Crash with Random occurrence on MacBook Pro Big Sur
Needs Triage, NormalPublic
Operating system:MocOS Big Sur 11.1 2.4 GHz 8-Core Intel Core i9 64 GB 2667 MHz DDR4
Graphics card: Intel UHD Graphics 630 1536 MB
Broken: Version 2.91.0 (2.91.0 2020-11-25)
Worked: (2.81)
Blender crashes randomly on Mac OS. Sometimes after just sitting idle for several minutes, other times after editing meshes or attempt to render in viewport (Cycles or EEVEE) or render frames or animation.
Very hard to find a definitive pattern when crash occurs.
Seems that when I create files on version 2.83 or 2.91 it works better, but loading files (especially large files) from earlier versions crash very often.
See OS crash log below :
Process:               Blender [741]
Path:                  /Applications/Blender_291/Blender.app/Contents/MacOS/Blender
Identifier:            org.blenderfoundation.blender
Version:               2.91.0 (2.91.0 2020-11-25)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Blender [741]
User ID:               502
Date/Time:             2021-01-18 10:23:19.889 -0700
OS Version:            macOS 11.1 (20C69)
Report Version:        12
Bridge OS Version:     5.1 (18P3030)
Anonymous UUID:        531B82B0-E5F1-69EA-9B13-8CDC7102AB5B
Time Awake Since Boot: 660 seconds
System Integrity Protection: enabled
Crashed Thread:        1
Exception Type:        EXC_CRASH (SIGSEGV)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   Blender [741]
Thread 0:: Dispatch queue: com.apple.main-thread
0   GLEngine                      	0x00007fff6cbc4690 gleRunVertexSubmitImmediate + 5632
1   GLEngine                      	0x00007fff6cb4b197 glDrawElementsInstancedBaseVertex_GL3Exec + 807
2   libGL.dylib                   	0x00007fff6ca923cf glDrawElementsInstancedBaseVertex + 45
3   org.blenderfoundation.blender 	0x000000010083c775 draw_call_single_do + 469
4   org.blenderfoundation.blender 	0x000000010083bf1a drw_draw_pass_ex + 1626
5   org.blenderfoundation.blender 	0x000000010083b8af DRW_draw_pass + 31
6   org.blenderfoundation.blender 	0x000000010087cf4d OVERLAY_draw_scene + 365
7   org.blenderfoundation.blender 	0x0000000100832d8a drw_engines_draw_scene + 186
8   org.blenderfoundation.blender 	0x000000010083198d DRW_draw_render_loop_ex + 1565
9   org.blenderfoundation.blender 	0x00000001010c3778 view3d_main_region_draw + 136
10  org.blenderfoundation.blender 	0x0000000100c71e70 ED_region_do_draw + 336
11  org.blenderfoundation.blender 	0x00000001006f849d wm_draw_update + 1757
12  org.blenderfoundation.blender 	0x00000001006f6110 WM_main + 48
13  org.blenderfoundation.blender 	0x00000001002f297a main + 890
14  libdyld.dylib                 	0x00007fff203aa621 start + 1
Thread 1 Crashed:
0   libsystem_kernel.dylib        	0x00007fff2035aeba semaphore_wait_trap + 10
1   libdispatch.dylib             	0x00007fff201e4c5c _dispatch_sema4_wait + 16
2   libdispatch.dylib             	0x00007fff201e512e _dispatch_semaphore_wait_slow + 98
3   org.blenderfoundation.blender 	0x000000010624dc32 IlmThread_2_4::(anonymous namespace)::DefaultWorkerThread::run() + 50
4   org.blenderfoundation.blender 	0x000000010624c79e void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_4::Thread::*)(), IlmThread_2_4::Thread*> >(void*) + 62
5   libsystem_pthread.dylib       	0x00007fff2038f950 _pthread_start + 224
6   libsystem_pthread.dylib       	0x00007fff2038b47b thread_start + 15
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:: AMCP Logging Spool
1   com.apple.audio.caulk         	0x00007fff2848a92a caulk::mach::semaphore::wait_or_error() + 16
2   com.apple.audio.caulk         	0x00007fff284776e6 caulk::semaphore::timed_wait(double) + 110
3   com.apple.audio.caulk         	0x00007fff28477634 caulk::concurrent::details::worker_thread::run() + 30
4   com.apple.audio.caulk         	0x00007fff284773c0 void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 45
Thread 18:: com.apple.audio.IOThread.client
0   libsystem_kernel.dylib        	0x00007fff2035ae7e mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x00007fff2035b1f0 mach_msg + 60
2   com.apple.audio.CoreAudio     	0x00007fff21e7dde5 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111
3   com.apple.audio.CoreAudio     	0x00007fff21d19477 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 3435
4   com.apple.audio.CoreAudio     	0x00007fff21ebcf3a HALB_IOThread::Entry(void*) + 72
Thread 19:
1   org.blenderfoundation.blender 	0x00000001006ecc68 tbb::internal::rml::private_worker::run() + 104
2   org.blenderfoundation.blender 	0x00000001006ecbf9 tbb::internal::rml::private_worker::thread_routine(void*) + 9
3   libsystem_pthread.dylib       	0x00007fff2038f950 _pthread_start + 224
4   libsystem_pthread.dylib       	0x00007fff2038b47b thread_start + 15
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:: com.apple.NSEventThread
2   com.apple.CoreFoundation      	0x00007fff20487bf7 __CFRunLoopServiceMachPort + 316
3   com.apple.CoreFoundation      	0x00007fff204862ca __CFRunLoopRun + 1315
4   com.apple.CoreFoundation      	0x00007fff204856ce CFRunLoopRunSpecific + 563
5   com.apple.AppKit              	0x00007fff22e28c16 _NSEventThread + 124
6   libsystem_pthread.dylib       	0x00007fff2038f950 _pthread_start + 224
7   libsystem_pthread.dylib       	0x00007fff2038b47b thread_start + 15
Thread 35:: Dispatch queue: com.apple.opengl.cvmDoWork
2   libdispatch.dylib             	0x00007fff201fa776 _dispatch_mach_send_and_wait_for_reply + 518
3   libdispatch.dylib             	0x00007fff201fab6e dispatch_mach_send_with_result_and_wait_for_reply + 50
4   libxpc.dylib                  	0x00007fff200d21ac xpc_connection_send_message_with_reply_sync + 238
5   libCoreVMClient.dylib         	0x00007fff6c86670a cvms_element_build_and_get_internal + 229
6   libCoreVMClient.dylib         	0x00007fff6c86660e cvms_element_build_from_source + 169
7   libCVMSPluginSupport.dylib    	0x00007fff6c87bf14 cvm_deferred_build_modular(void*) + 422
8   libdispatch.dylib             	0x00007fff201e47c7 _dispatch_client_callout + 8
9   libdispatch.dylib             	0x00007fff201ea5fe _dispatch_lane_serial_drain + 606
10  libdispatch.dylib             	0x00007fff201eb0cb _dispatch_lane_invoke + 375
11  libdispatch.dylib             	0x00007fff201f4c5d _dispatch_workloop_worker_thread + 819
12  libsystem_pthread.dylib       	0x00007fff2038c499 _pthread_wqthread + 314
13  libsystem_pthread.dylib       	0x00007fff2038b467 start_wqthread + 15
Thread 36:
0   libsystem_pthread.dylib       	0x00007fff2038b458 start_wqthread + 0
Thread 37:
Thread 38:
Thread 1 crashed with X86 Thread State (64-bit):
  rax: 0x000000000000000e  rbx: 0x00006000001cd210  rcx: 0x000070000c275f08  rdx: 0x0000000000000028
  rdi: 0x0000000000001903  rsi: 0x0000000000000003  rbp: 0x000070000c275f20  rsp: 0x000070000c275f08
   r8: 0x0000000000001703   r9: 0x0000000000000000  r10: 0x0000000000002503  r11: 0x0000000000000246
  r12: 0x0000000000000000  r13: 0x0000000000000000  r14: 0x00006000001cd210  r15: 0xffffffffffffffff
  rip: 0x00007fff2035aeba  rfl: 0x0000000000000246  cr2: 0x000070000c275ff8
Logical CPU:     0
Error Code:      0x01000024
Trap Number:     133
Thread 1 instruction stream not available.
Thread 1 last branch register state not available.
Binary Images:
       0x1001ae000 -        0x10a981fff +org.blenderfoundation.blender (2.91.0 - 2.91.0 2020-11-25) <A18D3102-5B87-3997-9B07-0AAF11241DA7> /Applications/Blender_291/Blender.app/Contents/MacOS/Blender
       0x11162e000 -        0x11169afff +libomp.dylib (0) <535E76BC-1650-3651-9C62-97A995647107> /Applications/Blender_291/Blender.app/Contents/Resources/lib/libomp.dylib
       0x115871000 -        0x115874fff  com.apple.CloudDocsFileProvider (1.0 - 726) <89C091B1-BB9C-3919-8051-B8A86E94FC57> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider
       0x117196000 -        0x1172f9fff  com.apple.audio.units.Components (1.14 - 1.14) <79BEEEC4-3C3B-3C49-AF25-792C6CE5BF68> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
       0x117332000 -        0x1178e1fff  com.apple.audio.AudioDSPComponents (1.0 - 1) <6F81B244-A378-3A25-BFBB-5C3EFCF560B6> /System/Library/Components/AudioDSP.component/Contents/MacOS/AudioDSP
       0x117d2e000 -        0x117d3dfff  libobjc-trampolines.dylib (818.2) <12B587A2-8631-3B7A-B862-5091C411AC2C> /usr/lib/libobjc-trampolines.dylib
       0x117d89000 -        0x118108fff  com.apple.AMDRadeonX6000MTLDriver (4.2.13 - 4.0.2) <1448CDC1-D6D3-3312-A291-7E17D1610D5D> /System/Library/Extensions/AMDRadeonX6000MTLDriver.bundle/Contents/MacOS/AMDRadeonX6000MTLDriver
       0x11898e000 -        0x118ae1fff  com.apple.AMDRadeonX6000GLDriver (4.2.13 - 4.0.2) <5669BE74-1CF9-3829-9F6D-4FFFC8147A8E> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/AMDRadeonX6000GLDriver
       0x11f305000 -        0x11f306fff +_heapq.cpython-37m-darwin.so (0) <20086BF0-0130-3463-B824-F98C6D51BE39> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_heapq.cpython-37m-darwin.so
       0x11f50f000 -        0x11f514fff +math.cpython-37m-darwin.so (0) <F76ADA60-2AAA-34A7-BB31-26405F501673> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/math.cpython-37m-darwin.so
       0x11fbf1000 -        0x11fe0afff +_hashlib.cpython-37m-darwin.so (0) <C9C14775-5B8E-3512-98E0-537BF4984A54> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_hashlib.cpython-37m-darwin.so
       0x11fea3000 -        0x11fea8fff +_blake2.cpython-37m-darwin.so (0) <7FD886EF-36D2-329A-B8CE-AAF09D7269E8> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_blake2.cpython-37m-darwin.so
       0x11feb2000 -        0x11fec2fff +_sha3.cpython-37m-darwin.so (0) <D7698BDC-8C9A-3198-81AD-6044B3FFB378> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_sha3.cpython-37m-darwin.so
       0x11fecd000 -        0x11fecdfff +_bisect.cpython-37m-darwin.so (0) <1F871C75-B7E3-3531-B4FD-9127E49825DD> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_bisect.cpython-37m-darwin.so
       0x11fed5000 -        0x11fed6fff +_random.cpython-37m-darwin.so (0) <6EA0F0A9-EB67-39B1-8BC9-CD20C494E8F6> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_random.cpython-37m-darwin.so
       0x11ff1e000 -        0x11ff24fff +_json.cpython-37m-darwin.so (0) <6C52949D-6062-3DBB-8601-8FC34D195603> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_json.cpython-37m-darwin.so
       0x11ffad000 -        0x11ffbffff +zlib.cpython-37m-darwin.so (0) <8EF3CAAD-13A3-3C17-B25F-8F3D16F65850> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/zlib.cpython-37m-darwin.so
       0x11ffca000 -        0x11ffe0fff +_bz2.cpython-37m-darwin.so (0) <E0F8E75D-B92D-3624-ABAE-FAC3B29181F2> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_bz2.cpython-37m-darwin.so
       0x11ffeb000 -        0x120019fff +_lzma.cpython-37m-darwin.so (0) <B82293C1-035E-3C19-B6E1-E93BEB44DA1B> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_lzma.cpython-37m-darwin.so
       0x120028000 -        0x120028fff +grp.cpython-37m-darwin.so (0) <DEEAC15B-D065-3D28-9F79-32426A8C67B7> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/grp.cpython-37m-darwin.so
       0x120030000 -        0x120034fff +_struct.cpython-37m-darwin.so (0) <AFC22996-5DC5-3B8F-B881-06BF3CE37AA9> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_struct.cpython-37m-darwin.so
       0x120042000 -        0x120048fff +binascii.cpython-37m-darwin.so (0) <03796BF6-3DC5-3C9B-9D69-32549A2602EB> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/binascii.cpython-37m-darwin.so
       0x120311000 -        0x12031ffff +_datetime.cpython-37m-darwin.so (0) <87D99FDA-6F48-3410-B90A-CD992418681B> /Applications/Blender_291/Blender.app/Contents/Resources/2.91/python/lib/python3.7/lib-dynload/_datetime.cpython-37m-darwin.so
       0x120a8d000 -        0x120a90fff  com.apple.FileProviderOverride (326 - 326) <30A4FABB-09A9-3847-9097-C47264FE43CC> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
       0x120aa1000 -        0x120abcfff  com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride (1.0 - 1350.2.10) <13CEAF66-0099-3F21-B489-6DA4F088AB43> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
       0x121019000 -        0x1210b4fff  dyld (832.7.1) <DEA51514-B4E8-3368-979B-89D0F8397ABC> /usr/lib/dyld
    0x7fff200c5000 -     0x7fff200c6fff  libsystem_blocks.dylib (78) <9CF131C6-16FB-3DD0-B046-9E0B6AB99935> /usr/lib/system/libsystem_blocks.dylib
    0x7fff200c7000 -     0x7fff200fcfff  libxpc.dylib (2038.40.38) <003A027D-9CE3-3794-A319-88495844662D> /usr/lib/system/libxpc.dylib
    0x7fff200fd000 -     0x7fff20114fff  libsystem_trace.dylib (1277.50.1) <48C14376-626E-3C81-B0F5-7416E64580C7> /usr/lib/system/libsystem_trace.dylib
    0x7fff20115000 -     0x7fff201b3fff  libcorecrypto.dylib (1000.60.19) <92F0211E-506E-3760-A3C2-808BF3905C07> /usr/lib/system/libcorecrypto.dylib
    0x7fff201b4000 -     0x7fff201e0fff  libsystem_malloc.dylib (317.40.8) <2EF43B96-90FB-3C50-B73E-035238504E33> /usr/lib/system/libsystem_malloc.dylib
    0x7fff201e1000 -     0x7fff20225fff  libdispatch.dylib (1271.40.12) <CEF1460B-1362-381A-AE69-6BCE2D8C215B> /usr/lib/system/libdispatch.dylib
    0x7fff20226000 -     0x7fff2025efff  libobjc.A.dylib (818.2) <45EA2DE2-B612-3486-B156-2359CE279159> /usr/lib/libobjc.A.dylib
    0x7fff2025f000 -     0x7fff20261fff  libsystem_featureflags.dylib (28.60.1) <7B4EBDDB-244E-3F78-8895-566FE22288F3> /usr/lib/system/libsystem_featureflags.dylib
    0x7fff20262000 -     0x7fff202eafff  libsystem_c.dylib (1439.40.11) <06D9F593-C815-385D-957F-2B5BCC223A8A> /usr/lib/system/libsystem_c.dylib
    0x7fff202eb000 -     0x7fff20340fff  libc++.1.dylib (904.4) <AE3A940A-7A9C-3F99-B175-3511528D8DFE> /usr/lib/libc++.1.dylib
    0x7fff20341000 -     0x7fff20359fff  libc++abi.dylib (904.4) <DDFCBF9C-432D-3B8A-8641-578D2EDDCAD8> /usr/lib/libc++abi.dylib
    0x7fff2035a000 -     0x7fff20388fff  libsystem_kernel.dylib (7195.60.75) <4BD61365-29AF-3234-8002-D989D295FDBB> /usr/lib/system/libsystem_kernel.dylib
    0x7fff20389000 -     0x7fff20394fff  libsystem_pthread.dylib (454.60.1) <8DD3A0BC-2C92-31E3-BBAB-CE923A4342E4> /usr/lib/system/libsystem_pthread.dylib
    0x7fff20395000 -     0x7fff203cffff  libdyld.dylib (832.7.1) <2F8A14F5-7CB8-3EDD-85EA-7FA960BBC04E> /usr/lib/system/libdyld.dylib
    0x7fff203d0000 -     0x7fff203d9fff  libsystem_platform.dylib (254.60.1) <3F7F6461-7B5C-3197-ACD7-C8A0CFCC6F55> /usr/lib/system/libsystem_platform.dylib
    0x7fff203da000 -     0x7fff20405fff  libsystem_info.dylib (542.40.3) <0979757C-5F0D-3F5A-9E0E-EBF234B310AF> /usr/lib/system/libsystem_info.dylib
    0x7fff20406000 -     0x7fff208a1fff  com.apple.CoreFoundation (6.9 - 1770.300) <EAC298C4-CE3E-3551-A832-42ED9A13EF74> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff208a2000 -     0x7fff20ad1fff  com.apple.LaunchServices (1122.11 - 1122.11) <CAEEC254-68AE-39B5-8452-EC3E1EE8577B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff20ad2000 -     0x7fff20ba5fff  com.apple.gpusw.MetalTools (1.0 - 1) <C235D5FA-0B9D-3E72-A8CE-67174E1B9E7C> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
    0x7fff20ba6000 -     0x7fff20e09fff  libBLAS.dylib (1336.40.1) <AD2D155C-1294-3D10-817A-F6A581E6ACF1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff20e0a000 -     0x7fff20e57fff  com.apple.Lexicon-framework (1.0 - 86.1) <D54364A6-1C4C-33D7-8B24-C753777B3654> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
    0x7fff20e58000 -     0x7fff20ec6fff  libSparse.dylib (106) <60559226-6E4B-3601-B6CA-E3B85B5EB27B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
    0x7fff20ec7000 -     0x7fff20f44fff  com.apple.SystemConfiguration (1.20 - 1.20) <8524EE4C-628F-315A-9531-44DD83CE275E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff20f45000 -     0x7fff20f7afff  libCRFSuite.dylib (50) <6CA29EAA-0585-3682-9AD2-DFD3D87A74D4> /usr/lib/libCRFSuite.dylib
    0x7fff20f7b000 -     0x7fff211b2fff  libmecabra.dylib (929.1.1) <39F5AD50-3AF2-3CFB-BD21-2DC45AA92A91> /usr/lib/libmecabra.dylib
    0x7fff211b3000 -     0x7fff21516fff  com.apple.Foundation (6.9 - 1770.300) <44A7115B-7FF0-3300-B61B-0FA71B63C715> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff21517000 -     0x7fff21603fff  com.apple.LanguageModeling (1.0 - 247.1) <BCB1F8A7-54B9-36D1-B742-70DF7657BF0B> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff21604000 -     0x7fff2173afff  com.apple.CoreDisplay (231.3 - 231.3) <229BF97A-1D56-3CB4-8338-E0D464F73A33> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff2173b000 -     0x7fff219b0fff  com.apple.audio.AudioToolboxCore (1.0 - 1180.23) <56821802-07B9-3FA9-AF73-D943BAE0DE57> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
    0x7fff219b1000 -     0x7fff21b99fff  com.apple.CoreText (677.2.0.5 - 677.2.0.5) <B0B2A8DD-A6F1-3EF7-9351-1BA604353A11> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff21b9a000 -     0x7fff2223dfff  com.apple.audio.CoreAudio (5.0 - 5.0) <DF623EC9-FC55-3B3C-94FF-6A5C50A981B3> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff2223e000 -     0x7fff2258ffff  com.apple.security (7.0 - 59754.60.13) <A20AB68D-51DA-340B-B813-F2AFC81F7143> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff22590000 -     0x7fff227f1fff  libicucore.A.dylib (66109) <6C0A0196-2778-3035-81CE-7CA48D6C0628> /usr/lib/libicucore.A.dylib
    0x7fff227f2000 -     0x7fff227fbfff  libsystem_darwin.dylib (1439.40.11) <BD269412-C9D0-32EE-B42B-B09A187A9B95> /usr/lib/system/libsystem_darwin.dylib
    0x7fff227fc000 -     0x7fff22ae3fff  com.apple.CoreServices.CarbonCore (1307 - 1307) <9C615967-6D8E-307F-B028-6278A4FA7C8C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff22ae4000 -     0x7fff22b22fff  com.apple.CoreServicesInternal (476 - 476) <FD1692F7-A4B4-3FE5-B9C8-E0840D53C7D0> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff22b23000 -     0x7fff22b5dfff  com.apple.CSStore (1122.11 - 1122.11) <088D0108-AA14-3610-86A0-89D0C605384F> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
    0x7fff22b5e000 -     0x7fff22c0bfff  com.apple.framework.IOKit (2.0.2 - 1845.60.2) <F2299682-5884-363F-9069-AA804E712C74> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff22c0c000 -     0x7fff22c17fff  libsystem_notify.dylib (279.40.4) <98D74EEF-60D9-3665-B877-7BE1558BA83E> /usr/lib/system/libsystem_notify.dylib
    0x7fff22c18000 -     0x7fff22c63fff  libsandbox.1.dylib (1441.60.4) <243C983D-0AEF-3A09-9489-CF1FC75925CC> /usr/lib/libsandbox.1.dylib
    0x7fff22c64000 -     0x7fff239c6fff  com.apple.AppKit (6.9 - 2022.20.119) <4CB42914-672D-3AF0-A0A5-2209088A3DA0> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff239c7000 -     0x7fff23c1afff  com.apple.UIFoundation (1.0 - 726.11) <71C63CE5-094D-34AF-B538-8DCAB3B66DE9> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff23c1b000 -     0x7fff23c2dfff  com.apple.UniformTypeIdentifiers (633.0.2 - 633.0.2) <7BEC7DDC-2B7A-3B5D-B994-5FA352FC485A> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers
    0x7fff23c2e000 -     0x7fff23db8fff  com.apple.desktopservices (1.17 - 1346.2.1) <732C8A0C-E7F8-372D-AE5B-84497067135E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff23db9000 -     0x7fff23dcbfff  com.apple.metadata.SpotlightLinguistics (1.0 - 1) <C49ACE74-8DBC-300C-8A31-FD95FE8BC03A> /System/Library/PrivateFrameworks/SpotlightLinguistics.framework/Versions/A/SpotlightLinguistics
    0x7fff24085000 -     0x7fff246c8fff  libnetwork.dylib (2288.60.5) <180FE916-8DD6-3385-B231-0C423B7D2BD3> /usr/lib/libnetwork.dylib
    0x7fff246c9000 -     0x7fff24b66fff  com.apple.CFNetwork (1209.1 - 1209.1) <60DE4CD6-B5AF-3E0E-8AF1-39ECFC1B8C98> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff24b67000 -     0x7fff24b75fff  libsystem_networkextension.dylib (1295.60.5) <F476B1CB-3561-30C5-A78E-44E99B1720A3> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff24b76000 -     0x7fff24b76fff  libenergytrace.dylib (22) <9BE5E51A-F531-3D59-BBBC-486FFF97BD30> /usr/lib/libenergytrace.dylib
    0x7fff24b77000 -     0x7fff24bd2fff  libMobileGestalt.dylib (978.60.2) <F721B185-0E6A-396B-A50F-0F55810D9A67> /usr/lib/libMobileGestalt.dylib
    0x7fff24bd3000 -     0x7fff24be9fff  libsystem_asl.dylib (385) <940C5BB9-4928-3A63-97F2-132797C8B7E5> /usr/lib/system/libsystem_asl.dylib
    0x7fff24bea000 -     0x7fff24c01fff  com.apple.TCC (1.0 - 1) <457D5F24-A346-38FC-8FA1-43B0C835E035> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff24c02000 -     0x7fff24f67fff  com.apple.SkyLight (1.600.0 - 569.6) <35876384-45F9-3C62-995B-38EC31BE75D7> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fff24f68000 -     0x7fff255fbfff  com.apple.CoreGraphics (2.0 - 1463.2.2) <323F725F-CB03-3AAD-AFBC-37B430B3FD4E> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff255fc000 -     0x7fff256f2fff  com.apple.ColorSync (4.13.0 - 3472) <7387EBC7-CBD9-34FE-B4A3-345E4750FD81> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff256f3000 -     0x7fff2574efff  com.apple.HIServices (1.22 - 713) <9AF2CDD9-8B68-3606-8C9E-1842420ACDA7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff25afa000 -     0x7fff25f18fff  com.apple.CoreData (120 - 1044.3) <76179A55-CA89-3967-A0A7-C419DB735983> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff25f19000 -     0x7fff25f2ffff  com.apple.ProtocolBuffer (1 - 285.20.8.8.1) <8EE538E7-2BB1-3E29-8FC3-938335998B22> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff25f30000 -     0x7fff260effff  libsqlite3.dylib (321.1) <D7017429-8D46-3ECB-8B70-4625C74918F3> /usr/lib/libsqlite3.dylib
    0x7fff260f0000 -     0x7fff2616cfff  com.apple.Accounts (113 - 113) <99421243-019F-3A2F-A671-092026FA2F74> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
    0x7fff2616d000 -     0x7fff26185fff  com.apple.commonutilities (8.0 - 900) <76711775-FF46-38CA-88F3-B4201C285C7F> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
    0x7fff26186000 -     0x7fff26207fff  com.apple.BaseBoard (526 - 526) <38C24B3A-8226-3FD5-8C28-B11D02747B56> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
    0x7fff26208000 -     0x7fff26253fff  com.apple.RunningBoardServices (1.0 - 505.60.2) <F99A0D0C-D063-3E3F-8D1F-0E0B35E7CE2C> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
    0x7fff26254000 -     0x7fff262c9fff  com.apple.AE (918.0.1 - 918.0.1) <3A298716-A130-345E-B8FF-74194849015E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff262ca000 -     0x7fff262d0fff  libdns_services.dylib (1310.60.4) <61EB26AD-C09E-3140-955E-16BF7DD2D6E3> /usr/lib/libdns_services.dylib
    0x7fff262d1000 -     0x7fff262d8fff  libsystem_symptoms.dylib (1431.60.1) <88F35AAC-746F-3176-81DF-49CE3D285636> /usr/lib/system/libsystem_symptoms.dylib
    0x7fff262d9000 -     0x7fff2645dfff  com.apple.Network (1.0 - 1) <EED4099E-B17C-3E0B-AA8F-78A2D4F26CBF> /System/Library/Frameworks/Network.framework/Versions/A/Network
    0x7fff2645e000 -     0x7fff26482fff  com.apple.analyticsd (1.0 - 1) <99FE0234-454F-36FF-9DE9-36B94D8753F9> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
    0x7fff26483000 -     0x7fff26485fff  libDiagnosticMessagesClient.dylib (112) <1014A32B-89EE-3ADD-971F-9CB973172F69> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff26486000 -     0x7fff264d2fff  com.apple.spotlight.metadata.utilities (1.0 - 2150.7.2) <37A1E760-2006-366C-9FAC-FB70227393FB> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
    0x7fff264d3000 -     0x7fff2656dfff  com.apple.Metadata (10.7.0 - 2150.7.2) <509C6597-ABB2-3B81-8E09-C51A755CCDA2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff2656e000 -     0x7fff26574fff  com.apple.DiskArbitration (2.7 - 2.7) <83DED679-BE65-3475-8AFF-D664BBAFA60A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff26575000 -     0x7fff26c1bfff  com.apple.vImage (8.1 - 544) <305D97CC-B47C-32FD-9EC5-43259A469A14> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff26c1c000 -     0x7fff26ee9fff  com.apple.QuartzCore (1.11 - 925.5) <D59138DC-10CD-3DF8-9F04-CCDB6102C370> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff26eea000 -     0x7fff26f2bfff  libFontRegistry.dylib (309) <790676A3-2B74-3239-A60D-429069933542> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff26f2c000 -     0x7fff2706dfff  com.apple.coreui (2.1 - 689.4) <0DA8F4E0-9473-374E-8B48-F0A40AEC63CE> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff2706e000 -     0x7fff27159fff  com.apple.ViewBridge (551.3 - 551.3) <36D0DCA7-CAAE-33C1-90F6-98876CB8BCF3> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff2715a000 -     0x7fff27165fff  com.apple.PerformanceAnalysis (1.275 - 275) <2F811EE6-D4D4-347E-B4A0-961F0DF050E5> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff27166000 -     0x7fff27175fff  com.apple.OpenDirectory (11.1 - 230.40.1) <7710743E-6F55-342E-88FA-18796CF83700> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff27176000 -     0x7fff27195fff  com.apple.CFOpenDirectory (11.1 - 230.40.1) <32ECCB06-56D8-3704-935B-7D5363B2988E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff27196000 -     0x7fff2719efff  com.apple.CoreServices.FSEvents (1290.40.2 - 1290.40.2) <FB18B8D7-C7F5-3CAB-B538-3F4B4E85D1F1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff2719f000 -     0x7fff271c3fff  com.apple.coreservices.SharedFileList (144 - 144) <93D2192D-7A27-3FD4-B3AB-A4DCBF8419B7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff271c4000 -     0x7fff271c6fff  libapp_launch_measurement.dylib (14.1) <9E2700C3-E993-3695-988E-FEF798B75E34> /usr/lib/libapp_launch_measurement.dylib
    0x7fff271c7000 -     0x7fff2720ffff  com.apple.CoreAutoLayout (1.0 - 21.10.1) <998BC461-F4F5-396E-9798-1C8126AD61DA> /System/Library/PrivateFrameworks/CoreAutoLayout.framework/Versions/A/CoreAutoLayout
    0x7fff27210000 -     0x7fff272f2fff  libxml2.2.dylib (34.8) <68396181-8100-390C-8886-EFB79F5B484C> /usr/lib/libxml2.2.dylib
    0x7fff272f3000 -     0x7fff2733ffff  com.apple.CoreVideo (1.8 - 408.4) <0D5AD16E-A871-3ACB-B910-39B87928E937> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff27340000 -     0x7fff27342fff  com.apple.loginsupport (1.0 - 1) <4F860927-F6F5-3A99-A103-744CF365634F> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff27343000 -     0x7fff2736bfff  com.apple.aps.framework (4.0 - 4.0) <F8FAEB30-AFCF-36A1-9E72-25681E6C5BF7> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
    0x7fff2736c000 -     0x7fff27389fff  com.apple.UserManagement (1.0 - 1) <B5CEAA26-4C5F-3AF4-BDFE-35DE7C8DE1BE> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
    0x7fff2738a000 -     0x7fff27529fff  com.apple.cloudkit.CloudKit (962 - 962) <2D82071D-495C-3E80-BF3C-CB181FECB500> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fff2752a000 -     0x7fff275acfff  com.apple.CloudDocs (1.0 - 726) <C6CB66A3-64B6-31C5-BA53-8F564D4D5719> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fff282a6000 -     0x7fff28322fff  com.apple.corelocation (2420.12.12 - 2420.12.12) <F4C3D15D-BEFE-37A9-A55F-2BFB16842FBE> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fff28323000 -     0x7fff28333fff  libsystem_containermanager.dylib (318.60.1) <4ED09A19-04CC-3464-9EFB-F674932020B5> /usr/lib/system/libsystem_containermanager.dylib
    0x7fff28334000 -     0x7fff28345fff  com.apple.IOSurface (289.3 - 289.3) <A3B10665-5909-30EE-BE34-F3284D6D5975> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff28346000 -     0x7fff2834efff  com.apple.IOAccelerator (439.52 - 439.52) <3944C92D-7838-3D2F-A453-9DB15C815D7B> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff2834f000 -     0x7fff28474fff  com.apple.Metal (244.32.7 - 244.32.7) <413B81AE-653F-3CF7-B5A4-A4391436E6D1> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff28475000 -     0x7fff28491fff  com.apple.audio.caulk (1.0 - 70) <952BA9D4-BAD3-3319-8C17-F7BB2655F80C> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
    0x7fff28492000 -     0x7fff2857bfff  com.apple.CoreMedia (1.0 - 2760.6.4.6) <CBCD783B-B3C9-37B8-835C-A3BACEC35BB5> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff2857c000 -     0x7fff286d8fff  libFontParser.dylib (305.2.0.6) <76C6C92A-1B16-3FB7-9EA2-7227D379C20F> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
    0x7fff286d9000 -     0x7fff289d8fff  com.apple.HIToolbox (2.1.1 - 1060.4) <93518490-429F-3E31-8344-15D479C2F4CE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff289d9000 -     0x7fff289ecfff  com.apple.framework.DFRFoundation (1.0 - 265) <FB85651D-6221-38AF-BD6D-29BFF5830D36> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fff289ed000 -     0x7fff289f0fff  com.apple.dt.XCTTargetBootstrap (1.0 - 17500) <13ADD312-F6F5-3C03-BD3B-9331B3851285> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
    0x7fff289f1000 -     0x7fff28a1afff  com.apple.CoreSVG (1.0 - 149) <A0DAE6AE-9DDA-37B4-A087-545A242CF982> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
    0x7fff28a1b000 -     0x7fff28c54fff  com.apple.ImageIO (3.3.0 - 2130.2.7) <0FE3D51B-EC76-3558-BD56-7BFF61A6793D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff28c55000 -     0x7fff28fd2fff  com.apple.CoreImage (16.1.0 - 1120.10) <46F1E4F5-DF8F-32D4-8D0C-6FCF2C27A5CD> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff28fd3000 -     0x7fff2902efff  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <E2377275-53D7-31A0-AEAF-0A0273B99B92> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSCore.framework/Versions/A/MPSCore
    0x7fff2902f000 -     0x7fff29032fff  libsystem_configuration.dylib (1109.60.2) <C57B346B-0A03-3F87-BCAC-87B702FA0719> /usr/lib/system/libsystem_configuration.dylib
    0x7fff29033000 -     0x7fff29037fff  libsystem_sandbox.dylib (1441.60.4) <8CE27199-D633-31D2-AB08-56380A1DA9FB> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff29038000 -     0x7fff29039fff  com.apple.AggregateDictionary (1.0 - 1) <7F2AFEBB-FF06-3194-B691-B411F3456962> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
    0x7fff2903a000 -     0x7fff2903dfff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <250CD2CA-E796-3CB0-9ADD-054998903B1D> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fff2903e000 -     0x7fff2903ffff  liblangid.dylib (136) <224DC045-2B60-39AF-B89E-E524175667F5> /usr/lib/liblangid.dylib
    0x7fff29040000 -     0x7fff290e0fff  com.apple.CoreNLP (1.0 - 245) <F876FD71-F077-3CF7-B94D-9E05A17E03D7> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
    0x7fff290e1000 -     0x7fff290e7fff  com.apple.LinguisticData (1.0 - 399) <D1B7F1D5-EB9E-3555-BA57-3611FA153C44> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
    0x7fff290e8000 -     0x7fff297a4fff  libBNNS.dylib (288.60.2) <E3FF47D5-7DD9-3A9E-A819-C79B0CC17C03> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fff297a5000 -     0x7fff29978fff  libvDSP.dylib (760.40.6) <9434101D-E001-357F-9503-9896C6011F52> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff29979000 -     0x7fff2998bfff  com.apple.CoreEmoji (1.0 - 128) <7CCFC59A-8746-3E52-AF1D-1B67798E940C> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fff2998c000 -     0x7fff29996fff  com.apple.IOMobileFramebuffer (343.0.0 - 343.0.0) <9A6F913C-EC79-3FC1-A92C-3A1BA96D8DFB> /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/Versions/A/IOMobileFramebuffer
    0x7fff29997000 -     0x7fff29a69fff  com.apple.framework.CoreWLAN (16.0 - 1657) <AB3F880B-52C5-3006-82FE-9E6857C09DE7> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff29a6a000 -     0x7fff29c69fff  com.apple.CoreUtils (6.5 - 650.5) <198A4273-5B92-3A05-A99D-7FD4914A959A> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fff29c6a000 -     0x7fff29c8cfff  com.apple.MobileKeyBag (2.0 - 1.0) <2B6BF51A-68B0-3108-9597-8B618E6B457B> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fff29c8d000 -     0x7fff29c9dfff  com.apple.AssertionServices (1.0 - 505.60.2) <9F8620BD-A58D-3A42-9B9E-DEC21517EF1A> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
    0x7fff29c9e000 -     0x7fff29d2afff  com.apple.securityfoundation (6.0 - 55240.40.4) <5F06D141-62F4-3405-BA72-24673B170A16> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff29d2b000 -     0x7fff29d34fff  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <C5E4B35C-FFDA-3423-890F-06DAD1F684F5> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
    0x7fff29d35000 -     0x7fff29d39fff  com.apple.xpc.ServiceManagement (1.0 - 1) <2C03BEB7-915C-3A3A-A44F-A77775E1BFD5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff29d3a000 -     0x7fff29d3cfff  libquarantine.dylib (119.40.2) <19D42B9D-3336-3543-AF75-6E605EA31599> /usr/lib/system/libquarantine.dylib
    0x7fff29d3d000 -     0x7fff29d48fff  libCheckFix.dylib (31) <3381FC93-F188-348C-9345-5567A7116CEF> /usr/lib/libCheckFix.dylib
    0x7fff29d49000 -     0x7fff29d60fff  libcoretls.dylib (169) <9C244029-6B45-3583-B27F-BB7BBF84D814> /usr/lib/libcoretls.dylib
    0x7fff29d61000 -     0x7fff29d71fff  libbsm.0.dylib (68.40.1) <DC652D50-FA69-3801-9361-004D4D6832D0> /usr/lib/libbsm.0.dylib
    0x7fff29d72000 -     0x7fff29dbbfff  libmecab.dylib (929.1.1) <B5D8C96C-D3B8-32F8-84F9-A432CEAD4E5C> /usr/lib/libmecab.dylib
    0x7fff29dbc000 -     0x7fff29dc1fff  libgermantok.dylib (24) <F9772A76-7AFA-3E0B-A02C-A61FC6CA8D8B> /usr/lib/libgermantok.dylib
    0x7fff29dc2000 -     0x7fff29dd7fff  libLinearAlgebra.dylib (1336.40.1) <D2826FAB-174C-3CD6-A765-06D83A9A0EDB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff29dd8000 -     0x7fff29ffffff  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <231CF580-952A-32BC-A423-9B9756AC9744> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
    0x7fff2a000000 -     0x7fff2a04ffff  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <65A993E4-3DC2-3152-98D5-A1DF3DB4573F> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
    0x7fff2a050000 -     0x7fff2a196fff  com.apple.MLCompute (1.0 - 1) <BCEA1149-197E-398F-9424-E29B0AD0829F> /System/Library/Frameworks/MLCompute.framework/Versions/A/MLCompute
    0x7fff2a197000 -     0x7fff2a1cdfff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <F719DA57-EAAA-3527-B859-21025722932F> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
    0x7fff2a1ce000 -     0x7fff2a20bfff  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <FCCC0D3F-74D2-3107-82B3-E2B500E36AAE> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
    0x7fff2a20c000 -     0x7fff2a29cfff  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <21527A17-2D6F-3BDF-9A74-F90FA6E26BB3> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSImage.framework/Versions/A/MPSImage
    0x7fff2a29d000 -     0x7fff2a2acfff  com.apple.AppleFSCompression (125 - 1.0) <D1E7DC71-1929-30A8-B73E-268387110608> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff2a2ad000 -     0x7fff2a2bafff  libbz2.1.0.dylib (44) <0575C0D0-B107-3E53-857F-DEC55998197B> /usr/lib/libbz2.1.0.dylib
    0x7fff2a2bb000 -     0x7fff2a2bffff  libsystem_coreservices.dylib (127) <A2D875B9-8BA8-33AD-BE92-ADAB915A8D5B> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff2a2c0000 -     0x7fff2a2edfff  com.apple.CoreServices.OSServices (1122.11 - 1122.11) <870F34BE-C0ED-318B-858D-5F1E4757D552> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff2a2ee000 -     0x7fff2a41ffff  com.apple.AuthKit (1.0 - 1) <8239C235-54DE-39F3-98DC-920AF2BE6187> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
    0x7fff2a4c3000 -     0x7fff2a4d5fff  libz.1.dylib (76) <9F89FD60-03F7-3175-AB34-5112B99E2B8A> /usr/lib/libz.1.dylib
    0x7fff2a4d6000 -     0x7fff2a51dfff  libsystem_m.dylib (3186.40.2) <79820D9E-0FF1-3F20-AF4F-F87EE20CE8C9> /usr/lib/system/libsystem_m.dylib
    0x7fff2a51e000 -     0x7fff2a51efff  libcharset.1.dylib (59) <414F6A1C-1EBC-3956-AC2D-CCB0458F31AF> /usr/lib/libcharset.1.dylib
    0x7fff2a51f000 -     0x7fff2a524fff  libmacho.dylib (973.4) <28AE1649-22ED-3C4D-A232-29D37F821C39> /usr/lib/system/libmacho.dylib
    0x7fff2a525000 -     0x7fff2a540fff  libkxld.dylib (7195.60.75) <3600A314-332A-343D-B45D-D9D8B302545D> /usr/lib/system/libkxld.dylib
    0x7fff2a541000 -     0x7fff2a54cfff  libcommonCrypto.dylib (60178.40.2) <1D0A75A5-DEC5-39C6-AB3D-E789B8866712> /usr/lib/system/libcommonCrypto.dylib
    0x7fff2a54d000 -     0x7fff2a557fff  libunwind.dylib (200.10) <C5792A9C-DF0F-3821-BC14-238A78462E8A> /usr/lib/system/libunwind.dylib
    0x7fff2a558000 -     0x7fff2a55ffff  liboah.dylib (203.13.2) <FF72E19B-3B02-34D4-A821-3397BB28AC02> /usr/lib/liboah.dylib
    0x7fff2a560000 -     0x7fff2a56afff  libcopyfile.dylib (173.40.2) <89483CD4-DA46-3AF2-AE78-FC37CED05ACC> /usr/lib/system/libcopyfile.dylib
    0x7fff2a56b000 -     0x7fff2a572fff  libcompiler_rt.dylib (102.2) <0DB26EC8-B4CD-3268-B865-C2FC07E4D2AA> /usr/lib/system/libcompiler_rt.dylib
    0x7fff2a573000 -     0x7fff2a575fff  libsystem_collections.dylib (1439.40.11) <D40D8097-0ABF-3645-B065-168F43ACFF4C> /usr/lib/system/libsystem_collections.dylib
    0x7fff2a576000 -     0x7fff2a578fff  libsystem_secinit.dylib (87.60.1) <99B5FD99-1A8B-37C1-BD70-04990FA33B1C> /usr/lib/system/libsystem_secinit.dylib
    0x7fff2a579000 -     0x7fff2a57bfff  libremovefile.dylib (49.40.3) <750012C2-7097-33C3-B796-2766E6CDE8C1> /usr/lib/system/libremovefile.dylib
    0x7fff2a57c000 -     0x7fff2a57cfff  libkeymgr.dylib (31) <2C7B58B0-BE54-3A50-B399-AA49C19083A9> /usr/lib/system/libkeymgr.dylib
    0x7fff2a57d000 -     0x7fff2a584fff  libsystem_dnssd.dylib (1310.60.4) <81EFC44D-450E-3AA3-AC8F-D7EF68F464B4> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff2a585000 -     0x7fff2a58afff  libcache.dylib (83) <2F7F7303-DB23-359E-85CD-8B2F93223E2A> /usr/lib/system/libcache.dylib
    0x7fff2a58b000 -     0x7fff2a58cfff  libSystem.B.dylib (1292.60.1) <A7FB4899-9E04-37ED-9DD8-8FFF0400879C> /usr/lib/libSystem.B.dylib
    0x7fff2a58d000 -     0x7fff2a590fff  libfakelink.dylib (3) <34B6DC95-E19A-37C0-B9D0-558F692D85F5> /usr/lib/libfakelink.dylib
    0x7fff2a591000 -     0x7fff2a591fff  com.apple.SoftLinking (1.0 - 1) <90D679B3-DFFD-3604-B89F-1BCF70B3EBA4> /System/Library/PrivateFrameworks/SoftLinking.framework/Versions/A/SoftLinking
    0x7fff2a592000 -     0x7fff2a5c9fff  libpcap.A.dylib (98.40.1) <E1995A1C-7EEB-3340-B1E1-DD45FA625C12> /usr/lib/libpcap.A.dylib
    0x7fff2a5ca000 -     0x7fff2a6bafff  libiconv.2.dylib (59) <3E53F735-1D7E-3ABB-BC45-AAA37F535830> /usr/lib/libiconv.2.dylib
    0x7fff2a6bb000 -     0x7fff2a6ccfff  libcmph.dylib (8) <865FA425-831D-3E49-BD1B-14188D2A98AA> /usr/lib/libcmph.dylib
    0x7fff2a6cd000 -     0x7fff2a73efff  libarchive.2.dylib (83.40.4) <76B2F421-5335-37FB-9CD5-1018878B9E74> /usr/lib/libarchive.2.dylib
    0x7fff2a73f000 -     0x7fff2a7a6fff  com.apple.SearchKit (1.4.1 - 1.4.1) <7BDD2800-BDDC-3DE0-A4A8-B1E855130E3B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff2a7a7000 -     0x7fff2a7a8fff  libThaiTokenizer.dylib (3) <513547CD-5C7F-37BE-A2AD-55A22F279588> /usr/lib/libThaiTokenizer.dylib
    0x7fff2a7a9000 -     0x7fff2a7d0fff  com.apple.applesauce (1.0 - 16.26) <AE525243-2CE7-373E-994E-C2457611EB3C> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
    0x7fff2a7d1000 -     0x7fff2a7e8fff  libapple_nghttp2.dylib (1.41) <CC004768-6E3B-3D80-9431-61149EBE2E10> /usr/lib/libapple_nghttp2.dylib
    0x7fff2a7e9000 -     0x7fff2a7fbfff  libSparseBLAS.dylib (1336.40.1) <CEBD7B0F-A54D-3A43-BD7E-E8BC2C7B7F0C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff2a7fc000 -     0x7fff2a7fdfff  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <1BFEB124-CF05-342F-BC65-B233EAB661D9> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fff2a7fe000 -     0x7fff2a802fff  libpam.2.dylib (28.40.1) <AE84F5FA-DDB0-3028-AF25-D6B6A12DBA6A> /usr/lib/libpam.2.dylib
    0x7fff2a803000 -     0x7fff2a81bfff  libcompression.dylib (96.40.6) <45B8B821-8EB6-34FE-92E9-5CBA474499E2> /usr/lib/libcompression.dylib
    0x7fff2a81c000 -     0x7fff2a821fff  libQuadrature.dylib (7) <FB21F53D-4A40-327F-BD3B-C7C8D08C6A86> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fff2a822000 -     0x7fff2abbefff  libLAPACK.dylib (1336.40.1) <509FBCC6-4ECB-3192-98A6-D0C030E4E9D8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff2abbf000 -     0x7fff2ac0dfff  com.apple.DictionaryServices (1.2 - 341) <83CDCE83-6B48-35F1-BACF-83240D940777> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff2ac0e000 -     0x7fff2ac26fff  liblzma.5.dylib (16) <A45348BC-AA9C-39D6-A7C3-2246A3EFA34C> /usr/lib/liblzma.5.dylib
    0x7fff2ac27000 -     0x7fff2ac28fff  libcoretls_cfhelpers.dylib (169) <C0F19E92-DACB-3100-8610-62DEC5E5FB81> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fff2ac29000 -     0x7fff2ad22fff  com.apple.APFS (1677.60.23 - 1677.60.23) <8271EE40-CDF5-3E0B-9F42-B49DC7C46C98> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
    0x7fff2ad23000 -     0x7fff2ad30fff  libxar.1.dylib (452) <3F3DA942-DC7B-31EF-BCF1-38F99F59A660> /usr/lib/libxar.1.dylib
    0x7fff2ad31000 -     0x7fff2ad34fff  libutil.dylib (58.40.2) <85CF2B3B-6BEB-381D-8683-1DE2B0167ECC> /usr/lib/libutil.dylib
    0x7fff2ad35000 -     0x7fff2ad5dfff  libxslt.1.dylib (17.2) <2C881E82-6E2C-3E92-8DC5-3C2D05FE7C95> /usr/lib/libxslt.1.dylib
    0x7fff2ad5e000 -     0x7fff2ad68fff  libChineseTokenizer.dylib (37) <36891BB5-4A83-33A3-9995-CC5DB2AB53CE> /usr/lib/libChineseTokenizer.dylib
    0x7fff2ad69000 -     0x7fff2ae27fff  libvMisc.dylib (760.40.6) <219319E1-BDBD-34D1-97B7-E46256785D3C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff2ae28000 -     0x7fff2aec0fff  libate.dylib (3.0.4) <51D50D08-F614-3929-AFB1-BF4ED9BE4751> /usr/lib/libate.dylib
    0x7fff2aec1000 -     0x7fff2aec8fff  libIOReport.dylib (64) <3C26FBDC-931E-3318-8225-C10849CF1D60> /usr/lib/libIOReport.dylib
    0x7fff2aec9000 -     0x7fff2aef7fff  com.apple.CrashReporterSupport (10.13 - 15047) <5377E0C9-5D89-38C0-B129-1A086716F3E9> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff2afe4000 -     0x7fff2afebfff  libMatch.1.dylib (38) <DC1E67E0-2690-3EE0-840D-461DA2980D9D> /usr/lib/libMatch.1.dylib
    0x7fff2afec000 -     0x7fff2b077fff  libCoreStorage.dylib (554) <8EEB1047-EFC1-3C1B-8E33-A446EB043AD5> /usr/lib/libCoreStorage.dylib
    0x7fff2b078000 -     0x7fff2b0cbfff  com.apple.AppleVAFramework (6.1.3 - 6.1.3) <8A5B1C42-DD83-303B-85DE-754FB6C10E1A> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff2b0cc000 -     0x7fff2b0e5fff  libexpat.1.dylib (26) <4408FC72-BDAA-33AE-BE14-4008642794ED> /usr/lib/libexpat.1.dylib
    0x7fff2b0e6000 -     0x7fff2b0effff  libheimdal-asn1.dylib (597.40.10) <032931C8-B042-3B3D-93D3-5B3E27431FEA> /usr/lib/libheimdal-asn1.dylib
    0x7fff2b0f0000 -     0x7fff2b104fff  com.apple.IconFoundation (479.3 - 479.3) <650C91C9-D6A1-3FF7-964B-DE1065F2243C> /System/Library/PrivateFrameworks/IconFoundation.framework/Versions/A/IconFoundation
    0x7fff2b105000 -     0x7fff2b172fff  com.apple.IconServices (479.3 - 479.3) <63CAB1AB-C485-382A-9088-F6E3937BB8E9> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff2b173000 -     0x7fff2b210fff  com.apple.MediaExperience (1.0 - 1) <A7A754CE-61AB-39B8-AA31-3AEB14695F55> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
    0x7fff2b211000 -     0x7fff2b23afff  com.apple.persistentconnection (1.0 - 1.0) <C3F975D3-A87C-353C-BA1F-072825E60E8C> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
    0x7fff2b23b000 -     0x7fff2b249fff  com.apple.GraphVisualizer (1.0 - 100.1) <7035CCDF-5B9D-365C-A1FA-1D961EBEE44D> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
    0x7fff2b24a000 -     0x7fff2b665fff  com.apple.vision.FaceCore (4.3.2 - 4.3.2) <E0518821-B65D-31A4-8C37-DF3569CF8867> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff2b666000 -     0x7fff2b6b0fff  com.apple.OTSVG (1.0 - 677.2.0.5) <D2722431-6C71-3144-A024-6ED06334AEE0> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
    0x7fff2b6b1000 -     0x7fff2b6b7fff  com.apple.xpc.AppServerSupport (1.0 - 2038.40.38) <27B96AA0-421E-3E5A-B9D8-9BA3F0D133E9> /System/Library/PrivateFrameworks/AppServerSupport.framework/Versions/A/AppServerSupport
    0x7fff2b6b8000 -     0x7fff2b6c9fff  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <CAD78803-0F56-316E-A7F1-D2BF26CA2DD6> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
    0x7fff2b6ca000 -     0x7fff2b6ccfff  libspindump.dylib (295) <C6F804A3-5682-3766-A324-76667364873D> /usr/lib/libspindump.dylib
    0x7fff2b6cd000 -     0x7fff2b78dfff  com.apple.Heimdal (4.0 - 2.0) <8BB18335-5DD3-3154-85C8-0145C64556A2> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff2b78e000 -     0x7fff2b7a8fff  com.apple.login (3.0 - 3.0) <343A182A-F6C9-366E-BF0C-2124E5367F19> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
    0x7fff2b928000 -     0x7fff2b92bfff  libodfde.dylib (26) <E653BDF5-2C86-3FFB-928A-2D86B3D661E5> /usr/lib/libodfde.dylib
    0x7fff2b92c000 -     0x7fff2b996fff  com.apple.bom (14.0 - 233) <A62EEEE5-3027-3F25-BCD9-32D36922106E> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x7fff2b997000 -     0x7fff2b9e1fff  com.apple.AppleJPEG (1.0 - 1) <A2E9E2A4-AEDC-3481-BDC9-05D9AD84FC25> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff2b9e2000 -     0x7fff2bac0fff  libJP2.dylib (2130.2.7) <9D837C01-3D6C-3D71-8E92-3673CE06A21F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff2bac1000 -     0x7fff2bac4fff  com.apple.WatchdogClient.framework (1.0 - 98.60.1) <8374BBBB-65CB-3D46-9AD6-0DD1FB99AD88> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
    0x7fff2bac5000 -     0x7fff2baf8fff  com.apple.MultitouchSupport.framework (4400.28 - 4400.28) <E9A95272-5E84-3B64-8263-8C7F84456269> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff2baf9000 -     0x7fff2bc4bfff  com.apple.VideoToolbox (1.0 - 2760.6.4.6) <35098775-A188-3BE0-B0B1-7CE0027BA295> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff2bc4c000 -     0x7fff2bc7efff  libAudioToolboxUtility.dylib (1180.23) <58B4505B-F0EA-37FC-9F5A-6F9F05B0F2A5> /usr/lib/libAudioToolboxUtility.dylib
    0x7fff2bc7f000 -     0x7fff2bca5fff  libPng.dylib (2130.2.7) <1F3FED3B-FB07-3F43-8EAD-6100017FBAB5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff2bca6000 -     0x7fff2bd03fff  libTIFF.dylib (2130.2.7) <27E9A2D3-003D-3D97-AD85-BE595EA0516F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff2bd04000 -     0x7fff2bd1efff  com.apple.IOPresentment (53 - 37) <070919DC-978E-3DB3-80FD-FB0C1BAAE80A> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fff2bd1f000 -     0x7fff2bd25fff  com.apple.GPUWrangler (6.2.2 - 6.2.2) <F4B3905F-C024-33C1-82C8-F1744AF8516E> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
    0x7fff2bd26000 -     0x7fff2bd29fff  libRadiance.dylib (2130.2.7) <7ABF94D2-5281-363F-A613-9C945D77AAE8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff2bd2a000 -     0x7fff2bd2ffff  com.apple.DSExternalDisplay (3.1 - 380) <BA802582-F1EB-35B8-902F-3D0F426124E0> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fff2bd30000 -     0x7fff2bd54fff  libJPEG.dylib (2130.2.7) <FDD55379-6673-31E4-B916-7949459B60AE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff2bd55000 -     0x7fff2bd84fff  com.apple.ATSUI (1.0 - 1) <B82D099B-4F53-3B60-8BAA-975C41EFD356> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
    0x7fff2bd85000 -     0x7fff2bd89fff  libGIF.dylib (2130.2.7) <C51FB0BA-E5C0-335B-9C64-185B1DDC9166> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff2bd8a000 -     0x7fff2bd93fff  com.apple.CMCaptureCore (1.0 - 80.17.1.1) <A0D43E58-B960-3A80-8807-4115F0E1EF74> /System/Library/PrivateFrameworks/CMCaptureCore.framework/Versions/A/CMCaptureCore
    0x7fff2bd94000 -     0x7fff2bddbfff  com.apple.print.framework.PrintCore (16 - 531) <FC56A643-F502-3578-9EFF-375BE6B87691> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff2bddc000 -     0x7fff2bea8fff  com.apple.TextureIO (3.10.9 - 3.10.9) <0AC15003-4B6A-3FB3-9B41-3EF61A2BD430> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fff2bea9000 -     0x7fff2beb1fff  com.apple.InternationalSupport (1.0 - 60) <5485FFDC-CE44-37F4-865F-91B2EFBC6CAF> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
    0x7fff2beb2000 -     0x7fff2bf2dfff  com.apple.datadetectorscore (8.0 - 674) <A2DEEF63-7643-37AA-9420-ED875629D1B2> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff2bf2e000 -     0x7fff2bf8cfff  com.apple.UserActivity (435 - 435) <075FD354-28FD-3A13-881C-955FA9106D5C> /System/Library/PrivateFrameworks/UserActivity.framework/Versions/A/UserActivity
    0x7fff2bf8d000 -     0x7fff2c6f7fff  com.apple.MediaToolbox (1.0 - 2760.6.4.6) <8F9D0503-298B-3FCA-8135-3B3722EF287C> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff2cbb1000 -     0x7fff2cbd9fff  com.apple.locationsupport (2420.12.12 - 2420.12.12) <F02D6025-16B4-3C77-ACEA-89B4808214D3> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
    0x7fff2cbda000 -     0x7fff2cc0bfff  libSessionUtility.dylib (76.7) <95615EDE-46B9-32AE-96EC-7F6E5EB6A932> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
    0x7fff2cc0c000 -     0x7fff2cd3cfff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <D0F9F628-F241-3FA2-A785-7B9DCBB2FEC4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff2cd3d000 -     0x7fff2cda4fff  com.apple.audio.AudioSession (1.0 - 76.7) <C0B1C9EB-A594-31E3-ADDF-118583840E6F> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
    0x7fff2cda5000 -     0x7fff2cdb7fff  libAudioStatistics.dylib (25.1) <1D07EA54-BE7C-37C4-AA73-5224D402F0C3> /usr/lib/libAudioStatistics.dylib
    0x7fff2cdb8000 -     0x7fff2cdc7fff  com.apple.speech.synthesis.framework (9.0.51 - 9.0.51) <B86A2136-8DD7-395D-BB9F-9416C56DD2D6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff2cdc8000 -     0x7fff2ce33fff  com.apple.ApplicationServices.ATS (377 - 516) <3A435648-CC5F-387E-AB37-391AAEABE314> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff2ce34000 -     0x7fff2ce4cfff  libresolv.9.dylib (68) <9957A6F4-8B66-3429-86CD-6DF4993EB6F5> /usr/lib/libresolv.9.dylib
    0x7fff2ce4d000 -     0x7fff2ce60fff  libsasl2.2.dylib (214) <F20902AE-3733-3F37-801D-6C3B78C0008A> /usr/lib/libsasl2.2.dylib
    0x7fff2cf7f000 -     0x7fff2d05efff  libSMC.dylib (20) <CE5162B7-379E-3DF0-9D1E-44BC98BD2422> /usr/lib/libSMC.dylib
    0x7fff2d05f000 -     0x7fff2d0befff  libcups.2.dylib (494.1) <04A4801E-E1B5-3919-9F14-100F0C2D049B> /usr/lib/libcups.2.dylib
    0x7fff2d0bf000 -     0x7fff2d0cefff  com.apple.LangAnalysis (1.7.0 - 254) <120945D9-B74D-3A6F-B160-2678E6B6481D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff2d0cf000 -     0x7fff2d0d9fff  com.apple.NetAuth (6.2 - 6.2) <C65B2F54-67EA-3E4D-B84A-BBA94998BD6B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff2d0da000 -     0x7fff2d0e1fff  com.apple.ColorSyncLegacy (4.13.0 - 1) <33DA9348-EADF-36D2-B999-56854481D272> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
    0x7fff2d0e2000 -     0x7fff2d0edfff  com.apple.QD (4.0 - 416) <7FFC9049-7E42-372B-9105-1C4C94DE0110> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff2d0ee000 -     0x7fff2d75cfff  com.apple.audio.AudioResourceArbitration (1.0 - 1) <098FD431-D302-3DD5-9AD1-453615A73E68> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
    0x7fff2d75d000 -     0x7fff2d769fff  com.apple.perfdata (1.0 - 67.40.1) <85A57A67-8721-3035-BCEE-D4AC98332D2C> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
    0x7fff2d76a000 -     0x7fff2d778fff  libperfcheck.dylib (41) <67113817-A463-360A-B321-9286DC50FEDA> /usr/lib/libperfcheck.dylib
    0x7fff2d779000 -     0x7fff2d788fff  com.apple.Kerberos (3.0 - 1) <2E872705-0841-3695-AF79-4160D2A436AB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff2d789000 -     0x7fff2d7d8fff  com.apple.GSS (4.0 - 2.0) <2A38D59F-5F3A-3779-A421-2F8128F22B95> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff2d7d9000 -     0x7fff2d7e9fff  com.apple.CommonAuth (4.0 - 2.0) <D9431F22-A16B-3237-9676-B6159B36F5EA> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff2d7ea000 -     0x7fff2d810fff  com.apple.MobileAssets (1.0 - 659.60.1) <D8986A88-2061-3157-A1BE-452E20ED34F6> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
    0x7fff2d83e000 -     0x7fff2d860fff  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <3554A1B0-A9AD-3D89-A755-1C9CC7CEA239> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
    0x7fff2d861000 -     0x7fff2d869fff  com.apple.CorePhoneNumbers (1.0 - 1) <0DF4C527-E7D3-30E0-9402-4C43B29729CB> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
    0x7fff2d9be000 -     0x7fff2d9befff  liblaunch.dylib (2038.40.38) <05A7EFDD-4111-3E4D-B668-239B69DE3D0F> /usr/lib/system/liblaunch.dylib
    0x7fff2e1b9000 -     0x7fff2e300fff  com.apple.Sharing (1575 - 1575) <4E590A26-5934-33EE-BFD9-391A64686FDE> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff2e301000 -     0x7fff2e421fff  com.apple.Bluetooth (8.0.2 - 8.0.2f9) <E3CF73C4-B439-3E30-B74D-3344C2EA2FC9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff2e422000 -     0x7fff2e436fff  com.apple.AppContainer (4.0 - 509.60.2) <A9D28E73-B08F-34E3-AE7B-0855DBA96C3C> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fff2e437000 -     0x7fff2e43afff  com.apple.SecCodeWrapper (4.0 - 509.60.2) <55B0C208-B176-3FE4-8CA2-9F28CA59F8F1> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fff2e43b000 -     0x7fff2e494fff  com.apple.ProtectedCloudStorage (1.0 - 1) <C84C9C98-5382-3E27-8275-AC9816AA28E8> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff2e6e8000 -     0x7fff2fbd7fff  com.apple.GeoServices (1.0 - 1757.22.10.6.12) <4D6F8EF4-47D4-3F93-90AC-3F4A5772CBCB> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fff2fbd8000 -     0x7fff2fbe3fff  com.apple.DirectoryService.Framework (11.1 - 230.40.1) <FC96A8F6-8E19-3CB4-A3ED-4E30B1491746> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x7fff2fbe4000 -     0x7fff2fc0ffff  com.apple.RemoteViewServices (2.0 - 163) <AC6E2D2F-8131-3A40-97D7-E24E2A45CD66> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff2fc10000 -     0x7fff2fc1ffff  com.apple.SpeechRecognitionCore (6.1.12 - 6.1.12) <F2A0E41A-7976-3175-959A-98DC24AAFFCC> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff2fc20000 -     0x7fff2fc27fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <9C14FA0A-D905-375B-8C32-E311ED59B6AD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff2fe6b000 -     0x7fff2fe6bfff  libsystem_product_info_filter.dylib (8.40.1) <7CCAF1A8-F570-341E-B275-0C80B092F8E0> /usr/lib/system/libsystem_product_info_filter.dylib
    0x7fff2ff46000 -     0x7fff2ff46fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <510A463F-5CA5-3585-969F-2D44583B71C8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff2ff6d000 -     0x7fff2ff6dfff  com.apple.CoreServices (1122.11 - 1122.11) <5DDB040C-6E92-3DBE-9049-873F510F26E2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff3023b000 -     0x7fff3023bfff  com.apple.Accelerate (1.11 - Accelerate 1.11) <F2FFCC7B-EE3D-3768-A73B-342851B53741> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff3027c000 -     0x7fff30287fff  com.apple.MediaAccessibility (1.0 - 130) <9B4710C9-6238-3507-9918-FDA38CDC0B00> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff30288000 -     0x7fff302a7fff  com.apple.networking.AlgosScoreFramework (1.0 - 1) <DAB40772-57A1-3545-94FD-4C823D13135C> /System/Library/PrivateFrameworks/AlgosScoreFramework.framework/Versions/A/AlgosScoreFramework
    0x7fff302a8000 -     0x7fff302acfff  com.apple.AppleSRP (5.0 - 1) <882084C9-F925-308F-B778-398FE6741654> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff302ad000 -     0x7fff302b8fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <96849317-5346-3D5D-95B7-6C48C3015427> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff302b9000 -     0x7fff302f0fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <E28F11F0-2155-331E-9CFE-BF858E06ACED> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
    0x7fff30ab2000 -     0x7fff30b14fff  com.apple.CoreBluetooth (1.0 - 1) <0FF4CFB1-B8DD-31C3-A000-5016CFE45EB9> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff30b15000 -     0x7fff30b1efff  com.apple.SymptomDiagnosticReporter (1.0 - 79.40.12) <4536FFDF-598E-3085-8DDD-26798E1EEBD6> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
    0x7fff30b1f000 -     0x7fff30b32fff  com.apple.PowerLog (1.0 - 1) <7EA1C552-E90E-3DF6-A5B6-915D26694670> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
    0x7fff30b33000 -     0x7fff30b3ffff  com.apple.AppleIDAuthSupport (1.0 - 1) <1EE88692-4059-3A33-B492-E7D7112EFB0C> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
    0x7fff30b40000 -     0x7fff30be8fff  com.apple.DiscRecording (9.0.3 - 9030.4.5) <8676CDCB-15CC-3723-9411-8B8AFA3B370A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff30be9000 -     0x7fff30c1cfff  com.apple.MediaKit (16 - 927.40.2) <C7FB3929-E0E1-3A6C-B138-EE504CCE9EF0> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff30c1d000 -     0x7fff30d08fff  com.apple.DiskManagement (14.0 - 1733.60.1) <328DB6AD-221B-35FA-8E31-2E5CD860A0F3> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
    0x7fff30d09000 -     0x7fff310c3fff  com.apple.CoreAUC (322.2.0 - 322.2.0) <5E5A1D7F-5D43-3975-AA23-AA0815DCE998> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff310c4000 -     0x7fff310c7fff  com.apple.Mangrove (1.0 - 25) <81A9BA84-C61F-3CBF-A127-406E3FD2459E> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fff310c8000 -     0x7fff310f5fff  com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <10CA0E34-19B1-365C-888C-94543A25F10F> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fff310f6000 -     0x7fff31216fff  com.apple.FileProvider (326 - 326) <B2A33B9E-66D9-30B5-A18C-AD0D7F3592C5> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
    0x7fff31217000 -     0x7fff3123afff  com.apple.GenerationalStorage (2.0 - 322) <F2740CA7-334B-3F24-AFE8-2451D1A041C2> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff31a89000 -     0x7fff31ac8fff  com.apple.AppleVPAFramework (3.20.4 - 3.20.4) <DF632ED6-E230-3208-8741-446E8E35A515> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
    0x7fff31b99000 -     0x7fff31bd5fff  com.apple.DebugSymbols (195.1 - 195.1) <6AA76BBC-B0F2-3F37-A6EE-19014DCD06D9> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff31bd6000 -     0x7fff31c93fff  com.apple.CoreSymbolication (12.2 - 64541.4) <A100000D-F881-3C3C-ABC5-3EAC7A272579> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff31c94000 -     0x7fff31c9dfff  com.apple.CoreTime (284) <1BE28F6E-940C-31C8-B460-2761FC6B4A3F> /System/Library/PrivateFrameworks/CoreTime.framework/Versions/A/CoreTime
    0x7fff32b29000 -     0x7fff32b8cfff  com.apple.framework.Apple80211 (17.0 - 1728) <2DBC65AC-A7DF-38F9-9174-3382667FBF0F> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff32b8d000 -     0x7fff32cdffff  com.apple.CoreWiFi (3.0 - 341) <C18D2E57-A964-380F-A74B-AEFDB3B3ADEC> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff32cf9000 -     0x7fff32d30fff  com.apple.LDAPFramework (2.4.28 - 194.5) <C3E9E36B-B981-3FAD-A8EA-9BADE5F2B30D> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fff32d31000 -     0x7fff32d32fff  com.apple.TrustEvaluationAgent (2.0 - 35) <D0B7904B-37ED-32B1-8FD3-462383F2BDCB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff32d33000 -     0x7fff32e36fff  libcrypto.44.dylib (56.60.2) <7464291F-2D5C-3AE3-9197-54C8676C23F1> /usr/lib/libcrypto.44.dylib
    0x7fff32e37000 -     0x7fff32e64fff  libssl.46.dylib (56.60.2) <0692D04B-A0C4-3632-BB08-2C0C2AC68479> /usr/lib/libssl.46.dylib
    0x7fff32e65000 -     0x7fff32f14fff  com.apple.DiskImagesFramework (595.40.1 - 595.40.1) <B0A2C1DD-79A0-3C26-A1A8-22F1989E5415> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fff32f4c000 -     0x7fff32f5bfff  com.apple.xpc.RemoteServiceDiscovery (1.0 - 2038.40.38) <EFEFC279-E73A-3557-A4AE-BF67E7C96962> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
    0x7fff32f5c000 -     0x7fff32f73fff  com.apple.xpc.RemoteXPC (1.0 - 2038.40.38) <DC43AED2-6DD7-31AB-8186-EF69ED7027C4> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
    0x7fff32fbb000 -     0x7fff32fbefff  com.apple.help (1.3.8 - 71) <599F7E42-DEF1-3B70-83AB-C3BDF727CF93> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff32fbf000 -     0x7fff32fc6fff  com.apple.EFILogin (2.0 - 2) <B94BFCCA-45B6-3E80-84E7-758350D7CAFD> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff32fc7000 -     0x7fff32fd2fff  libcsfde.dylib (554) <1F4DFF13-17EC-3672-8A41-056F4E44A377> /usr/lib/libcsfde.dylib
    0x7fff32fd3000 -     0x7fff33038fff  libcurl.4.dylib (121.40.2) <C9541242-9ED5-3F9B-A2B2-415503447A1F> /usr/lib/libcurl.4.dylib
    0x7fff33039000 -     0x7fff33040fff  com.apple.LoginUICore (4.0 - 4.0) <8AE86484-F756-3BDE-973A-A70C0345697B> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
    0x7fff33200000 -     0x7fff33200fff  com.apple.ApplicationServices (48 - 50) <7B536871-3F10-3138-B06B-9C2A3C07EC1E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff33500000 -     0x7fff33500fff  libHeimdalProxy.dylib (79) <1BD94BF6-8E63-3B21-95DC-E5EEEBFB8AE8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
    0x7fff335b3000 -     0x7fff335b3fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <F5EC07DD-8937-37CB-84DF-C7475FFA573E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff335d8000 -     0x7fff3361afff  com.apple.StreamingZip (1.0 - 1) <FEA8C519-ACB4-381C-9F9D-CB92AE094B23> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
    0x7fff3365d000 -     0x7fff33662fff  com.apple.PushKit (1.0 - 1) <309B12FF-9B68-3120-ABC6-8B52A0E26127> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
    0x7fff33663000 -     0x7fff33699fff  com.apple.C2 (1.3 - 569) <5370F4A2-1C27-395C-80E4-A36E5BF414E9> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
    0x7fff336cc000 -     0x7fff33ed9fff  com.apple.vision.EspressoFramework (1.0 - 256.2.2) <C2903F04-5EE0-3FCA-A7D8-6ABFDD38A27B> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
    0x7fff33eda000 -     0x7fff33ef1fff  com.apple.ANEServices (4.51 - 4.51) <F86B479B-3FA0-366C-84A6-D35253ABBF5E> /System/Library/PrivateFrameworks/ANEServices.framework/Versions/A/ANEServices
    0x7fff3428d000 -     0x7fff34550fff  com.apple.spotlight.index (10.7.0 - 2150.7.2) <D7C1EBB8-2025-3D21-81AE-B43E6005051F> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
    0x7fff34569000 -     0x7fff345b9fff  com.apple.ChunkingLibrary (334 - 334) <E392AB7F-6EAC-3E2E-93F8-01BA240FEACD> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff34e85000 -     0x7fff34e9bfff  com.apple.CoreML.AppleNeuralEngine (1.0 - 1) <BB0C2E05-9F10-3990-9A4B-0A3796F912AB> /System/Library/PrivateFrameworks/AppleNeuralEngine.framework/Versions/A/AppleNeuralEngine
    0x7fff35001000 -     0x7fff35004fff  com.apple.Cocoa (6.11 - 23) <E44AC98B-5BEA-3087-AB41-C73CEB8A98C8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff36444000 -     0x7fff3645ffff  com.apple.openscripting (1.7 - 190) <D0B98DF9-7A61-3810-AE81-2F870DCC2AC0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff36460000 -     0x7fff36463fff  com.apple.securityhi (9.0 - 55008) <DD7770F7-661C-363B-A1F4-8B69EB0FFB6A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff36464000 -     0x7fff36467fff  com.apple.ink.framework (10.15 - 227) <E10C40B6-2656-36D1-882C-2091CE02883A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff36468000 -     0x7fff3646bfff  com.apple.CommonPanels (1.2.6 - 101) <101582BA-E64F-391A-BD23-50DCC3CF8939> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff3646c000 -     0x7fff36473fff  com.apple.ImageCapture (1708 - 1708) <FE9D13DD-D733-3B2A-B4A6-D3C8313005F5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff39459000 -     0x7fff3945cfff  com.apple.OSAServicesClient (1.0 - 1) <44E39868-F624-3644-B453-962D34737998> /System/Library/PrivateFrameworks/OSAServicesClient.framework/Versions/A/OSAServicesClient
    0x7fff3d15e000 -     0x7fff3d161fff  com.apple.print.framework.Print (15 - 271) <8411879F-7E3E-3882-BD06-68E797A3B9D6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff3d162000 -     0x7fff3d165fff  com.apple.Carbon (160 - 164) <5683716A-5610-3B97-B473-B4652067E7A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff3d3ea000 -     0x7fff3d409fff  com.apple.private.SystemPolicy (1.0 - 1) <CFE0B0C6-DF5B-31EB-9D79-B23E00A80B05> /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy
    0x7fff3dd33000 -     0x7fff3dd3efff  com.apple.MallocStackLogging (1.0 - 1) <C1A21524-381D-39CA-AD63-A3B9F67FC6CA> /System/Library/PrivateFrameworks/MallocStackLogging.framework/Versions/A/MallocStackLogging
    0x7fff3dd54000 -     0x7fff3dd66fff  libmis.dylib (274.60.2) <54387457-A60B-3390-AD6D-3B380792CD79> /usr/lib/libmis.dylib
    0x7fff3dd67000 -     0x7fff3dd6afff  com.apple.gpusw.GPURawCounter (12.25 - 12.0) <17751B3E-2CF3-3944-BA02-124E56A10426> /System/Library/PrivateFrameworks/GPURawCounter.framework/Versions/A/GPURawCounter
    0x7fff4151a000 -     0x7fff41523fff  com.apple.IOAccelMemoryInfo (1.0 - 1) <90735179-1E6C-3D1F-8CCF-08AC441B19A2> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
    0x7fff4195a000 -     0x7fff41978fff  libCGInterfaces.dylib (544) <488D608D-374C-3A2F-B8AC-D78E2F6E6DB7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff43f68000 -     0x7fff441e1fff  com.apple.RawCamera.bundle (9.10.0 - 1420.3) <D6521255-C614-3A4C-83E1-42A3C3079CBE> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fff46c60000 -     0x7fff46c6bfff  libGPUSupportMercury.dylib (18.1.1) <5C061A05-CD21-3442-A80B-1901D64C9B9E> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fff482cc000 -     0x7fff4831afff  com.apple.osanalytics.OSAnalytics (1.0 - 1) <EF7537E3-982B-3FA2-BFFC-F8071EFF0B31> /System/Library/PrivateFrameworks/OSAnalytics.framework/Versions/A/OSAnalytics
    0x7fff4c35f000 -     0x7fff4c362fff  com.apple.FinderSyncPriv (1.3 - 1350.2.10) <456C118F-398C-329C-BC89-7B1EAC693835> /System/Library/PrivateFrameworks/FinderSyncPriv.framework/Versions/A/FinderSyncPriv
    0x7fff5228a000 -     0x7fff5231cfff  com.apple.Symbolication (12.2 - 64541.7.1) <EC806042-5249-35DC-90BA-953A86D1854A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff56452000 -     0x7fff56455fff  com.apple.ForceFeedback (1.0.6 - 1.0.6) <AB29674E-26C2-360C-9117-54AC93E80CB0> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
    0x7fff5ea3a000 -     0x7fff5eecafff  com.apple.driver.AppleIntelKBLGraphicsMTLDriver (16.1.7.1 - 16.0.1) <B3FAA649-5890-3A9C-8111-CE3DC093C5B3> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
    0x7fff5eecb000 -     0x7fff5f8defff  libSC.dylib (4.2.13) <7F3979D1-8399-3098-80F8-88707ED65975> /System/Library/Extensions/AMDShared.bundle/Contents/PlugIns/libSC.dylib
    0x7fff5fc27000 -     0x7fff60c0afff  com.apple.driver.AppleIntelKBLGraphicsGLDriver (16.1.7.1 - 16.0.1) <413F1002-6C49-39B7-85BE-3151E4104B88> /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver
    0x7fff6a3f0000 -     0x7fff6a3f4fff  libmetal_timestamp.dylib (31001.160) <2EC7EA90-5313-3812-8E72-910C643A996C> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/31001/Libraries/libmetal_timestamp.dylib
    0x7fff6c85e000 -     0x7fff6c864fff  libCoreFSCache.dylib (177.22) <4ECE128D-5E79-3ADF-8FE7-4FE8F565F8AA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff6c865000 -     0x7fff6c869fff  libCoreVMClient.dylib (177.22) <E0DBED1D-39B4-3E51-9EA8-D1ECAED93EAB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff6c86a000 -     0x7fff6c879fff  com.apple.opengl (18.1.1 - 18.1.1) <D8EE3AD0-C0D0-32F7-9C6D-39341099EB55> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff6c87a000 -     0x7fff6c87cfff  libCVMSPluginSupport.dylib (18.1.1) <5F020D32-8663-3CB8-A50C-F939D4D4C31F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff6c87d000 -     0x7fff6c885fff  libGFXShared.dylib (18.1.1) <2271532D-E2B3-3D4D-ADF0-0935F8DCE89B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff6c886000 -     0x7fff6c8b9fff  libGLImage.dylib (18.1.1) <528E53A3-33E1-34C7-8EE3-C42AE5255553> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff6c8ba000 -     0x7fff6c8f6fff  libGLU.dylib (18.1.1) <15CBDF20-8A87-3D84-90F8-D19F4A2B06E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff6c8f7000 -     0x7fff6ca8bfff  libGLProgrammability.dylib (18.1.1) <570616B1-98D2-3DF2-844A-EE845A8B8EDE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff6ca8c000 -     0x7fff6ca96fff  libGL.dylib (18.1.1) <157B74E1-F30D-3F9D-9AF8-AAA333D2812D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff6ca97000 -     0x7fff6cc12fff  GLEngine (18.1.1) <155E1C82-C69A-3E86-8569-3C134C7FEAC6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fff6cc13000 -     0x7fff6cc3cfff  GLRendererFloat (18.1.1) <49B0A782-AE84-35BC-91F8-880C2B7EE004> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fff6decd000 -     0x7fff6df25fff  com.apple.opencl (4.5 - 4.5) <8A3D06D5-4E82-355C-AE1B-E2C91DB58233> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff6ee48000 -     0x7fff6ee97fff  ATIRadeonX6000SCLib.dylib (4.2.13) <D3702C4F-73AC-3AED-9D42-33299E60E0C3> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/ATIRadeonX6000SCLib.dylib
    0x7fff6f7af000 -     0x7fff6f7d1fff  com.apple.audio.OpenAL (1.8 - 1.8) <8CF29FAE-D1F5-37FA-B529-D999AFE990FD> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
    0x7fff7012d000 -     0x7fff70137fff  com.apple.AccessibilityBundles (1.0 - 172) <5522C7FE-EAC0-3080-B363-56F19547B00A> /System/Library/PrivateFrameworks/AccessibilityBundles.framework/Versions/A/AccessibilityBundles
    0x7fff783e5000 -     0x7fff783ecfff  libRosetta.dylib (203.13.2) <FF72E19B-3B02-34D4-A821-3397BB28AC02> /usr/lib/libRosetta.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 3
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 523
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=7.3G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=7.3G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               512K        4
Activity Tracing                   256K        1
CG backing stores                 4608K        6
CG image                           580K        6
CoreAnimation                       76K        7
CoreGraphics                        12K        2
CoreUI image data                  672K        5
Foundation                          16K        1
Kernel Alloc Once                    8K        1
MALLOC                             5.3G      474
MALLOC guard page                   48K       10
MALLOC_MEDIUM (reserved)         960.0M       15         reserved VM address space (unallocated)
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
OpenGL GLSL                        256K        3
STACK GUARD                        156K       39
Stack                             72.8M       40
VM_ALLOCATE                      663.3M     1326
__CTF                               759        1
__DATA                            89.4M      382
__DATA_CONST                      17.5M      211
__DATA_DIRTY                       914K      113
__FONT_DATA                          4K        1
__GLSLBUILTINS                    5176K        1
__LINKEDIT                       545.7M       38
__OBJC_RO                         60.5M        1
__OBJC_RW                         2452K        3
__TEXT                           460.0M      380
__UNICODE                          588K        1
mapped file                       89.6M       26
shared memory                       40K        4
TOTAL                              8.6G     3103
TOTAL, minus reserved VM space     7.3G     3103
The problem appears to be in the graphics driver since it occurs in glDrawElementsInstancedBaseVertex.
Unfortunately the crash log does not provide enough information for developers to be able to identify and provide a workarround for this OS.
There are plans to port blender to a different rendering API (Vulkan). Problems like this are expected to be resolved.
This might be a duplicate of T83791: Blender crash on iMac Pro with Big Sur
Also noted that crash occurs when MacBook goes to sleep with Blender active and then woken. As soon as the viewport is activated Blender crashes
