Introduction
This task tracks progress of regression tests for mesh operators. A regression takes a test mesh, applies an operator on it and compares the result with a reference mesh (typically called expected object).
Note: Multiple developers can work on this task after discussing with other subscribers/assignee for clarification.
Adding a new test
- Define the test case in the python file blender/tests/python/operators.py
- Create a test mesh and an expected mesh in lib/tests/modeling/operators.blend
The wiki explains the steps in much more details: Python Tests
Some examples:
D10218 (remove doubles)
rB22a8a3b21497 (Deform tests)
rB8373f497b (Curve tests)
Test cases
First screening of operators can be find in this sheet link for insights.
Add new tests for operators from the list below, they can be accessed by bpy.ops.mesh in the python console in Blender. For documentation, please refer here
Operator | Typical case | Further cases | Comments |
average_normals | |||
beautify_fill | |||
bevel | x | tests are in bevel_regression.blend and bevel_operator.py | |
bisect | x | ||
blend_from_shape | x | ||
bridge_edge_loops | x | ||
colors_reverse | |||
colors_rotate | |||
convex_hull | |||
customdata_custom_splitnormals_add | |||
customdata_custom_splitnormals_clear | |||
customdata_mask_clear | |||
customdata_skin_add | |||
customdata_skin_clear | |||
decimate | x | ||
delete | x | delete Faces/Verts/Edges | |
delete_edgeloop | x | delete Verts/Edges | |
delete_loose | x | ||
dissolve_degenerate | x | ||
dissolve_edges | x | ||
dissolve_faces | x | ||
dissolve_limited | |||
dissolve_mode | |||
dissolve_verts | x | ||
dupli_extrude_cursor | Requires user input, cannot test. | ||
duplicate | x | ||
duplicate_move | |||
edge_collapse | |||
edge_face_add | x | ||
edge_rotate | x | ||
edge_split | x | ||
edgering_select | Requires user input, cannot test. | ||
edges_select_sharp | |||
extrude_context | Requires user input, cannot test. | ||
extrude_context_move | Requires user input, cannot test. | ||
extrude_edges_indiv | Requires user input, cannot test. | ||
extrude_edges_move | Requires user input, cannot test. | ||
extrude_faces_indiv | Requires user input, cannot test. | ||
extrude_faces_move | Requires user input, cannot test. | ||
extrude_region | Requires user input, cannot test. | ||
extrude_region_move | Requires user input, cannot test. | ||
extrude_region_shrink_fatten | Requires user input, cannot test. | ||
extrude_repeat | Requires user input, cannot test. | ||
extrude_vertices_move | Requires user input, cannot test. | ||
extrude_verts_indiv | Requires user input, cannot test. | ||
face_make_planar | x | ||
face_split_by_edges | x | ||
faces_mirror_uv | |||
faces_select_linked_flat | x | ||
faces_shade_flat | |||
faces_shade_smooth | |||
fill | x | ||
fill_grid | x | ||
fill_holes | x | ||
flip_normals | |||
hide | |||
inset | x | ||
intersect | x | ||
intersect_boolean | x | x | See boolean_operator.py |
knife_project | |||
knife_tool | |||
loop_multi_select | |||
loop_select | |||
loop_to_region | |||
loopcut | |||
loopcut_slide | |||
mark_freestyle_edge | |||
mark_freestyle_face | |||
mark_seam | |||
mark_sharp | |||
merge | |||
merge_normals | |||
mod_weighted_strength | |||
normals_make_consistent | |||
normals_tools | |||
offset_edge_loops | |||
offset_edge_loops_slide | |||
paint_mask_extract | |||
paint_mask_slice | |||
point_normals | |||
poke | |||
polybuild_delete_at_cursor | |||
polybuild_dissolve_at_cursor | |||
polybuild_extrude_at_cursor_move | |||
polybuild_face_at_cursor | |||
polybuild_face_at_cursor_move | |||
polybuild_split_at_cursor | |||
polybuild_split_at_cursor_move | |||
polybuild_transform_at_cursor | |||
polybuild_transform_at_cursor_move | |||
primitive_circle_addrotation= | |||
primitive_cone_addlocation= | |||
primitive_cube_add | |||
primitive_cylinder_add | |||
primitive_grid_add | |||
primitive_ico_sphere_add | |||
primitive_monkey_add | |||
primitive_plane_add | |||
primitive_torus_add | |||
primitive_uv_sphere_add | |||
quads_convert_to_tris | |||
region_to_loop | |||
remove_doubles | |||
reveal | |||
rip | |||
rip_edge | |||
rip_edge_move | |||
rip_move | |||
screw | |||
select_all | |||
select_axis | |||
select_face_by_sides | |||
select_interior_faces | |||
select_less | |||
select_linked | |||
select_linked_pick | |||
select_loose | |||
select_mirror | |||
select_mode | |||
select_more | |||
select_next_item | |||
select_non_manifold | |||
select_nth | |||
select_prev_item | |||
select_random | |||
select_similar | |||
select_similar_region | |||
select_ungrouped | |||
separate | |||
set_normals_from_faces | |||
shape_propagate_to_all | |||
shortest_path_pick | |||
shortest_path_select | |||
smoothen_normals | |||
solidify | |||
sort_elements | |||
spin | |||
split | |||
split_normals | |||
subdivide | |||
subdivide_edgering | |||
symmetrize | |||
symmetry_snap | |||
tris_convert_to_quads | |||
unsubdivide | |||
uv_texture_add | |||
uv_texture_remove | |||
uvs_reverse | |||
uvs_rotate | |||
vert_connect | |||
vert_connect_concave | |||
vert_connect_nonplanar | |||
vert_connect_path | |||
vertex_color_add | |||
vertex_color_remove | |||
vertices_smooth | |||
vertices_smooth_laplacian | |||
wireframe |
