Scale and Location are Bugged - ARCHITECTURAL ISSUE #84851
Reference: blender/blender#84851
Graphics card: Intel(R) UHD Graphics 630 Intel 4.5.0 - Build 27.20.100.8681
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-01-18 23:28, hash:
09c7c63890
Z Location Do not Match the Scale
[Hi so I recently started using software for architectural purposes and realized that it does not work. Z location does not match with Scale of the Scene. So I cant use it exactly for Architecture purpose.]
1.Create a Default Cube
2. Change Location to Z=1
3. Object > Origin > Set Origin to 3d Cursor
4. Set Z Scale = 3
CONFIRMATION 1: Make another Default Cube to see, Scale is Correct but Z location is not
CONFIRMATION 2: Make a plane and Extrude it to 3m height , it do not match....]
003 - Video Explaining.mov
Here is the File in 2.93 version, still not solved, happens on all 2.8 releases. I don't know if 2.7 versions had this problem or not
003 - Blender Bug Reporting - Z Elevation.blend
Added subscriber: @yochintohere
Added subscriber: @Stan_Pancakes
Default cube is 2x2x2. Setting its Z scale to 3 makes its Z dimension 6.
Thanks ,
That makes sense now. Thanks alot.
Let me test that..
Added subscriber: @filedescriptor
As @Stan_Pancakes mentioned, the default cube is 2x2x2 (in the 3d view, press
N
to see the properties panel, at the bottom, there are the dimensions of the selected object). So the scaled cube is 6 units tall (as you can so see by the grid). This is not a bug. Closing.Added subscriber: @rjg
This is not a bug in Blender. The default cube is 2 m high, you offset it by 1 m so the top is 2 m away from center of the global coordinates. You then scale it by factor 3 along the Z-axis, given that the origin of the object is at 1 m above the ground, that result in the top of the cube at 4 m and the the bottom at -2 m. You then place the plane at 3 m above ground.
If you need help learning or using Blender, please post a question on one of our [community websites ]], for instance https:*blender.stackexchange.com/ , https:*blenderartists.org/ or the [ https:*blender.chat/channel/support | #support channel on Blender chat . The bug tracker is only for bug reports.
