Image Texture node shortcut not working #84286
Closed
opened 2020-12-31 05:44:36 +01:00 by Cheo · 9 comments
Graphics card: GeForce GTX 1650/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.79
Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash: 3e85bb34d0
the shortcut to add an image texture node does not work. I have closed blender multiple times to see if it was a temp bug but it still wont work. I 1st tried it with a project that i was working on, then tried it with the default cube scene and I still am not able to add the image texture node with the short cut shift + A. It only works when pressing the Add-> texture-> image texture.
  1. select the shading tab
  2. on the texture node at the bottom, press shift + A to bring up shortcut to add a node.
    3.select texture -> image texture
  3. the image texture node does not appear.
  • If I select the add-> texture-> image texture it will work. It will not let me add other nodes either using the shortcut. I will have to update to 2.91.0 since it is the current version at this time.
Thank you.
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce GTX 1650/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.79 **Blender Version** Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash: `3e85bb34d0` Worked: (newest version of Blender that worked as expected) **Short description of error** the shortcut to add an image texture node does not work. I have closed blender multiple times to see if it was a temp bug but it still wont work. I 1st tried it with a project that i was working on, then tried it with the default cube scene and I still am not able to add the image texture node with the short cut shift + A. It only works when pressing the Add-> texture-> image texture. **Exact steps for others to reproduce the error** 1. select the shading tab 2. on the texture node at the bottom, press shift + A to bring up shortcut to add a node. 3.select texture -> image texture 4. the image texture node does not appear. * If I select the add-> texture-> image texture it will work. It will not let me add other nodes either using the shortcut. I will have to update to 2.91.0 since it is the current version at this time. Thank you.
Author
Added subscriber: @CTcheo
Author
Removed subscriber: @CTcheo
Author
Added subscriber: @rjg
I can't reproduce the problem in 2.90.1 or more recent versions. Could it be that you've installed an add-on that interferes with the operation?
Please open Blender's installation directory and double-click on the blender_factory_startup.cmd. This will start Blender with factory default setting, including the keymap and activated add-ons. Check if the issue still occurs.
I can't reproduce the problem in 2.90.1 or more recent versions. Could it be that you've installed an add-on that interferes with the operation? Please open Blender's installation directory and double-click on the `blender_factory_startup.cmd`. This will start Blender with factory default setting, including the keymap and activated add-ons. Check if the issue still occurs.
@CTcheo Please provide the requested information. The current report does not allow me to reproduce the problem or identify the issue in the code.
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
2 Participants
Reference: blender/blender#84286
