bug
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
Robert Guetzkow (rjg) closed this task as Archived.Jan 15 2021, 8:19 PM
Thank you for your report. Unfortunately, it is empty and thus does not contain the requested information, which are required for us to investigate the issue. Please read this guide, it may help you write a bug report that allows us to fix your problem.
In case you believe that you've found a bug, please create a new bug report through Help > Report a Bug in Blender. We expect all bug reports to follow the submission template. Please provide system information (operating system, GPU, graphics driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
