crash while rendering #84955
Closed
opened 2021-01-22 09:00:07 +01:00 by suraj · 10 comments
PLEASE REPLY AS SOON AS POSSIBLE AND PLEASE HELP ME RESOLVE MY ERROR
Operating system: Windows 10 home
Graphics card: Nvidia GeForce RTX 2060, Version: 3.20.5.70, Driver Version: 460.89
Broken: (example: 2.80, edbf15d3c0, master, 2018-11-28, as found on the splash screen): 2.90.1
Worked: (newest version of Blender that worked as expected)Did not try any other
When i finished my modeling then switched to render mode to better work with the materials but as i went on with my materials' assigning blender crashed without any error message. But then i tried to resume my work again but happened the same. Then tried to hit render image without even finishing with my materials IT CRASHED AGAIN :(
this is the file creating errors
lecture3.blend
Here are the files i got after running debug.cmd tool
blender_system_info.txt
blender_debug_output.txt
lecture3.crash.txt
blender.crash.txt
  1. Switched to render mode to better work with materials
  2. While working on materials blender crashed without any error message
  3. If not crashed while being in render mode then crashes as I hit the render image mode
PLEASE REPLY AS SOON AS POSSIBLE AND PLEASE HELP ME RESOLVE MY ERROR **System Information** Operating system: Windows 10 home Graphics card: Nvidia GeForce RTX 2060, Version: 3.20.5.70, Driver Version: 460.89 **Blender Version** Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen): 2.90.1 Worked: (newest version of Blender that worked as expected)Did not try any other **Short description of error** When i finished my modeling then switched to render mode to better work with the materials but as i went on with my materials' assigning blender crashed without any error message. But then i tried to resume my work again but happened the same. Then tried to hit render image without even finishing with my materials IT CRASHED AGAIN :( this is the file creating errors [lecture3.blend](https://archive.blender.org/developer/F9592006/lecture3.blend) Here are the files i got after running debug.cmd tool [blender_system_info.txt](https://archive.blender.org/developer/F9591999/blender_system_info.txt) [blender_debug_output.txt](https://archive.blender.org/developer/F9592001/blender_debug_output.txt) [lecture3.crash.txt](https://archive.blender.org/developer/F9592002/lecture3.crash.txt) [blender.crash.txt](https://archive.blender.org/developer/F9592003/blender.crash.txt) **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible). 1. Switched to render mode to better work with materials 2. While working on materials blender crashed without any error message 3. If not crashed while being in render mode then crashes as I hit the render image mode
Author
Added subscriber: @justme-4
Closed as duplicate of #81116
Added subscriber: @rjg
Please update to Blender 2.91.2.
Author
will optix work in 2.91.2 ?
And by the way thank you very much for the help, thanks a lot.
will optix work in 2.91.2 ? And by the way thank you very much for the help, thanks a lot.
@justme-4 Yes, it should. If it doesn't, then please create a new report.
Author
sorry to disturb you again but i got i more problem.
when i was trying to render the same file by disabling the optix denoiser then it rendered but the problem was that the objects which i made hidden by clicking over that little eye icon were displayed in the render. what possibly went wrong?
sorry to disturb you again but i got i more problem. when i was trying to render the same file by disabling the optix denoiser then it rendered but the problem was that the objects which i made hidden by clicking over that little eye icon were displayed in the render. what possibly went wrong?
The eye icon only hides the object in the viewport. You need to click on the filter icon and then on the camera icon in the drop down to display the restriction toggle to disable the display in render. There are many questions similar to yours on Blender's Stack Exchange .
If you need help learning or using Blender, please post a question on one of our [community websites ]], for instance https:*blender.stackexchange.com/ , https:*blenderartists.org/ or the [ https:*blender.chat/channel/support | #support channel on Blender chat .
The eye icon only hides the object in the viewport. You need to click on the filter icon and then on the camera icon in the drop down to display the restriction toggle to disable the display in render. There are many questions similar to yours on [Blender's Stack Exchange ](https://blender.stackexchange.com/questions/185347/avoid-rendering-hidden-objects-blender-2-8). If you need help learning or using Blender, please post a question on one of our [community websites ]], for instance [[ https:*blender.stackexchange.com/ | Blender's StackExchange ]], [[ https:*blenderartists.org/ | blenderartists.org ]] or the [[ https:*blender.chat/channel/support | #support channel on Blender chat ](https:*www.blender.org/community/).
Author
Hi Robert. I have i query please help me solving it. And it is i want to know how to make i solid mesh to work with when i have used say array modifier to design an object. Because when we use array modifier it just makes the same object visible the number of times we want it to, it does not create a duplicate of it.
Like in the file attached i have made a chocolate bar by using array modifier but when i switch to edit mode it only shows the 1 editable piece which i made initially not those made by using array modifier.
Check this:lecture3.blend
and 1 more thing can i make the changes permanent like if i created the cheese using spheres and boolean modifier and now after getting my cheese ready is there any way so that i delete the spheres and the cheese remains intact as it was.
Hi Robert. I have i query please help me solving it. And it is i want to know how to make i solid mesh to work with when i have used say array modifier to design an object. Because when we use array modifier it just makes the same object visible the number of times we want it to, it does not create a duplicate of it. Like in the file attached i have made a chocolate bar by using array modifier but when i switch to edit mode it only shows the 1 editable piece which i made initially not those made by using array modifier. Check this:[lecture3.blend](https://archive.blender.org/developer/F9599709/lecture3.blend) and 1 more thing can i make the changes permanent like if i created the cheese using spheres and boolean modifier and now after getting my cheese ready is there any way so that i delete the spheres and the cheese remains intact as it was.
@justme-4 As I wrote in my previous comment, if you need help learning Blender, please post your questions on one of our community websites. The bug trackers is for bugs only.
2 Participants
Reference: blender/blender#84955
