uv_on_emitter crash #84588
Reference: blender/blender#84588
Graphics card: GeForce GTX 760M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 425.31
Broken:
1709bc5164
61f1faac3f
Worked: ?
Crashes:
Running bpy.types.Particle.uv_on_emitter() results in unexpected behavior, including returning
nan
,0
,<number>e-40/e+40
in different combinations and eventually giving anEXCEPTION_ACCESS_VIOLATION
crash. The behavior is present when accompanied by viewport updates of any sort and having other modifiers on the mesh. Open the attached file and run theuv_on_emitter_crash
script multiple times.Running bpy.types.ParticleSystem.uv_on_emitter() results in an
crash if theparticle
parameter is not specified. Open the attached file and run theno_particle_crash
script.uv_on_emitter_crash_test.blend
210111_130012_%pn_%t.mp4
Added subscriber: @unwave
Added subscriber: @rjg
Running the script causes a heap-buffer overflow for me, according to ASAN.
2.92:
Addressable: 00
Partially addressable: 01 02 03 04 05 06 07
Heap left redzone: fa
Freed heap region: fd
Stack left redzone: f1
Stack mid redzone: f2
Stack right redzone: f3
Stack after return: f5
Stack use after scope: f8
Global redzone: f9
Global init order: f6
Poisoned by user: f7
Container overflow: fc
Array cookie: ac
Intra object redzone: bb
ASan internal: fe
Left alloca redzone: ca
Right alloca redzone: cb
Shadow gap: cc
2.91:
Addressable: 00
Global redzone: f9
Array cookie: ac
ASan internal: fe
Shadow gap: cc
2.83
Addressable: 00
Global redzone: f9
Array cookie: ac
ASan internal: fe
Shadow gap: cc
It appears that
rna_Particle_uv_on_emitter
use ofmtface += num;
makes it point to an incorrect memory address. In this particular casenum
fromparticle->num_dmcache
is-2
(DMCACHE_ISCHILD
).It seems to me that
only handles the cases wherenum_dmcache
is eitherDMCACHE_NOTFOUND
orPOINTER_AS_INT(...)
, but notDMCACHE_ISCHILD
. Subtracting from themtface
pointer doesn't make sense as an offset in this context, as far as I can see.For instance
psys_thread_create_path
,particle_calculate_parent_uvs
,psys_face_mat
,get_particle_uv
and others check ifnum_dmcache
isDMCACHE_NOTFOUND
orDMCACHE_ISCHILD
and then usenum
instead ofnum_dmcache
if that is the case.This issue was referenced by
f5c0ef52cf
@rjg What about the second crash?
Changed status from 'Resolved' to: 'Confirmed'
@unwave Thank you for reminding me, the ticket was automatically closed by the commit that fixed the first issue. It's on the ToDo list for Monday.
The parameter
particle
was not intended to be optional, there was a mistake in the definition of the function.This issue was referenced by
821df20797
