"Fix T84049: Crash when using Cycles Progressive Refine with OptiX+CPU" actually causes hybrid rendering to crash
Operating system: Linux-5.8.0-40-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.32.03
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-01-20 15:35, hash: rBe12eb89f22c6
Worked: all 2.93 versions before commit 4a09907eab2a
F12 rendering anything with CUDA+CPU instantly crashes Blender or stops the rendering and throws a CUDA error
  • Open Blender / default cube or anything else
  • Configure Blender to use CUDA with both GPU and CPU enabled (Edit > Preferences > System)
  • Enable View Layer Properties > Passes > Data > Denoising Data
  • Press F12
  • Crash or CUDA error
I'm unable to reproduce the issue, but maybe that's not surprising since I also couldn't reproduce T84049.
Invalid value in cuMemFree(mem.device_pointer) (device_cuda_impl.cpp:970)
Launch failed in cuMemcpyDtoH( (char *)mem.host_pointer + offset, (CUdeviceptr)mem.device_pointer + offset, size) (device_cuda_impl.cpp:1034)
Hi. I cannot reproduce in latest Blender from master built by myself ( Linux, Nvidia 460.32.03, Blender c07c110467ca, OptiX 7.2.0)
But maybe I'm confused with the steps you mention. Title says Optix+CPU and description CUDA+CPU. Anyway here it works with CUDA or OptiX and Progressive Refine in my tests.
Thanks for testing YAFU. I don't mean progressive refine but normal tiled rendering with GPU+CPU (CUDA+CPU).
The OptiX and progressive part of that bug report comes from the commit that caused the crashes for me ;)
I also build with OptiX 7.2.0
Oh I understand. But no, I can't make it crash here. Using CUDA V10.1.105 to build.
Hmm, I'm using CUDA 11.2 on my side. Maybe that's the problem.
OK, a quick update:
I tried several things and after renaming the startup.blend file I could render properly. I think I found the cause:
In my startup.blend I activated "Denoising Data" pass by default because I always use it in compositing afterwards. As soon as I unchecked this pass the rendering was working properly again.
So if someone tries to reproduce this, please also switch the "Denoising Data" pass on!
And just to confirm I just downloaded today's Buildbot build and it fails the same way as my own build yesterday. So it's not a CUDA 10 vs 11 thing. ( blender-2.93.0-41a945d7469f-linux64 )
Robert Guetzkow (rjg) changed the task status from Needs Triage to Confirmed.Jan 21 2021, 12:34 PM
Robert Guetzkow (rjg) updated the task description. (Show Details)
Ah, that's right, with Denoising Data here hybrid render with default cube does not finish, it hangs and I can't cancel render either.
This is why it is important to share a .blend file no matter how simple the steps are to reproduce the problem :)
Yeah, right! At first it looked too easy because I didn't notice that Denoising Data was enabled and I could easily reproduce it with an empty scene file (which I assumed was a bit stupid to upload). But in the end it would've helped.
