Cannot get Round Cube in adding a new Mesh #84263
Closed
opened 2020-12-30 08:26:59 +01:00 by NIHAL DE MEL · 7 comments
Operating system: Windows 7 professional 64 bit
Graphics card: Nvidia quadro 600
Blender Version 2.91
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Short description of error I cannot add "Round Cube". It only opens a regular cube with rounded edges. I have checked and verified that "Add Mesh Extra Objects" is selected under Addons in Preferences.
Exact steps for others to reproduce the error Just delete everything and add mesh --> Round Cube
**System Information** Operating system: Windows 7 professional 64 bit Graphics card: Nvidia quadro 600 **Blender Version** 2.91 Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen) Worked: (newest version of Blender that worked as expected) **Short description of error** I cannot add "Round Cube". It only opens a regular cube with rounded edges. I have checked and verified that "Add Mesh Extra Objects" is selected under Addons in Preferences. **Exact steps for others to reproduce the error** Just delete everything and add mesh --> Round Cube Based on the default startup or an attached .blend file (as simple as possible).
Author
Added subscriber: @nihal18
Member
Added subscribers: @cwolf3d, @lichtwerk
Member
Member
Seems like this changed in 1072d96b7 [where the default radius was changed from 1.0 to 0.2]
@cwolf3d : just raising awareness, not sure if this is really what was intended?
So you can still achieve the spherical round cube by setting radius to 1 or above in the Adjust Last Operation panel (or hitting {key F9}).
I have to assume though that this was an intentional change, it is not really a bug after all. [@cwolf3d : correct me if I am wrong].
Will close, thx reporting anyways!
Seems like this changed in 1072d96b7 [where the default radius was changed from 1.0 to 0.2] @cwolf3d : just raising awareness, not sure if this is really what was intended? So you can still achieve the spherical round cube by setting radius to 1 or above in the Adjust Last Operation panel (or hitting {key F9}). I have to assume though that this was an intentional change, it is not really a bug after all. [@cwolf3d : correct me if I am wrong]. Will close, thx reporting anyways!
This is not a bug. Changed this default to look more like a cube rather than a ball. But this is not a matter of principle. Also added the ability to return to editing parameters. This makes it possible to use it in boolean operations and return to its parameters (the "change Roundcube" button in the context menu).
NIHAL DE MEL self-assigned this 2020-12-30 20:15:47 +01:00
Author
Hello Vladimir,
Thanks for getting back to me so very promptly.
Please explain the steps to convert the round edged cube to the round cube I need to have. I do not know how to go to "change roundcube" in the context menu.
Thank you,
Nihal
Hello Vladimir, Thanks for getting back to me so very promptly. Please explain the steps to convert the round edged cube to the round cube I need to have. I do not know how to go to "change roundcube" in the context menu. Thank you, Nihal
![image.png](https://archive.blender.org/developer/F9538962/image.png)
Reference: blender/blender-addons#84263
