[Mantaflow] Fluid volume loss with moving obstacle. #84287
7 Participants
Reference: blender/blender#84287
Operating system: Linux-5.8.0-33-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 455.38
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-12-30 11:38, hash:
f910342c8d
The fluid suffers a loss of volume when a container obstacle moves.
MF_MovingObstacle_BUG.mp4
The attached file contains a setup that demonstrates the issue. Just hit play and wath at the moment that the bowl moves the fluid inside simply starts to disappear...
MF_MovingObstacle_BUG.blend
Added subscriber: @EvertonSchneider
Added subscriber: @rjg
I'm not sure if this is related to your issue, but I'm getting an exception when trying to bake your simulation with Type set to All and Mesh enabled.
Offset index 32768 is out of bounds
.Added subscribers: @sebbas, @lichtwerk
Can confirm the volume loss.
(have not tried baking to mesh though)
CC @sebbas
Fluid volume loss with moving obstacle.to [Mantaflow] Fluid volume loss with moving obstacle.Added subscriber: @darklord666
Hey i'm seeing this pretty badly also (2.91). Moving Effector and volume loss. Have tried so many things including:
Just to re-iterate, particles are definitely NOT leaking through my effector. It just seems to be a volume loss over time. Happens pretty quickly too. I've read that this is one of the issues with FLIP in general?
Either way @sebbas @lichtwerk is this something we can expect some workaround/fixes to?
Thank you!
Hi @EvertonSchneider @sebbas @lichtwerk
I may be close to a solution for mass conservation / volume loss issue. Please let me know if I'm on the right track and if this can be more clear in the tooltips
Playing with Narrow Band Width setting - which to my understanding removes particles from the inner volume of the fluid to save on calculations (seeing as how it’s mostly the surface that sees activity that requires constant calculation). Looks like by increasing Narrow Band Width, the simulation will fill the inner volume with particles giving more accuracy. So far so good, my volume is remaining!!
I’m also playing with Fractional obstacles settings a bit to see if I can smoothen the boundary between fluid & obstacle.
Narrow Band Width:
Controls the width in grid cell units of the narrow band that liquid particles are allowed to flow in. A high value will result in a thicker band and can result in an inflow region completely filled with particles. Unless the goal of the simulation is to visualize the liquid particles it is recommended to not increase the band width significantly as more particles slow down the simulation.
In some situations increasing this value can help create volume when the simulation appears to leak. In all other cases it is best to keep the narrow band as thin as possible since the liquid surface contains most details and simulating particles inside the liquid is not an optimal use of computing resources.
Added subscriber: @dfelinto
OK so update on my research. I'd really like for someone to chip in with more experience though. (the following could be the wrong direction I'm not sure)
I've seen a lot of people mention that volume loss is kind of an inherent behavior to FLIP fluids. And that other solvers are recommended for different types of fluid animations. In this case, I've seen people mention SPH as a more capable solver when dealing with moving boundaries.
With further digging, I realized that blender's fluid particle system uses SPH! After testing using blender's fluid particles, and then using metaballs to fill in the blanks, I found SPH to be a super good solver for this kind of fluid.
Can I suggest that blender adds SPH as a potential solver to use in the Fluid options? So, FLIP, APAIC, and SPH? It would be nice to a) have all fluid solvers be in the same place and 2) allow SPH to benefit from whatever meshing solution is used in fluid simulations (because using metaballs is OK but not perfect).
@dfelinto @sebbas @lichtwerk @EvertonSchneider
Added subscriber: @Erosion139
This has never worked with mantaflow since it was introduced in some version (2.82?) Every once in a while I check to see if they fixed it but I haven't once been able to utilize mantaflow simulations with anything more than a static scene, which means I don't make anything that looks cool. Even when you change it from FLIP to whatever the other algorithm is it doesn't make any difference, unfortunately.
Added subscriber: @yiusay
I encountered the same problem in 2.92.
I have found that this problem does not seem to occur if we use flip fluids addon. It is the paid addon but you can try the demo version for free so you may want to see if the addon can solve your problem.
https://github.com/rlguy/Blender-FLIP-Fluids/wiki/FLIP-Fluids-Demo-Addon
Yeah I like how people say the FLIP addon is irrelevant because blender now does flip. At the same time the FLIP addon is still superior in multiple ways, and laughably especially in the simulation characteristics part too. In blender, matter is created and destroyed randomly lol.
Removed subscriber: @dfelinto
Mantaflow (fluid simulator) has no active developer at the moment. Moving those bugs as known issues so at least other users can find their issues already reported.
