Missing "Sanitize" operation in 2.92
Closed, DuplicatePublic
Broken: Since version 2.92
Worked: Worked fine in 2.83 - 2.91
The function does not appear when I try to search It.
Adrian Lipiec (Coverop) changed the task status from Needs Triage to Needs Information from Developers.Jan 5 2021, 2:36 PM
Adrian Lipiec (Coverop) created this task.
Adrian Lipiec (Coverop) updated the task description. (Show Details)
Robert Guetzkow (rjg) changed the task status from Needs Information from Developers to Needs Information from User.Jan 5 2021, 2:49 PM
Could you please check if you find the operator when activating Developer Extras in Edit > Preferences > Interface. The add-on you're using likely didn't add the option to one of the menus. The F3 search without Developer Extras enabled only lists operators that can be found in menus (see T74157 and T76227).
It works. I didn't know It was a developer function.
