Cycles viewport denoising fails with OIDN if it's not selected before going into rendered mode (GPU) #84813
Reference: blender/blender#84813
Graphics card: GeForce GTX 1070 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.67
Broken: version:
0876829e7a
30dd31a7b3
23233fcf05
fdd3032f8f
0f45cab862
Worked: Never?
If you're using Cycles, device set to GPU, and are in the rendered view mode, if you then select viewport denoising with OIDN the viewport will fail to render and you'll receive a "Denoiser type not supported by compute device"
However, if you select the denoising option before going into rendered mode, things will work fine. See steps below.
Start with default scene
Enable Cycles, set the device to GPU, AND enable Viewport denoising set to OIDN
Switch to rendered mode
Things work fine. Toggle the viewport denoising option on and off. Still works fine.
Go back to Solid shading mode AND disable Viewport denoising
Go back to Rendered mode. Works fine
Enable Viewport denoising now. Fails
Added subscriber: @deadpin
Added subscriber: @rjg
The computation of OpenImageDenoise is happening on the CPU. However, if it works or not shouldn't depend on the order of operations, so even if this wouldn't be supported in
newer versionsbecause of a reason unknown to me, it should behave consistently.I have to correct myself, the same issue can be reproduced in 2.91.0.
This issue was referenced by
1451f7d093
