Vertex weight options error modifing parameters
Closed, DuplicatePublic
Operating system: Linux-5.4.0-58-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce GT 710/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 455.38
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: rB0f45cab862b8
In weight paint if you apply an option and modify the parameters they make effect only on the first vertex group that you enter in
*Download the attached .blend and open the file
*Select one of two vertex group and next switch to weight paint
*Select an option (for exemple smooth) and change any parameters (for example factor)
*It is stil ok, but if you switch to the other vertex goup and repeat these passages when you change any parameters it returns to the first one
If i want apply the right parameters I have to leave weight paint, select another vertex group and re-enter, or I could apply the option to the first, then I cancel whit crt+z (if I don't want it) and re-apply whitout changing anything to the another
