Crash dragging a collection over Outliner with active filter without matches #85027
Closed
opened 2021-01-24 22:02:05 +01:00 by Georg K · 6 comments
Operating system: Linux-5.10.2-2-MANJARO-x86_64-with-arch-Manjaro-Linux 64 Bits
Graphics card: AMD VERDE (DRM 2.50.0, 5.10.2-2-MANJARO, LLVM 11.0.0) AMD 4.5 (Core Profile) Mesa 20.3.1
Broken: version:
  • 2.93.0 Alpha, branch: master, commit date: 2021-01-24 20:29, hash: c8d6e2dfa0
  • 2.92.0
  • 2.91.0
  • 2.90.1
  • 2.83.10
  • 2.82
  • 2.81
  • 2.80
    Worked: Never
If there is a second Outliner with a filter that does not match anything and you drag a collection from the first outliner over the second outliner, dragging gets stuck and Blender crashes (Segmentation fault (core dumped)).
Crash dragging a collection over Outliner with active filter without matches.jpg
Content of blender.crash.txt:
# Blender 2.93.0, Commit date: 2021-01-24 20:29, Hash c8d6e2dfa0e0
bpy.context.space_data.filter_text = "test"  # Property
bpy.ops.outliner.item_rename()  # Operator
bpy.ops.outliner.item_activate(extend=False, deselect_all=True)  # Operator
# backtrace
./blender(BLI_system_backtrace+0x33) [0x86d2573]
./blender() [0xe85ebe]
/usr/lib/libc.so.6(+0x3d6a0) [0x7f13000956a0]
./blender() [0x1c6bf01]
./blender() [0x1c6bfc4]
./blender() [0x1c6c1d1]
./blender() [0x1214727]
./blender(wm_drags_check_ops+0x154) [0x1214b84]
./blender(wm_event_do_handlers+0x73b) [0x121e53b]
./blender(WM_main+0x20) [0x1214680]
./blender(main+0x330) [0xdc3760]
/usr/lib/libc.so.6(__libc_start_main+0xf2) [0x7f1300080152]
./blender(_start+0x2e) [0xe8262e]
In the default scene, split the Outliner area in two,
add a search term to the new Outliner that does not match anything (like "8" or "[" or "test"),
drag a collection from the first Outliner down towards the buttons area.
Dragging will stop at the bottom of the header of the second Outliner and Blender will crash shortly after.
**System Information** Operating system: Linux-5.10.2-2-MANJARO-x86_64-with-arch-Manjaro-Linux 64 Bits Graphics card: AMD VERDE (DRM 2.50.0, 5.10.2-2-MANJARO, LLVM 11.0.0) AMD 4.5 (Core Profile) Mesa 20.3.1 **Blender Version** Broken: version: - 2.93.0 Alpha, branch: master, commit date: 2021-01-24 20:29, hash: `c8d6e2dfa0` - 2.92.0 - 2.91.0 - 2.90.1 - 2.83.10 - 2.82 - 2.81 - 2.80 Worked: Never **Short description of error** If there is a second Outliner with a filter that does not match anything and you drag a collection from the first outliner over the second outliner, dragging gets stuck and Blender crashes (Segmentation fault (core dumped)). ![Crash dragging a collection over Outliner with active filter without matches.jpg](https://archive.blender.org/developer/F9595785/Crash_dragging_a_collection_over_Outliner_with_active_filter_without_matches.jpg) Content of blender.crash.txt: ``` # Blender 2.93.0, Commit date: 2021-01-24 20:29, Hash c8d6e2dfa0e0 bpy.context.space_data.filter_text = "test" # Property bpy.ops.outliner.item_rename() # Operator bpy.ops.outliner.item_activate(extend=False, deselect_all=True) # Operator # backtrace ./blender(BLI_system_backtrace+0x33) [0x86d2573] ./blender() [0xe85ebe] /usr/lib/libc.so.6(+0x3d6a0) [0x7f13000956a0] ./blender() [0x1c6bf01] ./blender() [0x1c6bfc4] ./blender() [0x1c6c1d1] ./blender() [0x1214727] ./blender(wm_drags_check_ops+0x154) [0x1214b84] ./blender(wm_event_do_handlers+0x73b) [0x121e53b] ./blender(WM_main+0x20) [0x1214680] ./blender(main+0x330) [0xdc3760] /usr/lib/libc.so.6(__libc_start_main+0xf2) [0x7f1300080152] ./blender(_start+0x2e) [0xe8262e] ``` **Exact steps for others to reproduce the error** In the default scene, split the Outliner area in two, add a search term to the new Outliner that does not match anything (like "8" or "[" or "test"), drag a collection from the first Outliner down towards the buttons area. Dragging will stop at the bottom of the header of the second Outliner and Blender will crash shortly after.
Author
Added subscriber: @georgK
Added subscriber: @rjg
I can confirm this issue.
Stack trace for 2.93.0 Alpha, branch: master, commit date: 2021-01-25 10:10, hash: 7cb65a1e67
outliner_drop_insert_find(bContext * C, const wmEvent * event, TreeElementInsertType * r_insert_type) Line 179	C
outliner_drop_insert_collection_find(bContext * C, const wmEvent * event, TreeElementInsertType * r_insert_type) Line 226	C
collection_drop_init(bContext * C, wmDrag * drag, const wmEvent * event, CollectionDrop * data) Line 1116	C
collection_drop_poll(bContext * C, wmDrag * drag, const wmEvent * event, const unsigned char * * r_tooltip) Line 1181	C
dropbox_active(bContext * C, ListBase * handlers, wmDrag * drag, const wmEvent * event) Line 228	C
wm_dropbox_active(bContext * C, wmDrag * drag, const wmEvent * event) Line 259	C
wm_drop_operator_options(bContext * C, wmDrag * drag, const wmEvent * event) Line 285	C
wm_drags_check_ops(bContext * C, const wmEvent * event) Line 304	C
wm_event_do_handlers(bContext * C) Line 3402	C
WM_main(bContext * C) Line 640	C
main(int argc, const unsigned char * * UNUSED_argv_c) Line 526	C
I can confirm this issue. Stack trace for 2.93.0 Alpha, branch: master, commit date: 2021-01-25 10:10, hash: `7cb65a1e67` ```lines outliner_drop_insert_find(bContext * C, const wmEvent * event, TreeElementInsertType * r_insert_type) Line 179 C outliner_drop_insert_collection_find(bContext * C, const wmEvent * event, TreeElementInsertType * r_insert_type) Line 226 C collection_drop_init(bContext * C, wmDrag * drag, const wmEvent * event, CollectionDrop * data) Line 1116 C collection_drop_poll(bContext * C, wmDrag * drag, const wmEvent * event, const unsigned char * * r_tooltip) Line 1181 C dropbox_active(bContext * C, ListBase * handlers, wmDrag * drag, const wmEvent * event) Line 228 C wm_dropbox_active(bContext * C, wmDrag * drag, const wmEvent * event) Line 259 C wm_drop_operator_options(bContext * C, wmDrag * drag, const wmEvent * event) Line 285 C wm_drags_check_ops(bContext * C, const wmEvent * event) Line 304 C wm_event_do_handlers(bContext * C) Line 3402 C WM_main(bContext * C) Line 640 C main(int argc, const unsigned char * * UNUSED_argv_c) Line 526 C ```
This issue was referenced by 5c490bcbc8
This issue was referenced by 5c490bcbc82b43487f2e08978b69f1900e8bfce5
Member
Julian Eisel self-assigned this 2021-01-25 14:38:53 +01:00
Reference: blender/blender#85027
