Sky Texture Node - Height max at 60km? #84303
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#84303
In Blender 2.9.1, the Sky texture node's "Height" attribute maxes out at 60km although the kerman line (the line used to define the end of the atmosphere and the beginning of space) is at 100km.
Added subscriber: @J-M
Added subscriber: @rjg
Based on the documentation and code this appears to be the case because the model only considers the first 60 km as stated in [this article ]], which is linked on the [ https:*docs.blender.org/manual/en/latest/render/shader_nodes/textures/sky.html | manual page of the Sky Texture Node.
This issue was referenced by 7525
Changed status from 'Archived' to: 'Resolved'
