feedback loops occuring with Geonode Modifier when working with vertex-group attr #84757
Reference: blender/blender#84757
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2021-01-12 20:03, hash:
719bea0d6d
In this simple example (file available below) I created a vertex group that i used as an attr in a geonode modifier then remove some weight using an attr math node, at first glance everything seem to work fine. But on some condition (entering a field then hit esc, or evaluating the depsgraph with python or else?) the node keep re-evaluating itself, this can be repeated indefinitely.
So the attr workflow seems to re-evaluate the attr it produces (feedback loop) This is quite an unexpected workflow-breaking behavior, it's the first time that a modifier re-evaluate something that it produces (for example the vgedit modifier only evaluate the vertex-group initially, and don't re-evaluate the resulting vertex-group) Somehow this is not making any crashes as the re-evaluation is not continuous. blender is re-evaluating only on some conditions, not sure why and when this re-evaluation occurs?
this is significantly breaking the attr workflow.
here's a gif illustrating the issue
Blank file:
Use file below:
feedback_loop.blend
note that entering edit mode will reset the weight
Added subscriber: @dodododorian
Geonode Modifier is creating feedback loops when changing vertex-groups (possibily with other attr?)to feedback loops occuring with Geonode Modifier when working with vertex-group attrAdded subscribers: @JulianEisel, @rjg
I'm not familiar with the design decision here so this is more of an observation/comment than triaging.
@JacquesLucke CC
@dodododorian I can see that this might be an issue if this would be a continuous loop or cause unexpected internal state. However, as far as I can tell, this is not the case and since you are deliberately using the same attribute for input and output,
I'm not entirely sure what behavior you're expecting? The way is see this, the implementation could either update the attribute that it is using as an input for subsequent evaluation or refuse to write to an attribute that it uses as input*. Evaluating it only once doesn't seem like a plausible solution.(*) Edit: Always starting the evaluation with the original value would make sense I suppose.
The current behavior does seem to match the description in the manual that states:
Removed subscriber: @JulianEisel
I haven't looked at the file yet, but I'm pretty sure this is a bug. We do not support any kind of feedback loops yet.
My guess is that we forgot to copy a referenced custom data layer in the attribute system. Will check it in more detail a bit later.
The goal of this example is to do operations on vertex groups, similar to modifiers like VG-edit or VG-proximity (input is also output in these cases).
the geometry node is a modifier like any other. no current modifiers can evaluate the content it creates, only evaluates what's above of them on the stack
If this is by design, there's a strong contradiction with current established modifiers behaviors
You're right, the geometry nodes should operate like a modifier. From this perspective the behavior is definitely wrong. Apologies for my misunderstanding/uninformedness. Given that @JacquesLucke confirmed that geometry nodes are not supposed to break with the convention of modifiers and I can reproduce the behavior, I'm marking this ticket as confirmed.
This issue was referenced by
1e193a0b56
