 0 libGL.dylib 0x00007fff378e9393 glGetProgramiv + 20 1 org.blenderfoundation.blender 0x000000010e1b958d blender::gpu::GLShader::vertformat_from_shader(GPUVertFormat*) const + 77 2 org.blenderfoundation.blender 0x00000001091c4141 py_shader_calc_format + 33 3 org.blenderfoundation.blender 0x000000010e295427 _PyMethodDef_RawFastCallKeywords + 775 4 org.blenderfoundation.blender 0x000000010e29b421 _PyMethodDescr_FastCallKeywords + 81 5 org.blenderfoundation.blender 0x000000010e36a978 call_function + 888 6 org.blenderfoundation.blender 0x000000010e36734e _PyEval_EvalFrameDefault + 27230 7 org.blenderfoundation.blender 0x000000010e36b69d _PyEval_EvalCodeWithName + 3021 8 org.blenderfoundation.blender 0x000000010e294689 _PyFunction_FastCallKeywords + 217 9 org.blenderfoundation.blender 0x000000010e36a90c call_function + 780 10 org.blenderfoundation.blender 0x000000010e367408 _PyEval_EvalFrameDefault + 27416 11 org.blenderfoundation.blender 0x000000010e36b69d _PyEval_EvalCodeWithName + 3021 12 org.blenderfoundation.blender 0x000000010e294187 _PyFunction_FastCallDict + 455 13 org.blenderfoundation.blender 0x000000010859012a bpy_app_generic_callback + 314 14 org.blenderfoundation.blender 0x0000000107c01992 BKE_callback_exec_id_depsgraph + 146 15 org.blenderfoundation.blender 0x0000000107d7864d scene_graph_update_tagged + 461 16 org.blenderfoundation.blender 0x00000001087be48a bake + 1610 17 org.blenderfoundation.blender 0x00000001087c02f5 bake_startjob + 341 18 org.blenderfoundation.blender 0x0000000107ff1b07 do_job_thread + 39 19 libsystem_pthread.dylib 0x00007fff67ca0109 _pthread_start + 148 20 libsystem_pthread.dylib 0x00007fff67c9bb8b thread_start + 15 Thread 0 crashed with X86 Thread State (64-bit): ``` rax: 0x0000000000000104 rbx: 0x0000000000000002 rcx: 0x00007ffee8186818 rdx: 0x0000000000000000 rdi: 0x00000001154e3660 rsi: 0x0000020100000300 rbp: 0x00007ffee81868b0 rsp: 0x00007ffee8186818 r8: 0x0000000000000000 r9: 0x00000000000000a0 r10: 0x0000000000000000 r11: 0x0000000000000202 r12: 0x00000001154e3660 r13: 0x0000000000000016 r14: 0x0000020100000300 r15: 0x000000012562cdc0 rip: 0x00007fff67bdf882 rfl: 0x0000000000000203 cr2: 0x00007000042d0000 ``` Logical CPU: 0 Error Code: 0x02000131 Trap Number: 133 Binary Images: 0x107a79000 - 0x112430f8f +org.blenderfoundation.blender (2.92.0 - 2.92.0 2020-12-28) <3F8822B8-8F38-366A-9BCE-B1AE9AE62EE1> /Applications/Blender.app/Contents/MacOS/Blender 0x1191e8000 - 0x119254ffb +libomp.dylib (0) <535E76BC-1650-3651-9C62-97A995647107> /Applications/Blender.app/Contents/Resources/lib/libomp.dylib 0x11aee6000 - 0x11aeeafff com.apple.audio.AppleHDAHALPlugIn (283.15 - 283.15) <AB88E450-7A43-3F72-9A07-FA761BA1B389> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn 0x11daf3000 - 0x11dc4cff7 com.apple.audio.units.Components (1.14 - 1.14) <21193A0C-D32B-3EAD-B84B-28DF911131B6> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio 0x11dc7f000 - 0x11e0dffff com.apple.audio.AudioDSPComponents (1.0 - 1) <F84D78A6-A8F1-3A07-BEB7-306455FDD65A> /System/Library/Components/AudioDSP.component/Contents/MacOS/AudioDSP 0x11e14c000 - 0x11e14f047 libobjc-trampolines.dylib (787.1) <88F9B648-C455-36F8-BBB9-7D1A9F57D073> /usr/lib/libobjc-trampolines.dylib 0x125562000 - 0x1255f3f47 dyld (750.6) <F58DDECD-315C-3B7C-8162-A5E8E1D62FE3> /usr/lib/dyld 0x12772c000 - 0x12772eff3 com.apple.CloudDocsFileProvider (1.0 - 698.17) <C03D572A-4C6B-3DFA-8AA9-064B4808BA72> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider 0x127738000 - 0x12773bfff com.apple.FileProviderOverride (304.1 - 304.1) <FF452DA5-75BC-3EF3-B372-F4FD9B7D57B9> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride 0x12c047000 - 0x12c048ff7 +_heapq.cpython-37m-darwin.so (0) <20086BF0-0130-3463-B824-F98C6D51BE39> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_heapq.cpython-37m-darwin.so 0x12c251000 - 0x12c256ffb +math.cpython-37m-darwin.so (0) <F76ADA60-2AAA-34A7-BB31-26405F501673> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/math.cpython-37m-darwin.so 0x12c9a3000 - 0x12c9a8ff3 +_blake2.cpython-37m-darwin.so (0) <7FD886EF-36D2-329A-B8CE-AAF09D7269E8> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_blake2.cpython-37m-darwin.so 0x12c9d3000 - 0x12c9e3ff3 +_sha3.cpython-37m-darwin.so (0) <D7698BDC-8C9A-3198-81AD-6044B3FFB378> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_sha3.cpython-37m-darwin.so 0x12c9ee000 - 0x12c9effff +test_compile.cpython-37m-darwin.so (0) <1F455AF4-310D-3F55-9312-0D2D6E241239> /Users/USER/Library/Application Support/Blender/*/test_compile.cpython-37m-darwin.so 0x12ca53000 - 0x12cc6c11b +_hashlib.cpython-37m-darwin.so (0) <C9C14775-5B8E-3512-98E0-537BF4984A54> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_hashlib.cpython-37m-darwin.so 0x12cd45000 - 0x12cd49ff3 +_struct.cpython-37m-darwin.so (0) <AFC22996-5DC5-3B8F-B881-06BF3CE37AA9> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_struct.cpython-37m-darwin.so 0x12cd57000 - 0x12cd69fff +zlib.cpython-37m-darwin.so (0) <8EF3CAAD-13A3-3C17-B25F-8F3D16F65850> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/zlib.cpython-37m-darwin.so 0x12cdb4000 - 0x12cdc6fff +_pickle.cpython-37m-darwin.so (0) <85237162-4DE3-38EA-99F5-287A1DB8BB02> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_pickle.cpython-37m-darwin.so 0x12cdd7000 - 0x12cdedffb +_bz2.cpython-37m-darwin.so (0) <E0F8E75D-B92D-3624-ABAE-FAC3B29181F2> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_bz2.cpython-37m-darwin.so 0x12cdf8000 - 0x12ce26ff7 +_lzma.cpython-37m-darwin.so (0) <B82293C1-035E-3C19-B6E1-E93BEB44DA1B> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_lzma.cpython-37m-darwin.so 0x12ce35000 - 0x12ce35ffb +grp.cpython-37m-darwin.so (0) <DEEAC15B-[D65](https://archive.blender.org/developer/D65)-3D28-9F79-32426A8C67B7> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/grp.cpython-37m-darwin.so 0x12cebd000 - 0x12cebdffb +_bisect.cpython-37m-darwin.so (0) <1F871C75-B7E3-3531-B4FD-9127E49825DD> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_bisect.cpython-37m-darwin.so 0x12cec5000 - 0x12cec6ffb +_random.cpython-37m-darwin.so (0) <6EA0F0A9-EB67-39B1-8BC9-CD20C494E8F6> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_random.cpython-37m-darwin.so 0x12cf4e000 - 0x12cf53ff7 +cmath.cpython-37m-darwin.so (0) <4032EF0D-74B8-370D-A823-4F202C0A740F> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/cmath.cpython-37m-darwin.so 0x12d1a0000 - 0x12d509ff7 +_multiarray_umath.cpython-37m-darwin.so (0) <8B761C71-2D89-37F3-BEB5-B9254A2C3E02> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/core/_multiarray_umath.cpython-37m-darwin.so 0x12d666000 - 0x12d674ff3 +_datetime.cpython-37m-darwin.so (0) <87D99FDA-6F48-3410-B90A-CD992418681B> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_datetime.cpython-37m-darwin.so 0x12d804000 - 0x12d811ff7 +_multiarray_tests.cpython-37m-darwin.so (0) <15017CB9-B1EE-3481-9902-487DBE7BDB6E> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/core/_multiarray_tests.cpython-37m-darwin.so 0x12d825000 - 0x12d837ff7 +_ctypes.cpython-37m-darwin.so (0) <B0269B94-1975-35FC-93D8-B7862608A10E> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_ctypes.cpython-37m-darwin.so 0x12d88d000 - 0x12d88efff +_posixsubprocess.cpython-37m-darwin.so (0) <3DC85D51-0860-37D2-9F6A-0AD91A2595CE> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_posixsubprocess.cpython-37m-darwin.so 0x12d896000 - 0x12d899fff +select.cpython-37m-darwin.so (0) <02400D4C-4C27-3FCA-B63B-7F29026E1FB1> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/select.cpython-37m-darwin.so 0x12d8e4000 - 0x12d8e5ffb +lapack_lite.cpython-37m-darwin.so (0) <13E4865F-46D4-3301-9D3E-49CCFDD3D095> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/linalg/lapack_lite.cpython-37m-darwin.so 0x12d8ed000 - 0x12d905ffb +_umath_linalg.cpython-37m-darwin.so (0) <01FBC95E-932B-3A93-962E-52168F690BD9> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/linalg/_umath_linalg.cpython-37m-darwin.so 0x12da18000 - 0x12da55ff7 +_decimal.cpython-37m-darwin.so (0) <E8636347-BAF6-3D6F-B05A-49B6FDB71DD2> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_decimal.cpython-37m-darwin.so 0x12da7a000 - 0x12da8bff3 +_pocketfft_internal.cpython-37m-darwin.so (0) <988AA5B5-36FB-3D86-805C-F00EEF719789> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/fft/_pocketfft_internal.cpython-37m-darwin.so 0x12dad4000 - 0x12db3cff7 +mtrand.cpython-37m-darwin.so (0) <8D5E395F-CCC8-36F1-96D9-A6E9DDA41AAF> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/mtrand.cpython-37m-darwin.so 0x12db94000 - 0x12dbc4ff3 +common.cpython-37m-darwin.so (0) <61D582CA-1C59-3309-8A00-F442A082F200> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/common.cpython-37m-darwin.so 0x12dbde000 - 0x12dc30ffb +bounded_integers.cpython-37m-darwin.so (0) <36A58A6D-37D5-3609-8C1B-BBA03F904E00> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/bounded_integers.cpython-37m-darwin.so 0x12dc58000 - 0x12dc6bffb +mt19937.cpython-37m-darwin.so (0) <2802AEBB-A054-36AF-A4C8-CC8456F69F62> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/mt19937.cpython-37m-darwin.so 0x12dc7c000 - 0x12dc9affb +bit_generator.cpython-37m-darwin.so (0) <A731D255-3FD7-3C14-B391-DE7EBA4DE4D9> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/bit_generator.cpython-37m-darwin.so 0x12dcfa000 - 0x12dd00ff7 +binascii.cpython-37m-darwin.so (0) <03796BF6-3DC5-3C9B-9D69-32549A2602EB> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/binascii.cpython-37m-darwin.so 0x12dd09000 - 0x12dd16ff3 +philox.cpython-37m-darwin.so (0) <57D29373-83CC-374B-96C9-4B36D0F68B4F> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/philox.cpython-37m-darwin.so 0x12dd27000 - 0x12dd31ff3 +pcg64.cpython-37m-darwin.so (0) <90C29A5D-B621-3CE6-B439-AAB6B4337604> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/pcg64.cpython-37m-darwin.so 0x12dd41000 - 0x12dd49ff7 +sfc64.cpython-37m-darwin.so (0) <2C7FCA5F-DA2E-34A5-9D04-A984B86BC536> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/sfc64.cpython-37m-darwin.so 0x12dd58000 - 0x12ddceff7 +generator.cpython-37m-darwin.so (0) <86FEA253-4515-3EF4-8253-E3E8DF2F4BD3> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/site-packages/numpy/random/generator.cpython-37m-darwin.so 0x12e367000 - 0x12e367ff7 +_opcode.cpython-37m-darwin.so (0) <DA893BE1-01DF-330B-ACCA-C9A9A6B7EE04> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_opcode.cpython-37m-darwin.so 0x12e3ef000 - 0x12e41cff3 +pyexpat.cpython-37m-darwin.so (0) <8DE98AAE-6AC5-322D-B1B4-BB5B13CD12CE> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/pyexpat.cpython-37m-darwin.so 0x12e7f5000 - 0x12e7fbfff +array.cpython-37m-darwin.so (0) <13F2F1B6-3644-36EB-A680-74EBC5DCE26F> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/array.cpython-37m-darwin.so 0x12ea0a000 - 0x12ea10ffb +_json.cpython-37m-darwin.so (0) <6C52949D-6062-3DBB-8601-8FC34D195603> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_json.cpython-37m-darwin.so 0x12ec59000 - 0x12ec62ffb +_socket.cpython-37m-darwin.so (0) <A4DDE5D0-B31B-3A17-82BE-4532FC9BCDA3> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_socket.cpython-37m-darwin.so 0x12eef5000 - 0x12eefdff3 +_elementtree.cpython-37m-darwin.so (0) <E40CCCAE-65D4-3AEC-92BA-4D6BD010A4D0> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_elementtree.cpython-37m-darwin.so 0x12f38c000 - 0x12f63c81b +_ssl.cpython-37m-darwin.so (0) <354522B6-4702-3B5C-BA0E-AB7A4E479091> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_ssl.cpython-37m-darwin.so 0x12f746000 - 0x12f746ff3 +_scproxy.cpython-37m-darwin.so (0) <9673CE7F-B1B9-3C49-96D2-D03BFEB345AE> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_scproxy.cpython-37m-darwin.so 0x12f8ce000 - 0x12f8cffff +_queue.cpython-37m-darwin.so (0) <2E95FB49-FE7E-3065-A632-9E7EBE8D25EA> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_queue.cpython-37m-darwin.so 0x12f918000 - 0x12f918ff3 +_uuid.cpython-37m-darwin.so (0) <AE6BA881-84D6-3766-9641-7A5B34B11A16> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_uuid.cpython-37m-darwin.so 0x12f99f000 - 0x12f9a1ffb +murmurhash3.cpython-37m-darwin.so (0) <9FBCE98F-6717-38A9-82B4-824AEA3C5B98> /Users/USER/Library/Application Support/Blender/*/murmurhash3.cpython-37m-darwin.so 0x12f9a5000 - 0x12f9a6ff7 +utils.cpython-37m-darwin.so (0) <3CF51A19-C559-3005-8009-479278D8D205> /Users/USER/Library/Application Support/Blender/*/utils.cpython-37m-darwin.so 0x12f9aa000 - 0x12f9c0ff7 +implementations.cpython-37m-darwin.so (0) <6F546C77-8754-3366-9F04-90BD15DF5E75> /Users/USER/Library/Application Support/Blender/*/implementations.cpython-37m-darwin.so 0x12f9da000 - 0x12f9e4ff3 +clist.cpython-37m-darwin.so (0) <C5CEEA92-7202-3C1D-923C-03CDAF998E9D> /Users/USER/Library/Application Support/Blender/*/clist.cpython-37m-darwin.so 0x12f9ee000 - 0x12fb8bff3 +base_lists.cpython-37m-darwin.so (0) <E346535F-ED9C-3384-9CC1-673FBBD0D058> /Users/USER/Library/Application Support/Blender/*/base_lists.cpython-37m-darwin.so 0x12fc50000 - 0x12fc52fff +geometry.cpython-37m-darwin.so (0) <8D468471-BC20-3A54-B375-FCDBFA731B24> /Users/USER/Library/Application Support/Blender/*/geometry.cpython-37m-darwin.so 0x12fc56000 - 0x12fc59ff3 +vector.cpython-37m-darwin.so (0) <8C7C1C06-8383-3233-8516-D13A39910C0C> /Users/USER/Library/Application Support/Blender/*/vector.cpython-37m-darwin.so 0x12fc5d000 - 0x12fc68ffb +conversion.cpython-37m-darwin.so (0) <5C3BBBF3-8909-3DC5-8D55-A1C67DD31251> /Users/USER/Library/Application Support/Blender/*/conversion.cpython-37m-darwin.so 0x12fc6e000 - 0x12fc74ff3 +list_operations.cpython-37m-darwin.so (0) <08F2DAD4-B9E1-3A75-9C1E-76D3BBB69F55> /Users/USER/Library/Application Support/Blender/*/list_operations.cpython-37m-darwin.so 0x12fc7a000 - 0x12fc80ff7 +matrix.cpython-37m-darwin.so (0) <BABFDFF3-D1D8-3A17-A227-2AC86921CE87> /Users/USER/Library/Application Support/Blender/*/matrix.cpython-37m-darwin.so 0x12fc85000 - 0x12fc8bff3 +rotation_conversion.cpython-37m-darwin.so (0) <D04FF7E0-C9CC-3224-A133-1C321FD6CA54> /Users/USER/Library/Application Support/Blender/*/rotation_conversion.cpython-37m-darwin.so 0x12fc91000 - 0x12fc96ff3 +utils.cpython-37m-darwin.so (0) <D27BBA2F-38B2-387D-ADB3-4915DF42BED7> /Users/USER/Library/Application Support/Blender/*/utils.cpython-37m-darwin.so 0x12fc9b000 - 0x12fcafffb +polygon_indices_list.cpython-37m-darwin.so (0) <F5C6F374-3835-3E58-8E45-9BBFB4C9E1BB> /Users/USER/Library/Application Support/Blender/*/polygon_indices_list.cpython-37m-darwin.so 0x12fcbd000 - 0x12fcd2fff +virtual_list.cpython-37m-darwin.so (0) <84D01A38-4777-323B-98A8-14013CCB17BC> /Users/USER/Library/Application Support/Blender/*/virtual_list.cpython-37m-darwin.so 0x12fce1000 - 0x12fd1aff7 +virtual_clists.cpython-37m-darwin.so (0) <0E90D8E3-549E-332C-8045-3DD634326A67> /Users/USER/Library/Application Support/Blender/*/virtual_clists.cpython-37m-darwin.so 0x12fd7d000 - 0x12fd82ff3 +default_list.cpython-37m-darwin.so (0) <1AA25C9E-B6A8-3EC0-9A10-FE58335F0447> /Users/USER/Library/Application Support/Blender/*/default_list.cpython-37m-darwin.so 0x12fd87000 - 0x12fd8bffb +c_default_list.cpython-37m-darwin.so (0) <9A9C9050-967B-31B4-81B0-5CD0A21F0A8B> /Users/USER/Library/Application Support/Blender/*/c_default_list.cpython-37m-darwin.so 0x12fd90000 - 0x12fdbafff +mesh_data.cpython-37m-darwin.so (0) <765C8D73-2B67-3B19-B8DD-A795E0443ED6> /Users/USER/Library/Application Support/Blender/*/mesh_data.cpython-37m-darwin.so 0x12fdcc000 - 0x12fdceff3 +number.cpython-37m-darwin.so (0) <D6C531E1-9F16-322F-9D92-D88774890781> /Users/USER/Library/Application Support/Blender/*/number.cpython-37m-darwin.so 0x12fdd2000 - 0x12fde8ff7 +validate.cpython-37m-darwin.so (0) <415435FA-00EA-37D2-B5FA-106D99644623> /Users/USER/Library/Application Support/Blender/*/validate.cpython-37m-darwin.so 0x12fdf5000 - 0x12fdfdffb +triangulate_mesh.cpython-37m-darwin.so (0) <5FA7BE67-5F79-38BB-AFC9-01D17B8CC031> /Users/USER/Library/Application Support/Blender/*/triangulate_mesh.cpython-37m-darwin.so 0x12fe05000 - 0x12fe11ff7 +poly_spline.cpython-37m-darwin.so (0) <EC3AFE70-7B7D-39A1-8095-E073EB1ABF4D> /Users/USER/Library/Application Support/Blender/*/poly_spline.cpython-37m-darwin.so 0x12fe1b000 - 0x12fe33ff7 +base_spline.cpython-37m-darwin.so (0) <EDFB9BBA-6F41-357A-B934-6FB6E150C23C> /Users/USER/Library/Application Support/Blender/*/base_spline.cpython-37m-darwin.so 0x12fe41000 - 0x12fe43ff3 +lists.cpython-37m-darwin.so (0) <F46CEAE8-A9A2-3DCC-AA00-B5B80671F896> /Users/USER/Library/Application Support/Blender/*/lists.cpython-37m-darwin.so 0x12fe47000 - 0x12fe5cff7 +bezier_spline.cpython-37m-darwin.so (0) <DCE6B086-C02D-32A0-AED2-FBC79EA4B2CA> /Users/USER/Library/Application Support/Blender/*/bezier_spline.cpython-37m-darwin.so 0x12fe68000 - 0x12fe76ff7 +evaluation.cpython-37m-darwin.so (0) <DFEB5A3D-EE10-34FD-B53C-4B9D63834E55> /Users/USER/Library/Application Support/Blender/*/evaluation.cpython-37m-darwin.so 0x12fe80000 - 0x12fe89fff +falloff_base.cpython-37m-darwin.so (0) <31372925-48FE-315C-99AC-1E696A6160DD> /Users/USER/Library/Application Support/Blender/*/falloff_base.cpython-37m-darwin.so 0x12fe91000 - 0x12fe97ff3 +types.cpython-37m-darwin.so (0) <FB0B7B2B-2756-394C-B338-2011779DC9E7> /Users/USER/Library/Application Support/Blender/*/types.cpython-37m-darwin.so 0x12fe9d000 - 0x12fe9eff3 +pointers.cpython-37m-darwin.so (0) <E5C5544A-E92C-39A4-B2AD-B838FF23F1AA> /Users/USER/Library/Application Support/Blender/*/pointers.cpython-37m-darwin.so 0x12fea2000 - 0x12fea8fff +interpolation.cpython-37m-darwin.so (0) <7012E25F-C844-32CA-8E38-DC5267528473> /Users/USER/Library/Application Support/Blender/*/interpolation.cpython-37m-darwin.so 0x12feaf000 - 0x12fec2ff7 +action_base.cpython-37m-darwin.so (0) <C017E42B-A2DB-3557-88BF-96BDB7D0A805> /Users/USER/Library/Application Support/Blender/*/action_base.cpython-37m-darwin.so 0x12fed1000 - 0x12fedbff3 +action_channels.cpython-37m-darwin.so (0) <BCD5DC8C-29C8-37F5-B6F2-B9AA7F531F2E> /Users/USER/Library/Application Support/Blender/*/action_channels.cpython-37m-darwin.so 0x12fee3000 - 0x12ff11ff3 +action_types.cpython-37m-darwin.so (0) <79E076C4-EF89-3D29-8A44-7F3BB8AF753B> /Users/USER/Library/Application Support/Blender/*/action_types.cpython-37m-darwin.so 0x12ffec000 - 0x12ffeeff7 +clamp.cpython-37m-darwin.so (0) <6899B1CC-7B10-309F-9ECE-8F84463C4061> /Users/USER/Library/Application Support/Blender/*/clamp.cpython-37m-darwin.so 0x12fff2000 - 0x12fff5fff +limits.cpython-37m-darwin.so (0) <1CD28F8F-DF9A-3ADB-AA70-C73DC9A52899> /Users/USER/Library/Application Support/Blender/*/limits.cpython-37m-darwin.so 0x12fffa000 - 0x130002ffb +presets.cpython-37m-darwin.so (0) <637E965F-73D5-3B5E-8D08-8316F5A56CE9> /Users/USER/Library/Application Support/Blender/*/presets.cpython-37m-darwin.so 0x13000a000 - 0x130014fff +shuffle.cpython-37m-darwin.so (0) <01F31611-7CF8-38BA-9AD2-84FA0CA13B70> /Users/USER/Library/Application Support/Blender/*/shuffle.cpython-37m-darwin.so 0x13001e000 - 0x130025ffb +reverse.cpython-37m-darwin.so (0) <FC5488B7-A780-3A1D-860C-FB982B9A99B7> /Users/USER/Library/Application Support/Blender/*/reverse.cpython-37m-darwin.so 0x13002d000 - 0x130039ff3 +repeat.cpython-37m-darwin.so (0) <14B8AF64-FE83-326A-BD54-A046AEA19A6D> /Users/USER/Library/Application Support/Blender/*/repeat.cpython-37m-darwin.so 0x130043000 - 0x13004effb +sample.cpython-37m-darwin.so (0) <A8E084DE-822E-3895-9E5C-71371488114A> /Users/USER/Library/Application Support/Blender/*/sample.cpython-37m-darwin.so 0x130058000 - 0x130064ffb +fill.cpython-37m-darwin.so (0) <21911DD3-1F12-30B9-B221-5DA0626E9833> /Users/USER/Library/Application Support/Blender/*/fill.cpython-37m-darwin.so 0x13006e000 - 0x130077ff7 +mask.cpython-37m-darwin.so (0) <598278F1-199B-37F8-B7B9-D1A68CAD9669> /Users/USER/Library/Application Support/Blender/*/mask.cpython-37m-darwin.so 0x130081000 - 0x13008cffb +repeat_elements.cpython-37m-darwin.so (0) <98592AFE-7A0E-349D-AD2F-DE2062BCE70C> /Users/USER/Library/Application Support/Blender/*/repeat_elements.cpython-37m-darwin.so 0x130096000 - 0x13009dff7 +random.cpython-37m-darwin.so (0) <CE889400-DB99-3F51-8DD4-23223D81E28C> /Users/USER/Library/Application Support/Blender/*/random.cpython-37m-darwin.so 0x1300a5000 - 0x1300aafff +py_interface.cpython-37m-darwin.so (0) <DFD5A320-4401-3BAD-A99A-86C03F939E22> /Users/USER/Library/Application Support/Blender/*/py_interface.cpython-37m-darwin.so 0x1300af000 - 0x1300b7ffb +symbol_string.cpython-37m-darwin.so (0) <5B99B66F-218D-30DD-9767-0D7F260F7814> /Users/USER/Library/Application Support/Blender/*/symbol_string.cpython-37m-darwin.so 0x1300c1000 - 0x1300c9ff3 +apply_rules.cpython-37m-darwin.so (0) <1DC18DD0-D42F-33CE-9EFD-EE58451A6EF3> /Users/USER/Library/Application Support/Blender/*/apply_rules.cpython-37m-darwin.so 0x1300d1000 - 0x1300d9fff +geometry.cpython-37m-darwin.so (0) <C7FBB577-0016-30B6-897C-32C98D63B713> /Users/USER/Library/Application Support/Blender/*/geometry.cpython-37m-darwin.so 0x1300e1000 - 0x1300f1ff7 +parsing.cpython-37m-darwin.so (0) <5BFC15A7-727A-36CC-B158-BEF8C188B5BA> /Users/USER/Library/Application Support/Blender/*/parsing.cpython-37m-darwin.so 0x1300f7000 - 0x1300feffb +translation.cpython-37m-darwin.so (0) <5ED7CB0F-A430-395C-9F6B-1BB258633B6B> /Users/USER/Library/Application Support/Blender/*/translation.cpython-37m-darwin.so 0x130106000 - 0x13010dff3 +rotation.cpython-37m-darwin.so (0) <2EE132CE-40FF-3E44-8995-283027B00F97> /Users/USER/Library/Application Support/Blender/*/rotation.cpython-37m-darwin.so 0x130115000 - 0x13011bffb +scale.cpython-37m-darwin.so (0) <E47DCE2F-D55D-3197-BED9-4DCA4BF4950C> /Users/USER/Library/Application Support/Blender/*/scale.cpython-37m-darwin.so 0x130123000 - 0x13012cff7 +points_scatter.cpython-37m-darwin.so (0) <84BF952F-AB12-3FF9-89C8-ABF93737F82E> /Users/USER/Library/Application Support/Blender/*/points_scatter.cpython-37m-darwin.so 0x130134000 - 0x130137ff7 +splitmix64.cpython-37m-darwin.so (0) <38222BA7-3BE2-3420-96E8-A5482BA04227> /Users/USER/Library/Application Support/Blender/*/splitmix64.cpython-37m-darwin.so 0x13013c000 - 0x13013fffb +xoshiro256starstar.cpython-37m-darwin.so (0) <9893CE02-5BAC-3BA8-85ED-F861097797A5> /Users/USER/Library/Application Support/Blender/*/xoshiro256starstar.cpython-37m-darwin.so 0x130144000 - 0x130147fff +xoshiro256plus.cpython-37m-darwin.so (0) <6B317636-E300-3F92-B9D7-1631E14B689E> /Users/USER/Library/Application Support/Blender/*/xoshiro256plus.cpython-37m-darwin.so 0x13014c000 - 0x130156fff +circle.cpython-37m-darwin.so (0) <E7C8C00A-5450-3992-8466-11836BF32D45> /Users/USER/Library/Application Support/Blender/*/circle.cpython-37m-darwin.so 0x13015f000 - 0x130169ff7 +cylinder.cpython-37m-darwin.so (0) <8CE85044-6069-3AB6-AA62-7DB210195C69> /Users/USER/Library/Application Support/Blender/*/cylinder.cpython-37m-darwin.so 0x130173000 - 0x13017eff7 +find_shortest_path.cpython-37m-darwin.so (0) <1D62A4A4-6FB2-34E3-B5B0-778C6C3887FA> /Users/USER/Library/Application Support/Blender/*/find_shortest_path.cpython-37m-darwin.so 0x130188000 - 0x130190ffb +line.cpython-37m-darwin.so (0) <1BD1401C-8205-3EAF-BB17-C3258F174B8F> /Users/USER/Library/Application Support/Blender/*/line.cpython-37m-darwin.so 0x130198000 - 0x1301aaff3 +grid.cpython-37m-darwin.so (0) <4D6AA531-6D63-384A-A4B6-DA59519C419F> /Users/USER/Library/Application Support/Blender/*/grid.cpython-37m-darwin.so 0x1301b6000 - 0x1301cdff7 +loft.cpython-37m-darwin.so (0) <0EF5929D-6745-32C2-8ADD-15283E62D71C> /Users/USER/Library/Application Support/Blender/*/loft.cpython-37m-darwin.so 0x1301dc000 - 0x1301e7ffb +revolve.cpython-37m-darwin.so (0) <792EA137-5885-35D4-BCB7-ED041B0D2F79> /Users/USER/Library/Application Support/Blender/*/revolve.cpython-37m-darwin.so 0x1301f1000 - 0x1301fcff3 +perlin_noise.cpython-37m-darwin.so (0) <B4857759-8FD5-3D9C-B6D7-7B65CE45535B> /Users/USER/Library/Application Support/Blender/*/perlin_noise.cpython-37m-darwin.so 0x130206000 - 0x130210ff3 +random.cpython-37m-darwin.so (0) <26827144-E41F-3348-9866-87FAE93FEA77> /Users/USER/Library/Application Support/Blender/*/random.cpython-37m-darwin.so 0x130218000 - 0x130222ffb +rotation_and_direction.cpython-37m-darwin.so (0) <F70260CD-D0C7-35E8-BA93-82C7E9143C5B> /Users/USER/Library/Application Support/Blender/*/rotation_and_direction.cpython-37m-darwin.so 0x1302ac000 - 0x1302f9fff +convert.cpython-37m-darwin.so (0) <1AA044E9-6AD9-3F9A-BE45-17E26DDCB35C> /Users/USER/Library/Application Support/Blender/*/convert.cpython-37m-darwin.so 0x13038b000 - 0x130393fff +to_blender.cpython-37m-darwin.so (0) <E303A21F-381D-3E0A-8F0D-A34495EBF190> /Users/USER/Library/Application Support/Blender/*/to_blender.cpython-37m-darwin.so 0x130399000 - 0x13039ffff +c_utils.cpython-37m-darwin.so (0) <A1A77585-F44B-32FA-A87A-E4907236F4ED> /Users/USER/Library/Application Support/Blender/*/c_utils.cpython-37m-darwin.so 0x1303a6000 - 0x1303b1ff3 +mesh_indices.cpython-37m-darwin.so (0) <ED09E056-0756-3179-8E1A-17706E9726D4> /Users/USER/Library/Application Support/Blender/*/mesh_indices.cpython-37m-darwin.so 0x1303fb000 - 0x130516ff3 +wrapper.cpython-37m-darwin.so (0) <3169E079-3A4B-357D-9157-C11977FF0440> /Users/USER/Library/Application Support/Blender/*/wrapper.cpython-37m-darwin.so 0x13052e000 - 0x130530ff3 +color.cpython-37m-darwin.so (0) <EB26D7A6-C2E9-35F5-A41E-0F8C461ACF32> /Users/USER/Library/Application Support/Blender/*/color.cpython-37m-darwin.so 0x130534000 - 0x130536ffb +euler.cpython-37m-darwin.so (0) <5C552C61-[D51](https://archive.blender.org/developer/D51)-3900-AC61-5285FFCD2380> /Users/USER/Library/Application Support/Blender/*/euler.cpython-37m-darwin.so 0x13053a000 - 0x13053cff3 +quaternion.cpython-37m-darwin.so (0) <A563ABD3-CB6C-3CBC-A5EB-817119BE7FBC> /Users/USER/Library/Application Support/Blender/*/quaternion.cpython-37m-darwin.so 0x130540000 - 0x130552ff3 +action_from_object.cpython-37m-darwin.so (0) <8654974E-958D-3BE5-8821-6528AE58DAFE> /Users/USER/Library/Application Support/Blender/*/action_from_object.cpython-37m-darwin.so 0x130560000 - 0x130571fff +chain_actions.cpython-37m-darwin.so (0) <09D55FBB-EF94-375B-837E-35F28A28D4F4> /Users/USER/Library/Application Support/Blender/*/chain_actions.cpython-37m-darwin.so 0x13057f000 - 0x130585ffb +delay_action.cpython-37m-darwin.so (0) <7A7549CF-551C-39F3-B6D6-7D8174F72574> /Users/USER/Library/Application Support/Blender/*/delay_action.cpython-37m-darwin.so 0x13058c000 - 0x130597ff3 +follow_spline_action.cpython-37m-darwin.so (0) <8159E9EF-F134-3477-8DCB-EFC10759081D> /Users/USER/Library/Application Support/Blender/*/follow_spline_action.cpython-37m-darwin.so 0x1305a2000 - 0x1305baff7 +object_action_output.cpython-37m-darwin.so (0) <5AE9B392-8500-3DD0-8D75-37BB00060BE8> /Users/USER/Library/Application Support/Blender/*/object_action_output.cpython-37m-darwin.so 0x13060b000 - 0x13061cff7 +overlay_action.cpython-37m-darwin.so (0) <FF8D6FE5-9A88-3348-8C86-F5C33D8F9D6B> /Users/USER/Library/Application Support/Blender/*/overlay_action.cpython-37m-darwin.so 0x13062a000 - 0x13063dfff +wiggle_action.cpython-37m-darwin.so (0) <52DEA5B4-80AF-3BF3-8CE8-DEF335774CA5> /Users/USER/Library/Application Support/Blender/*/wiggle_action.cpython-37m-darwin.so 0x13064c000 - 0x130653ff7 +c_utils.cpython-37m-darwin.so (0) <20FBF653-1532-3B74-A3EE-6199823394E7> /Users/USER/Library/Application Support/Blender/*/c_utils.cpython-37m-darwin.so 0x13065b000 - 0x13066aff7 +c_utils.cpython-37m-darwin.so (0) <8F62B4EA-8C5D-3958-A9C9-FC33A34F01B0> /Users/USER/Library/Application Support/Blender/*/c_utils.cpython-37m-darwin.so 0x130675000 - 0x13067fff3 +constant_falloff.cpython-37m-darwin.so (0) <3A86C057-51DF-367B-9520-6D7A129781E4> /Users/USER/Library/Application Support/Blender/*/constant_falloff.cpython-37m-darwin.so 0x130689000 - 0x130693fff +custom_falloff.cpython-37m-darwin.so (0) <7EC82DC5-04B3-3055-A83E-F86102D8CF93> /Users/USER/Library/Application Support/Blender/*/custom_falloff.cpython-37m-darwin.so 0x13069e000 - 0x1306a9ff3 +delay_falloff.cpython-37m-darwin.so (0) <513DF90C-B113-3BA7-A151-75986C271991> /Users/USER/Library/Application Support/Blender/*/delay_falloff.cpython-37m-darwin.so 0x1306b4000 - 0x1306beff7 +interpolate_falloff.cpython-37m-darwin.so (0) <C29C8982-B4D2-396F-8AA3-FF12E51B1A54> /Users/USER/Library/Application Support/Blender/*/interpolate_falloff.cpython-37m-darwin.so 0x1306c8000 - 0x1306d5fff +directional_falloff.cpython-37m-darwin.so (0) <D70046A7-689D-3E94-8800-ADC3CE0F5A44> /Users/USER/Library/Application Support/Blender/*/directional_falloff.cpython-37m-darwin.so 0x130722000 - 0x130732ff7 +evaluate_falloff.cpython-37m-darwin.so (0) <3C430908-1CF8-30FA-A142-943FE14556AB> /Users/USER/Library/Application Support/Blender/*/evaluate_falloff.cpython-37m-darwin.so 0x130740000 - 0x130750ff7 +fade_falloff.cpython-37m-darwin.so (0) <6518B1FB-0747-300C-9098-6E3F2CB66520> /Users/USER/Library/Application Support/Blender/*/fade_falloff.cpython-37m-darwin.so 0x13075e000 - 0x13076cff7 +index_mask_falloff.cpython-37m-darwin.so (0) <4FB845FC-985B-3470-9C70-5C7B44B6307B> /Users/USER/Library/Application Support/Blender/*/index_mask_falloff.cpython-37m-darwin.so 0x130779000 - 0x130784ff3 +interpolate_list_falloff.cpython-37m-darwin.so (0) <80F27467-74BE-329F-AE50-0B0524D1D203> /Users/USER/Library/Application Support/Blender/*/interpolate_list_falloff.cpython-37m-darwin.so 0x13078f000 - 0x13079bffb +remap_falloff.cpython-37m-darwin.so (0) <6EEC05DF-A99F-3653-BDFC-D1746D442C27> /Users/USER/Library/Application Support/Blender/*/remap_falloff.cpython-37m-darwin.so 0x1307a7000 - 0x1307b3ffb +mesh_falloff.cpython-37m-darwin.so (0) <216C61B3-AAFF-394F-9256-96E0A3E6E796> /Users/USER/Library/Application Support/Blender/*/mesh_falloff.cpython-37m-darwin.so 0x1307be000 - 0x1307d8ff7 +mix_falloffs.cpython-37m-darwin.so (0) <57220CA9-0F42-3D39-A707-7DEBAAA4615C> /Users/USER/Library/Application Support/Blender/*/mix_falloffs.cpython-37m-darwin.so 0x1307ec000 - 0x1307f7ff7 +noise_falloff.cpython-37m-darwin.so (0) <F2344D45-5725-30D2-8157-6064DA2A53B0> /Users/USER/Library/Application Support/Blender/*/noise_falloff.cpython-37m-darwin.so 0x130803000 - 0x13081effb +object_controller_falloff.cpython-37m-darwin.so (0) <1BC16317-75B8-3977-81C7-CF273CF86AE2> /Users/USER/Library/Application Support/Blender/*/object_controller_falloff.cpython-37m-darwin.so 0x13082e000 - 0x130838ff7 +radial_falloff.cpython-37m-darwin.so (0) <D7570733-CE9B-3098-8F3D-20660391CBD5> /Users/USER/Library/Application Support/Blender/*/radial_falloff.cpython-37m-darwin.so 0x130843000 - 0x13084dff3 +point_distance_falloff.cpython-37m-darwin.so (0) <EBABDDCC-415B-38BF-B016-43B5BE6D514E> /Users/USER/Library/Application Support/Blender/*/point_distance_falloff.cpython-37m-darwin.so 0x130858000 - 0x130862fff +random_falloff.cpython-37m-darwin.so (0) <646419F6-C496-3D0A-8306-16C3EAC5FBB7> /Users/USER/Library/Application Support/Blender/*/random_falloff.cpython-37m-darwin.so 0x13086c000 - 0x13088affb +sound_falloff.cpython-37m-darwin.so (0) <9C12BD2A-0995-3A91-B138-03AF95D7DE0C> /Users/USER/Library/Application Support/Blender/*/sound_falloff.cpython-37m-darwin.so 0x13089e000 - 0x1308b2fff +spline_falloff.cpython-37m-darwin.so (0) <302C603C-44D3-3DB3-85C2-51DC6424C455> /Users/USER/Library/Application Support/Blender/*/spline_falloff.cpython-37m-darwin.so 0x1308c1000 - 0x1308ccffb +wiggle_falloff.cpython-37m-darwin.so (0) <153CF1DA-CE59-383A-8F26-35CE782201EA> /Users/USER/Library/Application Support/Blender/*/wiggle_falloff.cpython-37m-darwin.so 0x1308d7000 - 0x1308e0ff7 +c_utils.cpython-37m-darwin.so (0) <4B71C4BC-A602-36E0-AA82-62D27FCAE36D> /Users/USER/Library/Application Support/Blender/*/c_utils.cpython-37m-darwin.so 0x130928000 - 0x13093affb +c_utils.cpython-37m-darwin.so (0) <70E81877-119F-3BBC-BB63-46986CEE70F6> /Users/USER/Library/Application Support/Blender/*/c_utils.cpython-37m-darwin.so 0x130987000 - 0x130995fff +c_utils.cpython-37m-darwin.so (0) <62A271D2-6145-30C4-B1D0-BEBDF9BB7F80> /Users/USER/Library/Application Support/Blender/*/c_utils.cpython-37m-darwin.so 0x1309a0000 - 0x1309aaffb +c_utils.cpython-37m-darwin.so (0) <7C87D245-15B2-3881-BACB-43D04C26064B> /Users/USER/Library/Application Support/Blender/*/c_utils.cpython-37m-darwin.so 0x130a34000 - 0x130a47ff7 +c_utils.cpython-37m-darwin.so (0) <1617C212-A5FA-34E1-94A9-749DE85CFDEA> /Users/USER/Library/Application Support/Blender/*/c_utils.cpython-37m-darwin.so 0x130a55000 - 0x130a70fff +distribute_matrices.cpython-37m-darwin.so (0) <ECD71D0C-8E05-3C74-99CA-231FBFF4262E> /Users/USER/Library/Application Support/Blender/*/distribute_matrices.cpython-37m-darwin.so 0x130ac4000 - 0x130aecff7 +c_utils.cpython-37m-darwin.so (0) <054BF2CF-F623-37B7-A14C-489BEE7B80E4> /Users/USER/Library/Application Support/Blender/*/c_utils.cpython-37m-darwin.so 0x130b40000 - 0x130b51fff +offset_vector.cpython-37m-darwin.so (0) <8C4BB186-29BB-3303-AC02-AA2D99AFB4CE> /Users/USER/Library/Application Support/Blender/*/offset_vector.cpython-37m-darwin.so 0x130b5f000 - 0x130b81fff +float_math.cpython-37m-darwin.so (0) <EE964595-FAC0-3044-834F-7C700F8BC366> /Users/USER/Library/Application Support/Blender/*/float_math.cpython-37m-darwin.so 0x130bd9000 - 0x130bf2ffb +vector_math.cpython-37m-darwin.so (0) <BA745F6E-3F32-3FDC-9B45-7D7D52C8F9DA> /Users/USER/Library/Application Support/Blender/*/vector_math.cpython-37m-darwin.so 0x130c04000 - 0x130c16ff3 +object_matrix_output.cpython-37m-darwin.so (0) <7BBE9303-91AD-3C17-B0CF-D70AB2BB00D6> /Users/USER/Library/Application Support/Blender/*/object_matrix_output.cpython-37m-darwin.so 0x130c65000 - 0x130c6bff3 +c_utils.cpython-37m-darwin.so (0) <CEA7E3BC-D91A-3465-B3B0-35C8DCE0F7A5> /Users/USER/Library/Application Support/Blender/*/c_utils.cpython-37m-darwin.so 0x130c72000 - 0x130c7cfff +c_utils.cpython-37m-darwin.so (0) <75C3E4CA-8564-385E-A198-0DE9B5516D29> /Users/USER/Library/Application Support/Blender/*/c_utils.cpython-37m-darwin.so 0x130cc6000 - 0x130ccffff +c_utils.cpython-37m-darwin.so (0) <507BC8A6-DAED-3BE1-8381-15E76B302F88> /Users/USER/Library/Application Support/Blender/*/c_utils.cpython-37m-darwin.so 0x130cd7000 - 0x130ce0ffb +splines_from_edges_utils.cpython-37m-darwin.so (0) <6EA76869-9E19-3801-ADA3-2440E5005D2E> /Users/USER/Library/Application Support/Blender/*/splines_from_edges_utils.cpython-37m-darwin.so 0x130da9000 - 0x130daaff3 +_lsprof.cpython-37m-darwin.so (0) <CEAF2FAC-4A24-3963-AA3A-67B30E682A0E> /Applications/Blender.app/Contents/Resources/2.92/python/lib/python3.7/lib-dynload/_lsprof.cpython-37m-darwin.so 0x1316a4000 - 0x1316bbffb com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride (1.0 - 1298.7.1) <1911451B-5BA5-3A08-AB9F-2729A55BDE38> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride 0x7fff20aa1000 - 0x7fff20ceeff8 com.apple.RawCamera.bundle (9.02.0 - 1350.29) <59F81722-039E-33F5-A20E-936E997575A3> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera 0x7fff23950000 - 0x7fff23e5dff7 com.apple.driver.AppleIntelHD5000GraphicsGLDriver (14.7.11 - 14.0.7) <07F632A9-EEC9-3E00-89E6-3F060FDDA5AD> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver 0x7fff23e5e000 - 0x7fff23ef1ffd com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (14.7.11 - 14.0.7) <B03B7BE4-9B2F-3DB5-BB92-5B2BA59E4C0A> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsMTLDriver 0x7fff280b0000 - 0x7fff289bcfff com.apple.GeForceGLDriver (14.0.32 - 14.0.0) <CF1A44F3-384F-3D89-9C05-B8EAC239CA2F> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver 0x7fff289bd000 - 0x7fff29094fff libclh.dylib (14.0.32) <8E599513-C443-3D47-8484-E529BE971893> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib 0x7fff29095000 - 0x7fff29248ff3 com.apple.GeForceMTLDriver (14.0.32 - 14.0.0) <F5B46A69-56CB-3ACB-A749-958C818DD76A> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver 0x7fff29636000 - 0x7fff29636fff com.apple.Accelerate (1.11 - Accelerate 1.11) <4F9977AE-DBDB-3A16-A536-AC1F9938DCDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x7fff29637000 - 0x7fff2964dfef libCGInterfaces.dylib (524.2.1) <8FD09D09-BB19-36C5-ADE9-4F22DA235AEE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib 0x7fff2964e000 - 0x7fff29ca4fff com.apple.vImage (8.1 - 524.2.1) <EA6F5FF2-7A1B-35D5-A5A3-D2B3386ECB75> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x7fff29ca5000 - 0x7fff29f0cff7 libBLAS.dylib (1303.60.1) <C6C2D42F-7456-3DBF-8BE2-9AA06EFC78FD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x7fff29f0d000 - 0x7fff2a3e0fef libBNNS.dylib (144.100.2) <99C61C48-B14C-3DA6-8C31-6BF72DA0A3A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib 0x7fff2a3e1000 - 0x7fff2a77cfff libLAPACK.dylib (1303.60.1) <5E3E3867-50C3-3E6A-9A2E-007CE77A4641> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x7fff2a77d000 - 0x7fff2a792fec libLinearAlgebra.dylib (1303.60.1) <3D433800-0099-33E0-8C81-15F83247B2C9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib 0x7fff2a793000 - 0x7fff2a798ff3 libQuadrature.dylib (7) <371F36A7-B12F-363E-8955-F24F7C2048F6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib 0x7fff2a799000 - 0x7fff2a809fff libSparse.dylib (103) <B8A10D0C-4577-343D-B310-A3E81265D107> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib 0x7fff2a80a000 - 0x7fff2a81cfef libSparseBLAS.dylib (1303.60.1) <B147FEF6-A0DB-3830-BF06-45BEC58DB576> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib 0x7fff2a81d000 - 0x7fff2a9f4fd7 libvDSP.dylib (735.140.1) <D63DC0A5-B8B4-3562-A574-E73BC3B57407> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x7fff2a9f5000 - 0x7fff2aab7fef libvMisc.dylib (735.140.1) <3601FDE3-B142-398D-987D-8151A51F0A96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x7fff2aab8000 - 0x7fff2aab8fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <F6C5613D-2284-342B-9160-9731F78B4DE5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x7fff2aab9000 - 0x7fff2ab18ff0 com.apple.Accounts (113 - 113) <E2438070-30AB-3B89-AE63-1E485B92D108> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts 0x7fff2ac62000 - 0x7fff2ba22ff2 com.apple.AppKit (6.9 - 1894.60.100) <322D043D-1140-3486-9523-3F56FF4D8349> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff2ba72000 - 0x7fff2ba72fff com.apple.ApplicationServices (48 - 50) <20CF59CD-A395-3570-A4DB-589D55C70B3F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x7fff2ba73000 - 0x7fff2badefff com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <87EA5DE1-506A-39FD-88BE-D8A3416C9012> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x7fff2bb77000 - 0x7fff2bbb5ff0 libFontRegistry.dylib (274.0.5.1) <F3461C05-0370-359B-9F03-5C1C1F7763EC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x7fff2bc10000 - 0x7fff2bc3ffff com.apple.ATSUI (1.0 - 1) <5F513967-DDD7-3F22-AD14-8A38ABD9F2D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI 0x7fff2bc40000 - 0x7fff2bc44ffb com.apple.ColorSyncLegacy (4.13.0 - 1) <72EE68DB-F069-37F5-AA2A-40D5FCF139F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy 0x7fff2bcde000 - 0x7fff2bd35ffa com.apple.HIServices (1.22 - 676) <14DF4D42-E24D-3EBD-9A9D-93124D8D6AA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x7fff2bd36000 - 0x7fff2bd44fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <01B8B6B3-E2C3-3607-B34A-8283A7E0E924> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x7fff2bd45000 - 0x7fff2bd8affa com.apple.print.framework.PrintCore (15.4 - 516.2) <437BCF12-48D2-3770-8BC9-567718FB1BCA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x7fff2bd8b000 - 0x7fff2bd95ff7 com.apple.QD (4.0 - 413) <27A36D07-B5E9-32E6-87B6-3127F260F48D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x7fff2bd96000 - 0x7fff2bda3ffc com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <75344F8F-32CA-3558-B4E6-F56D498250E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x7fff2bda4000 - 0x7fff2be85ffa com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <6185BF20-D2E7-3812-8FD8-EC5237672104> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x7fff2be87000 - 0x7fff2be87fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <918ED3EB-0232-31F3-9BF5-18D1CB11523F> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x7fff2c21e000 - 0x7fff2c5adffa com.apple.CFNetwork (1128.0.1 - 1128.0.1) <07F9CA9C-B954-3EA0-A710-3122BFF9F057> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff2c629000 - 0x7fff2c629fff com.apple.Carbon (160 - 162) <6A5EB506-7A43-3879-A358-E6B9182C3733> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x7fff2c62a000 - 0x7fff2c62dff3 com.apple.CommonPanels (1.2.6 - 101) <9F6E13D9-374B-386F-8E15-FDD6CE967859> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x7fff2c62e000 - 0x7fff2c922ff3 com.apple.HIToolbox (2.1.1 - 994.6) <EAF2DAC3-66B1-30BF-AF10-72DDA90D1044> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff2c923000 - 0x7fff2c926ff3 com.apple.help (1.3.8 - 71) <36483951-6F3E-3F7E-8A5B-191C2357EF17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x7fff2c927000 - 0x7fff2c92cff7 com.apple.ImageCapture (9.0 - 1600.65) <1A1F320E-3E85-3F3D-8AE0-B238C4E92D40> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x7fff2c92d000 - 0x7fff2c92dfff com.apple.ink.framework (10.15 - 227) <284507AE-EF47-3ABC-86A4-669243DB1D33> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x7fff2c92e000 - 0x7fff2c948ffa com.apple.openscripting (1.7 - 185.1) <B6E28747-5FC7-3461-8A71-864A969ED022> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x7fff2c969000 - 0x7fff2c969fff com.apple.print.framework.Print (15 - 271) <0D9FB08F-EA87-3BE7-821B-C61BA5601050> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x7fff2c96a000 - 0x7fff2c96cff7 com.apple.securityhi (9.0 - 55008) <390C6FAA-99BF-3924-9180-9EAE41D9C6BE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x7fff2c96d000 - 0x7fff2c973fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <9614A01E-8303-3422-A3BA-6CE27540E09A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x7fff2c974000 - 0x7fff2cb0cffa com.apple.cloudkit.CloudKit (867 - 867) <1B851180-FC00-357F-B6C1-BB0EA7D6D5CA> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit 0x7fff2cb0d000 - 0x7fff2cb0dfff com.apple.Cocoa (6.11 - 23) <85C8B9B4-6F0B-3BD5-8934-C299FE481A44> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x7fff2cb1b000 - 0x7fff2cc11fff com.apple.ColorSync (4.13.0 - 3394.9) <A126406C-DA38-3FFE-8B25-BB9859EFD159> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x7fff2cefc000 - 0x7fff2d405ffb com.apple.audio.CoreAudio (5.0 - 5.0) <47923B12-3D14-328A-9C86-27A3A2A73068> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x7fff2d458000 - 0x7fff2d490fff com.apple.CoreBluetooth (1.0 - 1) <23DBB313-A082-3C08-8E1F-2D31EE4247EF> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth 0x7fff2d491000 - 0x7fff2d87bfe8 com.apple.CoreData (120 - 977.3) <49AE61CA-C91E-31FE-9BD0-1AACFFB5181E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x7fff2d87c000 - 0x7fff2d9aeff6 com.apple.CoreDisplay (1.0 - 186.6.15) <213D7011-8180-3CF4-9BE7-FB8F75DCDB95> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay 0x7fff2d9af000 - 0x7fff2de2efeb com.apple.CoreFoundation (6.9 - 1677.201) <56B0FE5F-[D493](https://archive.blender.org/developer/D493)-3DF1-ABFF-ECC450268B97> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff2de30000 - 0x7fff2e4a5ff8 com.apple.CoreGraphics (2.0 - 1355.22) <4A3CDE7B-4578-3058-966A-3D1DC095A935> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x7fff2e4b3000 - 0x7fff2e80eff0 com.apple.CoreImage (15.0.0 - 940.9) <69361069-01AB-342E-862B-73A74271A765> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage 0x7fff2e80f000 - 0x7fff2e878ff0 com.apple.corelocation (2394.0.22 - 2394.0.22) <75966124-2FB7-33C3-BE49-3DD5F327F911> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation 0x7fff2ebcf000 - 0x7fff2ecaaffc com.apple.CoreMedia (1.0 - 2625.9) <A3FF3AFC-8C1C-36E5-9179-66D8F075EE35> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia 0x7fff2ed97000 - 0x7fff2ed97fff com.apple.CoreServices (1069.24 - 1069.24) <2D1A6C60-DD34-368F-88FF-E39C9FE549A9> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x7fff2ed98000 - 0x7fff2ee1dfff com.apple.AE (838.1 - 838.1) <2E5FD5AE-8A7F-353F-9BD1-0241F3586181> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x7fff2ee1e000 - 0x7fff2f0ffff7 com.apple.CoreServices.CarbonCore (1217 - 1217) <BE379206-99FA-30CD-8391-2708473A633F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x7fff2f100000 - 0x7fff2f14dffd com.apple.DictionaryServices (1.2 - 323.6) <26B70C82-25BC-353A-858F-945B14C803A2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x7fff2f14e000 - 0x7fff2f156ff7 com.apple.CoreServices.FSEvents (1268.100.1 - 1268.100.1) <FC84DB48-A3CE-30F7-A918-B3587731ACC7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents 0x7fff2f157000 - 0x7fff2f391ff6 com.apple.LaunchServices (1069.24 - 1069.24) <9A5359D9-9148-3B18-B868-56A9DA5FB60C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x7fff2f392000 - 0x7fff2f42aff1 com.apple.Metadata (10.7.0 - 2076.7) <0973F7E5-D58C-3574-A3CE-4F12CAC2D4C7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x7fff2f42b000 - 0x7fff2f458fff com.apple.CoreServices.OSServices (1069.24 - 1069.24) <0E4F48AD-402C-3E9D-9CA9-6DD9479B28F9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x7fff2f459000 - 0x7fff2f4c0fff com.apple.SearchKit (1.4.1 - 1.4.1) <2C5E1D85-E8B1-3DC5-91B9-E3EDB48E9369> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x7fff2f4c1000 - 0x7fff2f4e5ff5 com.apple.coreservices.SharedFileList (131.4 - 131.4) <02DE0D56-E371-3EF5-9BC1-FA435451B412> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList 0x7fff2f80a000 - 0x7fff2f9c1ffc com.apple.CoreText (643.1.5.2 - 643.1.5.2) <ADDE38C3-C247-34AD-9903-0276050E242C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText 0x7fff2f9c2000 - 0x7fff2fa06ffb com.apple.CoreVideo (1.8 - 344.3) <5314E70D-325F-3E98-99FC-00FDF520747E> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x7fff2fa07000 - 0x7fff2fa94ffc com.apple.framework.CoreWLAN (13.0 - 1601.2) <6223BFD5-[D451](https://archive.blender.org/developer/D451)-3DE9-90F6-F609AC0B0027> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN 0x7fff2fd2b000 - 0x7fff2fd31fff com.apple.DiskArbitration (2.7 - 2.7) <0BBBB6A6-604D-368B-9943-50B8CE75D51D> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x7fff2ff26000 - 0x7fff30054ff6 com.apple.FileProvider (304.1 - 304.1) <E8BB1D4B-05D6-386C-865C-F8C750CEC308> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider 0x7fff30069000 - 0x7fff3006bff3 com.apple.ForceFeedback (1.0.6 - 1.0.6) <9B324178-4FAA-3686-9E01-634607F38493> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback 0x7fff3006c000 - 0x7fff30431fff com.apple.Foundation (6.9 - 1677.201) <E020DC09-4221-3961-A450-638525789B38> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff3049e000 - 0x7fff304eeff7 com.apple.GSS (4.0 - 2.0) <2F3A67E6-D42A-3CF0-9041-A42C22D46F95> /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x7fff3062b000 - 0x7fff3073fff3 com.apple.Bluetooth (7.0.6 - 7.0.6f8) <C7AF719C-51B4-3727-A947-EB01204272D9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth 0x7fff307a5000 - 0x7fff30849ff3 com.apple.framework.IOKit (2.0.2 - 1726.140.1) <14223387-6F81-3976-8605-4BC2F253A93E> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x7fff3084b000 - 0x7fff3085cffb com.apple.IOSurface (269.11 - 269.11) <BCD744D4-E17E-3C2E-B69C-F69C789892E9> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x7fff308db000 - 0x7fff30a38fee com.apple.ImageIO.framework (3.3.0 - 1976.11.4) <6FC6EE76-F76F-312C-9C67-4B9F0E0B832A> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x7fff30a39000 - 0x7fff30a3cfff libGIF.dylib (1976.11.4) <F57785E7-6FDA-30A1-B926-CD4D727B56DC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x7fff30a3d000 - 0x7fff30af6fe7 libJP2.dylib (1976.11.4) <A6CC541D-37C4-3A90-86B0-2F67B917B4EE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x7fff30af7000 - 0x7fff30b1afe3 libJPEG.dylib (1976.11.4) <37FA33BD-1C78-3FA6-8D35-3F3755462597> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x7fff30d97000 - 0x7fff30db1fef libPng.dylib (1976.11.4) <1AD4B940-5B1F-39A4-873C-9C568AA287B7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x7fff30db2000 - 0x7fff30db3fff libRadiance.dylib (1976.11.4) <868D2C2C-1909-31B1-A0C2-C971F0BE1EC5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x7fff30db4000 - 0x7fff30dfafff libTIFF.dylib (1976.11.4) <1125DCD0-337D-3E01-84F9-106DEEEA5715> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x7fff3235c000 - 0x7fff3236eff3 com.apple.Kerberos (3.0 - 1) <03BB492B-016E-37BF-B020-39C2CF7487FE> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x7fff3236f000 - 0x7fff3236ffff libHeimdalProxy.dylib (77) <0A2905EE-9533-3345-AF9B-AAC71513BDFD> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib 0x7fff32701000 - 0x7fff3270bffb com.apple.MediaAccessibility (1.0 - 125.1) <98065EA1-3484-3A5A-B05C-D2FABED8CEA4> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility 0x7fff327d7000 - 0x7fff32f24ff2 com.apple.MediaToolbox (1.0 - 2625.9) <3A848992-9182-382A-BF7D-5CB9707BE27B> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox 0x7fff32f26000 - 0x7fff32ff0fff com.apple.Metal (212.8 - 212.8) <98C944D6-62C8-355E-90F8-C1CA2429EF24> /System/Library/Frameworks/Metal.framework/Versions/A/Metal 0x7fff3300d000 - 0x7fff3304aff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <7EBAC15D-7837-395D-B405-1E29F7DA68FA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore 0x7fff3304b000 - 0x7fff330d5fe2 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <B424FE0C-6E90-3BFA-A6E7-DD86C735AE90> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage 0x7fff330d6000 - 0x7fff330fbff4 com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <02006D92-E2AB-3892-A96B-37F6520C19BA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix 0x7fff330fc000 - 0x7fff33111ffb com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <CAA5A368-DB71-34F6-AEF9-27A8BC298F53> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray 0x7fff33112000 - 0x7fff33270ffc com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <05612E06-50CB-318F-9F8E-EF4D49FAB3B0> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork 0x7fff33271000 - 0x7fff332c0ff4 com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <B0B591F8-6875-351E-867F-8EB3CD38CD52> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector 0x7fff332c1000 - 0x7fff332c2ff5 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <F2921F9A-3041-3495-878D-64134267B847> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders 0x7fff34350000 - 0x7fff3435cffe com.apple.NetFS (6.0 - 4.0) <4415F027-D36D-3B9C-96BA-AD22B44A4722> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x7fff3435d000 - 0x7fff344b4ff3 com.apple.Network (1.0 - 1) <4A0F3B93-4D23-3E74-9A3D-AD19E9C0E59E> /System/Library/Frameworks/Network.framework/Versions/A/Network 0x7fff344b5000 - 0x7fff34715ffa com.apple.NetworkExtension (1.0 - 1) <3ED35C5A-B170-373E-8277-D4198E408810> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension 0x7fff347a0000 - 0x7fff347c2fff com.apple.audio.OpenAL (1.8 - 1.8) <6D66C5D7-8410-35B7-B06E-3BE56E0A708E> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL 0x7fff36edd000 - 0x7fff36ee5ff7 libcldcpuengine.dylib (2.14) <D20EF7DF-8508-3707-A9B3-B7D8190971F5> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib 0x7fff36ee6000 - 0x7fff36f3efff com.apple.opencl (3.5 - 3.5) <293FE223-9186-320B-81A4-EC8104C38357> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL 0x7fff36f3f000 - 0x7fff36f5bfff com.apple.CFOpenDirectory (10.15 - 220.40.1) <7E6C88EB-3DD9-32B0-81FC-179552834FA9> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x7fff36f5c000 - 0x7fff36f67ffd com.apple.OpenDirectory (10.15 - 220.40.1) <4A92D8D8-A9E5-3A9C-942F-28576F6BCDF5> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x7fff378cd000 - 0x7fff378cffff libCVMSPluginSupport.dylib (17.10.22) <2B6C3C16-3F5F-36A8-8070-2A862B90328B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x7fff378d0000 - 0x7fff378d5fff libCoreFSCache.dylib (176.15) <E9A20E72-B17F-33D6-8894-41934A10B822> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib 0x7fff378d6000 - 0x7fff378dafff libCoreVMClient.dylib (176.15) <018A48BA-1326-3847-8FB5-A7C99322EB87> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x7fff378db000 - 0x7fff378e3ff7 libGFXShared.dylib (17.10.22) <AB47B927-65E3-3924-88BE-0A5BE7906785> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x7fff378e4000 - 0x7fff378eefff libGL.dylib (17.10.22) <FB5E6A75-398E-38EF-8CB2-59F5BFE3034C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x7fff378ef000 - 0x7fff37923ff7 libGLImage.dylib (17.10.22) <9A3FE633-61B8-3CC7-8183-62960109401A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x7fff37924000 - 0x7fff37ab8ff7 libGLProgrammability.dylib (17.10.22) <85815C4E-3376-33DF-9FBB-6512142AB61B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib 0x7fff37ab9000 - 0x7fff37af5fff libGLU.dylib (17.10.22) <D8B4D804-7323-30BC-871C-B7236FFC2FE3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x7fff38531000 - 0x7fff38540ff7 com.apple.opengl (17.10.22 - 17.10.22) <D3C57A32-6BD0-3228-B1C4-0F42A6128A6C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x7fff38541000 - 0x7fff386bafff GLEngine (17.10.22) <B902FF53-A960-3137-99BD-1F9774F9586C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine 0x7fff386bb000 - 0x7fff386e3fff GLRendererFloat (17.10.22) <F3D43FBE-7871-3260-B7C9-9BE260F081CD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat 0x7fff38b9e000 - 0x7fff38ba4ff6 com.apple.PushKit (1.0 - 1) <AD547A25-1A0B-3FA6-8676-82C37F267A4A> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit 0x7fff394fe000 - 0x7fff39781ffb com.apple.QuartzCore (1.11 - 841.4) <FE927B0E-BD49-32CC-8A55-90F553C86C15> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x7fff3a304000 - 0x7fff3a64dff1 com.apple.security (7.0 - 59306.140.5) <B6F8368F-2395-379B-B768-71C53BB1B903> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x7fff3a64e000 - 0x7fff3a6d6ffb com.apple.securityfoundation (6.0 - 55236.60.1) <7C69DF47-4017-3DF2-B55B-712B481654CB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x7fff3a705000 - 0x7fff3a709ff8 com.apple.xpc.ServiceManagement (1.0 - 1) <9B36FD0E-[D280](https://archive.blender.org/developer/D280)-35EB-ABAB-6AC5D7B2118F> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement 0x7fff3b3b5000 - 0x7fff3b42fff7 com.apple.SystemConfiguration (1.19 - 1.19) <84F9B3BB-F7AF-3B7C-8CD0-D3C22D19619F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x7fff3b6af000 - 0x7fff3ba32ff4 com.apple.VideoToolbox (1.0 - 2625.9) <6CF18E28-A7A8-3952-8171-7E4FF4FB37FA> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox 0x7fff3f39f000 - 0x7fff3f464fe7 com.apple.APFS (1412.141.1 - 1412.141.1) <C86A3423-E61C-335A-9D17-0B3CE5BB6467> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS 0x7fff40579000 - 0x7fff4057aff1 com.apple.AggregateDictionary (1.0 - 1) <95A291F5-B69F-3C37-9483-C3B2EBF52AC1> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary 0x7fff40b14000 - 0x7fff40b31ff4 com.apple.AppContainer (4.0 - 448.100.6) <87CEE13C-8585-3EFB-92CD-0852DFF0921B> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer 0x7fff40b86000 - 0x7fff40b94ff7 com.apple.AppSandbox (4.0 - 448.100.6) <0F49AA04-3400-349A-9096-6D4D7ED61027> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox 0x7fff41010000 - 0x7fff41034ffb com.apple.framework.Apple80211 (13.0 - 1610.1) <D94E03E8-4C38-3B2F-8DF4-473ACC5A7D71> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211 0x7fff412f2000 - 0x7fff41301fd7 com.apple.AppleFSCompression (119.100.1 - 1.0) <466ABD77-2E52-36D1-8E39-77AE2CC61611> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression 0x7fff41400000 - 0x7fff4140bff7 com.apple.AppleIDAuthSupport (1.0 - 1) <74F6CD9C-27A7-39C7-A7EB-47E60D2517EB> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport 0x7fff4144d000 - 0x7fff41495ff7 com.apple.AppleJPEG (1.0 - 1) <6DE30A07-C627-319B-A0DE-EB7A832BEB88> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG 0x7fff41858000 - 0x7fff4187effb com.apple.aps.framework (4.0 - 4.0) <3ED300B6-43E3-31DC-B3C6-6A0FF41A2595> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService 0x7fff4187f000 - 0x7fff41883ff7 com.apple.AppleSRP (5.0 - 1) <70C25EA9-F7A7-366C-97C6-EEE7845FFCC3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP 0x7fff41884000 - 0x7fff418a6fff com.apple.applesauce (1.0 - 16.25) <68E0364C-AEA7-3654-A030-136BF3CD92F3> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce 0x7fff41965000 - 0x7fff41968fff com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <67255151-F989-39F0-BC87-0C0BDAE70730> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo 0x7fff41969000 - 0x7fff419b9ff7 com.apple.AppleVAFramework (6.1.2 - 6.1.2) <8E18983B-AF92-3853-8251-A6577A55AC15> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA 0x7fff41a02000 - 0x7fff41a11ff9 com.apple.AssertionServices (1.0 - 223.140.2) <48AD21CA-B81D-380E-A04F-90C48FDA5203> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices 0x7fff41f54000 - 0x7fff4234fff8 com.apple.audio.AudioResourceArbitration (1.0 - 1) <2BD68521-C19C-3D67-B5EB-DE3E9A4DAF0A> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration 0x7fff4248e000 - 0x7fff424dfff9 com.apple.audio.AudioSession (1.0 - 17) <AB93CA04-083D-3D80-9C33-28B30BA7A525> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession 0x7fff424e0000 - 0x7fff4250dff7 libSessionUtility.dylib (17) <54A1C204-FCBA-3106-A896-28F22ECF144E> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib 0x7fff425a5000 - 0x7fff427e5fe8 com.apple.audio.AudioToolboxCore (1.0 - 1104.95) <9DB96FE2-AE60-32AE-B706-546E25BAE53F> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore 0x7fff427e9000 - 0x7fff42905fff com.apple.AuthKit (1.0 - 1) <DC1A27C5-0172-3C72-9B24-06996D0B6207> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit 0x7fff42ac2000 - 0x7fff42acbff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <A6877DAD-8F47-363C-983A-DC8DDE83B7B5> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement 0x7fff42acc000 - 0x7fff42b6dff5 com.apple.backup.framework (1.11.7 - 1298.7.1) <C9DC35FA-E69F-3C64-9519-494126096337> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup 0x7fff42b6e000 - 0x7fff42bfaff6 com.apple.BaseBoard (466.3 - 466.3) <10D0F3BB-E8F3-365E-8528-6AC996A9B0E7> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard 0x7fff42cfc000 - 0x7fff42d38ff7 com.apple.bom (14.0 - 219.2) <79CBE5E7-054F-377B-9566-A86A9F120CF1> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom 0x7fff42e56000 - 0x7fff42e8dff5 com.apple.C2 (1.3 - 495) <4A7E2A63-E19A-3936-92F5-03F2FD602172> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2 0x7fff438b8000 - 0x7fff43907fff com.apple.ChunkingLibrary (307 - 307) <5B09C30D-FD2B-3E98-8B64-C5EF470FC13C> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary 0x7fff43a62000 - 0x7fff43aedff8 com.apple.CloudDocs (1.0 - 698.17) <900567ED-DEA4-30D5-A1C0-78BD53C58CD6> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs 0x7fff447b4000 - 0x7fff447c4ffb com.apple.CommonAuth (4.0 - 2.0) <CF67FF34-4238-3ECA-B4A4-EA04F18A0D36> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth 0x7fff447d8000 - 0x7fff447effff com.apple.commonutilities (8.0 - 900) <F4C97244-E5D8-3F7D-8D94-4B6841C5A4EC> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities 0x7fff44ef6000 - 0x7fff452cbfc8 com.apple.CoreAUC (283.0.0 - 283.0.0) <4341271C-[D270](https://archive.blender.org/developer/D270)-3F9F-8464-31A20D15158D> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC 0x7fff452cc000 - 0x7fff452f9ff7 com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <C3CFDC68-C7D9-3C44-9E7C-801D45575C10> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD 0x7fff4531c000 - 0x7fff4533dff4 com.apple.analyticsd (1.0 - 1) <2162671C-D49D-3891-AB69-9EEB1FA47DD8> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics 0x7fff45648000 - 0x7fff45653ff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <BB7D67B1-2102-3D71-9BB6-AEB8C6A6EBB2> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon 0x7fff458d4000 - 0x7fff458e4ff3 com.apple.CoreEmoji (1.0 - 107.1) <7C2B3259-083B-31B8-BCDB-1BA360529936> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji 0x7fff45f24000 - 0x7fff45f8eff0 com.apple.CoreNLP (1.0 - 213) <E70E2505-8078-324E-BAE1-01A2DA980E2C> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP 0x7fff463bc000 - 0x7fff463c4ff8 com.apple.CorePhoneNumbers (1.0 - 1) <E4DAD514-0B3B-3E0B-8AEA-39B320FAAF03> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers 0x7fff46db1000 - 0x7fff46dd4fff com.apple.CoreSVG (1.0 - 129.3) <F38189F9-C8F9-3D62-9D5F-3F520FB81724> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG 0x7fff46dd5000 - 0x7fff46e08fff com.apple.CoreServicesInternal (446.7 - 446.7) <65F53A22-6B61-382C-AAC2-B2C53F8FFB44> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal 0x7fff46e09000 - 0x7fff46e37ffd com.apple.CSStore (1069.24 - 1069.24) <C2D67667-FA0B-3DB6-AA34-6999EE4346A0> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore 0x7fff4735c000 - 0x7fff473f2ff7 com.apple.CoreSymbolication (11.4 - 64535.33.2) <0B3BF87A-7F95-3D79-B4F8-421D6FAC4A6C> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication 0x7fff4748a000 - 0x7fff475b6ff6 com.apple.coreui (2.1 - 609.4) <788818B7-7EBC-316D-9464-D12E365E3791> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI 0x7fff475b7000 - 0x7fff47770ffa com.apple.CoreUtils (6.2.4 - 624.7) <A74A1C65-6695-3F57-B703-0DEDE13E66C1> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils 0x7fff478aa000 - 0x7fff478bdff1 com.apple.CrashReporterSupport (10.13 - 15016) <ADF138F0-0274-3BA2-A1D2-48B91577FE53> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport 0x7fff47976000 - 0x7fff47988ff8 com.apple.framework.DFRFoundation (1.0 - 252.50.1) <8162057E-E856-3451-9160-04AEDDECFFA4> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation 0x7fff47989000 - 0x7fff4798efff com.apple.DSExternalDisplay (3.1 - 380) <31ECB5FD-7660-33DB-BC5B-2B2A2AA7C686> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay 0x7fff47a18000 - 0x7fff47a92ff0 com.apple.datadetectorscore (8.0 - 659) <B1534796-1000-3520-A641-A97A4AC5D39B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore 0x7fff47ade000 - 0x7fff47b1bff8 com.apple.DebugSymbols (194 - 194) <040AE30B-CF2C-3798-A289-0929B8CAB10D> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols 0x7fff47b1c000 - 0x7fff47ca4ff6 com.apple.desktopservices (1.14.6 - 1281.6.1) <C2355E6B-C5F7-3E39-B778-B117BD4652C6> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x7fff4819c000 - 0x7fff481d1ff7 com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) <D3F76E01-2F9F-33E1-B5C9-CAC6E01724C2> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X 0x7fff49665000 - 0x7fff49a80ff1 com.apple.vision.FaceCore (4.3.0 - 4.3.0) <5D32F65D-2CD7-3204-975C-F4C9256E505F> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore 0x7fff4a0d8000 - 0x7fff4a0d8fff com.apple.FinderSyncPriv (1.0.7 - 1298.7.1) <5E08FCCF-B5AA-367F-BD08-DEFD32AB073F> /System/Library/PrivateFrameworks/FinderSyncPriv.framework/Versions/A/FinderSyncPriv 0x7fff4a11f000 - 0x7fff4a256ff4 libFontParser.dylib (277.2.6.3) <D93AD0C8-4657-3A3B-87EB-3DF3D522C70C> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib 0x7fff4a257000 - 0x7fff4a28bfff libTrueTypeScaler.dylib (277.2.6.3) <93039A1A-4946-3166-88B6-82EDD1649C3D> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib 0x7fff4a2ef000 - 0x7fff4a2ffff6 libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <C4B38245-337D-3553-9669-75E5D90071AE> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib 0x7fff4d7e0000 - 0x7fff4d7e1fff libmetal_timestamp.dylib (902.14.11) <C29C7125-A894-3718-8E1D-249C53BCC0B8> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib 0x7fff4ee8f000 - 0x7fff4ee9aff7 libGPUSupportMercury.dylib (17.10.22) <398D9635-B9CB-3BBB-A1E4-D1D1270D3F99> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib 0x7fff4ee9b000 - 0x7fff4eea1fff com.apple.GPUWrangler (5.2.7 - 5.2.7) <FA34760B-4E5C-3A18-A6C3-DBA68F9D1220> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler 0x7fff4f1c0000 - 0x7fff4f1e6ff1 com.apple.GenerationalStorage (2.0 - 314) <54483E50-20BB-3AF8-900F-992320C109B0> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage 0x7fff4f1ff000 - 0x7fff501e8ff1 com.apple.GeoServices (1.0 - 1624.26.4.26.9) <F735575F-7DEF-3202-9151-589BEB162596> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices 0x7fff50314000 - 0x7fff50322ffb com.apple.GraphVisualizer (1.0 - 100.1) <507D5812-9CB4-3C94-938C-59ED2B370818> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer 0x7fff504c1000 - 0x7fff5057fff4 com.apple.Heimdal (4.0 - 2.0) <B86FE9DB-71BB-3B6E-A4AE-2B0B44570A7F> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0x7fff5270b000 - 0x7fff52713ff5 com.apple.IOAccelerator (438.7.3 - 438.7.3) <06E3E70B-C0D0-39A2-96B7-12ED6A0EBEE7> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator 0x7fff52720000 - 0x7fff52737fff com.apple.IOPresentment (47.10 - 37) <32F1B3BC-4644-3982-AAB2-8EB5D5FF0161> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment 0x7fff52abf000 - 0x7fff52b0aff1 com.apple.IconServices (438.3 - 438.3) <0DADB4C3-46FF-3FDB-8A86-51E2067FC7F4> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices 0x7fff52cc8000 - 0x7fff52ccfff9 com.apple.InternationalSupport (1.0 - 45.4) <8D8D4A7D-FD35-36B8-A456-7C93030EDAB3> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport 0x7fff52f5c000 - 0x7fff52f7bffd com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <6F655A32-F963-3A7E-B475-E460F4AC7D99> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle 0x7fff530b0000 - 0x7fff5317effd com.apple.LanguageModeling (1.0 - 215.1) <C456087D-5B3A-390E-A665-862FA284C59C> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling 0x7fff5317f000 - 0x7fff531c7fff com.apple.Lexicon-framework (1.0 - 72) <41F208B9-8255-3EC7-9673-FE0925D071D3> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon 0x7fff531ce000 - 0x7fff531d3ff3 com.apple.LinguisticData (1.0 - 353.18) <3B92F249-4602-325F-984B-D2DE61EEE4E1> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData 0x7fff531fa000 - 0x7fff5321effe com.apple.locationsupport (2394.0.22 - 2394.0.22) <CA6C86FD-051A-31BB-B3AF-3D02D6FD94B6> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport 0x7fff53a6c000 - 0x7fff53a6ffff com.apple.Mangrove (1.0 - 25) <482F300F-9B70-351F-A4DF-B440EEF7368D> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove 0x7fff53cd8000 - 0x7fff53d62ff8 com.apple.MediaExperience (1.0 - 1) <0203AF27-AB5E-32FA-B529-AB7F29EEB887> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience 0x7fff5453c000 - 0x7fff54588fff com.apple.spotlight.metadata.utilities (1.0 - 2076.7) <0237323B-EC78-3FBF-9FC7-5A1FE2B5CE25> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities 0x7fff54589000 - 0x7fff5465affa com.apple.gpusw.MetalTools (1.0 - 1) <99876E08-37D7-3828-8796-56D90C9AFBDB> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools 0x7fff546b8000 - 0x7fff546d1ff4 com.apple.MobileAssets (1.0 - 619.120.1) <07E116E6-7EBC-39F2-B5B4-31BAB6BAF852> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset 0x7fff5488e000 - 0x7fff548acfff com.apple.MobileKeyBag (2.0 - 1.0) <D5FA7041-297F-3ADC-8C7A-6EAAAB82EB68> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag 0x7fff54b0f000 - 0x7fff54b3fff7 com.apple.MultitouchSupport.framework (3440.1 - 3440.1) <6794E1C8-9627-33DF-84F4-FDD02C97F383> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0x7fff5503f000 - 0x7fff55049fff com.apple.NetAuth (6.2 - 6.2) <B0C03C41-87A3-352B-B130-96E1A6F94B47> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0x7fff55a55000 - 0x7fff55aa0ffb com.apple.OTSVG (1.0 - 643.1.5.2) <AD1D4601-05DE-37A7-AD7E-FCF46BF9981D> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG 0x7fff56cbd000 - 0x7fff56cc8ff2 com.apple.PerformanceAnalysis (1.243.2 - 243.2) <B47C00E5-ECC2-313D-93D4-DBDF562C48EF> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis 0x7fff56cc9000 - 0x7fff56cf1ffb com.apple.persistentconnection (1.0 - 1.0) <5B2D87A8-2641-3F6D-ACEA-96B00F85AAB5> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection 0x7fff587c7000 - 0x7fff587daffc com.apple.PowerLog (1.0 - 1) <FAD6E2DC-8C9D-38A0-9CB1-75F48473A3E2> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog 0x7fff59656000 - 0x7fff596b0ff6 com.apple.ProtectedCloudStorage (1.0 - 1) <6F271388-3817-336D-9B96-08C7AAC4BA39> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage 0x7fff596b1000 - 0x7fff596caffb com.apple.ProtocolBuffer (1 - 274.24.9.16.3) <5A020941-C43C-303E-8DE8-230FC6A84DBC> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer 0x7fff59b2a000 - 0x7fff59b53ff1 com.apple.RemoteViewServices (2.0 - 148) <D3AAC2BE-3423-3F18-9654-E35F1DD8DDB3> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices 0x7fff59cb8000 - 0x7fff59cf3ff0 com.apple.RunningBoardServices (1.0 - 223.140.2) <96BB04BD-D6E0-3D70-8F36-89B46DA1DA30> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices 0x7fff5b5d4000 - 0x7fff5b5d7ff5 com.apple.SecCodeWrapper (4.0 - 448.100.6) <C4BF691D-A09E-37E8-A6CC-1145B79B8722> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper 0x7fff5b74a000 - 0x7fff5b871fff com.apple.Sharing (1526.37 - 1526.37) <CBDA0ADD-F1E7-3B06-9118-C5E183F0D3D6> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing 0x7fff5cc86000 - 0x7fff5cf7cff7 com.apple.SkyLight (1.600.0 - 451.4) <A24929C3-95E6-35A7-9654-46FF3F4D1E80> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight 0x7fff5d7c9000 - 0x7fff5d7d7ffb com.apple.SpeechRecognitionCore (6.0.91.2 - 6.0.91.2) <4D6CAC2A-151B-3BBE-BDB7-E2BE72128691> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore 0x7fff5d899000 - 0x7fff5db25ffe com.apple.spotlight.index (10.7.0 - 2076.7) <932C7705-353B-395F-9A23-09D62EAFAD81> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex 0x7fff5deb3000 - 0x7fff5def4ff9 com.apple.StreamingZip (1.0 - 1) <72CA32F8-4C96-3264-A655-623329EB3A28> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip 0x7fff5e00b000 - 0x7fff5e014ff7 com.apple.SymptomDiagnosticReporter (1.0 - 1238.120.2) <C3D66901-7E31-3FDB-BD7A-441EB0520D1D> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter 0x7fff5e2cb000 - 0x7fff5e2dbff3 com.apple.TCC (1.0 - 1) <C9EB52E3-099B-3597-9623-067C403FA525> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC 0x7fff5e800000 - 0x7fff5e8c6ff0 com.apple.TextureIO (3.10.9 - 3.10.9) <EEDAB753-329A-396A-8119-5BEDF7DB5A56> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO 0x7fff5ea96000 - 0x7fff5eceeff0 com.apple.UIFoundation (1.0 - 662) <EC55B9E5-7E62-380A-9AB1-FC7BEF663653> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation 0x7fff5f964000 - 0x7fff5f984ffc com.apple.UserManagement (1.0 - 1) <9F00880E-6EA6-3684-B208-455E14EC07C8> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement 0x7fff60730000 - 0x7fff6081bff2 com.apple.ViewBridge (467 - 467) <09E8FFB8-4DA1-3E80-8E19-927A2D987BF9> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge 0x7fff609c1000 - 0x7fff609c2fff com.apple.WatchdogClient.framework (1.0 - 67.120.2) <FFA17DA1-F6DD-34D3-A708-1F73C8BA7EA7> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient 0x7fff615f2000 - 0x7fff615f5ffa com.apple.dt.XCTTargetBootstrap (1.0 - 16091) <D459D628-58C5-39A6-B7E8-B691CBEECEC1> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap 0x7fff6166f000 - 0x7fff6167dff5 com.apple.audio.caulk (1.0 - 32.3) <06D695EA-E2BC-31E4-9816-9C12542BA744> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk 0x7fff619bf000 - 0x7fff619c1ff3 com.apple.loginsupport (1.0 - 1) <12F77885-27DC-3837-9CE9-A25EBA75F833> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport 0x7fff619c2000 - 0x7fff619d5ffd com.apple.login (3.0 - 3.0) <C68367BA-2225-31DD-B2D8-16AC0A44421F> /System/Library/PrivateFrameworks/login.framework/Versions/A/login 0x7fff644a5000 - 0x7fff644d8ffa libAudioToolboxUtility.dylib (1104.95) <E534364D-5E5F-37BA-9FB6-FFFF1416820C> /usr/lib/libAudioToolboxUtility.dylib 0x7fff644df000 - 0x7fff64513fff libCRFSuite.dylib (48) <5E5DE3CB-30DD-34DC-AEF8-FE8536A85E96> /usr/lib/libCRFSuite.dylib 0x7fff64516000 - 0x7fff64520fff libChineseTokenizer.dylib (34) <7F0DA183-1796-315A-B44A-2C234C7C50BE> /usr/lib/libChineseTokenizer.dylib 0x7fff645ac000 - 0x7fff645aeff7 libDiagnosticMessagesClient.dylib (112) <C94F3B7B-1854-38EB-9778-834501C53B3F> /usr/lib/libDiagnosticMessagesClient.dylib 0x7fff645f4000 - 0x7fff647abffb libFosl_dynamic.dylib (100.4) <737573B2-190A-3BA1-8220-807AD0A2CE5E> /usr/lib/libFosl_dynamic.dylib 0x7fff647d2000 - 0x7fff647d8ff3 libIOReport.dylib (54) <75D177C4-BAD7-3285-B8E1-3019F49B3178> /usr/lib/libIOReport.dylib 0x7fff648ba000 - 0x7fff648c1fff libMatch.1.dylib (36) <5C6F3971-9D9E-3630-BDB6-60BFC5A665E0> /usr/lib/libMatch.1.dylib 0x7fff648f0000 - 0x7fff64910ff7 libMobileGestalt.dylib (826.140.5) <2BE94E6A-FA61-312F-84A1-F764D71B7E39> /usr/lib/libMobileGestalt.dylib 0x7fff64a82000 - 0x7fff64a83fff libSystem.B.dylib (1281.100.1) <8E6AD412-91E7-36FC-A6FD-C13B06A4952A> /usr/lib/libSystem.B.dylib 0x7fff64b10000 - 0x7fff64b11fff libThaiTokenizer.dylib (3) <4F4ADE99-0D09-3223-B7C0-C407AB6DE8DC> /usr/lib/libThaiTokenizer.dylib 0x7fff64b29000 - 0x7fff64b3ffff libapple_nghttp2.dylib (1.39.2) <07FEC48A-87CF-32A3-8194-FA70B361713A> /usr/lib/libapple_nghttp2.dylib 0x7fff64b74000 - 0x7fff64be6ff7 libarchive.2.dylib (72.140.2) <F9EA2883-5D5C-3FA6-B3F8-C5031BF88ABD> /usr/lib/libarchive.2.dylib 0x7fff64be7000 - 0x7fff64c80fe5 libate.dylib (3.0.1) <76EA60FB-748C-313F-8951-B076540BEA97> /usr/lib/libate.dylib 0x7fff64c84000 - 0x7fff64c84ff3 libauto.dylib (187) <B6124448-7690-34AE-8939-ED84AAC630CE> /usr/lib/libauto.dylib 0x7fff64d4a000 - 0x7fff64d5affb libbsm.0.dylib (60.100.1) <00BFFB9A-2FFE-3C24-896A-251BC61917FD> /usr/lib/libbsm.0.dylib 0x7fff64d5b000 - 0x7fff64d67fff libbz2.1.0.dylib (44) <14CC4988-B6D4-3879-AFC2-9A0DDC6388DE> /usr/lib/libbz2.1.0.dylib 0x7fff64d68000 - 0x7fff64dbafff libc++.1.dylib (902.1) <59A8239F-C28A-3B59-B8FA-11340DC85EDC> /usr/lib/libc++.1.dylib 0x7fff64dbb000 - 0x7fff64dd0ffb libc++abi.dylib (902) <E692F14F-C65E-303B-9921-BB7E97D77855> /usr/lib/libc++abi.dylib 0x7fff64dd1000 - 0x7fff64dd1fff libcharset.1.dylib (59) <72447768-9244-39AB-8E79-2FA14EC0AD33> /usr/lib/libcharset.1.dylib 0x7fff64dd2000 - 0x7fff64de3fff libcmph.dylib (8) <E72A20DB-2E86-378D-A237-EB9A1370F989> /usr/lib/libcmph.dylib 0x7fff64de4000 - 0x7fff64dfbfd7 libcompression.dylib (87) <64C91066-586D-38C0-A2F3-3E60A940F859> /usr/lib/libcompression.dylib 0x7fff650d5000 - 0x7fff650ebff7 libcoretls.dylib (167) <770A5B96-936E-34E3-B006-B1CEC299B5A5> /usr/lib/libcoretls.dylib 0x7fff650ec000 - 0x7fff650edfff libcoretls_cfhelpers.dylib (167) <940BF370-FD0C-30A8-AA05-FF48DA44FA4C> /usr/lib/libcoretls_cfhelpers.dylib 0x7fff656aa000 - 0x7fff65709ff7 libcups.2.dylib (483.7) <821ED293-B7B3-3B37-88C9-7B6CA91DA7FA> /usr/lib/libcups.2.dylib 0x7fff65813000 - 0x7fff65813fff libenergytrace.dylib (21) <162DFCC0-8F48-3DD0-914F-FA8653E27B26> /usr/lib/libenergytrace.dylib 0x7fff65814000 - 0x7fff6582cfff libexpat.1.dylib (19.60.2) <FED7C38B-92D8-342D-AED7-871B12D1F7E7> /usr/lib/libexpat.1.dylib 0x7fff6583a000 - 0x7fff6583cfff libfakelink.dylib (149.1) <36146CB2-E6A5-37BB-9EE8-1B4034D8F3AD> /usr/lib/libfakelink.dylib 0x7fff6584b000 - 0x7fff65850fff libgermantok.dylib (24) <D2AE5AC0-EDCE-3216-B8C9-CF59292A545F> /usr/lib/libgermantok.dylib 0x7fff65851000 - 0x7fff6585aff7 libheimdal-asn1.dylib (564.140.1) <0AC6FB62-2B0F-3E93-A931-E4DC4B1D757A> /usr/lib/libheimdal-asn1.dylib 0x7fff6585b000 - 0x7fff6594bfff libiconv.2.dylib (59) <18311A67-E4EF-3CC7-95B3-C0EDEE3A282F> /usr/lib/libiconv.2.dylib 0x7fff6594c000 - 0x7fff65ba3fff libicucore.A.dylib (64260.0.1) <8AC2CB07-E7E0-340D-A849-186FA1F27251> /usr/lib/libicucore.A.dylib 0x7fff65bbb000 - 0x7fff65bbcfff liblangid.dylib (133) <30CFC08C-EF36-3CF5-8AEA-C1CB070306B7> /usr/lib/liblangid.dylib 0x7fff65bbd000 - 0x7fff65bd5ff3 liblzma.5.dylib (16) <C131EF18-2CDD-3271-8A30-A8760D4FE166> /usr/lib/liblzma.5.dylib 0x7fff65bed000 - 0x7fff65c94ff7 libmecab.dylib (883.11) <0D5BFD01-D4A7-3C8D-AA69-C329C1A69792> /usr/lib/libmecab.dylib 0x7fff65c95000 - 0x7fff65ef7ff1 libmecabra.dylib (883.11) <E31DE74D-1B88-377F-ACD3-D789D29C3AE7> /usr/lib/libmecabra.dylib 0x7fff66264000 - 0x7fff66293fff libncurses.5.4.dylib (57) <995DFEEA-40F3-377F-B73D-D02AC59D591F> /usr/lib/libncurses.5.4.dylib 0x7fff663c3000 - 0x7fff6683fff5 libnetwork.dylib (1880.120.4) <BA294A54-F309-398D-B308-F97032AFF555> /usr/lib/libnetwork.dylib 0x7fff66840000 - 0x7fff66857fff libnetworkextension.dylib (1095.140.2) <D0E8454C-33A9-3F96-B3A0-EDB12C32283A> /usr/lib/libnetworkextension.dylib 0x7fff668e0000 - 0x7fff66913fde libobjc.A.dylib (787.1) <6DF81160-5E7F-3E31-AA1E-C875E3B98AF6> /usr/lib/libobjc.A.dylib 0x7fff66926000 - 0x7fff6692afff libpam.2.dylib (25.100.1) <0502F395-8EE6-3D2A-9239-06FD5622E19E> /usr/lib/libpam.2.dylib 0x7fff6692d000 - 0x7fff66963ff7 libpcap.A.dylib (89.120.1) <A76EC076-A8EA-354C-B95F-7AB1EAFBCC65> /usr/lib/libpcap.A.dylib 0x7fff669e7000 - 0x7fff669fffff libresolv.9.dylib (67.40.1) <C57EDFEF-D36A-310B-8D14-8C68A625B1E8> /usr/lib/libresolv.9.dylib 0x7fff66a01000 - 0x7fff66a45ff7 libsandbox.1.dylib (1217.141.2) <E8BA5E84-66AF-3995-8F8E-DDC93B0A88E1> /usr/lib/libsandbox.1.dylib 0x7fff66a59000 - 0x7fff66a5aff7 libspindump.dylib (281.3) <AE8C1AE9-5CBC-332F-BBE8-370A2A19FED6> /usr/lib/libspindump.dylib 0x7fff66a5b000 - 0x7fff66c45ff7 libsqlite3.dylib (308.5) <35A2BD9F-4E33-30DE-A994-4AB585AC3AFE> /usr/lib/libsqlite3.dylib 0x7fff66e96000 - 0x7fff66e99ffb libutil.dylib (57) <F01467F6-23A7-37EE-A170-33CE1577B41D> /usr/lib/libutil.dylib 0x7fff66e9a000 - 0x7fff66ea7ff7 libxar.1.dylib (425.2) <EE964412-9E25-30B3-BCC0-CCEFBCC8094B> /usr/lib/libxar.1.dylib 0x7fff66ead000 - 0x7fff66f8ffff libxml2.2.dylib (33.7) <20567881-7204-3C11-9179-50FE34B3301B> /usr/lib/libxml2.2.dylib 0x7fff66f93000 - 0x7fff66fbbfff libxslt.1.dylib (16.9) <34A45627-DA5B-37D2-9609-65B425E0010A> /usr/lib/libxslt.1.dylib 0x7fff66fbc000 - 0x7fff66fceff3 libz.1.dylib (76) <793D9643-CD83-3AAC-8B96-88D548FAB620> /usr/lib/libz.1.dylib 0x7fff6787d000 - 0x7fff67882ff3 libcache.dylib (83) <AF488D13-9E89-35E0-B078-BE37CC5B8586> /usr/lib/system/libcache.dylib 0x7fff67883000 - 0x7fff6788efff libcommonCrypto.dylib (60165.120.1) <C7912BE5-993E-3581-B2A0-6AABDC8C5562> /usr/lib/system/libcommonCrypto.dylib 0x7fff6788f000 - 0x7fff67896fff libcompiler_rt.dylib (101.2) <49B8F644-5705-3F16-BBE0-6FFF9B17C36E> /usr/lib/system/libcompiler_rt.dylib 0x7fff67897000 - 0x7fff678a0ff7 libcopyfile.dylib (166.40.1) <3C481225-21E7-370A-A30E-0CCFDD64A92C> /usr/lib/system/libcopyfile.dylib 0x7fff678a1000 - 0x7fff67933fdb libcorecrypto.dylib (866.140.1) <60567BF8-80FA-359A-B2F3-A3BAEFB288FD> /usr/lib/system/libcorecrypto.dylib 0x7fff67a40000 - 0x7fff67a80ff0 libdispatch.dylib (1173.100.2) <CD9C059C-91D9-30E8-8926-5B9CD0D5D4F5> /usr/lib/system/libdispatch.dylib 0x7fff67a81000 - 0x7fff67ab7fff libdyld.dylib (750.6) <789A18C2-8AC7-3C88-813D-CD674376585D> /usr/lib/system/libdyld.dylib 0x7fff67ab8000 - 0x7fff67ab8ffb libkeymgr.dylib (30) <DB3337BE-01CA-3425-BD0C-87774FC0CDC0> /usr/lib/system/libkeymgr.dylib 0x7fff67ab9000 - 0x7fff67ac5ff3 libkxld.dylib (6153.141.10) <11EABEB3-CD17-3787-86BE-B8B21817E89B> /usr/lib/system/libkxld.dylib 0x7fff67ac6000 - 0x7fff67ac6ff7 liblaunch.dylib (1738.140.2) <7200E214-9B4D-3B22-9844-4C7892FC890B> /usr/lib/system/liblaunch.dylib 0x7fff67ac7000 - 0x7fff67accff7 libmacho.dylib (959.0.1) <AA613A9C-961A-3B67-B696-4622FA59FC4E> /usr/lib/system/libmacho.dylib 0x7fff67acd000 - 0x7fff67acfff3 libquarantine.dylib (110.40.3) <F234E51D-FD0B-3EE4-B679-AE3EE9C536C3> /usr/lib/system/libquarantine.dylib 0x7fff67ad0000 - 0x7fff67ad1ff7 libremovefile.dylib (48) <7C7EFC79-BD24-33EF-B073-06AED234593E> /usr/lib/system/libremovefile.dylib 0x7fff67ad2000 - 0x7fff67ae9ff3 libsystem_asl.dylib (377.60.2) <1563EE02-0657-3B78-99BE-A947C24122EF> /usr/lib/system/libsystem_asl.dylib 0x7fff67aea000 - 0x7fff67aeaff7 libsystem_blocks.dylib (74) <0D53847E-AF5F-3ACF-B51F-A15DEA4DEC58> /usr/lib/system/libsystem_blocks.dylib 0x7fff67aeb000 - 0x7fff67b72fff libsystem_c.dylib (1353.100.2) <BBDED5E6-A646-3EED-B33A-91E4331EA063> /usr/lib/system/libsystem_c.dylib 0x7fff67b73000 - 0x7fff67b76ffb libsystem_configuration.dylib (1061.141.1) <0EE84C33-64FD-372B-974A-AF7A136F2068> /usr/lib/system/libsystem_configuration.dylib 0x7fff67b77000 - 0x7fff67b7afff libsystem_coreservices.dylib (114) <A199156E-058D-3ABB-BCE9-4B9F20DCED0F> /usr/lib/system/libsystem_coreservices.dylib 0x7fff67b7b000 - 0x7fff67b83fff libsystem_darwin.dylib (1353.100.2) <5B12B5DB-3F30-37C1-8ECC-49A66B1F2864> /usr/lib/system/libsystem_darwin.dylib 0x7fff67b84000 - 0x7fff67b8bfff libsystem_dnssd.dylib (1096.100.3) <EBB4C2C2-E031-3094-B40A-E67BF261D295> /usr/lib/system/libsystem_dnssd.dylib 0x7fff67b8c000 - 0x7fff67b8dffb libsystem_featureflags.dylib (17) <29FD922A-EC2C-3F25-BCCC-B58D716E60EC> /usr/lib/system/libsystem_featureflags.dylib 0x7fff67b8e000 - 0x7fff67bdbff7 libsystem_info.dylib (538) <8A321605-5480-330B-AF9E-64E65DE61747> /usr/lib/system/libsystem_info.dylib 0x7fff67bdc000 - 0x7fff67c08ff7 libsystem_kernel.dylib (6153.141.10) <FF092EE8-5BEE-3B9A-8749-F0A067115C7E> /usr/lib/system/libsystem_kernel.dylib 0x7fff67c09000 - 0x7fff67c50fff libsystem_m.dylib (3178) <00F331F1-0D09-39B3-8736-1FE90E64E903> /usr/lib/system/libsystem_m.dylib 0x7fff67c51000 - 0x7fff67c78fff libsystem_malloc.dylib (283.100.6) <8549294E-4C53-36EB-99F3-584A7393D8D5> /usr/lib/system/libsystem_malloc.dylib 0x7fff67c79000 - 0x7fff67c86ffb libsystem_networkextension.dylib (1095.140.2) <F06C65C5-2CBE-313C-96E1-A09240F9FE57> /usr/lib/system/libsystem_networkextension.dylib 0x7fff67c87000 - 0x7fff67c90ff7 libsystem_notify.dylib (241.100.2) <FA22F928-D91B-3AA5-96BB-3186AC0FB264> /usr/lib/system/libsystem_notify.dylib 0x7fff67c91000 - 0x7fff67c99fef libsystem_platform.dylib (220.100.1) <009A7C1F-313A-318E-B9F2-30F4C06FEA5C> /usr/lib/system/libsystem_platform.dylib 0x7fff67c9a000 - 0x7fff67ca4fff libsystem_pthread.dylib (416.100.3) <62CB1A98-0B8F-31E7-A02B-A1139927F61D> /usr/lib/system/libsystem_pthread.dylib 0x7fff67ca5000 - 0x7fff67ca9ff3 libsystem_sandbox.dylib (1217.141.2) <051C4018-4345-3034-AC98-6DE42FB8273B> /usr/lib/system/libsystem_sandbox.dylib 0x7fff67caa000 - 0x7fff67cacfff libsystem_secinit.dylib (62.100.2) <F80872AA-E1FD-3D7E-8729-467656EC6561> /usr/lib/system/libsystem_secinit.dylib 0x7fff67cad000 - 0x7fff67cb4ffb libsystem_symptoms.dylib (1238.120.2) <702D0910-5C34-3D43-9631-8BD215DE4FE1> /usr/lib/system/libsystem_symptoms.dylib 0x7fff67cb5000 - 0x7fff67ccbff2 libsystem_trace.dylib (1147.120.1) <BC141783-66D9-3137-A783-211B38E49ADB> /usr/lib/system/libsystem_trace.dylib 0x7fff67ccd000 - 0x7fff67cd2ff7 libunwind.dylib (35.4) <42B7B509-BAFE-365B-893A-72414C92F5BF> /usr/lib/system/libunwind.dylib 0x7fff67cd3000 - 0x7fff67d08ffe libxpc.dylib (1738.140.2) <54EEF402-42C7-3995-BADE-93C48EFC4452> /usr/lib/system/libxpc.dylib External Modification Summary: ``` Calls made by other processes targeting this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 7301 thread_create: 0 thread_set_state: 0 ``` VM Region Summary: ReadOnly portion of Libraries: Total=876.9M resident=0K(0%) swapped_out_or_unallocated=876.9M(100%) Writable regions: Total=971.0M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=971.0M(100%) ``` VIRTUAL REGION ``` REGION TYPE SIZE COUNT (non-coalesced) **=======** Accelerate framework 128K 1 Activity Tracing 256K 1 CG backing stores 992K 2 CG image 588K 8 CoreAnimation 152K 12 CoreGraphics 8K 1 CoreImage 32K 4 CoreUI image data 936K 8 Foundation 4K 1 Kernel Alloc Once 8K 1 MALLOC 570.4M 361 MALLOC guard page 32K 7 MALLOC_LARGE (reserved) 992K 4 reserved VM address space (unallocated) MALLOC_NANO (reserved) 256.0M 1 reserved VM address space (unallocated) OpenGL GLSL 256K 3 STACK GUARD 108K 27 Stack 38.7M 27 VM_ALLOCATE 88.9M 499 __DATA 103.5M 549 __DATA_CONST 360K 7 __FONT_DATA 4K 1 __GLSLBUILTINS 5176K 1 __LINKEDIT 445.4M 182 __OBJC_RO 32.3M 1 __OBJC_RW 1908K 2 __TEXT 431.5M 483 __UNICODE 564K 1 mapped file 73.5M 25 shared memory 640K 16 **=======** TOTAL 2.0G 2236 TOTAL, minus reserved VM space 1.8G 2236 Model: MacBookPro11,3, BootROM 429.0.0.0.0, 4 processors, Quad-Core Intel Core i7, 2,3 GHz, 16 GB, SMC 2.19f12 Graphics: kHW_IntelIrisProItem, Intel Iris Pro, spdisplays_builtin Graphics: kHW_NVidiaGeForceGTX750MItem, NVIDIA GeForce GT 750M, spdisplays_pcie_device, 2 GB Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x02FE, - Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x02FE, - AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1615.3) Bluetooth: Version 7.0.6f8, 3 services, 27 devices, 1 incoming serial ports Network Service: Wi-Fi, AirPort, en0 Serial ATA Device: APPLE SSD SM0512F, 500,28 GB USB Device: USB 3.0 Bus USB Device: Apple Internal Keyboard / Trackpad USB Device: BRCM20702 Hub USB Device: Bluetooth USB Host Controller Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
Added subscriber: @cobold
Reference: blender/blender#84107
