Adjusting properties in weighting operation popups reverts vertex group locks #84184
2 Participants
Reference: blender/blender#84184
Operating system: Linux (and others)
Graphics card: nVidia 1060
Broken: 2.9x
In Weight Paint mode:
If I lock some vertex groups and then Weights -> Smooth (or any operation that has adjustable values), things behave as expected.
BUT, if I then try to alter the values the Properties popup window, the list of locked vertex groups changes (revert/undo?), which causes weights to bleed undesirably & defeating the purpose of locking groups.
This can even return a "All groups are locked" error, if the previous configuration had 1 or less groups unlocked and Weights -> Normalize All is performed. Normalize All needs at least 2 groups unlocked to shift weights around, and if you try to alter the properties popup it will revert the locked weights list to an incompatible configuration.
I've verified this bug with the Smooth, Levels and Normalize All procedures. Therefore, I'm assuming this will affect any Weights operation that has an adjustable properties popup.
weightsUnlock_2020-12-27.mp4
Assumed Issue
Perhaps Blender is altering these Properties values via Undos?
If, in between steps 4 and 5, you perform another action (i.e. enter and exit Edit mode) it will not change the list of locked Vertex Groups.
Importance
This weight locking technique is very effective in preventing skin weights from bleeding across the model when skinning, which creates a mess that require cleanup (*see timestamp 9:30 Demeter's tutorial on "Weight Painting Part 2 ". Demeter demonstrates the problem and his workaround, which can introduces other problems, as the "Clean" operation is destructive and does not always fully fix the bleeding weights.
In the comments of the tutorial, I demonstrate the precision gained when using locked group weights and how it prevents bleeding, removing the need for any post cleanup.
This bug prevents the awesome property sliders from being used, meaning that values have to be set very low and the weighting operation needs to be performed in multiple steps till the desired effect is reached. This is not a very effective workaround.
BONUS
While looking at the code involved in this bug, I request looking at adding in a "Normalize" checkbox to allow the affects of the operations to be seen immediately on the vertex positions, without the requirement of additional Normalize steps.
When performing operations such as Smooth, it's very common (assumed) that this step will be followed up with a Normalize All operation. Many popular skin weighting addons (see below) try to fill this gap by introducing checkboxes to automatically perform Normalize operations after adjusting weights.
Here are two Example Addons that introduce an "auto normalize" for common Weight operations.
https://gumroad.com/l/weight_paint_tools
https://gumroad.com/l/smooth_unlocked
Added subscriber: @JerBot
Adjusting properties in "Smooth" weighting popup reverts vertex group locksto Adjusting properties in weighting operation popups reverts vertex group locksAdded subscriber: @lichtwerk
Thx for the detailed report Similar issue has been reported before, see the following related reports:
Not exactly sure if #78171 and #69760 are actually the same thing, will merge into #69760 since this seems a bit more specific to this exact case.
Please make sure to comment again if you think these are different issues (we can always reopen in this case)
Please use other channels for user feedback and feature requests: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
Closed as duplicate of #69760
Roger that @lichtwerk. ☑
Yes, it looks the same. Included a brief summary and a link to the video that I'd already uploaded, to assist & confirm the initial task description.
Will look to other channels for the "Auto Normal" checkbox feature request.
Cheers!
