Blender (2.91) crashes on change frame with handler set to render scene #84868
Open
opened 2021-01-19 18:38:13 +01:00 by Dolphin Dream · 11 comments
Member
Operating system: Catalina (10.15.7)
Graphics card:
2.91.0
I want to have the scene rendered automatically every time the frame changes.. so I set a post frame change handler do just that (according to blender documentation: https://docs.blender.org/api/current/bpy.app.handlers.html#bpy.app.handlers.frame_change_post)
Paste this in the Blender console to setup the handler:
import bpy
def my_handler(scene):
  bpy.ops.render.render(use_viewport=True)
bpy.app.handlers.frame_change_post.append(my_handler)
However, blender crashes as soon as I change the frame.
**System Information** Operating system: Catalina (10.15.7) Graphics card: ![Screen Shot 2021-01-19 at 12.35.10 PM.png](https://archive.blender.org/developer/F9587892/Screen_Shot_2021-01-19_at_12.35.10_PM.png) **Blender Version** 2.91.0 **Short description of error** I want to have the scene rendered automatically every time the frame changes.. so I set a post frame change handler do just that (according to blender documentation: https://docs.blender.org/api/current/bpy.app.handlers.html#bpy.app.handlers.frame_change_post) Paste this in the Blender console to setup the handler: ``` import bpy def my_handler(scene): bpy.ops.render.render(use_viewport=True) bpy.app.handlers.frame_change_post.append(my_handler) ``` However, blender crashes as soon as I change the frame. **Exact steps for others to reproduce the error** - Open attached file - Run script - Change frame [handler_ops_render_crash.blend](https://archive.blender.org/developer/F9589600/handler_ops_render_crash.blend)
Author
Member
Added subscriber: @MariusGiurgi
Member
Added subscriber: @filedescriptor
Member
The viewport in Blender is able to render automatically when you change the frame. Just switch to rendered mode. If you want to have a separate window with the rendered view, you can create a second window and have the rendered viewport there.
https://docs.blender.org/manual/en/latest/editors/3dview/display/shading.html#rendered
https://docs.blender.org/manual/en/latest/interface/window_system/areas.html#duplicate-area-into-new-window
The viewport in Blender is able to render automatically when you change the frame. Just switch to rendered mode. If you want to have a separate window with the rendered view, you can create a second window and have the rendered viewport there. https://docs.blender.org/manual/en/latest/editors/3dview/display/shading.html#rendered https://docs.blender.org/manual/en/latest/interface/window_system/areas.html#duplicate-area-into-new-window
Added subscriber: @mano-wii
Thanks for the report.
It doesn't seem like a good idea to set the render operator inside a handle since that operator depends a lot on the context and can change it.
But I'm confirming as a bug anyway.
Thanks for the report. It doesn't seem like a good idea to set the render operator inside a handle since that operator depends a lot on the context and can change it. But I'm confirming as a bug anyway.
Author
Member
@filedescriptor Not exactly what i’m looking for. I want to render the scene for the active camera at the resolution set for the final render, e.g. 32x32 pixels. The viewport renders at th e viewport/display resolution, not the render setting resolution. Why would I need 32x32 resolution you may ask? because I am working on a technique to voxelize a surface via rendering and I need to see the final render at the specified resolution. Besides, why does this event handler crash blender is the question. How can this be normal behavior?
Added subscriber: @brecht
There's an infinite recursion here. Rendering itself will change the frame causing this handled to be called.
Marking as low priority since this is outside of the intended usage of frame change handlers.
There's an infinite recursion here. Rendering itself will change the frame causing this handled to be called. Marking as low priority since this is outside of the intended usage of frame change handlers.
Added subscriber: @BartekMoniewski
Removed subscriber: @BartekMoniewski
Philipp Oeser removed the
label 2023-02-09 14:01:57 +01:00
5 Participants
Reference: blender/blender#84868
