UV editor loads all UDIM images even if not needed #84594
Reference: blender/blender#84594
Operating system: Darwin-19.6.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro Vega 64 OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.10.18
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash:
0f45cab862
Worked: never
I have a file with about 30 UDIM textures in it. I selected only one of the parts, using 3 UDIMs, copied it and pasted it in a new file. Took forever to turn the texture shading on.
I realized that Blender was loading all the textures, even if they are not used. You can see it in the UV editor. This is really inefficient. My 36 gigs of ram are maxed out because of one object.
Why load textures that are not even used in the scene at all? We also need a way to turn off BG images in the UV editor. It should be off by default.
Note that all textures have been copied as well.
UDIM_issue.zip
Added subscriber: @Funnybob
Added subscriber: @mano-wii
Could you provide a simple file showing the problem?
I fear this report does not contain all the requested information, which is required to investigate the issue.
Here you go. Once you relink the files, you will see that both images are loaded in memory even if the UVs are only in tile 1002. That's a major issue.
UDIM_issue.zip
What shading? Was that on Eevee, Cycles or elsewhere?
How did you realized that?
Shading is irrelevant. Eevee or Cycles also irrelevant. It was slow because it was loading over all 8k textures (30 UDIMs, 5 textures per UDIM) when I only needed 5.
If you look in the UV editor, you can see all images are loaded.
Added subscriber: @LukasStockner
Maybe I don't understand the problem yet.
So the problem is not the time it takes for the file to load, but the fact that if you copy an object that uses these UDIM textures to another file, all textures (including those not used by the object) in the UDIM tiles are also copied?
I don't know what the behavior should be in this situation, but in my opinion it doesn't seem to be a bug, maybe something that can be added to #72390 (Improve UDIM functionality).
Added subscriber: @rboxman
It's also not clear to me what's really expected here. The
xxx
Object has 2 UDIM tiles assigned to it. Blender will open and copy around those 2 UDIM tiles as necessary. There's no attempt to guess that the user only wants a subset of them just because the object UVs are only contained inside a subset of those tiles.Obviously you don't want to load texture images that are not needed. My example is a good one. 30 UDIMs, 5 textures per UDIMs, that make 150 images and they are all 8k. I only needed the textures for 2 UDIMs. So Blender should check first. Which UDIMs are "taken" by geometry. 1012 and 1013? Ok, I'll just load these textures then. Doesn't it make sense? :-)
Thanks for the report, but unfortunately this cannot be confirmed as a bug for at least 2 reasons:
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
