Wintab broken with multiple monitors (huion Kamvas 13) #84179
2 Participants
Reference: blender/blender#84179
Graphics card: AMD Radeon RX 5700 XT ATI Technologies Inc. 4.5.14736 Core Profile Context 20.11.1 27.20.12033.2007
Broken: 2.92.0 Alpha, branch: wintab-coalesced-logging
Whenever using multiple monitors, the cursor is with an offset from the pen
2020-12-21 18-41-42.mp4
a problem that can be seen in other softwares like gimp (https://youtu.be/OoPiBoD23dw)
Added subscriber: @Diogo_Valadares
Added subscriber: @PrototypeNM1
@Diogo_Valadares could you run this build, copy the system console here, and link the paste in a reply to this report?
here it goes P1862
Given there's nothing obvious in the log and that GIMP seems to have the same problem, and Huion drivers are known to be spotty, I'm guessing this is a driver bug. If we can't find a solution you may have better luck with Windows Ink.
1- yes, and also, changing the scaling has no effect.
2- no, its only mapped to the display itself as seen below
I don't think its a driver issue since this problem isn't present in blender 2.91.
If it is not something easy to fix, at least when set to automatic mode I think it should use windows ink when a huion tablet is being used if possible.
The reason a driver issue would not be present in 2.91 but is now is because 2.92 is more dependent on Wintab reported information. This dependency is necessary to enable high frequency tablet input for Wintab.
That said, could you check if there's a similar problem in GIMP? Blender's use of Wintab now more closely resembles GTK, and their code is filled with hard earned lessons.
IMO this should be the default. I'm assuming you tried Windows Ink and it worked for you?
yep it worked perfectly fine with windows ink.
yes, it has the same issue
Thank you for the follow up. I'll investigate defaulting to Windows Ink when available.
If you want to continue investigating check Krita too (make sure their tablet API is set to Wintab, requires restart); it uses Qt instead of GTK (GIMP). If they have the same problem this is almost certainly a driver issue that surfaced because Blender was updated to handle tablet input in a way similar to those applications.
krita is working perfectly right out of the box. I even checked if it wasn't using windows ink and no, it was with wintab.
Thanks, I'll keep it in mind while reviewing their source code.
@Diogo_Valadares could you open Krita and screencap the advanced tablet settings window (Settings > Configure Krita > Tablet Settings > Advanced)?
In addition to the above, another build, and paste link. I noticed some of the logging information last time wasn't quite correct.
krita is like this ^^
and the paste link: P1912
I'll leave a note that for some reason I was not able to not reproduce the bug now, for some weird reason its not happening neither in the new build you made or the older one, I even checked if I was using wintab and if the bug was still happening in gimp, and yes, it was both in wintab and happening in gimp.
I'm not sure if I forgot something here or if windows just went crazy,
The only difference I see is that in the earlier build Windows and Wintab reported the window coordinate range as...
... and the most recent build as...
So it looks like you moved the monitors around in some way. It looks like one of the monitors used to be a bit higher than the main monitor previously, but then I can't understand the change in width.
What tablet do you have and does it have an in-built screen? What's your monitor layout, could you screencap your display layout settings (see image below)?
the huion kamvas 13 has a 1080x1920 screen built in.
so, the difference is that the second monitor resolution I was using was higher, windows is glitching on me and is not letting the second monitor work properly anymore, so I'm leaving it deactivated most of the time.
When I reactivated it to test the bug, I can only get 640x480(I was using 1280x800 before), its enough to get the bug in gimp, but for some reason blender isn't catching it anymore. I may test it later if I manage to change the monitor resolution to what it was before.
(red outline was roughly what I had before)
Thanks. I think given this context it's safe to say this is a driver issue, either in your monitor or in Huion's driver. Given your issues with the monitor I'd say it's a likely candidate, but some tablet drivers have been known to misbehave when displays change resolution.
Feel free to add additional information, but for now I'm going to assume the issue is outside of Blender.
well, weirdly the bug came back after I deactivated the second monitor(not unplugging it)
also I don't know if you also take care of the windows ink part, but if so I found a bug on it, while drawing in a part of an image, blender draw a straight line up:
2021-01-26 11-11-38.mp4
as you can see, Gimp is fine, blender now has the offset and windows ink is a bit broken
edit: after reactivating the second monitor, gimp is offseted again, blender wintab AND windows ink are working fine, so multiple monitors seems to break both apis
Could you run [this build ]], and [ https:*developer.blender.org/paste/edit/form/default/ | upload the log again? I realized some of the logging wasn't set up correctly since your last upload (not that I have high hopes given the other weird system behavior).
the position seems correct, but now wintab sometimes is glitching like windows ink, and sometimes its glitching in another way
P1948
also the pressure seems to get messed up sometimes or just not work at all.
and both wintab and windows ink aren't working at all at any dual/single monitor setup I select, Maybe they only update when blender Restart, so I'm not sure,
here's a video showing it.
2021-02-05 12-33-18.mp4
Changed status from 'Archived' to: 'Confirmed'
Going to reopen for now so that I remember to review it later. In the meantime you might check if Windows Ink is better behaved in the this build (note: Wintab is disabled but you may still have to change the Tablet API).
yep. windows ink works flawlessly in this build, even changing the monitor setup it still works fine
This should be resolved by
2e81f2c01a
, if the issue is still present after tonight's daily build please let me know and I'll reopen the issue. If the daily build is earlier than Feb 17, the above change has not yet taken effect.so, there is still a problem in the sculpt, the first dot of a stroke has maximum pressure, both in wintab and windows ink, besides it, windows ink pressure doesn't work at all
2021-02-18 13-24-06.mp4
in the video you can also see the bug where the stroke glitches when reaching a certain part of the screen, tho it only happened because I changed from 2 display to one display while blender was open so I don't think this is one should be critical.
EDIT: I tried to switch to windows ink and restart blender and it worked well, then I switched to wintab(wihich also was working fine) and then back to windows ink and it with a weird laggy behavior where it only updates what you did when you finish making the stroke
EDIT2: I now tried to start blender with wintab first bug is back again.. so I'm guessing all the glitches I got have to do with switching the api from Wintab to windows ink or starting blender with Wintab.
I think all the issues you mention are expected from reverting the changes to Wintab. Fixing Wintab when the displays change and switching between Wintab and WinInk without restarting Blender were all in one package with high frequency Wintab.
