Issue on reusing child of constraint.
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: rB0f45cab862b8
Issue of using Child of constraint multiple times.
1- Create a simple armature [like a simple 2 hand armature]
2- Create another armature like a weapon [with mag attached to magBone]
3- Create child constraint on weapon's root bone and attach it to the right hand
4 -Create child constraint on the magazine and attach it to the Left hand
5- Use the left-hand constraint for a few frames and then set Constraint influence to zero for the other few frames.
6- Now change the hand pose and try to use the left-hand 'Child of Constraint' by setting influence to 1. [for better demonstration animate the hand during all of the processes like the hand is trying to pick it in another pose]
7- WOOHALA The binding is working but it has a strange Location Rotation offset.
I know, I know, I used the Set Inverse and I Set it once. because using it multiple times is messing everything up.
It Would be great if you are telling me that am I doing it wrong or it is a discovered bug.
Thank you
Robert Guetzkow (rjg) changed the task status from Needs Triage to Needs Information from User.Jan 1 2021, 11:37 AM
Thank you for your report! Could you please also provide a minimal example project file that demonstrates the issue, just in case we cannot reproduce the problem with the provided instructions.
Robert Guetzkow (rjg) closed this task as Archived.Jan 9 2021, 2:31 PM
