Export to FBX error
Closed, DuplicatePublic
Getting errors whenever I try to export certain models to FBX as well as a few other file types such as collada, not really sure as to whats causing the error as I dont know what to make of the error message that pops up *attached*
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.09
Broken: version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash: rB0330d1af29c0
It will be much easier to find the problem if you can attach a sample .blend-file in which you get this error.
Falk David (filedescriptor) changed the task status from Needs Triage to Needs Information from User.Jan 12 2021, 9:51 AM
This report does not contain the requested information, which is required for us to investigate the issue. Please read this guide, it may help you write a bug report that allows us to fix your problem.
Please provide any additional information you have in the ticket T79775.
Please find attached a copy of the blend file which has the issue.
