Copy data path instructions is incorrect #84430
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#84430
In this section: https://docs.blender.org/api/2.91/info_api_reference.html#copy-data-path
The second paragraph mentions a tooltip that shows the data path, but that isn't there anymore in 2.91 (at least not on by default).
The result of the "Copy Data Path" is 'modifiers["Subdivision"].levels' and not 'modifiers["Subsurf"].levels', so the console command should rather be:
bpy.context.active_object.modifiers["Subdivision"].levels
And the following command should be:
bpy.context.active_object.modifiers["Subsurf"].levels = 2
Also, recommend moving the third paragraph starting with "Note that the text copied..." to between the two commands since it's confusing to talk about copying text before it's done with the "Copy Data Path" option.
Added subscriber: @norulesjustfeels
Just realized that I had to enable the Python Tooltips in the display preferences to see the tooltip. I don't think I saw that anywhere in the API docs, so it might be a good idea to add that explicitly since it looks like all the API docs assume both Developer Extras and Python Tooltips are enabled.
The rest of the issues raised in the bug still need to be considered.
This issue was referenced by blender/blender@a9c607e60e
