[UI] Editing cursor not changed to normal when exiting the edit area like seach bar or drop down #84706
6 Participants
Reference: blender/blender#84706
Operating system: any
Graphics card: non
Broken: everywhere
Worked:
activate any search bar or text edit field on UI and move mouse out of that text field area, mouse cursor will stay in same state which is annoying
Added subscriber: @AbgaryanFX
Added subscriber: @rjg
The cursor will change back as soon as you click anywhere else thus changing focus from the search field to another UI element. Does that match the behavior you're seeing?
Added subscriber: @wannes.malfait
I haven't noticed this before, and it doesn't bother me, but it does seem that in most programs the cursor changes back to normal after leaving the test field even if it is still active. Programs I've looked at:
@rjg, yes.
Thanks @wannes.malfait for more info.
Here are additional motion sequences called videos`
Cursor behavior in Unity
b1.mp4
and in blender
b2.mp4
Thanks for the report, but this isn't a bug. The cursors state reflects that wherever your mouse is, the input is handled by the text box. To test that out, try pressing
ctrl-Q
when the text box is active.In Blender the "active button" is important, so while this might not look the greatest, I think changing this behavior would be misleading.
Changed status from 'Archived' to: 'Needs Triage'
Actually I won't close this report because I'm not positive others will agree with that opinion.
Added subscriber: @Harley
This isn't a bug. The cursor should change to inform the user of possible actions and it is doing its job perfectly there.
While editing that text box there are no other actions possible until you finish editing or cancel out of it. So the mouse has a deliberate pointer that is telling you that "sorry you can't do this right now because you are in the middle of text input". It could be clearer - could change to a "stopsign" cursor instead I suppose -- but that would be just as confusing and more annoying.
There is a patch (in review) to allow more things to be done while text editing. If that lands, and it allows enough other actions - like opening panels, etc - then it might make sense to change the cursor to a generic pointer.
I guess
Unity
is updating cursor status according to cursor'spixel position
, whereas inblender
, cursor status changes on performingon Click
operation (I have no deep idea about the code) .I don't think this is a bug. Unity and blender both are correct in their ways.
No, text editing in Blender is a modal operation. Once you start editing text you are in a section of code that allows nothing else but that Although you can continue to move your mouse about, you can't use it to affect anything else in the program - clicking anywhere just forces the text editing to end and exit the mode.
Part of the issue is the way that the mouse indicates which editor is active and therefore takes input. There is only ever one editor that takes input at a time. But you wouldn't want the mouse to work like this while editing text. Otherwise while changing the name of a object you would have to ensure that the mouse stayed within the confines of the Properties editor.
Similarly there are key binding that makes sense within the confines of text entry that you would not want to bubble outside of it. So while editing, hitting esc, backspace, tab, enter, arrows, etc have specific actions that are unrelated to the keymaps that might be set for the area that the mouse currently is in.
Oh, I did not know that . Thank you @Harley .
